1. Introduction
AXIS is a graphical front-end for LinuxCNC which features a live preview and backplot. It is written in Python and uses Tk and OpenGL to display its user interface.
images/axis-2.5.png
Figure 1. AXIS Window
2. Getting Started
If your configuration is not currently set up to use AXIS, you can change it by editing the .ini file. In the section [DISPLAY] change the DISPLAY line to read DISPLAY = axis.
The sample configuration sim/axis.ini is already configured to use AXIS as its front-end.
2.1. A Typical Session
  1. Start LinuxCNC.
  2. Reset E-STOP (F1) and turn the Machine Power (F2) on.
  3. Home all axes.
  4. Load the g-code file.
  5. Use the preview plot to verify that the program is correct.
  6. Load the material.
  7. Set the proper offset for each axis by jogging and using the Touch Off button as needed.
  8. Run the program.
Note
To run the same program again depends on your setup and requirements. You might need to load more material and set offsets or move over and set an offset then run the program again. If your material is fixtured then you might need to only run the program again. See the Machine Menu for more information on the run command.
3. AXIS Display
The AXIS window contains the following elements:
  • A display area that shows one of the following:
    • a preview of the loaded file (in this case, axis.ngc), as well as the current location of the CNC machine’s controlled point. Later, this area will display the path the CNC machine has moved through, called the backplot
    • a large readout showing the current position and all offsets.
  • A menu bar and toolbar that allow you to perform various actions
  • Manual Control Tab - which allows you to make the machine move, turn the spindle on or off, and turn the coolant on or off if included in the ini file.
  • MDI Tab - where G-code programs can be entered manually, one line at a time. This also shows the Active G Codes which shows which modal G Codes are in effect.
  • Feed Override - which allows you to scale the speed of programmed motions. The default maximum is 120% and can be set to a different value in the ini file. See the Integrator Manual for more information on this setting.
  • Spindle Override - which allows you to scale the spindle speed up or down.
  • Jog Speed - which allows you to set the jog speed within the limits set in the ini file. See the Integrator Manual for more information on the ini file.
  • Max Velocity - which allows you to restrict the maximum velocity of all programmed motions (except spindle synchronized motion).
  • A text display area that shows the loaded G-Code.
  • A status bar which shows the state of the machine. In this screen shot, the machine is turned on, does not have a tool inserted, and the displayed position is Relative (showing all offsets), and Actual (showing feedback position).
3.1. Menu Items
Some menu items might be grayed out depending on how you have your .ini file configured. For more information on configuration see the Integrator Manual.
File Menu
  • Open… - Opens a standard dialog box to open a g code file to load in AXIS. If you have configured LinuxCNC to use a filter program you can also open it up. See the Integrator manual for more information on filter programs.
  • Recent Files - Displays a list of recently opened files.
  • Edit… - Open the current g code file for editing if you have an editor configured in your ini file. See the Integrator Manual for more information on specifying an editor to use.
  • Reload - Reload the current g code file. If you edited it you must reload it for the changes to take affect. If you stop a file and want to start from the beginning then reload the file. The toolbar reload is the same as the menu.
  • Save gcode as… - Save the current file with a new name.
  • Properties - The sum of the rapid and feed moves. Does not factor in acceleration, blending or path mode so time reported will never be less than the actual run time.
  • Edit tool table… - Same as Edit if you have defined an editor you can open the tool table and edit it.
  • Reload tool table - After editing the tool table you must reload it.
  • Ladder editor - If you have loaded Classic Ladder you can edit it from here. See the Integrator Manual on setting up Classic Ladder
  • Quit - Terminates the current LinuxCNC session.
Machine Menu
  • Toggle Emergency Stop F1 - Change the state of the Emergency Stop.
  • Toggle Machine Power F2 - Change the state of the Machine Power if the Emergency Stop is not on.
  • Run Program - Run the currently loaded program from the beginning.
  • Run From Selected Line - Select the line you want to start from first. Use with caution as this will move the tool to the expected position before the line first then it will execute the rest of the code.
Warning
Do not use Run From Selected Line if your g code program contains subroutines.
  • Step - Single step through a program.
  • Pause - Pause a program.
  • Resume - Resume running from a pause.
  • Stop - Stop a running program. When run is selected after a stop the program will start from the beginning.
  • Stop at M1 - If an M1 is reached, and this is checked, program execution will stop on the M1 line. Press Resume to continue.
  • Skip lines with "/" - If a line begins with / and this is checked, the line will be skipped.
  • Clear MDI history - Clears the MDI history window.
  • Copy from MDI history - Copies the MDI history to the clipboard
  • Paste to MDI history - Paste from the clipboard to the MDI history window
  • Calibration - Starts a PID tuning assistant, which is mainly for servo systems. Some things can be changed on a stepper system.
  • Show HAL Configuration - Opens the HAL Configuration window where you can monitor HAL Components, Pins, Parameters, Signals, Functions, and Threads.
  • HAL Meter - Opens a window where you can monitor a single HAL Pin, Signal, or Parameter.
  • HAL Scope - Opens a virtual oscilloscope that allows plotting HAL values vs. time.
  • Show LinuxCNC Status - Opens a window showing LinuxCNC’s status.
  • Set Debug Level - Opens a window where debug levels can be viewed and some can be set.
  • Homing - Home one or all axes.
  • Unhoming - Unhome one or all axes.
  • Zero Coordinate System - Clear (set to zero) a chosen offset.
  • Tool touch off to workpiece - When performing Touch Off, the value entered is relative to the current workpiece (G5x) coordinate system, as modified by the axis offset (G92). When the Touch Off is complete, the Relative coordinate for the chosen axis will become the value entered. (See also G10 L10)
  • Tool touch off to fixture - When performing Touch Off, the value entered is relative to the ninth (G59.3) coordinate system, with the axis offset (G92) ignored. This is useful when there is a tool touch-off fixture at a fixed location on the machine, with the ninth (G59.3) coordinate system set such that the tip of a zero-length tool is at the fixture’s origin when the Relative coordinates are 0. See also G10 L11.
It’s all in your point of view
The AXIS display pick menu View refers to Top, Front, and Side views. These terms are correct if the CNC machine has its Z axis vertical, with positive Z up. This is true for vertical mills, which is probably the most popular application, and also true for almost all EDM machines, and even vertical turret lathes, where the part is turning below the tool.
The terms Top, Front, and Side might be confusing however, in other CNC machines, such as a standard lathe, where the Z axis is horizontal, or a horizontal mill, again where the Z axis is horizontal, or even an inverted vertical turret lathe, where the part is turning above the tool, and the Z axis positive direction is down!
Just remember that positive Z axis is (almost) always away from the part. So be familiar with your machine’s design and interpret the display as needed.
  • Top View - The Top View (or Z view) displays the gcode looking along the Z axis from positive to negative. This view is best for looking at X & Y.
  • Rotated Top View - The Rotated Top View (or rotated Z view) also displays the gcode looking along the Z axis from positive to negative. But sometimes it’s convenient to display the X & Y axes rotated 90 degrees to fit the display better. This view is also best for looking at X & Y.
  • Side View - The Side View (or X view) displays the gcode looking along the X axis from positive to negative. This view is best for looking at Y & Z.
  • Front View - The Front View (or Y view) displays the gcode looking along the Y axis from negative to positive. This view is best for looking at X & Z.
  • Perspective View - The Perpective View (or P view) displays the gcode looking at the part from an adjustable point of view, defaulting to X+, Y-, Z+. The position is adjustable using the mouse and the drag/rotate selector. This view is a compromise view, and while it does do a good job of trying to show three (to nine!) axes on a two-dimensional display, there will often be some feature that is hard to see, requiring a change in viewpoint. This view is best when you would like to see all three (to nine) axes at once.
  • Display Inches - Set the AXIS display scaling for inches.
  • Display MM - Set the AXIS display scaling for millimeters.
  • Show Program - The preview display of the loaded gcode program can be entirely disabled if desired.
  • Show Program Rapids - The preview display of the loaded gcode program will always show the feedrate moves (G1,G2,G3) in white. But the display of rapid moves (G0) in cyan can be disabled if desired.
  • Alpha-blend Program - This option makes the preview of complex programs easier to see, but may cause the preview to display more slowly.
  • Show Live Plot - The highlighting of the feedrate paths (G1,G2,G3) as the tool moves can be disabled if desired.
  • Show Tool - The display of the tool cone/cylinder can be disabled if desired.
  • Show Extents - The display of the extents (maximum travel in each axis direction) of the loaded gcode program can be disabled if desired.
  • Show Offsets - The selected fixture offset (G54-G59.3) origin location can be shown as a set of three orthogonal lines, one each of red, blue, and green. This offset origin (or fixture zero) display can be disabled if desired.
  • Show Machine Limits - The machine’s maximum travel limits for each axis, as set in the ini file, are shown as a rectangular box drawn in red dashed lines. This is useful when loading a new gcode program, or when checking for how much fixture offset would be needed to bring the gcode program within the travel limits of your machine. It can be shut off if not needed.
  • Show Velocity - A display of velocity is sometimes useful to see how close your machine is running to its design velocities. It can be disabled if desired.
  • Show Distance to Go - Distance to go is a very handy item to know when running an unknown gcode program for the first time. In combination with the rapid override and feedrate override controls, unwanted tool and machine damage can be avoided. Once the gcode program has been debugged and is running smoothly, the Distance to Go display can be disabled if desired.
  • Clear Live Plot - As the tool travels in the Axis display, the gcode path is highlighted. To repeat the program, or to better see an area of interest, the previously highlighted paths can be cleared.
  • Show Commanded Position - This is the position that LinuxCNC will try to go to. Once motion has stopped, this is the position LinuxCNC will try to hold.
  • Show Actual Position - Actual Position is the measured position as read back from the system’s encoders or simulated by step generators. This may differ slightly from the Commanded Position for many reasons including PID tuning, physical constraints, or position quantization.
  • Show Machine Position - This is the position in unoffset coordinates, as established by Homing.
  • Show Relative Position - This is the Machine Position modified by G5x, G92, and G43 offsets.
Help Menu
  • About Axis - We all know what this is.
  • Quick Reference - Shows the keyboard shortcut keys.
3.2. Toolbar buttons
From left to right in the Axis display, the toolbar buttons (keyboard shortcuts shown [in brackets]) are:
  • images/tool_estop.gif Toggle Emergency Stop [F1] (also called E-Stop)
  • images/tool_power.gif Toggle Machine Power [F2]
  • images/tool_open.gif Open G Code file [O]
  • images/tool_reload.gif Reload current file [Ctrl-R]
  • images/tool_run.gif Begin executing the current file [R]
  • images/tool_step.gif Execute next line [T]
  • images/tool_pause.gif Pause Execution [P] Resume Execution[S]
  • images/tool_stop.gif Stop Program Execution [ESC]
  • images/tool_blockdelete.gif Toggle Skip lines with "/" [Alt-M-/]
  • images/tool_optpause.gif Toggle Optional Pause [Alt-M-1]
  • images/tool_zoomin.gif Zoom In
  • images/tool_zoomout.gif Zoom Out
  • images/tool_axis_z.gif Top view
  • images/tool_axis_z2.gif Rotated Top view
  • images/tool_axis_x.gif Side view
  • images/tool_axis_y.gif Front view
  • images/tool_axis_p.gif Perspective view
  • images/tool_rotate.gif Toggle between Drag and Rotate Mode [D]
  • images/tool_clear.gif Clear live backplot [Ctrl-K]
3.3. Graphical Display Area
Coordinate Display
In the upper-left corner of the program display is the coordinate display. It shows the position of the machine. To the left of the axis name, an origin symbol is shown if the axis has been homed.
images/axis-homed.png
A limit symbol is shown if the axis is on one of its limit switches.
images/axis-limit.png
To properly interpret these numbers, refer to the Position: indicator in the status bar. If the position is Absolute, then the displayed number is in the machine coordinate system. If it is Relative, then the displayed number is in the offset coordinate system. When the coordinates displayed are relative and an offset has been set, the display will include a cyan machine origin marker.
images/axis-machineorigin.png
If the position is Commanded, then it is the ideal position --for instance, the exact coordinate given in a G0 command. If it is Actual, then it is the position the machine has actually moved to. These values can differ for several reasons: Following error, dead band, encoder resolution, or step size. For instance, if you command a movement to X 0.0033 on your mill, but one step of your stepper motor or one encoder count is 0.00125, then the Commanded position might be 0.0033, but the Actual position will be 0.0025 (2 steps) or 0.00375 (3 steps).
Preview Plot
When a file is loaded, a preview of it is shown in the display area. Fast moves (such as those produced by the G0 command) are shown as cyan lines. Moves at a feed rate (such as those produced by the G1 command) are shown as solid white lines. Dwells (such as those produced by the G4 command) are shown as small pink X marks.
G0 (Rapid) moves prior to a feed move will not show on the preview plot. Rapid moves after a T<n> (Tool Change) will not show on the preview until after the first feed move. To turn either of these features off program a G1 without any moves prior to the G0 moves.
Program Extents
The extents of the program in each axis are shown. At the ends, the least and greatest coordinate values are indicated. In the middle, the difference between the coordinates is shown.
When some coordinates exceed the soft limits in the .ini file, the relevant dimension is shown in a different color and enclosed by a box. In figure below the maximum soft limit is exceeded on the X axis as indicated by the box surrounding the coordinate value. The minimum X travel of the program is -1.95, the maximum X travel is 1.88, and the program requires 3.83 inches of X travel. To move the program so it’s within the machine’s travel in this case, jog to the left and Touch Off X again.
images/axis-outofrange.png
Figure 2. Soft Limit
Tool Cone
When no tool is loaded, the location of the tip of the tool is indicated by the tool cone. The tool cone does not provide guidance on the form, length, or radius of the tool.
When a tool is loaded (for instance, with the MDI command T1 M6 ), the cone changes to a cylinder which shows the diameter of the tool given in the tool table file.
Backplot
When the machine moves, it leaves a trail called the backplot. The color of the line indicates the type of motion: Yellow for jogs, faint green for rapid movements, red for straight moves at a feed rate, and magenta for circular moves at a feed rate.
Interacting
By left-clicking on a portion of the preview plot, the line will be highlighted in both the graphical and text displays. By left-clicking on an empty area, the highlighting will be removed.
By dragging with the left mouse button pressed, the preview plot will be shifted (panned).
By dragging with shift and the left mouse button pressed, or by dragging with the mouse wheel pressed, the preview plot will be rotated. When a line is highlighted, the center of rotation is the center of the line. Otherwise, the center of rotation is the center of the entire program.
By rotating the mouse wheel, or by dragging with the right mouse button pressed, or by dragging with control and the left mouse button pressed, the preview plot will be zoomed in or out.
By clicking one of the Preset View icons, or by pressing V, several preset views may be selected.
3.4. Text Display Area
By left-clicking a line of the program, the line will be highlighted in both the graphical and text displays.
When the program is running, the line currently being executed is highlighted in red. If no line has been selected by the user, the text display will automatically scroll to show the current line.
images/axis-currentandselected.png
Figure 3. Current and Selected Lines
3.5. Manual Control
While the machine is turned on but not running a program, the items in the Manual Control tab can be used to move the machine or control its spindle and coolant.
When the machine is not turned on, or when a program is running, the manual controls are unavailable.
Many of the items described below are not useful on all machines. When AXIS detects that a particular pin is not connected in HAL, the corresponding item in the Manual Control tab is removed. For instance, if the HAL pin motion.spindle-brake is not connected, then the Brake button will not appear on the screen. If the environment variable AXIS_NO_AUTOCONFIGURE is set, this behavior is disabled and all the items will appear.
The Axis group
Axis allows you to manually move the machine. This action is known as jogging. First, select the axis to be moved by clicking it. Then, click and hold the + or - button depending on the desired direction of motion. The first four axes can also be moved by the arrow keys (X and Y), PAGE UP and PAGE DOWN keys (Z), and the [ and ] keys (A).
If Continuous is selected, the motion will continue as long as the button or key is pressed. If another value is selected, the machine will move exactly the displayed distance each time the button is clicked or the key is pressed. By default, the available values are 0.1000, 0.0100, 0.0010, 0.0001
See the Configure section of the Integrator Manual for more information on setting the increments.
Homing
If your machine has home switches and a homing sequence defined for all axes the button will read Home All. The Home All button or the Ctrl-HOME key will home all axes using the homing sequence. Pressing the HOME key will home the current axis, even if a homing sequence is defined.
If your machine has home switches and no homing sequence is defined or not all axes have a homing sequence the button will read Home and will home the selected axis only. Each axis must be selected and homed separately.
If your machine does not have home switches defined in the configuration the Home button will set the current selected axis current position to be the absolute position 0 for that axis and will set the is-homed bit for that axis.
See the Integrator Manual for more information on homing.
Touch Off
By pressing Touch Off or the END key, the G54 offset for the current axis is changed so that the current axis value will be the specified value. Expressions may be entered using the rules for rs274ngc programs, except that variables may not be referred to. The resulting value is shown as a number.
images/touchoff.png
Figure 4. Touch Off
See also the Tool touch off to workpiece and Tool touch off to fixture options in the Machine menu.
Override Limits
By pressing Override Limits, the machine will temporarily be allowed to jog off of a physical limit switch. This check box is only available when a limit switch is tripped. The override is reset after one jog. If the axis is configured with separate positive and negative limit switches, LinuxCNC will allow the jog only in the correct direction. Override Limits will not allow a jog past a soft limit. The only way to disable a soft limit on an axis is to Unhome it.
The Spindle group
The buttons on the first row select the direction for the spindle to rotate: Counterclockwise, Stopped, Clockwise. Counterclockwise will only show up if the pin motion.spindle-reverse is in the HAL file (it can be net trick-axis motion.spindle-reverse ). The buttons on the next row increase or decrease the rotation speed. The checkbox on the third row allows the spindle brake to be engaged or released. Depending on your machine configuration, not all the items in this group may appear. Pressing the spindle start button sets the S speed to 1.
The Coolant group
The two buttons allow the Mist and Flood coolants to be turned on and off. Depending on your machine configuration, not all the items in this group may appear.
3.6. MDI
MDI allows G-code commands to be entered manually. When the machine is not turned on, or when a program is running, the MDI controls are unavailable.
images/axis-mdi.png
Figure 5. The MDI tab
  • History - This shows MDI commands that have been typed earlier in this session.
  • MDI Command - This allows you to enter a g-code command to be executed. Execute the command by pressing Enter or by clicking Go.
  • Active G-Codes - This shows the modal codes that are active in the interpreter. For instance, G54 indicates that the G54 offset is applied to all coordinates that are entered. When in Auto the Active G-Codes represent the codes after any read ahead by the interpreter.
3.7. Feed Override
By moving this slider, the programmed feed rate can be modified. For instance, if a program requests F60 and the slider is set to 120%, then the resulting feed rate will be 72.
3.8. Spindle Speed Override
By moving this slider, the programmed spindle speed can be modified. For instance, if a program requests S8000 and the slider is set to 80%, then the resulting spindle speed will be 6400. This item only appears when the HAL pin motion.spindle-speed-out is connected.
3.9. Jog Speed
By moving this slider, the speed of jogs can be modified. For instance, if the slider is set to 1 in/min, then a .01 inch jog will complete in about .6 seconds, or 1/100 of a minute. Near the left side (slow jogs) the values are spaced closely together, while near the right side (fast jogs) they are spaced much further apart, allowing a wide range of jog speeds with fine control when it is most important.
On machines with a rotary axis, a second jog speed slider is shown. This slider sets the jog rate for the rotary axes (A, B and C).
3.10. Max Velocity
By moving this slider, the maximum velocity can be set. This caps the maximum velocity for all programmed moves except spindle-synchronized moves.
4. Keyboard Controls
Almost all actions in AXIS can be accomplished with the keyboard. A full list of keyboard shortcuts can be found in the AXIS Quick Reference, which can be displayed by choosing Help > Quick Reference. Many of the shortcuts are unavailable when in MDI mode.
Feed Override Keys
The Feed Override keys behave differently when in Manual Mode. The keys '12345678 will select an axis if it is programed. If you have 3 axis then ' will select axis 0, 1 will select axis 1, and 2 will select axis 2. The remainder of the number keys will still set the Feed Override. When running a program '1234567890 will set the Feed Override to 0% - 100%.
The most frequently used keyboard shortcuts are shown in the following Table
Table 1. Most Common Keyboard Shortcuts
Keystroke Action Taken Mode
F1
All
F2
Turn machine on/off
All
`, 1 .. 9, 0
Set feed override from 0% to 100%
Varies
X, `
Activate first axis
Manual
Y, 1
Activate second axis
Manual
Z, 2
Activate third axis
Manual
A, 3
Activate fourth axis
Manual
I
Select jog increment
Manual
C
Continuous jog
Manual
Control-Home
Perform homing sequence
Manual
End
Touch off: Set G54 offset for active axis
Manual
Left, Right
Jog first axis
Manual
Up, Down
Jog second axis
Manual
Pg Up, Pg Dn
Jog third axis
Manual
Jog fourth axis
Manual
O
Open File
Manual
Control-R
Reload File
Manual
R
Run file
Manual
P
Pause execution
Auto
S
Resume Execution
Auto
ESC
Stop execution
Auto
Control-K
Clear backplot
Auto/Manual
V
Cycle among preset views
Auto/Manual
Shift-Left,Right
Rapid X Axis
Manual
Shift-Up,Down
Rapid Y Axis
Manual
Shift-PgUp, PgDn
Rapid Z Axis
Manual
5. Show LinuxCNC Status (linuxcnctop)
AXIS includes a program called linuxcnctop which shows some of the details of LinuxCNC’s state. You can run this program by invoking Machine > Show LinuxCNC Status
images/axis-emc-status.png
Figure 6. LinuxCNC Status Window
The name of each item is shown in the left column. The current value is shown in the right column. If the value has recently changed, it is shown on a red background.
6. MDI interface
AXIS includes a program called MDI which allows text-mode entry of MDI commands to a running LinuxCNC session. You can run this program by opening a terminal and typing
mdi /path/to/emc.nml
Once it is running, it displays the prompt MDI>. When a blank line is entered, the machine’s current position is shown. When a command is entered, it is sent to LinuxCNC to be executed.
This is a sample session of mdi.
$ MDI ~/emc2/configs/sim/emc.nml
MDI>
(0.0, 0.0, 0.0, 0.0, 0.0, 0.0)
MDI> G1 F5 X1
MDI>
(0.5928500000000374, 0.0, 0.0, 0.0, 0.0, 0.0)
MDI>
(1.0000000000000639, 0.0, 0.0, 0.0, 0.0, 0.0)
7. axis-remote
AXIS includes a program called axis-remote which can send certain commands to a running AXIS. The available commands are shown by running axis-remote --help and include checking whether AXIS is running (--ping), loading a file by name, reloading the currently loaded file (--reload), and making AXIS exit (--quit).
8. Manual Tool Change
LinuxCNC includes a userspace HAL component called hal_manualtoolchange, which shows a window prompt telling you what tool is expected when a M6 command is issued. After the OK button is pressed, execution of the program will continue.
The HAL configuration file configs/sim/axis_manualtoolchange.hal shows the HAL commands necessary to use this component.
hal_manualtoolchange can be used even when AXIS is not used as the GUI. This component is most useful if you have presettable tools and you use the tool table.
Note
Important Note: Rapids will not show on the preview after a T<n> is issued until the next feed move after the M6. This can be very confusing to most users. To turn this feature off for the current tool change program a G1 with no move after the T<n>.
images/manual-tool-change.png
Figure 7. The Manual Toolchange Window
9. Python modules
AXIS includes several Python modules which may be useful to others. For more information on one of these modules, use pydoc <module name> or read the source code. These modules include:
  • emc provides access to the LinuxCNC command, status, and error channels
  • gcode provides access to the rs274ngc interpreter
  • rs274 provides additional tools for working with rs274ngc files
  • hal allows the creation of userspace HAL components written in Python
  • _togl provides an OpenGL widget that can be used in Tkinter applications
  • minigl provides access to the subset of OpenGL used by AXIS
To use these modules in your own scripts, you must ensure that the directory where they reside is on Python’s module path. When running an installed version of LinuxCNC, this should happen automatically. When running in-place, this can be done by using scripts/rip-environment.
10. Using AXIS in Lathe Mode
By including the line LATHE = 1 in the [DISPLAY] section of the ini file, AXIS selects lathe mode. The Y axis is not shown in coordinate readouts, the view is changed to show the Z axis extending to the right and the X axis extending towards the bottom of the screen, and several controls (such as those for preset views) are removed. The coordinate readouts for X are replaced with diameter and radius.
Pressing V zooms out to show the entire file, if one is loaded.
When in lathe mode, the shape of the loaded tool (if any) is shown.
Lathe Tool Shape
images/axis-lathe-tool.png
11. Advanced Configuration
For more information on ini file settings that can change how AXIS works see the INI File/Sections/[DISPLAY] Section of Configuration chapter in the Integrator manual.
11.1. Program Filters
AXIS has the ability to send loaded files through a filter program. This filter can do any desired task: Something as simple as making sure the file ends with M2, or something as complicated as generating G-Code from an image.
The [FILTER] section of the ini file controls how filters work. First, for each type of file, write a PROGRAM_EXTENSION line. Then, specify the program to execute for each type of file. This program is given the name of the input file as its first argument, and must write rs274ngc code to standard output. This output is what will be displayed in the text area, previewed in the display area, and executed by LinuxCNC when Run. The following lines add support for the image-to-gcode converter included with LinuxCNC:
[FILTER]
PROGRAM_EXTENSION = .png,.gif Greyscale Depth Image
png = image-to-gcode
gif = image-to-gcode
It is also possible to specify an interpreter:
py = python
In this way, any Python script can be opened, and its output is treated as g-code. One such example script is available at nc_files/holecircle.py. This script creates g-code for drilling a series of holes along the circumference of a circle.
images/holes.png
Figure 8. Circular Holes
If the environment variable AXIS_PROGRESS_BAR is set, then lines written to stderr of the form
FILTER_PROGRESS=%d
will set the AXIS progress bar to the given percentage. This feature should be used by any filter that runs for a long time.
11.2. The X Resource Database
The colors of most elements of the AXIS user interface can be customized through the X Resource Database. The sample file axis_light_background changes the colors of the backplot window to a dark lines on white background scheme, and also serves as a reference for the configurable items in the display area. The sample file axis_big_dro changes the position readout to a larger size font. To use these files:
xrdb -merge /usr/share/doc/emc2/axis_light_background
xrdb -merge /usr/share/doc/emc2/axis_big_dro
For information about the other items which can be configured in Tk applications, see the Tk man pages.
Because modern desktop environments automatically make some settings in the X Resource Database that adversely affect AXIS, by default these settings are ignored. To make the X Resource Database items override AXIS defaults, include the following line in your X Resources:
    *Axis*optionLevel: widgetDefault
this causes the built-in options to be created at the option level widgetDefault, so that X Resources (which are level userDefault) can override them.
11.3. Physical jog wheels
To improve the interaction of AXIS with physical jog wheels, the axis currently selected in the GUI is also reported on a pin with a name like axisui.jog.x. One of these pins is TRUE at one time, and the rest are FALSE. These are meant to control motion’s jog-enable pins.
After AXIS has created these HAL pins, it executes the HAL file named in [HAL]POSTGUI_HALFILE. Unlike [HAL]HALFILE, only one such file may be used.
11.4. ~./axisrc
If it exists, the contents of ~/.axisrc are executed as Python source code just before the AXIS GUI is displayed. The details of what may be written in the axisrc are subject to change during the development cycle.
The following adds Control-Q as a keyboard shortcut for Quit.
root_window.bind("<Control-q>", "destroy .")
help2.append(("Control-Q", "Quit"))
11.5. External Editor
The menu options File > Edit… and File > Edit Tool Table… become available after defining the editor in the ini section [DISPLAY]. Useful values include EDITOR=gedit and EDITOR=gnome-terminal -e vim. For more information, see the DISPLAY section of the INI Configuration Chapter in the Integrator Manual.
11.6. Virtual Control Panel
AXIS can display a custom virtual control panel in the right-hand pane. You can program buttons, indicators, data displays and more. For more information, see the Integrator Manual.
11.7. Axis Preview Control
Special comments can be inserted into the G Code file to control how the preview of AXIS behaves. In the case where you want to limit the drawing of the preview use these special comments. Anything between the (AXIS,hide) and (AXIS,show) will not be drawn during the preview. The (AXIS,hide) and (AXIS,show) must be used in pairs with the (AXIS,hide) being first. Anything after a (AXIS,stop) will not be drawn during the preview.
These comments are useful to unclutter the preview display (for instance while debugging a larger g-code file, one can disable the preview on certain parts that are already working OK).
  • (AXIS,hide) Stops the preview (must be first)
  • (AXIS,show) Resumes the preview (must follow a hide)
  • (AXIS,stop) Stops the preview from here to the end of the file.
  • (AXIS,notify,the_text) Displays the_text as an info display This display can be useful in the Axis preview when (debug,message) comments are not displayed.
