1. Giriş
This document describes how to build the LinuxCNC software and documentation from source. This is primarily useful if you are a developer who is modifying LinuxCNC. It can also be useful if you’re a user who is testing developer branches, though then you also have the option of just installing Debian packages from the buildbot: http://buildbot.linuxcnc.org
1.1. Quick Start
For the impatient, try this:
$ git clone https://github.com/LinuxCNC/linuxcnc.git linuxcnc-dev
$ cd linuxcnc-dev/src
$ ./autogen.sh
$ ./configure --with-realtime=uspace
$ make
That will probably fail! That does not make you a bad person, it just means you should read this whole document to find out how to fix your problems. Especially the section on Satisfying Build Dependencies.
If you are running on a realtime-capable system (such as an install from the LinuxCNC Live/Install image, see the Realtime section below), one extra build step is needed at this time:
$ sudo make setuid
After you have successfully built LinuxCNC it is time to run the tests:
$ source ../scripts/rip-environment
$ runtests
This might fail too! Read this whole document, but especially the section on Setting up the test environment.
2. Supported Platforms
The LinuxCNC project targets modern Debian-based distributions, including Debian, Ubuntu, and Mint. We continuously test on the platforms listed at http://buildbot.linuxcnc.org.
LinuxCNC builds on most other Linux distributions, though dependency management will be more manual and less automatic. Patches to improve portability to new platforms are always welcome.
2.1. Realtime
LinuxCNC is a machine tool controller, and it requires a realtime platform to do this job. This version of LinuxCNC supports three realtime platforms
- RTAI
From https://www.rtai.org. A Linux kernel with the RTAI patch is available from the Debian archive at https://linuxcnc.org. See Getting LinuxCNC for installation instructions.
- Xenomai
From https://xenomai.org. You will have to compile or obtain a Xenomai kernel yourself.
- Preempt-RT
From https://rt.wiki.kernel.org. A Linux kernel with the Preempt-RT patch is occasionally available from the Debian archive at https://www.debian.org, and from the wayback machine at https://snapshot.debian.org.
To make use of the realtime capabilities of LinuxCNC, certain parts of LinuxCNC need to run with root privileges. To enable root for these parts, run this extra command after the make
that builds LinuxCNC:
$ sudo make setuid
2.2. Non-realtime
LinuxCNC can also be built and run on non-realtime platforms, such as a regular install of Debian or Ubuntu without any special realtime kernel.
In this mode LinuxCNC is not useful for controlling machine tools, but it is useful for simulating the execution of G-code and for testing the non-realtime parts of the system (such as the user interfaces, and some kinds of components and device drivers).
3. Build modes
There are two ways to build LinuxCNC: the developer-friendly "run in place" mode and the user-friendly Debian packaging mode.
3.1. Building for Run In Place
In a Run-In-Place build, the LinuxCNC programs are compiled from source and then run directly from within the build directory. Nothing is installed outside the build directory.
This is quick and easy, and suitable for rapid iteration of changes.
The LinuxCNC test suite runs only in a Run-In-Place build.
Most LinuxCNC developers primarily build using this mode.
Building for Run-In-Place follows the steps in the Quick Start section at the top of this document, possibly with different arguments to src/configure
and make
3.1.1. src/configure
arguments
The src/configure
script configures how the source code will be compiled. It takes many optional arguments.
List all arguments to src/configure
by running this:
$ ./configure --help
The most commonly used arguments are:
Build for any realtime platform, or for non-realtime. The resulting LinuxCNC executables will run on both a Linux kernel with Preempt-RT patches (providing realtime machine control) and on a vanilla (un-patched) Linux kernel (providing G-code simulation but no realtime machine control). If development files are installed for Xenomai (typically from package libxenomai-dev) or RTAI (typically from a package with a name starting "rtai-modules"), support for these real-time kernels will also be enabled.
--with-realtime=/usr/realtime-$VERSION
Build for the RTAI realtime platform using the older "kernel realtime" model. This requires that you have an RTAI kernel and the RTAI modules installed in
. The resulting LinuxCNC executables will only run on the specified RTAI kernel. As of LinuxCNC 2.7, this produces the best realtime performance. -
--enable-build-documentation
Build the documentation, in addition to the executables. This option adds significantly to the time required for compilation, as building the docs is quite time consuming. If you are not actively working on the documentation you may want to omit this argument.
--disable-build-documentation-translation
Disable building the translated documentation for all available languages. The building of the translated documentation takes a huge amount of time, so it is recommend to skip that if not really needed.
3.1.2. make
arguments
The make
command takes two useful optional arguments.
- Parallel compilation
make
takes an optional argument-jN
(where N is a number). This enables parallel compilation with N simultaneous processes, which can significantly speed up your build.A useful value for N is the number of CPUs in your build system. You can discover the number of CPUs by running
nproc
. - Building just a specific target
If you want to build just a specific part of LinuxCNC, you can name the thing you want to build on the
make
command line. For example, if you are working on a component namedfroboz
, you can build its executable by running:$ cd linuxcnc-dev/src $ make ../bin/froboz
3.2. Building Debian Packages
When building Debian packages, the LinuxCNC programs are compiled from source and then stored in a Debian package, complete with dependency information. This process by default also includes the building of the documentation, which takes its time because of all the I/O for many languages, but that can be skipped. LinuxCNC is then installed as part of those packages on the same machines or on whatever machine of the same architecture that the .deb files are copied to. LinuxCNC cannot be run until the Debian packages are installed on a target machine and then the executables are available in /usr/bin and /usr/lib just like other regular software of the sytem.
This build mode is primarily useful when packaging the software for delivery to end users, and when building the software for a machine that does not have the build environment installed, or that does not have internet access.
Building Debian packages requires the dpkg-buildpackage
tool, from the dpkg-dev
package:
$ sudo apt-get install dpkg-dev
Building Debian packages also requires that all build dependencies are installed, as described in the section Satisfying Build Dependencies.
Once those prerequisites are met, building the Debian packages consists of two steps.
The first step is generating the Debian package scripts and meta-data from the git repo by running this:
$ cd linuxcnc-dev
$ ./debian/configure
The The |
Once the Debian package scripts and meta-data are configured, build the package by running dpkg-buildpackage
$ dpkg-buildpackage -b -uc
3.2.1. debian/configure
arguments
The debian/configure
script configures the Debian packaging. It must be run before dpkg-checkbuilddeps
and dpkg-buildpackage
can be run.
It takes a single argument which specifies the realtime or non-realtime platform to build for. The normal values for this argument are:
no-docs
Skip building documentation.
uspace
Configure the Debian package for Preempt-RT realtime or for non-realtime (these two are compatible).
noauto
rtai
xenomai
Normally, the lists of RTOSes for uspace realtime to support is detected automatically. However, if you wish, you may specify one or more of these after
uspace
to enable support for these RTOSes. Or, to disable autodetection, specifynoauto
.If you want just the traditional RTAI "kernel module" realtime, use
-r
or$KERNEL_VERSION
instead. -
rtai=<package name>
If the development package for rtai lxrt does not start with "rtai-modules", or if the first such package listed by apt-cache search is not the desired one, then explicitly specify the package name.
-r
Configure the Debian package for the currently running RTAI kernel. You must be running an RTAI kernel on your build machine for this to work!
$KERNEL_VERSION
Configure the debian package for the specified RTAI kernel version (for example "3.4.9-rtai-686-pae"). The matching kernel headers debian package must be installed on your build machine (for example "linux-headers-3.4.9-rtai-686-pae"). Note that you can build LinuxCNC in this configuration, but if you are not running the matching RTAI kernel you will not be able to run LinuxCNC, including the test suite.
4. Satisfying Build Dependencies
On Debian-based platforms we provide packaging meta-data that knows what external software packages need to be installed in order to build LinuxCNC. These are referred to as the build dependencies of LinuxCNC, i.e. those packages that need to be available such that * the build succeeds and * the build can be built reproducibly.
You can use this meta-data to easily list the required packages missing from your build system. First, go to the source tree of LinuxCNC and initiate its default self-configuration, if not already performed:
$ cd linuxcnc-dev
This will prepare the file debian/control that contains lists of Debian packages to create with the runtime dependencies for those packages and for our cause also the build-dependencies for those to-be-created packages.
The most straightforward way to get all build-dependencies installed is to just execute (from the same directory):
sudo apt-get build-dep .
which will install all the dependencies required but available. The . is part of the command line, i.e. an instruction to retrieve the dependencies for the source tree at hand, not for dependencies of another package. This completes the installation of build-dependencies.
The remainder of this section describes a semi-manual approach. The list of dependencies in debian/control is long and it is tedious to compare the current state of packages already installed with it. Debian systems provide a program called dpkg-checkbuilddeps
that parses the package meta-data and compares the packages listed as build dependencies against the list of installed packages, and tells you what’s missing.
First, install the dpkg-checkbuilddeps
program by running:
Finally ask dpkg-checkbuilddeps
to do its job (note that it needs to run from the linuxcnc-dev
directory, not from linuxcnc-dev/debian
$ dpkg-checkbuilddeps
It will emit a list of packages that are required to build LinuxCNC on your system, but that are not installed yet. Install them all with sudo apt-get install
, followed by the package names.
You can rerun dpkg-checkbuilddeps
any time you want, to list any missing packages.
5. Setting up the environment
This section describes the special steps needed to set up a machine to run the LinuxCNC programs, including the tests.
5.1. Increase the locked memory limit
LinuxCNC tries to improve its realtime latency by locking the memory it uses into RAM. It does this in order to prevent the operating system from swapping LinuxCNC out to disk, which would have bad effects on latency.
Normally locking memory into RAM is frowned upon, and the operating system places a strict limit on how much memory a user is allowed to have locked.
When using the Preempt-RT realtime platform LinuxCNC runs with enough privilege to raise its memory lock limit itself. When using the RTAI realtime platform it does not have enough privilege, and the user must raise the memory lock limit.
If LinuxCNC displays the following message on startup, the problem is your system’s configured limit on locked memory:
RTAPI: ERROR: failed to map shmem
RTAPI: Locked memory limit is 32KiB, recommended at least 20480KiB.
To fix this problem, add a file named /etc/security/limits.d/linuxcnc.conf
(as root) with your favorite text editor (e.g., sudo gedit /etc/security/limits.d/linuxcnc.conf
). The file should contain the following line:
* - memlock 20480
Log out and log back in to make the changes take effect. Verify that the memory lock limit is raised using the following command:
$ ulimit -l
6. Building on Gentoo
Building on Gentoo is possible, but not supported. Be sure you are running a disktop profile. This project uses the Tk Widget Set, asciidoc, and has some other dependencies. They should be installed as root:
~ # euse -E tk imagequant
~ # emerge -uDNa world
~ # emerge -a dev-libs/libmodbus dev-lang/tk dev-tcltk/bwidget dev-tcltk/tclx
~ # emerge -a dev-python/pygobject dev-python/pyopengl dev-python/numpy
~ # emerge -a app-text/asciidoc app-shells/bash-completion
You can switch back to being a normal user for most of the rest of the install. As that user, create a virtual environment for pip, then install the pip packages:
~/src $ python -m venv --system-site-packages ~/src/venv
~/src $ . ~/src/venv/bin/activate
(venv) ~/src $ pip install yapps2
(venv) ~/src $
Then you can contrinue as normally:
(venv) ~/src $ git clone https://github.com/LinuxCNC/linuxcnc.git
(venv) ~/src $ cd linuxcnc
(venv) ~/src $ cd src
(venv) ~/src $ ./autogen.sh
(venv) ~/src $ ./configure --enable-non-distributable=yes
(venv) ~/src $ make
There is no need to run "make suid", just make sure your user is in the "dialout" group. To start linuxcnc, you must be in the Python Virtual Environment, and set up the linuxcnc environment:
~ $ . ~/src/venv/bin/activate
(venv) ~ $ . ~/src/linuxcnc/scripts/rip-environment
(venv) ~ $ ~/src/linuxcnc $ scripts/linuxcnc
7. Options for checking out the git repo
The Quick Start instructions at the top of this document clone our git repo at https://github.com/LinuxCNC/linuxcnc.git. This is the quickest, easiest way to get started. However, there are other options to consider.
7.1. Fork us on Github
The LinuxCNC project git repo is at https://github.com/LinuxCNC/linuxcnc. github is a popular git hosting service and code sharing website. You can easily (and for no cost) create a fork of our git repo at github, and use that to track and publish your changes.
After creating your own github fork of LinuxCNC, clone it to your development machine and proceed with your hacking as usual.
We of the LinuxCNC project hope that you will share your changes with us, so that the community can benefit from your work. Github makes this sharing very easy: after you polish your changes and push them to your github fork, send us a Pull Request.
