Qtscreen
uses QtVCP widgets for LinuxCNC integration.
Widget is the general name for the UI objects such as buttons and labels in PyQt.
There are also special widgets made for LinuxCNC that make integration easier. These are split in two, heading on the right side of the editor:
One is for HAL only widgets.
The other is for CNC control widgets.
Note
This description of widget properties can easily be out of date due to further development and lack of people to write docs (a good way to give back to the project). The definitive descriptions are found by looking in the source code. |
1. HAL Only Widgets
These widgets usually have HAL pins and don’t react to the machine controller.
1.1. XEmbed
- Program Embedding Widget
Allows one to embed a program into the widget.
Only programs that utilize the xembed
protocol will work such as:
GladeVCP virtual control panels
Onboard virtual keyboard
QtVCP virtual control panels
mplayer video player
1.2. Slider
- HAL Pin Value Adjusting Widget
Allows one to adjust a HAL pin value using a sliding pointer.
1.3. LED
- Indicator Widget
A LED like indicator that optionally follows a HAL pin’s logic.
halpin_option
Selects if the LED follows an input HAL pin or program state.
diameter
Diameter of the LED
color
Color of the LED when on.
off_color
Color of the LED when off.
alignment
Qt alignment hint.
state
Current state of LED
flashing
Turns flashing option on and off.
flashRate
Sets the flash rate.
The LED
properties can be defined in a stylesheet with the following code added to the .qss
file, name_of_led
being the widget name defined in Qt Designer’s editor:
LED #name_0f_led{ qproperty-color: red; qproperty-diameter: 20; qproperty-flashRate: 150; }
1.4. CheckBox
Widget
This widget allows the user to check a box to set a HAL pin true or false.
It is based on PyQt’s QCheckButton.
1.5. RadioButton
Widget
This widget allows a user to set HAL pins true or false. Only one RadioButton
widget of a group can be true at a time.
It is based on PyQt’s QRadioButton.
1.6. Gauge
- Round Dial Gauge Widget
Round Gauge can be used in a LinuxCNC GUI to display an input parameter on the dial face.
There are several properties that are user settable in order to customize the appearance of the gauge.
The following parameters can be set either programmatically or via the Qt Designer property editor.
halpin_option
Setting this to
True
will create 2 HAL pins:-
One is for setting the
value
input -
The other is for setting the
setpoint
If this option is not set, then
value
andsetpoint
must be connected programmatically, i.e., in the handler file. -
max_reading
This value determines the highest number displayed on the gauge face.
max_value
This is the maximum expected value of the value input signal.
In other words, it is the full scale input. -
num_ticks
This is the number of ticks/gauge readings on the gauge face.
It should be set to a number that ensures the text readings around the gauge face are readable.
The minimum allowed value is 2. -
zone1_color
Zone1 extends from the maximum reading to the threshold point.
It can be set to any RGB color. -
zone2_color
Zone2 extends from the threshold point to the minimum reading, which is 0.
bezel_color
This is the color of the outer ring of the gauge.
threshold
The threshold is the transition point between the zones.
It should be set to a value between 0 and the maximum value.
The maximum allowed value is set to the gauge’smax_value
and minimum value is 0. -
gauge_label
This is the text below the value readout, near the bottom of the gauge.
The function of the gauge is then easily visible.
There are 2 inputs that are not customizable. They can be set via HAL pins, programmatically or via signals from other widgets:
value
This is the actual input value that will be displayed with the gauge needle and in the digital readout.
It must be set to a value between 0 andmax_value
maximum value. -
setpoint
This is a value that determines the location of a small marker on the gauge face. It must be set to a value between 0 and the maximum value.
1.7. HalBar - HAL Bar Level Indicator
This widget is used to indicate level or value, usually of a HAL s32/float pin.
you can also disable the HAL pin and use Qt signals or python commands to change the level.
1.7.1. Bar Properties:
HalBar is a subclass of the Bar widget, so it inherits these properties
stepColorList: a list of color strings, the number of colors defines the number of bars.
backgroundColor: a QColor definition of the background color.
setMaximum: an integer that defines the maximum level of indication.
setMinimum: an integer that defines the lowest level of indication.
1.7.2. halBar Properties:
pinType: to select HAL pins type:
NONE
no HAL pin will be added -
S32
A S32 integer pin will be added -
FLOAT
A Float pin will be added
pinName: to change the HAL pin name otherwise the widget base name is used.
1.7.3. HalBar style sheets
The above Bar properties could be set in styles sheets.
pinType and pinName properties can not be changed in stylesheets.
Note
In style sheets, stepColorList is a single string of color names separated by commas. |
HalBar{ qproperty-backgroundColor: #000; qproperty-stepColorList: 'green,green,#00b600,#00b600,#00d600,#00d600,yellow,yellow,red,red'; }
1.8. HALPad
- HAL Buttons Joypad
This widget looks and acts like a 5 buttons D-pad, with an LED ring.
Each button has an selectable type (Bit, S32 or Float) output HAL pin.
The LED center ring has selectable colors for off and on and is controlled by a bit HAL pin.
HALPad
ENUMS
There are enumerated constants used:
To reference indicator positions:
NONE
LEFT
RIGHT
CENTER
TOP
BOTTOM
LEFTRIGHT
TOPBOTTOM
For HAL pins type:
NONE
BIT
S32
FLOAT
You use the widget name in Qt Designer plus the reference constant:
self.w.halpadname.set_highlight(self.w.halpadname.LEFTRIGHT)
HALPad
Properties-
pin_name
Optional name to use for the HAL pins basename. If left blank, the Qt Designer widget name will be used.
pin_type
Select the HAL output pin type. This property is only used at startup. Selection can be set in Qt Designer:
NONE
BIT
S32
FLOAT
left_image_path
right_image_path
center_image_path
top_image_path
bottom_image_path
File or resource path to an image to display in the described button location.
If the reset button is pressed in the Qt Designer editor property, the image will not be displayed (allowing optional text). -
left_text
right_text
center_text
top_text
bottom_text
A text string to be displayed in the described button location.
If left blank an image can be designated to be displayed. -
true_color
false_color
Color selection for the center LED ring to be displayed when the
<BASENAME>.light.center
HAL pin isTrue
orFalse
text_color
Color selection for the button text.
text_font
Font selection for the button text.
HALPad
StylesThe above properties could be set in styles sheets.
HALPad{ qproperty-on_color: #000; qproperty-off_color: #444; }
1.9. PushButton
- HAL Pin Toggle Widget
This widget allows a user to set a HAL pin true or false with the push of a button.
As an option it can be a toggle button.
For a LED Indicator Option, see [sub:qtvcp:widgets:indicatedpushbutton][IndicatedPushButton] below for more info.
It also has other options.
It is based on PyQt’s QPushButton.
1.10. focusOverlay
- Focus Overlay Widget
This widget places a colored overlay over the screen, usually while a dialog is showing.
Used to create a focused feel and to draw attention to critical information.
It can also show a translucent image.
It can also display message text and buttons.
This widget can be controlled with STATUS
messages.
1.11. gridLayout
- Grid Layout Widget
This widget controls if the widgets inside it are enabled or disabled.
Disabled widgets typically have a different color and do not respond to actions.
It is based on PyQt’s QGridLayout
1.12. hal_label
- HAL Label Widget
This widget displays values sent to it.
Values can be sent from:
HAL pins
The input pin can be selected as Bit, S32, Float or no pin selected -
Programmatically
A
QtSignal
There is a textTemplate
property to set the rich text and/or to format the text.
Basic formatting might be:
%r
for booleans -
%d
for integers -
%0.4f
for floats.
A rich text example might be:
self.w.my_hal_label.setProperty(textTemplate,""" <html> <head/> <body> <p><span style="font-size:12pt;font-weight:600;color:#f40c11;">%0.4f</span></p> </body> </html> """ )
The setDisplay
slot can be connected to an integer, a float or a bool signal.
If the property pin_name
is not set the widget name will be used.
There are function calls to display values:
[HALLabelName].setDisplay(some_value)
Can be used to set the display if no HAL pin is selected.
[HALLabelName].setProperty(textTemplate,"%d")
Sets the template of the display.
It is based on PyQt’s QLabel.
1.13. LCDNumber
- LCD Style Number Readout Widget
This widget displays HAL float/s32/bit values in a LCD looking way.
It can display numbers in decimal, hexadecimal, binary and octal formats by setting the mode
property.
When using floats you can set a formatting string.
You must set the digitCount
property to an appropriate setting to display the largest number.
pin_name
Option string to be used as the HAL pin name.
If set to an empty string the widget name will be used. -
bit_pin_type
Selects the input pin as type BIT.
s32_pin_type
Selects the input pin as type S32.
float_pin_type
Select the input pin as type
FLOAT
floatTemplate
A string that will be used as a Python3 format template to tailor the LCD display.
Only used when aFLOAT
pin is selected, e.g.,{:.2f}
will display a float rounded to 2 numbers after the decimal.
A blank setting will allow the decimal to move as required.
It is based on PyQt’s QLCDNumber.
1.14. DoubleScale
- Spin Button Entry Widget
This widget is a spin button entry widget used for setting a s32 and float HAL pin.
It has an internal scale factor, set to a default of 1, that can be set programmatically or using a QtSignal.
The setInput
slot can be connected to an integer, or a float signal.
[HALLabelName].setInput(some_value)
This is a function call to change the internal scaling factor.
The HAL pins will be set to the value of the internal scale times the widget displayed value.
1.15. GeneralHALInput
- General Signals/Slots Input Connection Widget
This widget is used to connect an arbitrary Qt widget to HAL using signals/slots.
It is used for widgets that should respond to HAL pin changes.
1.16. GeneralHALOutput
- General Signals/Slots Output Connection Widget
It is used for widgets that should control HAL pins.
1.17. WidgetSwitcher
- Multi-widget Layout View Switcher Widget
This is used to switch the view of a multi-widget layout to show just one widget, i.e. to flip between a large view of a widget and a smaller multi widget view.
It is different from a stacked widget as it can pull a widget from anywhere in the screen and place it in its page with a different layout than it originally had.
The original widget must be in a layout for switcher to put it back.
In Qt Designer you will:
Add the
WidgetSwitcher
widget on screen. -
Right click the
WidgetSwitcher
and add a page. -
Populate it with the widgets/layouts you wish to see in a default form.
Add as many pages as there are views to switch to.
On each page, add a layout widget.
After adding the layout you must right click the widget switcher again and set the layout option. -
Click on the
WidgetSwitcher
widget and then scroll to the bottom of the property editor. -
Look for the dynamic property
widget_list
and double click to the right of it. -
A dialog pops up allowing you to add the names of the widgets to move to the pages you added to the
WidgetSwitcher
There are function calls to display specific widgets.
By calling one of these functions, you control what widget is currently displayed:
[_WidgetSwitcherName_].show_id_widget(_number_)
[_WidgetSwitcherName_].show_named_widget(_widget_name_)
[_WidgetSwitcherName_].show_default()
This shows the
page 0
layout, and puts all other widgets back to where they were as initially built in Qt Designer. -
[_WidgetSwitcherName_].show_next()
Show next widget.
It is based on the QStack widget.
2. Machine Controller Widgets
These widgets interact with the Machine Controller state.
2.1. ActionButton
- Machine Controller Action Control Widget
These buttons are used for control actions on the machine controller.
They are built on top of IndicatedPushButton
so can have LEDs overlaid.
Note
If you left double click on this widget you can launch a dialog to set any of these actions. The dialogs will help to set the right related data to the selected action. You can also change these properties directly in the property editor. |
You can select one of these:
Estop
Machine On
Auto
mdi
manual
run
run_from_line status
Gets line number from
STATUS
messagegcode-line-selected
run_from_line slot
Gets line number from Qt Designer int/str slot
setRunFromLine
abort
pause
load dialog
Requires a dialog widget present.
Camview dialog
Requires
camview
dialog widget present. -
origin offset dialog
Requires origin offset dialog widget present.
macro dialog
Requires macro dialog widget present.
Launch Halmeter
Launch Status
Launch Halshow
Home
Set the joint number to -1 for
all-home
Unhome
all-unhome
Home Selected
Homes the joint/axis selected by
STATUS
Unhome Selected
Unhomes the joint/axis selected by
STATUS
zero axis
zero G5X
Zeros the current user coordinate system offsets.
zero G92
Zeros the optional
G92
offsets. -
zero Z rotational
Zeros the rotation offset.
jog joint positive
Set the joint number.
jog joint negative
jog selected positive
Selected with a different widget or
STATUS
jog selected negative
STATUS
jog increment
Set metric/imperial/angular numbers.
jog rate
Set the float/alt float number.
feed override
rapid override
spindle override
spindle fwd
spindle backward
spindle stop
spindle up
spindle down
view change
Set
view_type_string
limits override
flood
mist
block delete
optional stop
mdi command
Set
command_string
, i.e.,calls a hard coded MDI command -
INI mdi number
Set
ini_mdi_number
, i.e., calls an INI based MDI command -
dro absolute
dro relative
dro dtg
exit screen
Closes down LinuxCNC
Override limits
Temporarily override hard limits
launch dialogs
Pops up dialogs if they are included in ui file.
set DRO to relative
set DRO to absolute
set DRO to distance-to-go
These set attributes of the selected action (availability depends on the widget):
toggle float option
Allows jog rate and overrides to toggle between two rates.
joint number
Selects the joint/axis that the button controls.
incr imperial number
Sets the imperial jog increment (set negative to ignore).
incr mm number
Sets the metric jog increment (set negative to ignore).
incr angular number
Sets the angular jog increment (set negative to ignore).
float number
Used for
jograte
and overrides. -
float alternate number
For
jograte
and overrides that can toggle between two float numbers. -
view type string
Can be:
p
x
,y
,y2
,z
,z2
zoom-in
,zoom-out
pan-up
,pan-down
,pan-left
,pan-right
rotate-up
,rotate-down
,rotate-cw
,rotate-ccw
clear
command string
MDI command string that will be invoked if the MDI command action is selected.
ini_mdi_number
(Legacy way)
A reference to the INI file[MDI_COMMAND_LIST]
section.
Set an integer of select one line under the INI`s[MDI_COMMAND]
line starting at 0.
Then in the INI file, under the heading[MDI_COMMAND_LIST]
add appropriate lines.
Commands separated by the;
will be run one after another
The button label text can be set with any text after a comma, the\n
symbol adds a line break. -
ini_mdi_key
(preferred way)
section.
This string will be added to MDI_COMMAND_ to form an entry to look for
[MDI_COMMAND_LIST] MDI_COMMAND_MACRO0 = G0 Z25;X0 Y0;Z0, Goto\nUser\nZero MDI_COMMAND_MACRO1 = G53 G0 Z0;G53 G0 X0 Y0, Goto\nMachn\nZero
Action buttons are subclassed from [sub:qtvcp:widgets:indicatedpushbutton][IndicatedPushButton
]. See the following sections for more information about:
2.2. ActionToolButton
- Optional Actions Menu Button Widget
ActionToolButton
buttons are similar in concept to action buttons,
but they use QToolButtons to allow for optional actions to be selected by pushing and holding the button till the option menu pops up.
Currently there is only one option: userView
It is based on PyQt’s QToolButton.
userView
Record and Set User View WidgetUser View tool button allows to record and return to an arbitrary graphics view.
Press and hold the button to have the menu pop up and press record view to record the currently displayed graphics view.
Click the button normally to return to the last recorded position.
The recorded position will be remembered at shutdown if a preference file option is set up.
Note
Due to programming limitations, the recorded position may not show exactly the same. Particularly, if you pan zoomed out and pan zoomed in again while setting the desired view. Best practice is to select a main view, modify as desired, record, then immediately click the button to switch to the recorded position. If it is not as you like, modify its existing position and re-record. |
2.3. RoundButton
- Round Shapped ActionButton
Widget
Round buttons work the same as ActionButtons other than the button is cropped round.
They are intended only to be visually different.
They have two path properties for displaying images on true and false.
2.4. AxisToolButton
- Select and Set Axis Widget
This allows one to select and set an axis.
If the button is set checkable, it will indicate which axis is selected.
If you press and hold the button a pop up menu will show allowing one to:
Zero the axis
Divide the axis by 2
Set the axis arbitrarily
Reset the axis to the last number recorded
You must have selected an entry dialog that corresponds to the dialog_code_string, usually this is selected from the screenOptions widget.
You can select the property halpin_option, it will then set a HAL pin true when the axis is selected. The property joint_number should be set to the appropriate joint number. The property axis_letter should be set to the appropriate axis letter.
The property dialog_code_string can be changed to ENTRY or CALCULATOR to call a typing only entry dialog or a touch/typing calculator type entry dialog.
2.5. CamView
- Workpiece Alignment and Origin Setting Widget
This widget displays a image from a web camera.
It overlays an adjustable circular and cross hair target over the image.
CamView was built with precise visual positioning in mind.
This is used to align the work piece or zero part features using a webcam.
It uses OpenCV vision library.
2.6. DROLabel
- Axis Position Display Widget
This will display the current position of an axis.
Qjoint_number
Joint number of offset to display (10 will specify rotational offset).
Qreference_type
Actual, relative or distance to go (0,1,2).
metric_template
Format of display, e.g.
%10.3f
imperial_template
format of display, e.g.
%9.4f
angular_template
%Rotational: 10.1f
The DROLabel
widget holds a property isHomed
that can be used with a stylesheet to change the color of the DRO_Label
based on homing state of the joint number in LinuxCNC.
Here is a sample stylesheet entry that:
Sets the font of all
DRO_Label
widgets, -
Sets the text template (to set resolution) of the DRO,
Then sets the text color based on the Qt
isHomed
property.
DROLabel { font: 25pt "Lato Heavy"; qproperty-imperial_template: '%9.4f'; qproperty-metric_template: '%10.3f'; qproperty-angular_template: '%11.2f'; } DROLabel[isHomed=false] { color: red; } DROLabel[isHomed=true] { color: green; }
Here is how you specify a particular widget by its objectName
in Qt Designer:
DROLabel #dr0_x_axis [isHomed=false] { color: yellow; }
2.7. GcodeDisplay
- G-code Text Display Widget
This displays G-code in text form, highlighting the currently running line.
This can also display:
MDI history when LinuxCNC is in
MDI
mode. -
Log entries when LinuxCNC is in
MANUAL
mode. -
Preference file entries if you enter
PREFERENCE
in capitals into theMDILine
widget.
It has a signal percentDone(int)
that can be connected to a slot (such as a progressBar
to display percent run).
auto_show_mdi_status
Set true to have the widget switch to MDI history when in MDI mode.
auto_show_manual_status
Set true to have the widget switch to machine log when in Manual mode.
The GcodeDisplay
properties can be set in a stylesheet with the following code added to the .qss file (the following color choices are random).
EditorBase{ qproperty-styleColorBackground: lightblue; qproperty-styleColorCursor:white; qproperty-styleColor0: black; qproperty-styleColor1: #000000; /* black */ qproperty-styleColor2: blue; qproperty-styleColor3: red; qproperty-styleColor4: green; qproperty-styleColor5: darkgreen; qproperty-styleColor6: darkred; qproperty-styleColor7: deeppink; qproperty-styleColorMarginText: White; qproperty-styleColorMarginBackground: blue; qproperty-styleFont0: "Times,12,-1,0,90,0,0,0,0,0"; qproperty-styleFont1: "Times,18,-1,0,90,1,0,0,0,0"; qproperty-styleFont2: "Times,12,-1,0,90,0,0,0,0,0"; qproperty-styleFont3: "Times,12,-1,0,90,0,0,0,0,0"; qproperty-styleFont4: "Times,12,-1,0,90,0,0,0,0,0"; qproperty-styleFont5: "Times,12,-1,0,90,0,0,0,0,0"; qproperty-styleFont6: "Times,12,-1,0,90,0,0,0,0,0"; qproperty-styleFont7: "Times,12,-1,0,90,0,0,0,0,0"; qproperty-styleFontMargin: "Times,14,-1,0,90,0,0,0,0,0"; }
For GcodeDisplay
widget’s default G-code lexer:
styleColor0 = Default: Everything not part of the groups below
styleColor1 = LineNo and Comments: Nxxx and comments (characters inside of and including () or anything after ; (when used outside of parenthesis) with the exception of the note below)
styleColor2 = G-code: G and the digits after
styleColor3 = M-code: M and the digits after
styleColor4 = Axis: XYZABCUVW
styleColor5 = Other: EFHIJKDQLRPST (feed, rpm, radius, etc.)
styleColor6 = AxisValue: Values following XYZABCUVW
styleColor7 = OtherValue: Values following EFHIJKDQLRPST$
Note
For comments, the "OtherValue" color (Color 5) can be used to highlight "print," "debug," "msg," "logopen," "logappend," "logclose" "log," "pyrun," "pyreload" "abort," "probeopen" "probeclose" inside of a parenthesis comment in a line of G-code. As well as "py," if a line that starts with ";py,". Examples: (print, text), (log, text), (msg, text), or (debug, text). Only the last of the examples will be highlighted if there are more than one on the same line. |
Font definitions:
"style name, size, -1, 0, bold setting (0-99), italics (0-1),
underline (0-1),0,0,0"
It is based on PyQt’s QsciScintilla.
2.8. GcodeEditor
- G-code Program Editor Widget
This is an extension of the GcodeDisplay
widget that adds editing convenience.
It is based on PyQt’s QWidget which incorporates GcodeDisplay
widget.
2.9. GCodeGraphics
- G-code Graphic Backplot Widget
This displays the current G-code in a graphical form.
dro-font/dro-large-font
(string) -
Sets the small and large DRO font properties
Here we reference with the widget base name; GCodeGraphics
GCodeGraphics{ qproperty-dro_font:"monospace bold 12"; } GCodeGraphics{ qproperty-dro_large_font:"Times 25"; }
_view
(string) -
Sets the default view orientation on GUI load.
Valid choices for a lathe are p, y, y2. For other screens, valid choices are p, x, y, z, z2.
The following shows an example of how to set this property (referenced using the widget user selected name):#gcodegraphics{ qproperty-_view: z; }
_dro
(bool) -
Determines whether or not to show the DRO.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-_dro: False; }
_dtg
(bool) -
Determine whether or not to show the Distance To Go.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-_dtg: False; }
_metric
(bool) -
Determines whether or not to show the units in metric by default.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-_metric: False; }
_overlay
(bool) -
Determines whether or not to show the overlay by default.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-_overlay: False; }
_offsets
(bool) -
Determines whether or not to show the offsets by default.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-_offsets: False; }
_small_origin
(bool) -
Determines whether or not to show the small origin by default.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-_small_origin: False; }
overlay_color
(primary, secondary, or RGBA formatted color) -
Sets the default overlay color.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-overlay_color: blue; }
overlay_alpha
(float) -
Sets the default overlay alpha value. This affects the opacity of the overlay when set between 0.0 and 1.0.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-overlay_alpha: 0.15; }
background_color
Sets the default background color.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-background_color: blue; }
+_use_gradient_background+
(bool) -
Determines whether or not use a gradient background by default.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-_use_gradient_background: False; }
jog_color
Sets the default jog color.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-jog_color: red; }
Feed_color
Sets the default feed color.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-Feed_color: green; }
Rapid_color
Sets the default rapid color.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-Rapid_color: rgba(0, 0, 255, .5); }
InhibitControls
(bool) -
Determines whether or not to inhibit external controls by default.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-InhibitControls:True; }
MouseButtonMode
(int) -
Changes the mouse button behavior to rotate, move or zoom within the preview.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-MouseButtonMode: 1; }
There are 12 valid modes:
Mode
Move
Zoom
Rotate
0
Left
Middle
Right
1
Middle
Right
Left
2
Middle
Left
Right
3
Left
Right
Middle
4
Right
Left
Middle
5
Right
Middle
Left
Modes 6-11 are intended for machines that only require a 2D preview such as plasma or some lathes and have no rotate button assigned.
Mode
Move
Zoom
6
Left
Middle
7
Middle
Left
8
Right
Left
9
Left
Right
10
Middle
Right
11
Right
Middle
MouseWheelInvertZoom
(bool) -
Determines whether or not to invert the zoom direction when zooming with the mouse wheel.
The following shows an example of how to set this property:#gcodegraphics{ qproperty-MouseWheelInvertZoom:True; }
ACTION
functionsThe ACTION
library can control the G-code graphics widget.
ACTION.RELOAD_DISPLAY()
Reload the current program which recalculates the origin/offsets.
ACTION.SET_GRAPHICS_VIEW(_view_)
The following
view
commands can be sent:-
clear
zoom-in
zoom-out
pan-up
pan-down
pan-right
pan-left
rotate-cw
rotate-ccw
rotate-up
rotate-down
overlay-dro-on
overlay-dro-off
overlay-offsets-on
overlay-offsets-off
alpha-mode-on
alpha-mode-off
inhibit-selection-on
inhibit-selection-off
dimensions-on
dimensions-off
grid-size
record-view
set-recorded-view
P
X
Y
Y2
Z
Z2
set-large-dro
set-small-dro
ACTION.ADJUST_PAN(_X,Y_)
Directly set the relative pan of view in x and y direction.
ACTION.ADJUST_ROTATE(_X,Y_)
Directly set the relative rotation of view in x and y direction.
It is based on PyQt’s OpenGL widget.
2.10. StateLabel
- Controller Modes State Label Display Widget
This will display a label based on the machine controller modes true/false states.
You can select between different texts based on true or false.
The states are selectable via these properties:
css_mode_status
True
when machine is inG96
Constant Surface Speed Mode. -
diameter_mode_status
True
when machine is inG7
Lathe Diameter Mode. -
fpr_mode_status
True
when machine is inG95
Feed per revolution Mode. -
metric_mode_status
True
when machine is inG21
Metric Mode.
true_textTemplate
This will be the text set when the option is
True
You can use Qt rich text code for different fonts/colors etc.
Typical template for metric mode in true state, might be: Metric Mode -
false_textTemplate
False
Typical template for metric mode in false state, might be: Imperial Mode.
2.11. StatusLabel
- Controller Variables State Label Display Widget
This will display a label based on selectable status of the machine controller.
You can change how the status will be displayed by substituting python formatting code in the text template. You can also use rich text for different fonts/colors etc.
These states are selectable:
actual_spindle_speed_status
Used to display the actual spindle speed as reported from the HAL pin
spindle.0.speed-i
It’s converted to RPM.
AtextTemplate
of%d
would typically be used. -
actual_surface_speed_status
Used to display the actual cutting surface speed on a lathe based on X axis and spindle speed.
It’s converted to distance per minute.
AtextTemplate
of%4.1f
(feet per minute) andaltTextTemplate
of%d
(meters per minute) would typically be used. -
blendcode_status
Shows the current
G64
setting. -
current_feedrate_status
Shows the current actual feedrate.
current_FPU_status
Shows the current actual feed per unit.
fcode_status
Shows the current programmed
F
code setting. -
feed_override_status
Shows the current feed override setting in percent.
filename_status
Shows the last loaded file name.
filepath_status
Shows the last loaded full file path name.
gcode_status
Shows all active G-codes.
gcode_selected_status
Show the current selected G-code line.
halpin_status
Shows the HAL pin output of a selected HAL pin.
jograte_status
Shows the current QtVCP based Jog Rate.
jograte_angular_status
Shows the current QtVCP based Angular Jog Rate.
jogincr_status
Shows the current QtVCP based Jog increment.
jogincr_angular_status
Shows the current QtVCP based Angular Jog increment.
machine_state_status
Shows the current machine interpreter state using the text described from the machine_state_list.
The interpreter states are:-
Estopped
Running
Stopped
Paused
Waiting
Reading
max_velocity_override_status
Shows the current max axis velocity override setting.
mcode_status
Shows all active M-codes.
- motion_type_status
Shows current type of machine motion using the text described from the motion_type_list.
None
Rapid
Feed
Arc
Tool Change
Probe
Rotary Index
requested_spindle_speed_status
Shows the requested spindle speed - actual may be different.
rapid_override_status
Shows the current rapid override setting in (0-100) percent.
spindle_override_status
Shows the current spindle override setting in percent.
timestamp_status
Shows the time based on the system settings.
An example of a usefultextTemplate
setting:%I:%M:%S %p
See the Python time module for more info. -
tool comment_status
Returns the comment text from the current loaded tool.
tool diameter_status
Returns the diameter from the current loaded tool.
tool_number_status
Returns the tool number of the current loaded tool.
tool_offset_status
Returns the offset of the current loaded tool, indexed by
index_number
to select axis (0=x,1=y,etc.). -
user_system_status
Shows the active user coordinate system (
G5x
setting).
index_number
Integer that specifies the tool status index to display.
state_label_list
List of labels used to describe different machine states.
- motion_label_list
List of labels used to describe different motion types.
halpin_names
Name of a halpin to monitor (must be the complete name, including the HAL component basename).
textTemplate
This is usually used for imperial (
G20
) or angular numerical settings, though not every option has imperial/metric conversion.
This uses Python formatting rules to set the text output.
One can use%s
for no conversion,%d
for integer conversion,%f
for float conversion, etc.
You can also use Qt rich text code.
Typical template used for formatting imperial float numbers to text would be%9.4f
or%9.4f inch
alt_textTemplate
This is usually used for metric (
G21
) numerical settings.
Typical template used for formatting metric float to text would be%10.3f
or%10.3f mm
2.12. StatusImageSwitcher
- Controller Status Image Switcher
Status image switcher will switch between images based on LinuxCNC states.
watch_spindle
Toggles between 3 images:
stop
,fwd
,revs
watch_axis_homed
Toggles between 2 images:
axis not homed
,axis homed
watch_all_homed
Would toggle between 2 images:
not all homed
,all homed
watch_hard_limits
Would toggle between 2 images or one per joint.
Here is an example of using it to display an icon of Z axis homing state:
In the properties section notice that:
watch_axis_homed
is checked -
axis_letter
is set to Z
If you double click the image_list
a dialog will show and allow you to add image paths to.
If you have one image as an icon and one clear image then that will look like it shows and hides the icon.
Selecting image paths can be done by selecting the pixmap
property and selecting an image.
Note
The pixmap setting is for test display only and will be ignored outside of Qt Designer. |
Right click the image name and you should see Copy path.
Click Copy path.
Now double click the image list property so the dialog shows.
Click the New button.
Paste the image path in the entry box.
Do that again for the next image.
Use a clear image to represent a hidden icon.
You can test the images display from the image list by changing the image number
. In this case 0
is unhomed and 1
would be homed.
This is for test display only and will be ignored outside of Qt Designer.
2.13. StatusStacked
- Mode Status Display Switching Widget
This widget displays one of three panels based on LinuxCNC’s mode.
This allows you to automatically display different widgets on Manual, MDI and Auto modes.
It is based on PyQt’s QStacked widget.
2.14. JogIncrements
- Jog Increments Value Selection Widget
This widget allows the user to select jog increment values for jogging.
The jogging values come from the INI file under:
[DISPLAY]INCREMENTS
, or -
[DISPLAY]ANGULAR_INCREMENTS
This will be available to all widgets through STATUS
You can select linear or angular increments by the property linear_option
in Qt Designer property editor.
It is based on PyQt’s ComboBox.
2.15. ScreenOption
- General Options Setting widget
This widget doesn’t add anything visually to a screen but sets up important options.
This is the preferred way to use these options.
These properties can be set in Qt Designer, in Python handler code or (if appropriate) in stylesheets.
These include:
halCompBaseName
If left empty QtVCP will use the screen’s name as the HAL component’s basename.
If set, QtVCP will use this string as the HAL component’s basename.
If the-c
command line option is used when loading QtVCP, it will use the name specified on the command line - it overrides all above options.
If you programmatically set the basename in thehandlerfile
- it will override all above options.
This property cannot be set in stylesheets. -
notify_option
Hooking into the desktop notification bubbles for error and messages.
notify_max_messages
Number of messages shown on screen at one time.
catch_close_option
Catching the close event to pop up a 'are you sure' prompt.
close_overlay_color
Color of transparent layer shown when quitting.
catch_error_option
Monitoring of the LinuxCNC error channel.
This also sends the message throughSTATUS
to anything that registers. -
play_sounds_option
Playing sounds using
beep
,espeak
and the system sound. -
use_pref_file_option
Setting up a preferences file path.
Using the magic wordWORKINGFOLDER
in the preference file path will be replaced with the launched configuration path, e.g.WORKINFOLDER/my_preferences
use_send_zmq_option
Used to initiate ZMQ based outgoing messages.
use_receive_zmq_messages
Used to initiate ZMQ based in coming messages.
These messages can be used to call functions in the handler file, allowing external programs to integrate tightly with QtVCP based screens. -
embedded_program_option
Embed programs defined in the INI.
default_embed_tab
This is the property for a default location to embed external programs.
It should be set to name of a tab page widget in Qt Designer. -
focusOverlay_option
Focus_overlay will put a transparent image or colored panel over the main screen to emphasize focus to an external event - typically a dialog.
messageDialog_option
Sets up the message dialog - used for general messages.
message_overlay_color
Color of transparent layer shown when the message dialog is shown.
closeDialog_option
Sets up the standard close screen prompt dialog.
entryDialog_option
Sets up the numerical entry dialog.
entryDialogSoftKey_option
Sets up a floating software keyboard when entry dialog is focused.
entry_overlay_color
Color of transparent layer shown when the entry dialog is shown.
toolDialog_option
Sets up the manual tool change dialog, including HAL pin.
tool_overlay_color
Color of transparent layer shown when the tool dialog is shown.
ToolUseDesktopNotify
Option to use desktop notify dialogs for manual tool change dialog.
ToolFrameless
Frameless dialogs can not be easily moved by users.
fileDialog_option
Sets up the file choosing dialog.
file_overlay_color
Color of transparent layer shown when the file dialog is shown.
keyboardDialog_option
Sets up a keyboard entry widget.
keyboard_overlay_color
Color of transparent layer shown when the keyboard dialog is shown.
vesaProbe_option
Sets up the Versa style probe dialog.
versaProbe_overlay_color
versaProbe
dialog is shown. -
macroTabDialog_option
Sets up the macro selection dialog.
macroTab_overlay_color
macroTab
dialog is shown. -
camViewDialog_option
Sets up the camera alignment dialog.
camView_overlay_color
camView
dialog is shown. -
toolOffset_option
Sets up the tool offset display/editor dialog.
toolOffset_overlay_color
toolOffset
dialog is shown. -
originOffset_option
Sets up the origin display/editor dialog.
originOffset_overlay_color
originOffset
dialog is shown. -
calculatorDialog_option
Sets up the calculator entry dialog.
calculator_overlay_color
Color of transparent layer shown when the calculator dialog is shown.
machineLogDialog_option
Sets up a dialog to display logs from the machine and QtVCP.
machineLog_overlay_color
machineLog
dialog is shown. -
runFromLineDialog_option
Sets up a dialog to display starting options when starting machine execution from a arbitrary line.
runFromLine_overlay_color
runFromLine
dialog is shown. -
user1Color
Optional color the screen designer can use in their design.
user2Color
user3Color
user4Color
user5Color
user6Color
user7Color
user8Color
user9Color
user10Color
The screen designer chooses the default settings of the screenOptions
widget.
Once chosen, most won’t ever need to be changed. But if needed, some can be changed in the handler file or in stylesheets.
In the handler file:
Here we reference the widget by the Qt Designer user defined name:# red,green,blue,alpha 0-255 color = QtGui.QColor(0, 255, 0, 191) self.w.screen_options.setProperty('close_overlay_color', color) self.w.screen_options.setProperty('play_sounds_option',False)
In style sheets:
Here we can reference the widget by Qt Designer user defined name or by widget class name./* red, green, blue 0-255, alpha 0-100% or 0.0 to 1.0 */ /* the # sign is used to refer to Qt Designer defined widget name */ /* matches/applied to only this named widget */ #screen_options { qproperty-close_overlay_color: rgba(0, 255, 0, 0.75) }
Some settings are only checked on startup so will not cause changes after startup. In these cases you would need to make the changes in Qt Designer only.
If the preference file option is selected, screenOption
widget will make an INI based preference file.
While other QtVCP widgets will add to this list, the screenOptions
widget will add these entries under the following headings:
[SCREEN_OPTIONS]
catch_errors
(bool) -
desktop_notify
(bool) -
Whether to display errors/messages in the system’s notification mechanism.
notify_max_msgs
(int) -
Number of displayed errors at one time.
shutdown_check
(bool) -
Whether to pop a confirmation dialog.
sound_player_on
(bool) -
Turns all sounds on or off.
[MCH_MSG_OPTIONS]
mchnMsg_play_sound
(bool) -
To play alert sound when dialog pops.
mchnMsg_speak_errors
(bool) -
To use Espeak to speak error messages.
mchnMsg_speak_text
(bool) -
To use Espeak to speak all other messages.
mchnMsg_sound_type
(str) -
Sound to play when messages displayed. See notes below.
[USER_MSG_OPTIONS]
usermsg_play_sound
(bool) -
userMsg_sound_type
(str) -
Sound to play when user messages displayed. See notes below.
userMsg_use_focusOverlay
(bool)
[SHUTDOWN_OPTIONS]
shutdown_play_sound
(bool) -
shutdown_alert_sound_type
(str) -
shutdown_exit_sound_type
(str) -
shutdown_msg_title
(str) -
Short title string to display in dialog.
shutdown_msg_focus_text
(str) -
Large text string to superimpose in focus layer.
shutdown_msg_detail
(str) -
Longer descriptive string to display in dialog.
NOTIFY_OPTIONS
notify_start_greeting
(bool) -
Whether to display a greeting dialog on start-up.
notify_start_title
(str) -
Short Title string.
If the speak option is also selected it will be spoken with Espeak. -
notify_start_detail
(str) -
Longer description string.
notify_start_timeout
(int) -
Time in seconds to display before closing.
*_sound_type
entries-
System Sounds
In Debian/Ubuntu/Mint based installations these system sounds should be available as sound-type entries above:-
ERROR
READY
DONE
ATTENTION
RING
LOGIN
LOGOUT
BELL
These Sound options require
python3-gst1.0
installed. -
Audio Files
You can also specify a file path to an arbitrary audio file.
You can use~
in path to substitute for the user home file path. -
Kernel Beeps
If thebeep
kernel module is installed and it is not disabled, these sound-type entries are available:-
BEEP
BEEP_RING
BEEP_START
Text-To-Speech
If the Espeak module (python3-espeak
) is installed, you can use theSPEAK
entry to pronounce text: -
SPEAK '_my message_'
2.16. StatusSlider
- Controller Setting Adjustment Slider Widget
This widget allow the user to adjust a LinuxCNC setting via a slider.
The widget can adjust:
Jog rate
Angular jog rate
Feed rate
Spindle override rate
Rapid override rate
StatusSlider
has the following properties:
halpin_option
Sets option to make a HAL float pin that reflects current value.
rapid_rate
Selects a rapid override rate slider.
feed_rate
Selects a feed override rate slider.
spindle_rate
Selects a spindle override rate slider.
jograte_rate
Selects a linear jograte slider.
jograte_angular_rate
Selects a angular jograte slider.
max_velocity_rate
Selects a maximum velocity rate slider.
alertState
String to define style change:
read-only
,under
,over
andnormal
alertUnder
Sets the float value that signals the stylesheet for under warning.
alertOver
Sets the float value that signals the stylesheet for over warning.
These can be set in:
Qt Designer
Python handler code,
self.w.status_slider.setProperty('spindle_rate',True) self.w.status_slider.setProperty('alertUnder',35) self.w.status_slider.setProperty('alertOver',100)
Or (if appropriate) in stylesheets.
/* warning colors for overrides if out of normal range*/ /* widget object name is slider_spindle_ovr */ #slider_spindle_ovr[alertState='over'] { background: red; } #slider_spindle_ovr[alertState='under'] { background: yellow; }
It is based on PyQt’s QSlider.
2.17. StateLED
- Controller State LED Widget
This widget gives status on the selected LinuxCNC state.
The state options are:
is_paused_status
is_estopped_status
is_on_status
is_idle_status_
is_homed_status
is_flood_status
is_mist_status
is_block_delete_status
is_optional_stop_status
is_joint_homed_status
is_limits_overridden_status
is_manual_status
is_mdi_status
is_auto_status
is_spindle_stopped_status
is_spindle_fwd_status
is_spindle_rev_status
is_spindle_at_speed_status
is_neg_limit_tripped
is_pos_limit_tripped
is_limits_tripped
There are properties that can be changed:
halpin_option
Adds an output pin that reflects selected state.
invert_state_status
Invert the LED state compared to the LinuxCNC state.
diameter
Diameter of the LED.
color
off_color
alignment
Qt Alignment hint.
state
Current state of LED (for testing in Qt Designer).
flashing
flashRate
The LED properties can be defined in a stylesheet with the following code added to the .qss
file.
State_LED #name_of_led{ <1> qproperty-color: red; qproperty-diameter: 20; qproperty-flashRate: 150; }
name_of_led
would be the name defined in Qt Designer’s editor.
It is based on the LED widget.
2.18. StatusAdjustmentBar
- Controller Value Setting Widget
This widget allows setting values using buttons while displaying a bar.
It also has an optional hi/low toggle button that can be held down to set the levels.
Jog rate
Angular jog rate
Feed rate
Rapid override rate
It is based on PyQt’s QProgressBar.
2.19. SystemToolButton
- User System Selection Widget
This widget allows you to manually select a G5x user system by pressing and holding.
If you don’t set the button text it will automatically update to the current system.
2.20. MacroTab
- Special Macros Widget
This widget allows a user to select and adjust special macro programs for doing small jobs.
It uses images for visual representation of the macro and for an icon.
It searches for special macros using the INI definition:
[RS274NGC] SUBROUTINE_PATH =
The macros are O-word
subroutines with special comments to work with the launcher. The first three lines must have the keywords below, the fourth is optional.
Here is a sample for the first four lines in an O-word file:
; MACROCOMMAND = Entry1,Entry2 ; MACRODEFAULTS = 0,true ; MACROIMAGE = my_image.svg,Icon layer number,Macro layer number ; MACROOPTIONS = load:yes,save:yes,default:default.txt,path:~/macros
MACROCOMMAND
This is the first line in the O-word file.
It is a comma separated list of text to display above an entry.
There will be one for every variable required in the O-word function.
If the macro does not require variables, leave it empty:
; MACROCOMMAND=
MACRODEFAULTS
This must be the second line in the O-word file.
It is a comma separated list of the default values for each variable in the O-word function.
If you use the word true
or false
in the list, a *checkbutton*
will be shown.
MACROIMAGE
This must be the third line in the O-word file.
SVG Images
If using SVG image files, they must end with the.svg
extension.
The images must be added to SVG layers which are used to define the different images for macro and icon.
Value is comma separated list of three ordered fields:
; MACROIMAGE=filename.svg,macro_layer_name[,icon_layer_name]
With:
_filename_.svg
SVG image file name as first field.
It is assumed to be in the same folder as the O-word file. -
*macro_layer_name
Macro image layer name as second field.
icon_layer_name
Icon image layer name as optional third field. If the third entry is missing, the same image will be used for macro and icon.
PNG/JPG Images:
Value remains a comma separated list:; MACROIMAGE=macro_image.(png|jpg)[,icon_image.(png|jpg)]
With:
_macro_image_.(png|jpg)
Macro image file name as first field.
It is assumed that the image file are in the same folder than the macro. -
_icon_image_.(png|jpg)
Icon image file name as optional second field.
If the second entry is missing the same image will be used for macro and image.
If the keyword is present but the entries are missing, no images will be used.
MACROOPTIONS
This optional line must be the fourth line in the O-word file.
It is a comma separated list of keyword and data:
LOAD:yes
Shows a load button.
SAVE:yes
Shows a save button.
2.21. MDILine
- MDI Commands Line Entry Widget
One can enter MDI commands here.
A popup keyboard is available.
There are also embedded commands available from this widget.
Enter any of these case sensitive commands to load the respective program or access the feature:
HALMETER
Starts LinuxCNC
halmeter
utility. -
HALSHOW
Starts LinuxCNC
halshow
utility. -
HALSCOPE
Starts LinuxCNC
halscope
utility. -
STATUS
Starts LinuxCNC
status
utility. -
CALIBRATION
Starts LinuxCNC Calibration
CLASSICLADDER
Starts the ClassicLadder GUI if the ClassicLadder realtime HAL component was loaded by the machine’s config files.
PREFERENCE
Loads the preference file into the
GcodeEditor
CLEAR HISTORY
Clears the MDI History.
net
See
halcmd net
commands.
An error will result if the command is unsuccessful.-
Syntax:
net <signal name> <pin name>
Example:
net plasmac:jog-inhibit motion.jog-stop
setp
Sets the value of a pin or a parameter.
Valid values depend on the object type of the pin or parameter.
It results in an error if the data types do not match or the pin is connected to a signal.-
Syntax:
setp <pin/parameter-name> <value>
Example:
setp plasmac.resolution 100
unlinkp
Disconnects a pin from a signal.
An error will result if the pin does not exist.
Running LinuxCNC from terminal may help determine the root cause as error messages fromhal_lib.c
will be displayed there.-
Syntax:
unlinkp <pin name>
Example:
unlinkp motion.jog-stop
Note
The MDILine function spindle_inhibit can be used by a GUI’s handler file to inhibit M3 , M4 , and M5 spindle commands if necessary. |
It is based on PyQt’s QLineEdit.
2.22. MDIHistory
- MDI Commands History Widget
Displays a scrollable list of past MDI command.
An edit line is embedded for MDI commands. The same MDILine embedded commands may be accessed from this widget.
The history is recorded on a file defined in the INI under the heading [DISPLAY]
(this shows the default):
MDI_HISTORY_FILE = '~/.axis_mdi_history'
2.23. MDITouchy
- Touch Screen MDI Entry Widget
This widget displays buttons and entry lines to use for entering MDI commands.
Based on LinuxCNC’s Touchy screen’s MDI entry process, its large buttons are most useful for touch screens.
To use MDITouchy
First press one of the
G/XY
,G/RO
,M
orT
button. On the left will show the entry fields that can be filled out. -
Then press
Next
andBack
to navigate between fields. -
Calc
will pop up a calculator dialog. -
Clear
clears the current entry. -
Set Tool
will call for a tool change. -
Set Origin
will allow setting the origin of the current G6x system. -
Macro
will call any available macro ngc programs.
The widget requires an explicit call to MDITouchy Python code to actually run the MDI command:
For handler file code
If the widget was named mditouchy in Qt Designer, the command below would run the displayed MDI command:self.w.mditouchy.run_command()
For action button use
If the widget was named mditouchy in Qt Designer, use the action button’s Call Python commands option and enter:INSTANCE.mditouchy.run_command()
The macro button cycles though macros defined in the INI [DISPLAY] heading.
Add one or more MACRO
lines of the following format:
MACRO = macro_name [param1] [... paramN]
In the example below, increment
is the name of the macro, and it accepts two parameters, named xinc
and yinc
MACRO = incerment xinc yinc
Now, place the macro in a file named macro_name.ngc
in the PROGRAM_PREFIX
directory, or into any directory in the SUBROUTINE_PATH
specified in the INI file.
Keeping on with the example above, it would be named increment.ngc
and its content could look like:
O<increment> sub G91 G0 X#1 Y#2 G90 O<increment> endsub
Notice the name of the sub matches the file name and macro name exactly, including case.
When you invoke the macro by pressing the Macro button you can enter values for parameters (xinc
and yinc
in our example).
These are passed to the macro as positional parameters: #1
, #2
… #N
respectively.
Parameters you leave empty are passed as value 0
If there are several different macros, press the Macro button repeatedly to cycle through them.
In this simple example, if you enter -1 for xinc and invoke the running of the MDI cycle, a rapid G0 move will be invoked, moving one unit to the left.
This macro capability is useful for edge/hole probing and other setup tasks, as well as perhaps hole milling or other simple operations that can be done from the panel without requiring specially-written G-code programs.
2.24. OriginOffsetView
- Origins View and Setting Widget
This widget allows one to visualize and modify User System Origin offsets directly.
It will update LinuxCNC’s Parameter file for changes made or found.
The settings can only be changed in LinuxCNC after homing and when the motion controller is idle.
The display and entry will change between metric and imperial, based on LinuxCNC’s current G20
/ G21
setting.
The current in-use user system will be highlighted.
Extra actions can be integrated to manipulate settings.
These actions depend on extra code added either to a combined widget, like originoffsetview
dialog, or the screens handler code.
Typical actions might be Clear Current User offsets or Zero X.
Clicking on the columns and rows allows one to adjust the settings.
A dialog can be made to popup for data or text entry.
The comments section will be recorded in the preference file.
It is based on PyQt’s QTableView, QAbstractTableModel, and ItemEditorFactory.
Properties, functions and styles of the PyQt base objects are always available.
OriginOffsetView
dialog_code_string
Sets which dialog will pop up with numerical entry.
test_dialog_code_string
Sets which dialog will pop up with text entry.
metric_template
Metric numerical data format.
imperial_template
Imperial numerical data format.
styleCodeHighlight
Current in-use user system highlight color.
Qt Designer, in
Python handler code
self.w.originoffsetview.setProperty('dialog_code','CALCULATOR') self.w.originoffsetview.setProperty('metric_template','%10.3f')
OriginOffsetView{ qproperty-styleColorHighlist: lightblue; }
2.25. StateEnableGridlayout
- Controller State Enabled Container Widget
_disable the widgets inside it depending on LinuxCNC's current state_.
This is a container that other widgets can be placed in.
Embedded widgets are be greyed-out when the StateEnableGridlayout
is disabled.
It can selectably react to:
Machine on
Interpreter idle
E-stop off
All-homed
It is based on PyQt’s QGridLayout.
2.26. MachineLog
- Machine Events Journal Display Widget
FIXME MachineLog documentation
2.27. JointEnableWidget
- FIXME
FIXME JointEnableWidget documentation
2.28. StatusImageSwitcher
- Controller Status Image Switching Widget
This widget will display images based on LinuxCNC status.
You can watch:
the state of the spindle,
the state of all homed,
the state of a certain axis homed,
the state of hard limits.
It is based on PyQt’s FIXME
2.29. FileManager
- File Loading Selector Widget
This widget is used to select files to load.
It has a the ability to scroll the names with hardware such as a MPG.
One can class patch the function load(self,fname)
to customize file loading.
The function getCurrentSelected()
will return a Python tuple, containing the file path and whether it is a file.
temp = FILEMANAGER.getCurrentSelected() print('filepath={}'.format(temp[0])) if temp[1]: print('Is a file')
doubleClickSelection
(bool) -
Determines whether or not to require double clicking on a folder.
Single clicking a folder (False) is enabled by default and is intended for touch screen users.
The following shows an example of how to set this property:#filemanager { qproperty-doubleClickSelection: True; }
showListView
(bool) -
Determines whether or not to show the file/folder structure in list form.
Table view (False) is enabled by default.
The following shows an example of how to set this property:#filemanager { qproperty-showListView: True; }
2.30. RadioAxisSelector
- FIXME
FIXME RadioAxisSelector documentation
2.31. ToolOffsetView
- Tools Offsets View And Edit Widget
This widget displays and allows one to modify tools offsets.
It will update LinuxCNC’s tool table for changes made or found.
The tool settings can only be changed in LinuxCNC after homing and when the motion controller is idle.
The display and entry will change between metric and imperial based on LinuxCNC’s current G20
/G21
setting.
The current in-use tool will be highlighted, and the current selected tool will be highlighted in a different color.
The checkbox beside each tool can be used to select too for an action that depends on extra code added either to a combined widget, like the toolOffsetView
dialog or the screens handler code.
Typical actions are load selected tool, delete selected tools, etc.
The comments section will typically be displayed in the manual tool change dialog.
If using a lathe configuration, there can be columns for X and Z wear.
To use these columns to adjust the tool wear, it requires a remapped tool change routine.
ToolOffsetView
has properties that can be set in Qt Designer, in Python handler code or (if appropriate) in stylesheets:
dialog_code_string
metric_template
imperial_template
styleCodeHighlight
Current tool-in-use highlight color.
styleCodeSelected
Selected highlight color.
In a handler file:
self.w.tooloffsetview.setProperty('dialog_code','CALCULATOR') self.w.tooloffsetview.setProperty('metric_template','%10.3f')
and in style sheets:
ToolOffsetView{ qproperty-styleColorHighlist: lightblue; qproperty-styleColorSelected: #444; }
ToolOffsetView
has some functions useful for screen builders to add actions:
add_tool()
Adds a blank dummy tool (99) that the user can edit to suit.
delete_tools()
Deletes the currently checkbox selected tools.
get_checked_list()
Returns a list of tools selected by checkboxs.
set_all_unchecked()
Uncheck all selected tools.
self.w.tooloffsetview.add_tool() self.w.tooloffsetview.delete_tools() toolList = self.w.tooloffsetview.get_checked_list() self.w.tooloffsetview.set_all_unchecked()
2.32. BasicProbe
- Simple Mill Probing Widget
Widget for probing on a mill. Used by the QtDragon screen.
2.33. VersaProbe
- Mill Probing Widget
3. Dialog Widgets
Dialogs are used to present or request immediately required information in a focused way.
The typical used dialogs can be loaded using the ScreenOptions
widget.
You can also add them directly to the UI - but each dialog must have a unique launch name or you will see multiple dialogs displayed, one after another.
You can show dialogs directly with Python code, but a safer way is to use STATUS
messages to request the dialog to launch and to return the gathered information.
Register to
STATUS
channel:
To set this up, first register to catch thegeneral
message fromSTATUS
:STATUS.connect('general',self.return_value)
Add a function to call a dialog:
This function must build a messagedict
to send to the dialog.
This message will be passed back in the general message with the addition of thereturn
variable.
It is possible to add extra user information to the message. The dialog will ignore these and pass them back.-
NAME
Launches code name of dialog to show.
ID
A unique id so we process only a dialog that we requested.
TITLE
The title to use on the dialog.
def show_dialog(self): mess = {'NAME':'ENTRY','ID':'__test1__', 'TITLE':'Test Entry'} ACTION.CALL_DIALOG, mess)
Add a callback function that processes the general message:
Keep in mind this function will get all general messages so thedict
keynames are not guaranteed to be there. Using the.get()
function and/or usingtry
/except
is advisable. This function should:-
check the name and id is the same as we sent,
then extract the return value and any user variables.
# process the STATUS return message def return_value(self, w, message): rtn = message.get('RETURN') code = bool(message.get('ID') == '__test1__') name = bool(message.get('NAME') == 'ENTRY') if code and name and not rtn is None: print('Entry return value from {} = {}'.format(code, rtn))
3.1. LcncDialog
- General Message Dialog Widget
This is a general message dialog widget.
If there is a Focus Overlay widget present, it can signal it to display.
If the sound library is set up it can play sounds.
There are options that can be set when requesting a dialog, these would be added to the message dict
TITLE
Title of the dialog window.
MESSAGE
Title message text in bold.
MORE
Standard text under the heading.
DETAILS
Initial hidden text.
TYPE
(OK
|YESNO
|OKCANCEL
ICON
(QUESTION
|INFO
|CRITICAL
|WARNING
PINNAME
Not implemented yet.
FOCUSTEXT
(overlay text|None
Text to display if focus overlay is used. Use
None
for no text. -
FOCUSCOLOR
(QColor(_R, G, B, A_)
Color to use if focus overlay is used.
PLAYALERT
Sound to play if sound is available, i.e.,
SPEAK
<spoken_message> .
When using STATUS
's request-dialog
function, the default launch name is MESSAGE
It is based on PyQt’s QMessagebox.
3.2. ToolDialog
- Manual Tool Change Dialog Widget
This is used as a manual tool change prompt.
It has HAL pins to connect to the machine controller. The pins are named the same as the original AXIS manual tool prompt and works the same.
The tool change dialog can only be launched by HAL pins.
If there is a Focus Overlay widget present, it will signal it to display.
3.3. FileDialog
- Load and Save File Chooser Dialog Widget
This is used to load G-code files.
When using STATUS
's request-dialog
function, the default launch names are LOAD
or SAVE
There are options that can be set when requesting a dialog, these would be added to the message dict:
EXTENSIONS
FILENAME
DIRECTORY
An example Python call, for a load dialog:
mess = {'NAME':'LOAD','ID':'_MY_DIALOG_', 'TITLE':'Load Some text File', 'FILENAME':'~/linuxcnc/nc_files/someprogram.txt', 'EXTENSIONS':'Text Files (*.txt);;ALL Files (*.*)' } ACTION.CALL_DIALOG(mess)
And for a save dialog
mess = {'NAME':'SAVE','ID':'_MY_DIALOG_', 'TITLE':'Save Some text File', 'FILENAME':'~/linuxcnc/nc_files/someprogram.txt', 'EXTENSIONS':'Text Files (*.txt);;ALL Files (*.*)' } ACTION.CALL_DIALOG(mess)
3.4. OriginOffsetDialog
- Origin Offset Setting Dialog Widget
This widget allows one to modify User System origin offsets directly in a dialog form.
If there is an Focus Overlay widget present, it will signal it to display.
When using STATUS
's request-dialog
function, the default launch name is ORIGINOFFSET
It is based on PyQt’s QDialog.
3.5. ToolOffsetDialog
- Tool Offset Setting Dialog Widget
This widget allows one to modify Tool offsets directly in a dialog form.
When using STATUS
's request-dialog
function, the default launch name is TOOLOFFSET
3.6. MacroTabDialog
- Macro Launch Dialog Widget
This is a dialog to display the macrotab widget.
MacroTab
displays a choice of macro programs to run using icons.
When using ``STATUS``'s request-dialog
function, the default launch name is MACROTAB
3.7. CamViewDialog
- WebCam Part Alignment Dialog Widget
This is a dialog to display the CamView widget for Webcam part alignment.
function, the default launch name is CAMVIEW
3.8. EntryDialog
- Edit Line Dialog Widget
This is a dialog to display an edit line for information entry, such as origin offset.
It returns the entry via STATUS
messages using a Python DICT
The DICT
contains at minimum, the name of the dialog requested and an ID code.
function, the default launch name is ENTRY
3.9. CalculatorDialog
- Calculator Dialog Widget
This is a dialog to display a calculator for numeric entry, such as origin offset.
The DICT
function, the default launch name is CALCULATOR
3.10. RunFromLine
- Run-From-Line Dialog Widget
Dialog to preset spindle settings before running a program from a specific line.
3.11. VersaProbeDialog
- Part Touch Probing Dialog Widget
This is a dialog to display a part probing screen based on Verser Probe v2.
3.12. MachineLogDialog
- Machine and Debugging Logs Dialog Widget
This is a dialog to display the machine log and QtVCP’s debugging log.
4. Other Widgets
Other available widgets:
4.1. NurbsEditor
- NURBS Editing Widget
The Nurbs editor allows you to manipulate a NURBS based geometry on screen and then convert NURBS to G-code.
You can edit the G-code on screen and then send it to LinuxCNC.
4.2. JoyPad
- 5 button D-pad Widget
It is the base class for the HALPad
widget.
This widget looks and acts like a 5 button D-pad, with a LED like indicators in a ring.
You can put text or icons in each of the button positions.
You can connect to output signals when the buttons are pressed.
There are also input slots to change the color of the indicator(s).
There are enumerated constants used to reference indicator positions.
They are used in Qt Designer editor’s property editor or in Python code.
NONE
LEFT
,L
RIGHT
,R
CENTER
,C
TOP
,T
BOTTOM
,B
LEFTRIGHT
,X
TOPBOTTOM
,A
For Python handler code, you use the widget name in Qt Designer plus the reference constant:
self.w.joypadname.set_highlight(self.w.joypadname.LEFT)
def _pressedOutput(self, btncode): self.joy_btn_pressed.emit(btncode) self[''.format(btncode.lower())].emit(True) def _releasedOutput(self, btncode): self.joy_btn_released.emit(btncode) self['joy_{}_pressed'.format(btncode.lower())].emit(False)
As coded these function issue (emit) PyQt5 signals (joy_btn_pressed and joy<letter>_pressed) for the any button pressed or released_.
Signal joy_btn_pressed outputs a string code for the button.
Signal joy_<letter>_pressed outputs a bool value.
You could override the functions to do something else if making a custom widget:
reset_highlight()
Clears the highlight indicator.
set_highlight(_button_, state=_True_)
Set the highlight indicator in position
button
to statestate
You can use strings letters (LRCTBXA
) or positionENUMS
for the button argument. -
set_button_icon(_button_, _pixmap_)
Sets the button’s icon pixmap.
set_button_text(_button_, _text_)
Sets the button’s icon text.
set_tooltip(_button_, _text_)
Sets the buttons pop-up tooltip descriptive text.
setLight(_state_)
Sets the highlight indicator to the
True
color orFalse
color.
Theset_highlight()
function must be used prior to set the indicator to use.
These signals will be sent when buttons are pressed.
They can be connected to in Qt Designer editor or Python code.
The first two output a string that indicates the button pressed:
joy_btn_pressed
(string) -
joy_btn_released
(string) -
joy_l_pressed
(bool) -
joy_l_released
(bool) -
joy_r_pressed
(bool) -
joy_r_released
(bool) -
joy_c_pressed
(bool) -
joy_c_released
(bool) -
joy_t_pressed
(bool) -
joy_t_released
(bool) -
joy_b_pressed
(bool) -
joy_b_released
(bool) -
They are based on PyQt’s Signal (QtCore.pyqtSignal()
Slots can be connected to in Qt Designer editor or Python code:
set_colorStateTrue()
set_colorStateFalse()
set_colorState(_bool_)
set_true_color(_str_)
set_true_color(_qcolor_)
set_false_color(_str_)
set_false_color(_qcolor_)
These can be set in stylesheets or Python code:
highlightPosition
Set the indicator position.
setColorState
Select the color state of the indicator.
left_image_path
right_image_path
center_image_path
top_image_path
bottom_image_path
A file path or resource path to an image to display in the described button location.
If the reset button is pressed in Qt Designer editor property, the image will not be displayed (allowing optionally text). -
left_text
right_text
center_text
top_text
bottom_text
A text string to be displayed in the described button location.
If left blank an image can be designated to be displayed. -
true_color
false_color
Color selection for the center LED ring to be displayed, when the
BASENAME.light.center
HAL pin isTrue
orFalse
text_color
Color selection for the button text.
button_font
Font selection for the button text.
The above properties could be set in:
Stylesheets:
You would usually use the Qt Designer widget name with#
prefix to set individual widget properties, otherwise you would use theJoyPad
class name to set allJoyPad
widgets the same:#joypadname{ qproperty-true_color: #000; qproperty-false_color: #444; }
In Python handler code:
self.w.joypadename.setProperty('true_color','green') self.w.joypadename.setProperty('false_color','red')
4.3. WebWidget
This widget will create a html/pdf viewing page using the QtWebKit or QtWebEngine libraries. The newer QtWebEngine is preferred if both are on the system.
If the QtWebEngine library is used with the Qt Designer editor, a placeholder QWidget will show in Qesigner. This will be replaced with the QtWebEngine widget at run time.
5. BaseClass/Mixin Widgets
These widgets are used to combine different properties and behaviours into other widgets.
You will see them as a collapsible header in the Qt Designer properties column.
5.1. IndicatedPushButtons
This class modifies QPushButton
behaviour.
5.1.1. Indicator Option
indicator_option
puts a LED on the top of the button.
It can be a triangle, circle, top bar, or side bar.
The size and position can be adjusted.
It will indicate:
the current state of the button, or
the state of a HAL pin, or
LinuxCNC status.
These properties are available to customize the indicator (not all are applicable to every LED shape):
on_color
off_color
flashIndicator
flashRate
indicator_size
circle_diameter
shape_option
right_edge_offset
top_edge_offset
height_fraction
width_fraction
corner_radius
Indicator corner radius.
The LED indicator color can be defined in a stylesheet with the following code added to the .qss
file:
Indicated_PushButton{ qproperty-on_color: #000; qproperty-off_color: #444; }
Or for a particular button:
Indicated_PushButton #button_estop{ qproperty-on_color: black; qproperty-off_color: yellow; }
IndicatedPushButton
have exclusive options:
indicator_HAL_pin_option
Adds a
halpin
, named<buttonname>-led
that controls the button indicator state. -
indicator_status_option
Makes the LED indicate the state of these selectable LinuxCNC status:
Is Estopped
Is On
All Homed
Is Joint Homed
Idle
Paused
Flood
Mist
Block Delete
Optional Stop
Manual
MDI
Auto
Spindle Stopped
Spindle Forward
Spindle Reverse
On Limits
Some
indicator_status_options
holds a property that can be used with a stylesheet to change the color of the button based on the state of the property in LinuxCNC.
Currently these status properties can be used to auto style buttons:-
is_estopped_status
will toggle theisEstop
property -
is_on_status
will toggle theisStateOn
property -
is_manual_status
,is_mdi_status
,is_auto_status
will toggle theisManual
,isMDI
,isAuto
properties. -
is_homed_status
will toggle the isAllHomed property
Here is a sample stylesheet entry setting the background of mode button widgets when LinuxCNC is in that mode:
ActionButton[isManual=true] { background: red; } ActionButton[isMdi=true] { background: blue; } ActionButton[isAuto=true] { background: green; }
Here is how you specify a particular widget by its objectName in Qt Designer:
ActionButton #estop button [isEstopped=false] { color: yellow; }
5.1.2. Enabled by LinuxCNC State
Often, having the button disabled and enabled based on the state of LinuxCNC’s motion controller is necessary.
There are several properties that can be selected to aid with this:
isAllHomedSentive
isOnSensitive
isIdleSensitive
isRunSensitive
isRunPausedSensitive
isManSensitive
isMDISensitive
isAutoSensitive
You can select multiple properties for combined requirements.
5.1.3. Text Changes On State
Choosing the checked_state_text_option
allows a checkable button to change the text based on its checked state.
It uses the following properties to specify the text for each state:
true_state_string
false_state_string
\\n
will be converted to a newline.
You can set/change these in stylesheets:
ActionButton #action_aux{ qproperty-true_state_string: "Air\\nOn"; qproperty-false_state_string: "Air\\nOff"; }
5.1.4. Call Python Commands On State
The python_command_option
allow small snippets of Python code to be run from the push of a button, without having to edit the handler file. Though, it can call functions in the handler file.
When using the command_string
properties.
true_python_cmd_string
A Python command that will be called when the button is toggled
True
false_python_cmd_string
False
Special capitalized words will give access to the following:
INSTANCE
Will give access to the widgets instances and handler functions.
E.g.,INSTANCE.my_handler_function_call(True)
ACTION
Will give access to QtVCP’s
ACTION
library.
E.g.,ACTION.TOGGLE_FLOOD()
PROGRAM_LOADER
PROGRAM_LOADER
library.
E.g.,PROGRAM_LOADER.load_halshow()
HAL
Will give access to HAL’s Python module.
E.g.,HAL.set_p('motion.probe-input','1')
6. Import-Only Widgets
These widgets are usually the base class widget for other QtVCP widgets.
They are not available directly from the Qt Designer editor but could be imported and manually inserted.
They could also be subclassed to make a similar widget with new features.
6.1. Auto Height
Widget for measuring two heights with a probe.
For setup.
6.2. G-code Utility
Widgets for performing common machining processes.
6.3. Facing
Slab or face a definable area with different strategies.
6.4. Hole Circle
Drill multiple holes on a bolt hole circle.
6.5. Qt NGCGUI
QtVCP’s version of NGC subroutine selector (Shown as used in QtDragon).
6.5.1. INI settings
LinuxCNC needs to know where to look to run the subroutines.
If the subroutine calls other subroutines or custom M codes, those paths must be added too.
[RS274NGC] SUBROUTINE_PATH = ~/linuxcnc/nc_files/examples/ngcgui_lib:~/linuxcnc/nc_files/examples/ngcgui_lib/utilitysubs
QtVCP needs to know where to open subroutines from.
You can also specify subroutines to be pre-opened in tabs.
[DISPLAY] # NGCGUI subroutine path. # This path must also be in [RS274NGC] SUBROUTINE_PATH NGCGUI_SUBFILE_PATH = ~/linuxcnc/nc_files/examples/ngcgui_lib # pre selected programs tabs # specify filenames only, files must be in the NGCGUI_SUBFILE_PATH NGCGUI_SUBFILE = slot.ngc NGCGUI_SUBFILE = qpocket.ngc
6.5.2. Buttons
NEW TAB - add new blank tab to NGCGUI
SELECT PREAMBLE - select a file that add preamble G-code
SELECT SUBFILE - select a NGCGUI subroutine file
SELECT POST - select a file that add post G-code
REREAD FILE - reload the subroutine file
CREATE FEATURE - add feature to the list
RESTART FEATURE - remove all features from the list
FINALIZE GCODE - create the full G-code and send it to LinuxCNC/a file
6.5.3. Adding Custom Subroutines
You can create your own subroutines for use with NGCGUI. They must follow these rules:
For creating a subroutine for use with NGCGUI, the filename and the subroutine name must be the same.
The subroutine must be in a folder within LinuxCNC’s INI designated search path.
On the first line there may be a comment of type info:
The subroutine must be surrounded by the sub and endsub tags.
The variables used must be numbered variables and must not skip number.
Comments and presets may be included.
If an image file of the same name is in the folder, it will be shown.
(info: feedrate -- simple example for setting feedrate) o<feedrate> sub #<feedrate> = #1 (= 6 Feed Rate) ; comments in brackets will be shown in ngcui f#<feedrate> o<feedrate> endsub
6.6. Qt PDF
Allows adding loadable PDFs to a screen.
6.7. Qt Vismach
Use this to build/add OpenGl simulated machines.
6.8. Hal Selection Box
This widget is combobox that will allows selection of a pin or signal on the system.
from qtvcp.widgets.hal_selectionbox import HALSelectionBox def buildComboBox(self): # combo box for HAL pin selection combobox = HALSelectionBox() combobox.setShowTypes([combobox.PINS,combobox.SIGNALS]) combobox.setPinTypes([combobox.HAL_BIT], direction = [combobox.HAL_IN]) combobox.setSignalTypes([combobox.HAL_BIT], driven = [False,True]) combobox.hal_init() combobox.selectionUpdated.connect(lambda w: self.signalSelected(w)) def signalSelected(self, sig): print('Watching:',sig)
There are function calls
# set the list of types to show from: PINS SIGNALS combobox.setShowTypes([combobox.PINS]) # set the pin types to show: HAL_BIT,HAL_FLOAT,HAL_S32,HAL_U32 # and a list of directions: HAL_IN HAL_OUT combobox.setPinTypes(types=[combobox.HAL_BIT], direction = [HAL_IN]) # set the signal types to show: HAL_BIT,HAL_FLOAT,HAL_S32,HAL_U32 # and a list of driven/undriven (by a connected pin) to show combobox.setSignalTypes( types=[combobox.HAL_BIT], driven = [True,True])
