1. HAL Entity Names
All HAL entities are accessible and manipulable by their names, so documenting the names of pins, signals, parameters, etc., is very important. Names in HAL have a maximum length of 41 characters (as defined by HAL_NAME_LEN in hal.h). Many names will be presented in the general form, with formatted text <like-this> representing fields of various values.
When pins, signals, or parameters are described for the first time, their name will be preceded by their type in parentheses (float) and followed by a brief description. Typical pins definitions look like these examples:
- (bit) parport.<portnum>.pin-<pinnum>-in
The HAL pin associated with the physical input pin <pinnum> of the db25 connector.
- (float) pid.<loopnum>.output
The PID loop output
Occasionally, an abbreviated version of the name may be used, for example the second pin above could be simply called with .output when it can be done without causing confusion.
2. HAL General Naming Conventions
Consistent naming conventions would make HAL much easier to use. For example, if every encoder driver provided the same set of pins and named them the same way, then it would be easy to change from one type of encoder driver to another. Unfortunately, like many open-source projects, HAL is a combination of things that were designed, and things that simply evolved. As a result, there are many inconsistencies. This section attempts to address that problem by defining some conventions, but it will probably be a while before all the modules are converted to follow them.
Halcmd and other low-level HAL utilities treat HAL names as single entities, with no internal structure. However, most modules do have some implicit structure. For example, a board provides several functional blocks, each block might have several channels, and each channel has one or more pins. This results in a structure that resembles a directory tree. Even though halcmd doesn’t recognize the tree structure, proper choice of naming conventions will let it group related items together (since it sorts the names). In addition, higher level tools can be designed to recognize such structure, if the names provide the necessary information. To do that, all HAL components should follow these rules:
Dots (“.”) separate levels of the hierarchy. This is analogous to the slash (“/”) in a filename.
Hyphens (“-”) separate words or fields in the same level of the hierarchy.
Los componentes HAL no deben usar guiones bajos o "mezcla de mayúsculas y minúsculas".
[Se han eliminado caracteres subrayados, pero quedan algunos casos de mezcla errónea, por ejemplo pid.0.Pgain en lugar de pid.0.p-gain.]
Use only lowercase letters and numbers in names.
3. Hardware Driver Naming Conventions
Nota
Most drivers do not follow these conventions in version 2.0. This chapter is really a guide for future developments. |
3.1. Pins/Parameters names
Hardware drivers should use five fields (on three levels) to make up a pin or parameter name, as follows:
<device-name>.<device-num>.<io-type>.<chan-num>.<specific-name>
The individual fields are:
- <nombre-del-dispositivo>
The device that the driver is intended to work with. This is most often an interface board of some type, but there are other possibilities.
- <número-de-dispositivo>
It is possible to install more than one servo board, parallel port, or other hardware device in a computer. The device number identifies a specific device. Device numbers start at 0 and increment.
- <tipo-es>
Most devices provide more than one type of I/O. Even the simple parallel port has both digital inputs and digital outputs. More complex boards can have digital inputs and outputs, encoder counters, pwm or step pulse generators, analog-to-digital converters, digital-to-analog converters, or other unique capabilities. The I/O type is used to identify the kind of I/O that a pin or parameter is associated with. Ideally, drivers that implement the same I/O type, even if for very different devices, should provide a consistent set of pins and parameters and identical behavior. For example, all digital inputs should behave the same when seen from inside the HAL, regardless of the device.
- <chan-num>
Virtually every I/O device has multiple channels, and the channel number identifies one of them. Like device numbers, channel numbers start at zero and increment.
[One exception to the "channel numbers start at zero" rule is the parallel port. Its HAL pins are numbered with the corresponding pin number on the DB-25 connector. This is convenient for wiring, but inconsistent with other drivers. There is some debate over whether this is a bug or a feature.]
If more than one device is installed, the channel numbers on additional devices start over at zero. If it is possible to have a channel number greater than 9, then channel numbers should be two digits, with a leading zero on numbers less than 10 to preserve sort ordering. Some modules have pins and/or parameters that affect more than one channel. For example a PWM generator might have four channels with four independent "duty-cycle" inputs, but one "frequency" parameter that controls all four channels (due to hardware limitations). The frequency parameter should use "0-3" as the channel number. - <specific-name>
Un canal de E/S individual puede tener solo un pin HAL asociado con él, pero la mayoría tiene más de uno. Por ejemplo, una entrada digital tiene dos pines, uno es el estado del pin físico, el otro es la misma cosa pero invertida. Eso le permite al configurador elegir entre entradas activas bajas y activas altas. Para la mayoría de los tipos-io, hay un conjunto estándar de pines y parámetros, (denominada "interfaz canónica") que el driver debería implementar. Las interfaces canónicas se describen en el capítulo Interfaces canonicos de dispositivos.
- motenc.0.encoder.2.position
The position output of the third encoder channel on the first Motenc board.
- stg.0.din.03.in
The state of the fourth digital input on the first Servo-to-Go board.
- ppmc.0.pwm.00-03.frequency
The carrier frequency used for PWM channels 0 through 3 on the first Pico Systems ppmc board.
3.2. Function Names
Hardware drivers usually only have two kinds of HAL functions, ones that read the hardware and update HAL pins, and ones that write to the hardware using data from HAL pins. They should be named as follows:
<device-name>-<device-num>.<io-type>-<chan-num-range>.read|write
- <nombre-de-dispositivo>
The same as used for pins and parameters.
The specific device that the function will access.
- <tipo-es>
Optional. A function may access all of the I/O on a board, or it may access only a certain type. For example, there may be independent functions for reading encoder counters and reading digital I/O. If such independent functions exist, the <io-type> field identifies the type of I/O they access. If a single function reads all I/O provided by the board, <io-type> is not used.
[Note to driver programmers: Do NOT implement separate functions for different I/O types unless they are interruptible and can work in independent threads. If interrupting an encoder read, reading digital inputs, and then resuming the encoder read will cause problems, then implement a single function that does everything.]
- <chan-num-range>
Optional. Used only if the <io-type> I/O is broken into groups and accessed by different functions.
- read|write
Indicates whether the function reads the hardware or writes to it.
- motenc.0.encoder.read
Reads all encoders on the first motenc board.
- generic8255.0.din.09-15.read
Reads the second 8 bit port on the first generic 8255 based digital I/O board.
- ppmc.0.write
Writes all outputs (step generators, pwm, DACs, and digital) on the first Pico Systems ppmc board.
