This section describes the recommended way to download and make a fresh install of LinuxCNC. There are also Alternate Install Methods for the adventurous. If you have an existing install that you want to upgrade, go to the Updating LinuxCNC section instead.
To operate machinery LinuxCNC requires a special kernel with real-time extensions. There are three possibilities here: preempt-rt, RTAI or Xenomai. In addition there are two versions of LinuxCNC which work with these kernels. See the table below for details. However for code testing and simulation it is possible to run the linuxcnc-uspace application on a stock kernel. |
Fresh installs of LinuxCNC are most easily created using the Live/Install Image. This is a hybrid ISO filesystem image that can be written to a USB storage device or a DVD and used to boot a computer. At boot time you will be given a choice of booting the "Live" system (to run LinuxCNC without making any permanent changes to your computer) or booting the Installer (to install LinuxCNC and its operating system onto your computer’s hard drive).
The outline of the process looks like this:
Download the Live/Install Image.
Write the image to a USB storage device or DVD.
Boot the Live system to test out LinuxCNC.
Boot the Installer to install LinuxCNC.
1. Download the image
This section describes some methods for downloading the Live/Install image.
1.1. Normal Download
Software for LinuxCNC to download is presented on the project’s Downloads page. Most users will aim for the disk image for Intel/AMD PCs, the URL will resemble https://www.linuxcnc.org/iso/linuxcnc_2.9.2-amd64.hybrid.iso.
For the Raspberry Pi, multiple images are provided to address differences between the RPi4 and RPi5.
Do not use the regular Raspbian distribution for LinuxCNC that may have shipped with your RPi starter kit - that will not have the real-time kernel and you cannot migrate from Raspbian to Debian’s kernel image. |
1.2. Download using zsync
zsync is a download application that efficiently resumes interrupted downloads and efficiently transfers large files with small modifications (if you have an older local copy). Use zsync if you have trouble downloading the image using the Normal Download method.
Install zsync using Synaptic or, by running the following in a terminal
sudo apt-get install zsync
Then run this command to download the iso to your computer
zsync http://www.linuxcnc.org/iso/linuxcnc_2.9.2-amd64.hybrid.iso
There is a Windows port of zsync. It works as a console application and can be downloaded from https://www.assembla.com/spaces/zsync-windows/documents .
1.3. Verify the image
(This step is unnecessary if you used zsync)
After downloading, verify the checksum of the image to ensure integrity.
md5sum linuxcnc-2.9.2-amd64.iso
or
sha256sum linuxcnc-2.9.2-amd64.iso
Then compare to these checksums
amd64 (PC)
md5sum: 1815aceaac0e7861747aa34d61846e79
sha256sum: 08b3f59233e47c91cf1c9a85c41df48542c97b134efefa7446d3060c9a3e644b
arm64 (Pi)
md5sum: 4547e8a72433efb033f0a5cf166a5cd2
sha256sum: ff3ba9b8dfb93baf1e2232746655f8521a606bc0fab91bffc04ba74cc3be6bf0
Windows and Mac OS X do not come with an md5sum program, but there are alternatives. More information can be found at: How To MD5SUM
2. Write the image to a bootable device
The LinuxCNC Live/Install ISO Image is a hybrid ISO image which can be written directly to a USB storage device (flash drive) or a DVD and used to boot a computer. The image is too large to fit on a CD.
2.1. Raspberry Pi Image
The Raspberry Pi image is a complete SD card image and should be written to an SD card with the [Raspberry Pi Imager App](https://www.raspberrypi.com/software/).
2.2. AMD-64 (x86-64, PC) Image using GUI tools
Download and install [Balena Etcher](https://etcher.balena.io/#download-etcher) (Linux, Windows, Mac) and write the downloaded image to a USB drive.
If your image fails to boot then please also try Rufus. It looks more complicated but seems to be more compatible with various BIOSes.
2.3. Command line - Linux
Connect a USB storage device (for example a flash drive or thumb drive type device).
Determine the device file corresponding to the USB flash drive. This information can be found in the output of
dmesg
after connecting the device./proc/partitions
may also be helpful. -
Use the
dd
command to write the image to your USB storage device. For example, if your storage device showed up as/dev/sde
, then use this command:dd if=linuxcnc_2.9.2-amd64.hybrid.iso of=/dev/sde
2.4. Command line - MacOS
Open a terminal and type
diskutil list
Insert the USB and note the name of the new disk that appears, eg /dev/disk5
unmount the USB. The number found above should be substituted in place of the N
diskutil unmountDisk /dev/diskN
Transfer the data with dd, as for Linux above. Note that the disk name has an added "r" at the beginning
sudo dd if=/linuxcnc_2.9.2-amd64.hybrid.iso of=/dev/rdiskN bs=1m
Note that this may take a long time to complete and there will be no feedback during the process.
Insert a blank DVD into your burner. A CD/DVD Creator or Choose Disc Type window will pop up. Close this, as we will not be using it.
Browse to the downloaded image in the file browser.
Right click on the ISO image file and choose Write to Disc.
Select the write speed. It is recommended that you write at the lowest possible speed.
Start the burning process.
If a choose a file name for the disc image window pops up, just pick OK.
Download and install Infra Recorder, a free and open source image burning program: http://infrarecorder.org/
Insert a blank CD in the drive and select Do nothing or Cancel if an auto-run dialog pops up.
Open Infra Recorder, and select the Actions menu, then Burn image.
Download the .iso file
Right-click on the file in the Finder window and select "Burn to disc" (The option to burn to disc will only appear if the machine has an optical drive fitted or connected)
3. Testing LinuxCNC
With the USB storage device plugged in or the DVD in the DVD drive, shut down the computer then turn the computer back on. This will boot the computer from the Live/Install Image and choose the Live boot option.
If the system does not boot from the DVD or USB stick, it may be necessary to change the boot order in the PC BIOS. |
Once the computer has booted up you can try out LinuxCNC without installing it. You can not create custom configurations or modify most system settings in a Live session, but you can (and should) run the latency test.
To try out LinuxCNC: from the Applications/CNC menu pick LinuxCNC. A dialog box will open from which you can choose one of many sample configurations. At this point it only really makes sense to pick a "sim" configuration. Some of the sample configurations include onscreen 3D simulated machines, look for "Vismach" to see these.
To see if your computer is suitable for software step pulse generation run the Latency Test as shown here.
At the time of writing the Live Image is only available with the preempt-rt kernel and a matching LinuxCNC. On some hardware this might not offer good enough latency. There is an experimental version available using the RTAI realtime kernel which will often give better latency.
4. Installing LinuxCNC
To install LinuxCNC from the Live CD select Install (Graphical) at bootup.
5. Updates to LinuxCNC
With the normal install the Update Manager will notify you of updates to LinuxCNC when you go on line and allow you to easily upgrade with no Linux knowledge needed. It is OK to upgrade everything except the operating system when asked to.
Do not upgrade the operating system to a new version if prompted to do so. You should accept OS updates however, especially security updates. |
6. Install Problems
In rare cases you might have to reset the BIOS to default settings if during the Live CD install it cannot recognize the hard drive during the boot up.
7. Alternate Install Methods
The easiest, preferred way to install LinuxCNC is to use the Live/Install Image as described above. That method is as simple and reliable as we can make it, and is suitable for novice users and experienced users alike. However, this will typically replace any existing operating system. If you have files on the target PC that you want to keep, then use one of the methods described in this section.
In addition, for experienced users who are familiar with Debian system administration (finding install images, manipulating apt sources, changing kernel flavors, etc), new installs are supported on following platforms: ("amd64" means "64-bit", and is not specific to AMD processors, it will run on any 64-bit x86 system)
Distribution | Architecture | Kernel | Package name | Typical use |
Debian Bookworm |
amd64 & arm64 |
preempt-rt |
linuxcnc-uspace |
machine control & simulation |
Debian Bookworm |
amd64 |
RTAI |
linuxcnc |
machine control |
Debian Bullseye |
amd64 |
preempt-rt |
linuxcnc-uspace |
Debian Buster |
amd64 & arm64 |
preempt-rt |
linuxcnc-uspace |
Debian Buster |
amd64 |
RTAI |
linuxcnc |
machine control |
Any |
Any |
Stock |
linuxcnc-uspace |
simulation ONLY |
LinuxCNC v2.9 is not supported on Debian 9 or older. |
The Preempt-rt kernels are available for Debian from the regular debian.org archive. The package is called linux-image-rt-*
. Simply install the package in the same way as any other package from the Synaptic Package manager or with apt-get at the command-line.
The RTAI kernels are available for download from the linuxcnc.org debian archive. The apt source is:
Debian Bookworm:
deb http://linuxcnc.org bookworm base
Debian Bullseye:
deb http://linuxcnc.org bullseye base
Debian Buster:
deb http://linuxcnc.org buster base
LinuxCNC and the RTAI kernel are now only available for 64-bit OSes but there are very few surviving systems that can not run a 64-bit OS.
7.1. Installing on Debian Bookworm (with Preempt-RT kernel)
Install Debian Bookworm (Debian 12), amd64 version. You can download the installer here: https://www.debian.org/distrib/
After burning the iso and booting up if you don’t want Gnome desktop select Advanced Options > Alternative desktop environments and pick the one you like. Then select Install or Graphical Install.
Do not enter a root password, if you do sudo is disabled and you won’t be able to complete the following steps. -
Run the following in a terminal to bring the machine up to date with the latest packages.
sudo apt-get update sudo apt-get dist-upgrade
It is possible to download a version of LinuxCNC directly from Debian but this will install an old pre-release version, and is not recommended at this time. -
Install the Preempt-RT kernel and modules
sudo apt-get install linux-image-rt-amd64
Re-boot, and select the Linux 6.1.0-10-rt-amd64 kernel. The exact kernel version might be different, look for the "-rt" suffix. This might be hidden in the "Advanced options for Debian Bookworm" sub-menu in Grub. When you log in, verify that `PREEMPT RT`is reported by the following command.
uname -v
Open Applications Menu > System > Synaptic Package Manager search for linux-image and right click on the original non-rt and select Mark for Complete Removal. Reboot. This is to force the system to boot from the RT kernel. If you prefer to retain both kernels then the other kernels need not be deleted, but grub boot configuration changes will be needed beyond the scope of this document.
Add the LinuxCNC Archive Signing Key to your apt keyring by downloading [the LinuxCNC installer script](https://www.linuxcnc.org/linuxcnc-install.sh) You will need to make the script executable to run it:
chmod +x linuxcnc-install.sh
Then you can run the installer:
sudo ./linuxcnc-install.sh
7.2. Installing on Debian Bookworm (with experimental RTAI kernel)
This kernel and LinuxCNC version can be installed on top of the Live DVD install, or alternatively on a fresh Install of Debian Bookworm 64-bit as described above.
You can add the LinuxCNC Archive signing key and repository information by downloading and running the installer script as described above. If an RTAI kernel is detected it will stop before installing any packages.
Update the package list from linuxcnc.org
sudo apt-get update
Install the new realtime kernel, RTAI and the rtai version of linuxcnc.
sudo apt-get install linuxcnc
Reboot the machine, ensuring that the system boots from the new 5.4.258-rtai kernel.
7.3. Installing on Raspbian 12
Don’t do that. The latencies are too bad with the default kernel and the PREEMPT_RT (the RT is important) kernel of Debian does not boot on the Pi (as of 1/2024). Please refer to the images provided online. You can create them yourself following the scripts provided online.
