This documentation describes the linuxcnc python module, which provides a Python API for talking to LinuxCNC.
1. 简介
User interfaces control LinuxCNC activity by sending NML messages to the LinuxCNC task controller, and monitor results by observing the LinuxCNC status structure, as well as the error reporting channel.
Programmatic access to NML is through a C++ API; however, the most important parts of the NML interface to LinuxCNC are also available to Python programs through the linuxcnc module.
Beyond the NML interface to the command, status and error channels, the linuxcnc module also contains:
support for reading values from INI files
2. Usage Patterns for the LinuxCNC NML interface
The general pattern for linuxcnc usage is roughly like this:
Import the
linuxcncmodule. -
Establish connections to the command, status and error NML channels as needed.
Poll the status channel, either periodically or as needed.
Before sending a command, determine from status whether it is in fact OK to do so (for instance, there is no point in sending a Run command if task is in the ESTOP state, or the interpreter is not idle).
Send the command by using one of the
linuxcnccommand channel methods.
To retrieve messages from the error channel, poll the error channel periodically, and process any messages retrieved.
Print any error message and explore the exception code.
The module linuxcnc also defines the error Python exception type to support error reporting.
3. Reading LinuxCNC status with the linuxcnc Python module
Here is a Python fragment to explore the contents of the linuxcnc.stat object which contains some 80+ values (run while LinuxCNC is running for typical values):
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
import sys
import linuxcnc
try:
s = linuxcnc.stat() # create a connection to the status channel
s.poll() # get current values
except linuxcnc.error, detail:
print("error", detail)
sys.exit(1)
for x in dir(s):
if not x.startswith("_"):
print(x, getattr(s,x))
The linuxcnc module uses the default compiled-in path to the NML configuration file unless overridden, see ReadingINI file values for an example.
3.1. linuxcnc.stat attributes
- acceleration
(returns float) - default acceleration, reflects the INI entry [TRAJ]DEFAULT_ACCELERATION.
- active_queue
(returns integer) - number of motions blending.
- actual_position
(returns tuple of floats) - current trajectory position, (x y z a b c u v w) in machine units.
- adaptive_feed_enabled
(returns boolean) - status of adaptive feedrate override (0/1).
- ain
(returns tuple of floats) - current value of the analog input pins.
- angular_units
(returns float) - machine angular units per deg, reflects [TRAJ]ANGULAR_UNITS INI value.
- aout
(returns tuple of floats) - current value of the analog output pins.
- axes (Removed since version 2.9)
instead, use
axis_mask.bit_count()to get the number of axes configured. - axis
(returns tuple of dicts) - reflecting current axis values. See The axis dictionary.
- axis_mask
(returns integer) - mask of axis available as defined by
[TRAJ]COORDINATESin the INI file. Returns the sum of the axes X=1, Y=2, Z=4, A=8, B=16, C=32, U=64, V=128, W=256. - block_delete
(returns boolean) - block delete current status.
- call_level
(returns integer)` - current subroutine depth. - 0 if not in a subroutine, depth if not otherwise specified.
- command
(returns string) - currently executing command.
- current_line
(returns integer) - currently executing line.
- current_vel
(returns float) - current velocity in user units per second.
- cycle_time
(returns float) - thread period
- debug
(returns integer) - debug flag from the INI file.
- delay_left
(returns float) - remaining time on dwell (G4) command, seconds.
- din
(returns tuple of integers) - current value of the digital input pins.
- distance_to_go
(returns float) - remaining distance of current move, as reported by trajectory planner.
- dout
(returns tuple of integers) - current value of the digital output pins.
- dtg
(returns tuple of floats) - remaining distance of current move for each axis, as reported by trajectory planner.
- echo_serial_number
(returns integer) - The serial number of the last completed command sent by a UI to task. All commands carry a serial number. Once the command has been executed, its serial number is reflected in
echo_serial_number. - enabled
(returns boolean) - trajectory planner enabled flag.
- estop
(returns integer) - Returns either STATE_ESTOP or not.
- exec_state
(returns integer) - task execution state. One of EXEC_ERROR, EXEC_DONE, EXEC_WAITING_FOR_MOTION, EXEC_WAITING_FOR_MOTION_QUEUE, EXEC_WAITING_FOR_IO, EXEC_WAITING_FOR_MOTION_AND_IO, EXEC_WAITING_FOR_DELAY, EXEC_WAITING_FOR_SYSTEM_CMD, EXEC_WAITING_FOR_SPINDLE_ORIENTED.
- feed_hold_enabled
(returns boolean) - enable flag for feed hold.
- feed_override_enabled
(returns boolean) - enable flag for feed override.
- feedrate
(returns float) - current feedrate override, 1.0 = 100%.
- file
(returns string) - currently loaded G-code filename with path.
- flood
(returns integer) - Flood status, either FLOOD_OFF or FLOOD_ON.
- g5x_index
(returns integer) - currently active coordinate system, G54=1, G55=2 etc.
- g5x_offset
(returns tuple of floats) - offset of the currently active coordinate system.
- g68_active
(returns integer) - a tilted work plane (G68.2) is in effect.
- g68_offset
(returns tuple of floats) - origin of the tilted work plane, in the coordinate system it was defined in.
- g68_rotation
(returns tuple of floats) - rotation of the tilted work plane, nine values row by row; its columns are the plane’s X, Y and Z.
- g92_offset
(returns tuple of floats) - pose of the current g92 offset.
- gcodes
(returns tuple of integers) - Active G-codes for each modal group.
The integer values reflect the nominal G-code numbers multiplied by 10. (Examples: 10 = G1, 430 = G43, 923 = G92.3) - heartbeat
(returns integer) - motion controller heartbeat counter. Increments every servo cycle. Rate is determined by
[EMCMOT]SERVO_PERIODin the INI file. - homed
(returns tuple of integers) - currently homed joints, with 0 = not homed, 1 = homed.
- id
(returns integer) - currently executing motion ID.
- ini_filename
(returns string) - path to the INI file passed to linuxcnc.
- inpos
(returns boolean) - machine-in-position flag.
- input_timeout
(returns boolean) - flag for M66 timer in progress.
- interp_state
(returns integer) - current state of RS274NGC interpreter. One of INTERP_IDLE, INTERP_READING, INTERP_PAUSED, INTERP_WAITING.
- interpreter_errcode
(returns integer) - current RS274NGC interpreter return code. One of INTERP_OK, INTERP_EXIT, INTERP_EXECUTE_FINISH, INTERP_ENDFILE, INTERP_FILE_NOT_OPEN, INTERP_ERROR. see src/emc/nml_intf/interp_return.hh
- joint
(returns tuple of dicts) - reflecting current joint values. See The joint dictionary.
- joint_actual_position
(returns tuple of floats) - actual joint positions.
- joint_position
(returns tuple of floats) - Desired joint positions.
- joints
(returns integer) - number of joints. Reflects [KINS]JOINTS INI value.
- kinematics_type
(returns integer) - The type of kinematics. One of:
KINEMATICS_IDENTITY
KINEMATICS_FORWARD_ONLY
KINEMATICS_INVERSE_ONLY
KINEMATICS_BOTH
- limit
(returns tuple of integers) - axis limit masks. minHardLimit=1, maxHardLimit=2, minSoftLimit=4, maxSoftLimit=8.
- linear_units
(returns float) - machine linear units per mm, reflects [TRAJ]LINEAR_UNITS INI value.
- max_acceleration
(returns float) - maximum acceleration. Reflects [TRAJ]MAX_ACCELERATION.
- max_velocity
(returns float) - maximum velocity. Reflects the current maximum velocity. If not modified by halui.max-velocity or similar it should reflect [TRAJ]MAX_VELOCITY.
- mcodes
(returns tuple of 10 integers) - currently active M-codes.
- mist
(returns integer) - Mist status, either MIST_OFF or MIST_ON
- motion_line
(returns integer) - source line number motion is currently executing. Relation to
idunclear. - motion_mode
(returns integer) - This is the mode of the Motion controller. One of TRAJ_MODE_COORD, TRAJ_MODE_FREE, TRAJ_MODE_TELEOP.
- motion_type
(returns integer) - The type of the currently executing motion. One of:
MOTION_TYPE_TRAVERSE
MOTION_TYPE_FEED
MOTION_TYPE_ARC
MOTION_TYPE_TOOLCHANGE
MOTION_TYPE_PROBING
MOTION_TYPE_INDEXROTARY
Or 0 if no motion is currently taking place.
- optional_stop
(returns integer) - option stop flag.
- paused
(returns boolean) -
motion pausedflag. - single_stepping
(returns boolean) -
motion single_steppingflag. - pocket_prepped
(returns integer) - A Tx command completed, and this pocket is prepared. -1 if no prepared pocket.
- poll()
-(built-in function) method to update current status attributes.
- position
(returns tuple of floats) - trajectory position.
- probe_tripped
(returns boolean) - flag, True if probe has tripped (latch).
- probe_val
(returns integer) - reflects value of the
motion.probe-inputpin. - probed_position
(returns tuple of floats) - position where probe tripped.
- probing
(returns boolean) - flag, True if a probe operation is in progress.
- program_units
(returns integer) - one of CANON_UNITS_INCHES=1, CANON_UNITS_MM=2, CANON_UNITS_CM=3. Follows the active G20/G21 reported in gcodes: the executing line while a program runs, the interpreter otherwise. CANON_UNITS_CM is never reported: G-code cannot select it and canterp maps it to mm.
- queue
(returns integer) - current size of the trajectory planner queue.
- queue_full
(returns boolean) - the trajectory planner queue is full.
- rapidrate
(returns float) - rapid override scale.
- read_line
(returns integer) - line the RS274NGC interpreter is currently reading.
- rotation_xy
(returns float) - current XY rotation angle around Z axis.
- settings
(returns tuple of floats) - current interpreter settings:
settings[0] = sequence number,
settings[1] = feed rate,
settings[2] = speed,
settings[3] =G64 Pblend tolerance,
settings[4] =G64 Qnaive CAM tolerance. - spindle
' (returns tuple of dicts) ' - returns the current spindle status, see The spindle dictionary.
- spindles
(returns integer) - number of spindles. Reflects
[TRAJ]SPINDLESINI value. - state
(returns integer) - current command execution status. One of
RCS_DONE,RCS_EXEC,RCS_ERROR. - task_mode
(returns integer) - current task mode. One of
MODE_MDI,MODE_AUTO,MODE_MANUAL. - task_paused
(returns integer) - task paused flag.
- task_state
(returns integer) - current task state. One of
STATE_ESTOP,STATE_ESTOP_RESET,STATE_ON,STATE_OFF. - tool_in_spindle
(returns integer) - current tool number.
- taskbeat
(returns integer) - task main loop heartbeat counter. Increments every task cycle. Rate is determined by
[TASK]CYCLE_TIMEin the INI file. - tool_from_pocket
(returns integer) - pocket number for the currently loaded tool (0 if no tool loaded).
- tool_offset
(returns tuple of floats) - offset values of the current tool.
- tool_table
(returns tuple of tool_results) - list of tool entries. Each entry is a sequence of the following fields: id, xoffset, yoffset, zoffset, aoffset, boffset, coffset, uoffset, voffset, woffset, diameter, frontangle, backangle, orientation. The id and orientation are integers and the rest are floats.
import linuxcnc
s = linuxcnc.stat()
s.poll()
# to find the loaded tool information it is in tool table index 0
if s.tool_table[0].id != 0: # a tool is loaded
print(s.tool_table[0].zoffset)
else:
print("No tool loaded.")
- toolinfo(toolno)
(returns dict of tooldata for toolno) - An initial stat.poll() is required to initialize. toolno must be greater than zero and less than or equal to the highest tool number in use. Dictionary items include all tooldata items: toolno, pocketno, diameter,frontangle,backangle,orientation, xoffset,yoffset, … woffset, comment.
As an example, the following script
import linuxcnc
s = linuxcnc.stat()
s.poll()
toolno = 1
print(s.toolinfo(toolno))
produces the output:
': 0, 'xoffset': 0.0, 'yoffset': 0.0, 'zoffset': 0.18, 'aoffset': 0.0, 'boffset': 0.0, 'coffset': 0.0, 'uoffset': 0.0, 'voffset': 0.0, 'woffset': 0.0, 'comment': 'Tool_18 28Jan23:18.53.25'}
- velocity
(returns float) - This property is defined, but it does not have a useful interpretation.
3.2. The axis dictionary
The axis configuration and status values are available through a list of per-axis dictionaries. Here’s an example how to access an attribute of a particular axis: Note that many properties that were formerly in the axis dictionary are now in the joint dictionary, because on nontrivial kinematics machines these items (such as backlash) are not the properties of an axis.
- max_position_limit
(returns float) - maximum limit (soft limit) for axis motion, in machine units.configuration parameter, reflects
[JOINT___n__]MAX_LIMIT. - min_position_limit
(returns float) - minimum limit (soft limit) for axis motion, in machine units.configuration parameter, reflects
[JOINT___n__]MIN_LIMIT. - velocity
(returns float) - current velocity.
3.3. The joint dictionary
import linuxcnc
s = linuxcnc.stat()
s.poll()
print("Joint 1 homed: ", s.joint[1]["homed"])
For each joint, the following dictionary keys are available:
- backlash
(returns float) - Backlash in machine units. configuration parameter, reflects
[JOINT___n__]BACKLASH. - enabled
(returns integer) - non-zero means enabled.
- fault
(returns integer) - non-zero means axis amp fault.
- ferror_current
(returns float) - current following error.
- ferror_highmark
(returns float) - magnitude of max following error.
- homed
(returns integer) - non-zero means has been homed.
- homing
(returns integer) - non-zero means homing in progress.
- inpos
(returns integer) - non-zero means in position.
- input
(returns float) - current input position.
- jointType
(returns integer) - type of axis configuration parameter, reflects
[JOINT___n__]TYPEwithLINEAR=1,ANGULAR=2. See Joint INI configuration for details. - max_ferror
(returns float) - maximum following error. configuration parameter, reflects
[JOINT___n__]FERROR. - max_hard_limit
(returns integer) - non-zero means max hard limit exceeded.
(returns float) - maximum limit (soft limit) for joint motion, in machine units. configuration parameter, reflects
[JOINT___n__]MAX_LIMIT. - max_soft_limit
non-zero means
max_position_limitwas exceeded, int - min_ferror
(returns float) - configuration parameter, reflects
[JOINT___n__]MIN_FERROR. - min_hard_limit
(returns integer) - non-zero means min hard limit exceeded.
(returns float) - minimum limit (soft limit) for joint motion, in machine units. configuration parameter, reflects
[JOINT___n__]MIN_LIMIT. - min_soft_limit
min_position_limitwas exceeded. - output
(returns float) - commanded output position.
- override_limits
(returns integer) - non-zero means limits are overridden.
- units
(returns float) - joint units per mm, or per degree for angular joints.
(joint units are the same as machine units, unless set otherwise by the configuration parameter[JOINT___n__]UNITS) - velocity
3.4. The spindle dictionary
- brake
(returns integer) - value of the spindle brake flag.
- direction
(returns integer) - rotational direction of the spindle with forward=1, reverse=-1.
- enabled
(returns integer) - value of the spindle enabled flag.
- homed
(not currently implemented)
- increasing
(returns integer) - unclear.
- orient_fault
(returns integer)
- orient_state
(returns integer)
- override
(returns float) - spindle speed override scale.
- override_enabled
(returns boolean) - value of the spindle override enabled flag.
- speed
(returns float) - spindle speed value, rpm, > 0: clockwise, < 0: counterclockwise.
With G96 active this reflects the maximum speed set by the optional G96 D-word or, if the D-word was missing, the default values +/-1e30.
4. Preparing to send commands
Some commands can always be sent, regardless of mode and state; for instance, the linuxcnc.command.abort() method can always be called.
Other commands may be sent only in appropriate state, and those tests can be a bit tricky. For instance, an MDI command can be sent only if:
ESTOP has not been triggered, and
the machine is turned on and
the axes are homed and
the interpreter is not running and
the mode is set to
MDI mode
An appropriate test before sending an MDI command through linuxcnc.command.mdi() could be:
import linuxcnc
s = linuxcnc.stat()
c = linuxcnc.command()
def ok_for_mdi():
s.poll()
return not s.estop and s.enabled and (s.homed.count(1) == s.joints) and (s.interp_state == linuxcnc.INTERP_IDLE)
if ok_for_mdi():
c.mode(linuxcnc.MODE_MDI)
c.wait_complete() # wait until mode switch executed (or default timeout of 5s occurs!)
c.mdi("G0 X10 Y20 Z30")
Warning
Read important information on wait_complete() in the ‘linuxcnc.command methods’ section below. |
5. Sending commands through linuxcnc.command
Before sending a command, initialize a command channel like so:
import linuxcnc
# Usage examples for some of the commands listed below:
c.abort()
c.auto(linuxcnc.AUTO_RUN, program_start_line)
c.auto(linuxcnc.AUTO_STEP)
c.auto(linuxcnc.AUTO_PAUSE)
c.auto(linuxcnc.AUTO_RESUME)
c.brake(linuxcnc.BRAKE_ENGAGE)
c.brake(linuxcnc.BRAKE_RELEASE)
c.flood(linuxcnc.FLOOD_ON)
c.flood(linuxcnc.FLOOD_OFF)
c.home(2)
c.jog(linuxcnc.JOG_STOP, jjogmode, joint_num_or_axis_index)
c.jog(linuxcnc.JOG_CONTINUOUS, jjogmode, joint_num_or_axis_index, velocity)
c.jog(linuxcnc.JOG_INCREMENT, jjogmode, joint_num_or_axis_index, velocity, increment)
c.load_tool_table()
c.maxvel(200.0)
c.mist(linuxcnc.MIST_ON)
c.mist(linuxcnc.MIST_OFF)
c.mode(linuxcnc.MODE_AUTO)
c.mode(linuxcnc.MODE_MANUAL)
c.override_limits()
c.program_open("foo.ngc")
c.reset_interpreter()
c.tool_offset(toolno, z_offset, x_offset, diameter, frontangle, backangle, orientation)
5.1. linuxcnc.command attributes
serial-
the current command serial number
5.2. linuxcnc.command methods:
abort()-
send EMC_TASK_ABORT message.
auto(int[, int])-
run, step, pause or resume a program.
brake(int)-
engage or release spindle brake.
debug(int)-
set debug level via EMC_SET_DEBUG message.
display_msg(string)-
sends a operator display message to the screen. (max 254 characters)
error_msg(string)-
sends a operator error message to the screen. (max 254 characters)
feedrate(float)-
set the feedrate override, 1.0 = 100%.
flood(int)-
turn on/off flooding.
- Syntax
flood(command)
flood(linuxcnc.FLOOD_OFF) - Constants
FLOOD_ON
FLOOD_OFF
home(int)-
home a given joint.
jog(command-constant, bool, int[, float[, float]])-
- Syntax
jog(command, jjogmode, joint_num_or_axis_index, velocity[, distance])
jog(linuxcnc.JOG_INCREMENT, jjogmode, joint_num_or_axis_index, velocity, distance) - Command Constants
linuxcnc.JOG_STOP
linuxcnc.JOG_INCREMENT - jjogmode
- True
request individual joint jog (requires teleop_enable(0))
- False
request axis Cartesian coordinate jog (requires teleop_enable(1))
- joint_num_or_axis_index
- For joint jog (jjogmode=1)
joint_number
- For axis Cartesian coordinate jog (jjogmode=0)
zero-based index of the axis coordinate with respect to the known coordinate letters XYZABCUVW (x⇒0,y⇒1,z⇒2,a⇒3,b⇒4,c⇒5,u⇒6,v⇒7,w⇒8)
load_tool_table()-
reload the tool table.
maxvel(float)-
set maximum velocity
mdi(string)-
send an MDI command. Maximum 254 chars.
mist(int)-
turn on/off mist.
- Syntax
mist(command)
mist(linuxcnc.MIST_OFF) - Constants
MIST_ON
MIST_OFF
mode(int)-
set mode (MODE_MDI, MODE_MANUAL, MODE_AUTO).
override_limits()-
set the override axis limits flag.
program_open(string)-
open an NGC file.
rapidrate()-
set rapid override factor
reset_interpreter()-
reset the RS274NGC interpreter
set_adaptive_feed(int)-
set adaptive feed flag
set_analog_output(int, float)-
set analog output pin to value
set_block_delete(int)-
set block delete flag
set_digital_output(int, int)-
set digital output pin to value
set_feed_hold(int)-
set feed hold on/off
set_feed_override(int)-
set feed override on/off
set_max_limit(int, float)-
set max position limit for a given axis
set_min_limit()-
set min position limit for a given axis
set_optional_stop(int)-
set optional stop on/off
set_spindle_override(int [, int])-
set spindle override enabled. Defaults to spindle 0.
spindle(direction: int, speed: float=0, spindle: int=0, wait_for_speed: int=0)-
Direction: [
SPINDLE_FORWARD,SPINDLE_REVERSE,SPINDLE_OFF,SPINDLE_INCREASE,SPINDLE_DECREASE, orSPINDLE_CONSTANT] -
Speed: Speed in RPM, defaults to 0.
Spindle: Spindle number to command defaults to 0.
Wait_for_speed: if 1 motion will wait for speed before continuing, defaults to not.
Warning
MDI commands will ignore this. "S1000" after this will turn the spindle off. |
text_msg(string)-
sends a operator text message to the screen (max 254 characters).
import linuxcnc
# Increase speed of spindle 0 by 100rpm. Spindle must be on first.
c.spindle(linuxcnc.INCREASE)
# Increase speed of spindle 2 by 100rpm. Spindle must be on first.
c.spindle(linuxcnc.SPINDLE_INCREASE, 2)
# Set speed of spindle 0 to 1024 rpm.
c.spindle.(linuxcnc.SPINDLE_FORWARD, 1024)
# Set speed of spindle 1 to -666 rpm.
c.spindle.(linuxcnc.SPINDLE_REVERSE, 666, 1)
# Stop spindle 0.
c.spindle.(linuxcnc.SPINDLE_OFF)
# Stop spindle 0 explicitly.
c.spindle.(linuxcnc.SPINDLE_OFF, 0)
spindleoverride(float [, int])-
Set spindle override factor. Defaults to spindle 0.
state(int)-
Set the machine state. Machine state should be
STATE_ESTOP,STATE_ESTOP_RESET,STATE_ON, orSTATE_OFF. task_plan_sync()-
On completion of this call, the VAR file on disk is updated with live values from the interpreter.
teleop_enable(int)-
Enable/disable teleop mode (disable for joint jogging).
tool_offset(int, float, float, float, float, float, int)-
Set the tool offset. See usage example above.
traj_mode(int)-
Set trajectory mode. Mode is one of
MODE_FREE,MODE_COORD, orMODE_TELEOP. unhome(int)-
Unhome a given joint.
wait_complete([float])-
Wait for completion of the last command. Takes an optional timeout value in seconds.
Timeout defaults to 5 seconds if omitted.
Returns -1 if timed out.
ReturnsRCS_DONEorRCS_ERRORaccording to command execution status.
Note that python execution will be blocked until this function returns.
6. Reading the error channel
To handle error messages, connect to the error channel and periodically poll() it.
Note that the NML channel for error messages has a queue (other than the command and status channels), which means that the first consumer of an error message deletes that message from the queue; whether your another error message consumer (e.g. AXIS) will see the message is dependent on timing. It is recommended to have just one error channel reader task in a setup.
import linuxcnc
e = linuxcnc.error_channel()
error = e.poll()
if error:
kind, text = error
if kind in (linuxcnc.NML_ERROR, linuxcnc.OPERATOR_ERROR):
typus = "error"
else:
typus = "info"
print(typus, text)
7. Reading INI file values using linuxcnc.ini
The linuxcnc.ini module includes all functions to read values and information from INI-files.
Reading an INI-file is done by creating an instance of the module class:
import linuxcnc
try:
ini = linuxcnc.ini("/path/to/ini-file.ini")
except linuxcnc.error:
print("Ini-file not found or invalid")
The ini instance can then be used to extract values and other information from the INI-file.
Important
You should not roll your own type conversion functions to read boolean, integer or floating point values. The INI-file parser and Python wrapper already include these functions. Using the built-in functions guarantees consistent interpretation of values, also across locales. There are also helpers for enumerated types to read and convert them correctly and consistently. |
7.1. linuxcnc.ini Methods
All methods will throw an error on the following conditions:
TypeError,ValueError,UnicodeError,OverflowError: an argument was of the wrong type or value, -
linuxcnc.error: the num argument, if given, was less or equal zero (0).
Note
All methods that retrieve a This behavior is for compatibility only. You should not rely on this property. |
For all methods, the fallback= value, if given, may be of any type. It is returned verbatim if the method otherwise would have failed or returned None.
Conversion to both integer and floating point will ignore trailing content if it is separated by whitespace.
[BLUEBERRY]
PIE = 3.14159265 This is _/*very*/_ bad style but accepted
FAIL= 0.12345#Warning will be issued
The above example will correctly convert when using ini.getreal("BLUEBERRY","PIE") and the trailing content is ignored. A warning message (inifile:line: warning: Trailing character(s)...) will be reported on ini.getreal("BLUEBERRY","FAIL").
7.1.1. Method details
- ini = linuxcnc.ini(filename:string)
Creates an INI-file instance reading INI-file filename. Throws a
linuxcnc.errorif the file does not exist or cannot be parsed. - bool = ini.hassection(section:string)
Returns a boolean indicating whether or not the given section was found in the ini-file.
- bool = ini.hasvariable(section:string, variable:string [, num:int])
Returns a boolean indicating whether or not the given variable in section was found in the ini-file. The first occurrence of the variable name in any section will be searched if the section name is empty. The optional num argument may be used to test whether the num’th variable exists in the section.
- bool|None = ini.getbool(section:string, variable:string [, num:int] [, fallback=])
Returns the value of the variable converted to boolean if it was a valid boolean. The return value is
Noneif the variable was not found or an invalid value was detected and no fallback= was provided. The optional num argument may be used to select the num’th variable of that name in the section. - int|None = ini.getsint(section:string, variable:string [, num:int] [, fallback=])
Returns the value of the variable converted to signed integer if it was a valid integer. The return value is
Noneif the variable was not found or an invalid value was detected and no fallback= was provided. The optional num argument may be used to select the num’th variable of that name in the section. - int|None = ini.getint(section:string, variable:string [, num:int] [, fallback=])
Alias of
ini.getsint(). - int|None = ini.getuint(section:string, variable:string [, num:int] [, fallback=])
Returns the value of the variable converted to unsigned integer if it was a valid unsigned integer. The return value is
Noneif the variable was not found or an invalid value was detected and no fallback= was provided. The optional num argument may be used to select the num’th variable of that name in the section. - float|None = ini.getreal(section:string, variable:string [, num:int] [, fallback=])
Returns the value of the variable converted to floating point real if it was a valid real. The return value is
Noneif the variable was not found or an invalid value was detected and no fallback= was provided. The optional num argument may be used to select the num’th variable of that name in the section. - float|None = ini.getfloat(section:string, variable:string [, num:int] [, fallback=])
Alias of
ini.getreal(). - string|None = ini.getstring(section:string, variable:string [, num:int] [, fallback=])
Returns the value of the variable as a string if it exists. The return value is
Noneif the variable was not found and no fallback= was provided. The optional num argument may be used to select the num’th variable of that name in the section. - list = ini.getsections()
Returns a list of section names.
- list(name,value) = ini.getvariables([section:string])
Returns a list of (name,value) tuples of all variables in the named section, or the variables from all sections if the section name is not specified.
- string|None = ini.find(section:string, variable:string [, num:int] [, fallback=])
Alias of
ini.getstring(). - list = ini.findall(section:string [,variable:string])
Find value(s) from named section as a list matching the optional variable name.
- tuple(filename,lineno) = ini.lineof(section:string, variable:string [, num:int])
Returns a tuple with the filename and line number of num'th variable in the section. The first matching section variable is returned if num is not provided. The tuple (None, None) is returned if the variable is not found.
- float|None = ini.maplinearunits(enumstr:string [, fallback=])
Take the enumstr enumeration string argument and try to convert. Returns the value associated with enumerated type defined by [mm, metric, in, inch, imperial]. Returns
Noneif the enumstr contains an invalid string and fallback= is not specified. - float|None = ini.mapangularunits(enumstr:string [, fallback=])
Take the enumstr enumeration string argument and try to convert. Returns the value associated with enumerated type defined by [deg, degree, grad, gon, rad, radian]. Returns
Noneif the enumstr contains an invalid string and fallback= is not specified. - int|None = ini.mapjointtype(enumstr:string [, fallback=])
Take the enumstr enumeration string argument and try to convert. Returns the value associated with enumerated type defined by [LINEAR, ANGULAR]. Returns
Noneif the enumstr contains an invalid string and fallback= is not specified. - float|None = ini.getlinearunits(section:string, variable:string [, num:int] [, fallback=])
Get the ini variable from the section and convert the enumerated type. The optional num argument may be used to select the num’th variable of that name in the section. Returns the value associated with the enumerated type defined by [mm, metric, in, inch, imperial]. Returns
Noneif the variable is not found and fallback= is not specified. - float|None = ini.getangularunits(section:string, variable:string [, num:int] [, fallback=])
Get the ini variable from the section and convert the enumerated type. The optional num argument may be used to select the num’th variable of that name in the section. Returns the value associated with the enumerated type defined by [deg, degree, grad, gon, rad, radian]. Returns
Noneif the variable is not found and fallback= is not specified. - int|None = ini.getjointtype(section:string, variable:string [, num:int] [, fallback=])
Get the ini variable from the section and convert the enumerated type. The optional num argument may be used to select the num’th variable of that name in the section. Returns the value associated with enumerated type defined by [LINEAR, ANGULAR]. Returns
7.2. linuxcnc.ini Examples
Reading values from an INI file through the linuxcnc.ini object:
# run as:
# python3 ini-example.py ~/emc2-dev/configs/sim/axis/axis_mm.ini
import sys
import linuxcnc
fname = sys.argv[1] if len(sys.argv) > 1 else "<missing filename>"
try:
inifile = linuxcnc.ini(fname)
except linuxcnc.error as detail:
print("{}: error: {}".format(fname, detail))
sys.exit(1)
# inifile.getstring() returns None if the key wasn't found - the
# following idiom is useful for setting a default value:
machine_name = inifile.getstring("EMC", "MACHINE", fallback="unknown")
print("machine name:", machine_name)
# inifile.findall() returns a list of matches, or an empty list
# if the key wasn't found:
extensions = inifile.findall("FILTER", "PROGRAM_EXTENSION")
print("extensions :", extensions)
# Other examples:
realval = inifile.getreal("AXIS_X", "MAX_VELOCITY", fallback=5.0)
boolval = inifile.getbool("JOINT_0", "HOME_USE_INDEX", fallback=False)
# None is returned without fallback= if the variable was not found
intval = inifile.getint( "KINS", "JOINTS")
if intval is None:
print("Error: [KINS]JOINTS not defined or an invalid integer")
else:
print("[KINS]JOINTS:", intval)
Or for the same INI file as LinuxCNC:
# run as:
# python3 ini-example2.py
import linuxcnc
stat = linuxcnc.stat()
stat.poll()
inifile = linuxcnc.ini(stat.ini_filename)
# See example above for usage of 'inifile' object
8. The linuxcnc.positionlogger type
Some usage hints can be gleaned from src/emc/usr_intf/gremlin/gremlin.py.
8.1. members
npts-
number of points.
8.2. methods
start(float)-
start the position logger and run every ARG seconds
clear()-
clear the position logger
stop()-
stop the position logger
call()-
Plot the backplot now.
points()-
Return
(bytes, npts, is_xyuv): a copy (taken under the sampler lock) of the logged point buffer, the number of points, and whether the machine is a foam (XY/UV) cutter. Each point is a Clogger_point— 3 float32 (x, y, z), 4 uint8 RGBA, 3 float32 (rx, ry, rz or u, v, w), 4 uint8 RGBA — so the buffer isnpts * 32bytes. Added for the OpenGL 3.3 core renderer to upload the backplot to a GPU buffer; seers274.glcanonfor the numpy layout. last([int])-
Return the most recent point on the plot or None
