1. Introduction
This document describes how to build the LinuxCNC software from source. This is primarily useful if you are a developer who is modifying LinuxCNC. It can also be useful if you’re a user who is testing developer branches, though then you also have the option of just installing Debian packages from the buildbot (http://buildbot.linuxcnc.org) or as a regular package from your Linux distribution (https://tracker.debian.org/pkg/linuxcnc). Admittedly, this section also exists since LinuxCNC is a community effort. and you are encouraged to contribute to the development of LinuxCNC. Generally, you want to compile LinuxCNC yourself for immediate functional access
  • to a new development of LinuxCNC or
  • a new development you perhaps want to contribute to LinuxCNC or help other completing it.
You may for instance be porting LinuxCNC to some new Linux distribution or, and this common, a developer reacts to you reporting a problem whose fix you want to test. Any such change will see no buildbot to help, or that help is delayed, pending someone else’s review that you do not want to wait for or you are the only other individual with a particular hardware to test the code.
Besides the programs that control your machine that are built from the source tree, you can also build the same PDFs and/or HTML files that you are likely to have encountered online on https://linuxcnc.org/documents/.
If you want to contribute to LinuxCNC but are uncertain about where to start, please seriously consider to contribute to the documentation. Everyone always finds something to improve - and if you only leave a "FIXME: with a comment" in the text as a reference for yourself and others to revisit a section later. Also, translations to languages other than English are very likely to benefit from your scrutiny at https://hosted.weblate.org/projects/linuxcnc/ .
2. Downloading source tree
The LinuxCNC project git repository is at https://github.com/LinuxCNC/linuxcnc. GitHub is a popular git hosting service and code sharing website.
To retrieve the source tree you have two options:
Download tarball
On the LinuxCNC project page in GitHub find a reference to the "releases" or "tags", click that hyperlink to the archive page and download the latest .tar file. You will find that file compressed as a .tar.xz or .tar.gz file. This file, commonly referred to as a "tarball" is an archive very analogous to a .zip. Your Linux desktop will know how to treat that file when double-clicking on it.
Prepare a local copy of the LinuxCNC repository
You would first install the tool "git" on your machine if it is not available already (sudo apt install git). Then prepare a local instance of the source tree as follows: .
$ git clone https://github.com/LinuxCNC/linuxcnc.git linuxcnc-source-dir
. The first argument to the git command gives it away: This is called a "clone" of the LinuxCNC repository. The advantage is that this local clone supports the communication about changes you may decide to perform on the source tree.
GitHub is an infrastructure on its own and explained in depth elsewhere. Just to get you motivated if you do not know it already.offers to perform a clone for you and have that instance made publicly available. GitHub refers to such an additional instance of another repository as a "fork". You can easily (and at no cost) create a fork of the LinuxCNC git repository at GitHub, and use that to track and publish your changes. After creating your own GitHub fork of LinuxCNC, clone it to your development machine and proceed with your hacking as usual.
We of the LinuxCNC project hope that you will share your changes with us, so that the community can benefit from your work. GitHub makes this sharing very easy: After you polish your changes and push them to your github fork, send us a Pull Request.
2.1. Quick Start
For the impatient, try this:
$ cd linuxcnc-source-dir/src
$ ./autogen.sh
$ ./configure --with-realtime=uspace
$ make
That will probably fail! That doesn’t make you a bad person, it just means you should read this whole document to find out how to fix your problems. Especially the section on Satisfying Build Dependencies.
If you are running on a realtime-capable system (such as an install from the LinuxCNC Live/Install Image, see the Realtime section below), one extra build step is needed at this time:
$ sudo make setuid
After you have successfully built LinuxCNC it is time to run the tests:
$ source ../scripts/rip-environment
$ runtests
This might fail, too! Read this whole document, especially the section on Setting up the test environment.
3. Supported Platforms
The LinuxCNC project targets modern Debian-based distributions, including Debian, Ubuntu, and Mint. We continuously test on the platforms listed at http://buildbot.linuxcnc.org.
LinuxCNC builds on most other Linux distributions, though dependency management will be more manual and less automatic. Patches to improve portability to new platforms are always welcome.
3.1. Realtime
LinuxCNC is a machine tool controller, and it requires a realtime platform to do this job. This version of LinuxCNC supports the following platforms. The first three listed are realtime operating systems:
RTAI
From https://www.rtai.org. A Linux kernel with the RTAI patch is available from the Debian archive at https://linuxcnc.org. See Getting LinuxCNC for installation instructions.
Xenomai
From https://xenomai.org. You will have to compile or obtain a Xenomai kernel yourself.
Preempt-RT
From https://rt.wiki.kernel.org. A Linux kernel with the Preempt-RT patch is occasionally available from the Debian archive at https://www.debian.org, and from the wayback machine at https://snapshot.debian.org.
Non-realtime
LinuxCNC can also be built and run on non-realtime platforms, such as a regular install of Debian or Ubuntu without any special realtime kernel. . In this mode LinuxCNC is not useful for controlling machine tools, but it is useful for simulating the execution of G-code and for testing the non-realtime parts of the system (such as the user interfaces, and some kinds of components and device drivers). . To make use of the realtime capabilities of LinuxCNC, certain parts of LinuxCNC need to run with root privileges. To enable root for these parts, run this extra command after the make that builds LinuxCNC:
$ sudo make setuid
4. Build modes
There are two ways to build LinuxCNC: The developer-friendly "run in place" mode and the user-friendly Debian packaging mode.
4.1. Building for Run In Place
In a Run-In-Place build, the LinuxCNC programs are compiled from source and then run directly from within the build directory. Nothing is installed outside the build directory. This is quick and easy, and suitable for rapid iteration of changes. The LinuxCNC test suite runs only in a Run-In-Place build. Most LinuxCNC developers primarily build using this mode.
Building for Run-In-Place follows the steps in the Quick Start section at the top of this document, possibly with different arguments to src/configure and make.
4.1.1. src/configure arguments
The src/configure script configures how the source code will be compiled. It takes many optional arguments. List all arguments to src/configure by running this:
$ ./configure --help
The most commonly used arguments are:
Build for any realtime platform, or for non-realtime. The resulting LinuxCNC executables will run on both a Linux kernel with Preempt-RT patches (providing realtime machine control) and on a vanilla (un-patched) Linux kernel (providing G-code simulation but no realtime machine control).
If development files are installed for Xenomai (typically from package libxenomai-dev) or RTAI (typically from a package with a name starting "rtai-modules"),
support for these real-time kernels will also be enabled.
--with-realtime=/usr/realtime-$VERSION
Build for the RTAI realtime platform using the older "kernel realtime" model. This requires that you have an RTAI kernel and the RTAI modules installed in /usr/realtime-$VERSION. The resulting LinuxCNC executables will only run on the specified RTAI kernel. As of LinuxCNC 2.7, this produces the best realtime performance.
--enable-build-documentation
Build the documentation, in addition to the executables. This option adds significantly to the time required for compilation, as building the docs is quite time consuming. If you are not actively working on the documentation you may want to omit this argument.
--disable-build-documentation-translation
Disable building the translated documentation for all available languages. The building of the translated documentation takes a huge amount of time, so it is recommend to skip that if not really needed.
4.1.2. make arguments
The make command takes two useful optional arguments.
Parallel compilation
make takes an optional argument -j N (where N is a number). This enables parallel compilation with N simultaneous processes, which can significantly speed up your build.
A useful value for N is the number of CPUs in your build system.
You can discover the number of CPUs by running nproc.
Building just a specific target
If you want to build just a specific part of LinuxCNC, you can name the thing you want to build on the make command line. For example, if you are working on a component named froboz, you can build its executable by running:
$ make ../bin/froboz
4.2. Building Debian Packages
When building Debian packages, the LinuxCNC programs are compiled from source and then stored in a Debian package, complete with dependency information. This process by default also includes the building of the documentation, which takes its time because of all the I/O for many languages, but that can be skipped. LinuxCNC is then installed as part of those packages on the same machines or on whatever machine of the same architecture that the .deb files are copied to. LinuxCNC cannot be run until the Debian packages are installed on a target machine and then the executables are available in /usr/bin and /usr/lib just like other regular software of the sytem.
This build mode is primarily useful when packaging the software for delivery to end users, and when building the software for a machine that does not have the build environment installed, or that does not have internet access.
To build packages is primarily useful when packaging the software for delivery to end users. Developers among themselves exchange only the source code, likely supported by the LinuxCNC GitHub repository referenced below. Also, when building the software for a machine that doesn’t have the build environment installed, or that doesn’t have internet access, one happily accepts a prebuilt package.
Building Debian packages requires the dpkg-buildpackage tool the is provided by the dpkg-dev package. But when building a Debian package, is generally expected to have all scripts in place that would commonly be expected. This has been formally manifested as a virtual package named build-essential:
$ sudo apt-get install build-essential
Building Debian packages also requires that all package-specific build dependencies are installed, as described in the section Satisfying Build Dependencies.
Once those prerequisites are met, building the Debian packages consists of two steps.
The first step is generating the Debian package scripts and meta-data from the git repo by running this:
$ cd linuxcnc-dev
$ ./debian/configure
Note
The debian/configure script is different from the src/configure script!
The debian/configure accepts arguments depending on the platform you are building on/for, see the debian/configure arguments section. It defaults to LinuxCNC running in user space ("uspace"), expecting the preempt_rt kernel to minimize latencies.
Once the Debian package scripts and meta-data are configured, build the package by running dpkg-buildpackage:
$ dpkg-buildpackage -b -uc
Note
dpkg-buildpackage needs to run from the linuxcnc-source-dir directory, not from linuxcnc-source-dir/debian.
dpkg-buildpackage takes an optional argument ``-j``N (where N is a number). This enables to run multiple jobs simultaneously.
4.2.1. LinuxCNC’s debian/configure arguments
The LinuxCNC source tree has a debian directory with all the info about how the Debian package shall be built, but some key files within are only distributed as templates. The debian/configure script readies those build instructions for the regular Debian packaging utilities and must thus be run prior to dpkg-checkbuilddeps or dpkg-buildpackage.
The debian/configure script takes a single argument which specifies the underlying realtime or non-realtime platform to build for. The regular values for this argument are:
no-docs
Skip building documentation.
uspace
Configure the Debian package for Preempt-RT realtime or for non-realtime (these two are compatible).
noauto
rtai
xenomai
Normally, the lists of RTOSes for uspace realtime to support is detected automatically. However, if you wish, you may specify one or more of these after uspace to enable support for these RTOSes. Or, to disable autodetection, specify noauto.
If you want just the traditional RTAI "kernel module" realtime, use -r or $KERNEL_VERSION instead.
rtai=<package name>
If the development package for RTAI, lxrt, does not start with "rtai-modules", or if the first such package listed by apt-cache search is not the desired one, then explicitly specify the package name.
-r
Configure the Debian package for the currently running RTAI kernel. You must be running an RTAI kernel on your build machine for this to work!
$KERNEL_VERSION
Configure the Debian package for the specified RTAI kernel version (for example "3.4.9-rtai-686-pae"). The matching kernel headers Debian package must be installed on your build machine, e.g. "linux-headers-3.4.9-rtai-686-pae". Note that you can build LinuxCNC in this configuration, but if you are not running the matching RTAI kernel you will not be able to run LinuxCNC, including the test suite.
4.2.2. Satisfying Build Dependencies
On Debian-based platforms we provide packaging meta-data that knows what external software packages need to be installed in order to build LinuxCNC. These are referred to as the build dependencies of LinuxCNC, i.e. those packages that need to be available such that
  • the build succeeds and
  • the build can be built reproducibly.
You can use this meta-data to easily list the required packages missing from your build system. First, go to the source tree of LinuxCNC and initiate its default self-configuration, if not already performed:
$ cd linuxcnc-dev
This will prepare the file debian/control that contains lists of Debian packages to create with the runtime dependencies for those packages and for our cause also the build-dependencies for those to-be-created packages.
The most straightforward way to get all build-dependencies installed is to just execute (from the same directory):
sudo apt-get build-dep .
which will install all the dependencies required but available. The . is part of the command line, i.e. an instruction to retrieve the dependencies for the source tree at hand, not for dependencies of another package. This completes the installation of build-dependencies.
The remainder of this section describes a semi-manual approach. The list of dependencies in debian/control is long and it is tedious to compare the current state of packages already installed with it. Debian systems provide a program called dpkg-checkbuilddeps that parses the package meta-data and compares the packages listed as build dependencies against the list of installed packages, and tells you what’s missing.
First, install the dpkg-checkbuilddeps program by running:
$ sudo apt-get install dpkg-dev
This generates the file debian/control in a user-readable yaml-format which lists the build-dependencies close to the top. You can use this meta-data to easily list the required packages missing from your build system. You may decide to manually inspecting those files if you have a good understanding what is already installed.
Alternatively, Debian systems provide a program called dpkg-checkbuilddeps that parses the package meta-data and compares the packages listed as build dependencies against the list of installed packages, and tells you what’s missing. Also, dpkg-buildpackage would inform you about what is missing, and it should be fine. However, it reports missing build-deps only after patches in debian/patches are applied (if any). If you are new to Linux and git version management, a clean start may be preferable to avoid complications.
The dpkg-checkbuilddeps (also from the dpkg-dev package that is installed as part of the build-essential dependencies) program can be asked to do its job (note that it needs to run from the linuxcnc-source-dir directory, not from linuxcnc-source-dir/debian):
$ dpkg-checkbuilddeps
It will emit a list of packages that are required to build LinuxCNC on your system but are not installed, yet. You can now install missing build-dependencies
manually
Install them all with sudo apt-get install, followed by the package names. You can rerun dpkg-checkbuilddeps any time you want, to list any missing packages, which has no effect on the source tree.
automated
Run sudo apt build-dep . .
If in doubt about what a particular package of a build-dep may be providing, check out the package’s description with ``apt-cache show`` packagename.
4.2.3. Options for dpkg-buildpackage
For a typical Debian package to build, you would run dpkg-buildpackage without any arguments. As introduced above, the command has two extra options passed to it. Like for all good Linux tools, the man page has all the details with man dpkg-buildpackage.
-uc
Do not sign the resulting binaries. You would want to sign your packages with a GPG key of yours only if you would wanted to distribute them to others. Having that option not set and then failing to sign the package would not affect the .deb file.
-b
Only compiles the architecture-dependent packages (like the linuxcnc binaries and GUIs). This is very helpful to avoid compiling what is hardware-independent, which for LinuxCNC is the documentation. That documentation is available online anyway.
If you happen to run into difficulties while compiling, check the LinuxCNC forum online. Currently emerging is the support for the DEB_BUILD_OPTIONS environment variable. Set it to
nodocs
to skip building the documentation, preferably instead use the -B flag to dpkg-buildpackage.
nocheck
to skip self-tests of the LinuxCNC build process. This saves some time and reduces the demand for a few software packages that may not be available for your system, i.e. the xvfb in particular. You should not set this option for some extra confidence in your build to perform as expected unless running into difficulties with the dependencies.
An environment variable can be set together with the execution of the command, e.g.
DEB_BUILD_OPTIONS=nocheck dpkg-buildpackage -uc -B
would combine all the options introduced in this section.
4.2.4. Installing self-built Debian packages
A Debian package can be recognised by its .deb extension. The tool installing it, dpkg is part of every Debian installation. The .deb files created by dpkg-buildpackage are found in the directoy above the linuxcnc-source-dir, i.e. in ... To see what files are provided in a package, run
dpkg -c ../linuxcnc-uspace*.deb
The version of LinuxCNC will be part of the file name, which is meant to be matched by the asterisk. There may be too many files listed to fit on your screen. If you cannot scroll up in your terminal then add | more to that command to have its output passed through a so-called "pager". Quit with "q".
To install the packages, run
sudo dpkg -i ../linuxcnc*.deb
5. Setting up the environment
This section describes the special steps needed to set up a machine to run the LinuxCNC programs, including the tests.
5.1. Increase the locked memory limit
LinuxCNC tries to improve its realtime latency by locking the memory it uses into RAM. It does this in order to prevent the operating system from swapping LinuxCNC out to disk, which would have bad effects on latency. Normally, locking memory into RAM is frowned upon, and the operating system places a strict limit on how much memory a user is allowed to have locked.
When using the Preempt-RT realtime platform LinuxCNC runs with enough privilege to raise its memory lock limit itself. When using the RTAI realtime platform it does not have enough privilege, and the user must raise the memory lock limit.
If LinuxCNC displays the following message on startup, the problem is your system’s configured limit on locked memory:
RTAPI: ERROR: failed to map shmem
RTAPI: Locked memory limit is 32KiB, recommended at least 20480KiB.
To fix this problem, add a file named /etc/security/limits.d/linuxcnc.conf (as root) with your favorite text editor (e.g., sudo gedit /etc/security/limits.d/linuxcnc.conf). The file should contain the following line:
* - memlock 20480
Log out and log back in to make the changes take effect. Verify that the memory lock limit is raised using the following command:
$ ulimit -l
