This documentation describes the hal
python module, which provides a Python API for creating and accessing HAL pins and signals.
1. Basic usage
#!/usr/bin/env python3 import hal, time h = hal.component("passthrough") h.newpin("in", hal.HAL_FLOAT, hal.HAL_IN) h.newpin("out", hal.HAL_FLOAT, hal.HAL_OUT) h.ready()
2. Funksjoner
- component
+ The component itself is created by a call to the constructor
hal.component
. The arguments are the HAL component name and (optionally) the prefix used for pin and parameter names. If the prefix is not specified, the component name is used.
.Eksempel
- newpin
Create new pin.
Arguments: pin name suffix, pin type, and pin direction. For parameters, the arguments are: parameter name suffix, parameter type, and parameter direction.
.Example:
- ready
Tells the HAL system the component is initialized. Locks out adding pins.
- unready
Allows a component to add pins after ready() has been called. One should call ready() on the component after.
- component_exists
Does the specified component exist at this time.
hal.component_exists("testpanel")
- component_is_ready
Is the specified component ready at this time.
hal.component_is_ready("testpanel")
- get_msg_level
Get the current Realtime msg level.
- set_msg_level
Set the current Realtime msg level. used for debugging information.
- connect
Connect a pin to a signal.
hal.connect("pinname","signal_name")
- disconnect
Disconnect a pin from a signal.
hal.disconnect("pinname")
- get_value
Read a pin, param, or signal directly.
value = hal.get_value("iocontrol.0.emc-enable-in")
- get_info_pins()
Returns a list of dicts of all system pins.
listOfDicts = hal.get_info_pins() pinName1 = listOfDicts[0].get('NAME') pinValue1 = listOfDicts[0].get('VALUE') pinType1 = listOfDicts[0].get('TYPE') pinDirection1 = listOfDicts[0].get('DIRECTION')
- get_info_signals()
Returns a list of dicts of all system signals.
listOfDicts = hal.get_info_signals() signalName1 = listOfDicts[0].get('NAME') signalValue1 = listOfDicts[0].get('VALUE') driverPin1 = listOfDicts[0].get('DRIVER')
- get_info_params()
Returns a list of dicts of all system parameters.
listOfDicts = hal.get_info_params() paramName1 = listOfDicts[0].get('NAME') paramValue1 = listOfDicts[0].get('VALUE') paramDirection1 = listOfDicts[0].get('DIRECTION')
- new_sig
Create a new signal of the type specified.
hal.new_sig("signalname",hal.HAL_BIT)
- pin_has_writer
Does the specified pin have a driving pin connected.
Returns True or False.
h.in.pin_has_writer()
- get_name
Get the HAL object name.
Return a string.
h.in.get_name()
- get_type
Get the HAL object’s type.
Returns an integer.
h.in.get_type()
- get_dir
Get the HAL object direction type.
Returns an integer.
h.in.get_dir()
- get
Get the HAL object value.
h.in.get()
- set
Set the HAL object value.
h.out.set(10)
- is_pin
Is the object a pin or parameter?
h.in.is_pin()
- sampler_base
TODO
- stream_base
TODO
- stream
TODO
- set_p
Set a pin value of any pin in the HAL system.
hal.set_p("pinname","10")
- set_s
Set the value of any unconnected signal in the HAL system.
hal.set_s("signalname","10")
