LinuxCNC Documentation
This documentation describes the lcnc_realtime Python module, which provides a Python API for managing the realtime backend.
This is a Python wrapper of the realtime script.
1. Grundlegende Verwendung (engl. basic usage)
Verify realtime capability and check if the realtime backend is running
import lcnc_realtime
print("lcnc_realtime.verify " + str(lcnc_realtime.verify()))
print("lcnc_realtime.verify_info " + str(lcnc_realtime.verify_info()))
print("lcnc_realtime.status " + str(lcnc_realtime.status()))
2. Methoden
lcnc_realtime.verify() → bool
Returns a boolean to indicate whether the system is realtime capable.
lcnc_realtime.verify_info() → tuple[bool, str]
Returns a tuple (capable, type), where capable is the same boolean as verify() and type is a human-readable string naming the realtime type that rtapi is running (for example Preempt RT, RTAI or Xenomai), or No realtime when none is available.
lcnc_realtime.status() → bool
Returns a boolean to indicate whether the realtime backend is running.
