LinuxCNC Documentation
This page is 20% translated. Untranslated text is shown in English.
1. M-Code Quick Reference Table
Código Descripción
M0 M1
Pausa de programa
M2 M30
Fin del programa
M60
Pausa de cambio de pallet
M3 M4 M5
Control de husillo
M6
Cambio de herramienta
M7 M8 M9
Control de refrigerante
M19
Orientación del husillo
M26 M27
Rotary Modulo Path: Shortest / Literal
M48 M49
Feed & Spindle Overrides Enable/Disable
M50
Porcentaje de alimentación
M51
Spindle Override Control
M52
Control de avance adaptativo
M53
Control de paro de alimentación
M61
Set Current Tool Number
m62-m65
Control de salida
M66
Input Control
M67
Analog Output Control
M68
M70
Save Modal State
M71
Invalidate Stored Modal State
M72
Restore Modal State
M73
Save Autorestore Modal State
M98 M99
Call and Return From Subprogram
M100-M199
User Defined M-Codes
2. M0, M1 Program Pause
  • M0 - pause a running program temporarily. LinuxCNC remains in the Auto Mode so MDI and other manual actions are not enabled. Pressing the resume button will restart the program at the following line.
  • M1 - pause a running program temporarily if the optional stop switch is on. LinuxCNC remains in the Auto Mode so MDI and other manual actions are not enabled. Pressing the resume button will restart the program at the following line.
Note
It is OK to program M0 and M1 in MDI mode, but the effect will probably not be noticeable, because normal behavior in MDI mode is to stop after each line of input anyway.
3. M2, M30 Program End
  • M2 - end the program. Pressing Cycle Start ("R" in the Axis GUI) will restart the program at the beginning of the file.
  • M30 - exchange pallet shuttles and end the program. Pressing Cycle Start will start the program at the beginning of the file.
Both of these commands have the following effects:
  • Change from Auto mode to MDI mode.
  • Origin offsets are set to the default (like G54) unless disabled by INI setting DISABLE_AUTO_G54 = 1.
  • A tilted work plane is cancelled (like G69) unless kept by INI setting RETAIN_WORK_PLANE = 1.
  • Selected plane is set to XY plane (like G17).
  • Distance mode is set to absolute mode (like G90).
  • Feed rate mode is set to units per minute (like G94).
  • Feed and speed overrides are set to ON (like M48).
  • Cutter compensation is turned off (like G40).
  • The spindle is stopped (like M5).
  • The current motion mode is set to feed (like G1).
  • Coolant is turned off (like M9).
  • Rotary modulo path control is set to shortest path (like M26).
Note
Lines of code after M2/M30 will not be executed. Pressing Cycle Start will start the program at the beginning of the file.
Warning
Using % to wrap the G-code does not do the same thing as a Program End. See the section on File Requirements for more information on what using % does not do.
4. M60 Pallet Change Pause
  • M60 - intercambia lanzaderas de palets y luego detiene un programa en ejecución temporalmente (independientemente de la configuración de parada opcional). Presionando el botón de inicio del ciclo reiniciará el programa en la línea siguiente.
5. M3, M4, M5 Spindle Control
  • M3 [$n] - start the selected spindle clockwise at the S speed.
  • M4 [$n] - start the selected spindle counterclockwise at the S speed.
  • M5 [$n] - stop the selected spindle.
Use $ to operate on specific spindles. If $ is omitted then the commands default to operating on spindle 0. Use $-1 to operate on all active spindles.
This example will start spindles 0, 1, and 2 simultaneously at different speeds:
S100 $0
S200 $1
S300 $2
M3 $-1
Este ejemplo invertirá el husillo 1 pero dejará los otros husillos girando hacia adelante:
M4 $1
And this will stop spindle 2 and leave the other spindles rotating:
M5 $2
Si se omite $, entonces el comportamiento es exactamente el normal para una máquina de un solo husillo.
It is OK to use M3 or M4 if the S spindle speed is set to zero. If this is done (or if the speed override switch is enabled and set to zero), the spindle will not start turning. If, later, the spindle speed is set above zero (or the override switch is turned up), the spindle will start turning. It is OK to use M3 or M4 when the spindle is already turning or to use M5 when the spindle is already stopped.
6. M6 Tool Change
6.1. Cambio manual de herramienta
If the HAL component hal_manualtoolchange is loaded, M6 will stop the spindle and prompt the user to change the tool based on the last T- number programmed. For more information on hal_manualtoolchange see the Manual Tool Change section.
6.2. Tool Changer
To change a tool in the spindle from the tool currently in the spindle to the tool most recently selected (using a T word - see section Select Tool), program M6. When the tool change is complete:
  • The spindle will be stopped.
  • La herramienta seleccionada (por una palabra T en la misma línea o en cualquier línea después del cambio de herramienta anterior) estará en el husillo.
  • Si la herramienta seleccionada no estaba en el husillo antes del cambio de herramienta, la herramienta que estaba en el husillo (si hubiera) se colocará de nuevo en el cambiador de herramientas.
  • Si está configurado en el archivo INI, algunas posiciones de eje pueden moverse cuando se emite un M6. Vea la sección EMCIO para más información sobre opciones de cambio de herramienta.
  • No se realizarán otros cambios. Por ejemplo, el refrigerante continuará fluyendo durante el cambio de herramienta a menos que haya sido desactivado por un M9.
Note
La palabra T- es un número entero que designa el número de ranura de herramienta en el carrusel (no su índice).
Warning
El offset de la longitud de la herramienta no cambia con M6, use G43 después de M6 para cambiar el offset de longitud de la herramienta.
El cambio de herramienta puede incluir movimiento de ejes. Está bien (pero no es útil) programar un cambio en la herramienta que ya está en el husillo. Está bien si no hay ninguna herramienta en la ranura seleccionada; en ese caso, el husillo estará vacío después del cambio de herramienta. Si se seleccionó por última vez la ranura cero, definitivamente no habrá herramienta en el husillo después de un cambio de herramienta. El cambiador tendrá que estar configurado para realizar el cambio de herramienta en HAL y posiblemente en ClassicLadder.
7. M7, M8, M9 Control de refrigerante
  • M7 - activa el refrigerante de niebla. M7 controla el pin iocontrol.0.coolant-mist.
  • M8 - activa el refrigerante de inundación. M8 controla el pin iocontrol.0.coolant-flood.
  • M9 - apaga M7 y M8.
Conecte uno o ambos pines de control de refrigerante en HAL antes de que M7 o M8 puedan controlar una salida. M7 y M8 se pueden usar para activar cualquier salida a través del código G.
Está bien usar cualquiera de estos comandos, independientemente del estado actual del refrigerante.
8. M19 Orientación de husillo
M19 R- Q- [P-] [$-]
  • R Position to rotate to from 0, valid range is 0-360 degrees
  • Q Número de segundos de espera hasta que se complete la orientación. Si spindle.N.is-oriented no se hace true dentro del tiempo de espera Q, se produce un error.
  • P Direction to rotate to position.
    • 0 rotate for smallest angular movement (default)
    • 1 always rotate clockwise (same as M3 direction)
    • 2 always rotate counterclockwise (same as M4 direction)
    • 3 same as 0 but with preceding rotation to an index signal
    • 4 same as 1 but with preceding rotation to an index signal
    • 5 same as 2 but with preceding rotation to an index signal
  • $ The spindle to orient (actually only determines which HAL pins carry the spindle position commands)
M19 is a command of modal group 7, like M3, M4 and M5. M19 is cleared by any of M3,M4,M5.
Spindle orientation with modes 0,1,2 requires a quadrature encoder to sense the spindle shaft position and direction of rotation. Spindle orientation with modes 3,4,5 requires an additional index signal for referencing the spindle before orientation.
Configuración INI en la sección [RS274NGC]:
  • ORIENT_OFFSET = 0-360 (fixed offset in degrees added to M19 R word)
  • Pines HAL
    • spindle.N.orient-angle (real, out) Desired spindle orientation for M19. Value of the M19 R word parameter plus the value of the [RS274NGC]ORIENT_OFFSET INI parameter.
    • spindle.N.orient-mode (sint, out) Desired spindle rotation mode. Reflects M19 P parameter word, default = 0.
    • spindle.N.orient (bool, out) Indicates start of spindle orient cycle. Set by M19. Cleared by any of M3,M4,M5. If spindle-orient-fault is not zero during spindle-orient true, the M19 command fails with an error message.
    • spindle.N.is-oriented (bool, in) Acknowledge pin for spindle-orient. Completes orient cycle. If spindle-orient was true when spindle-is-oriented was asserted, the spindle-orient pin is cleared and the spindle-locked pin is asserted. Also, the spindle-brake pin is asserted.
    • spindle.N.orient-fault (sint, in) Fault code input for orient cycle. Any value other than zero will cause the orient cycle to abort.
    • spindle.N.locked (bool, out) Spindle orient complete pin. Cleared by any of M3,M4,M5.
9. M26, M27 Rotary Modulo Path Control
  • M26 - on rotary axes flagged with [AXIS_<L>] ROTARY_MODULO = 1, absolute moves take the shortest path: a programmed value is reached by moving at most 180 degrees in the shorter direction. A move of exactly 180 degrees is taken in the negative direction. A value that wraps to the angle the axis is already standing on commands no motion: G0 A360 from A0 leaves the axis where it is. This is the default when ROTARY_MODULO is enabled.
  • M27 - on the same axes, absolute moves take the modulo-with-sign-direction path: the programmed value is reduced mod 360, and the sign of the input picks the direction of approach. A positive (or zero) value approaches in the forward direction; a negative value approaches in the reverse direction. The resulting move is always less than one full turn. Programmed values outside +/-360 are accepted and wrapped, so A720 is treated as A0, A-540 as A-180. An axis already standing on the programmed angle does not move, whatever the sign: G0 A360 and G0 A-360 from A0 both leave the axis where it is. And the commanded travel changes abruptly right at the wrap point: from A0, A359.999 moves 359.999 degrees forward and A-359.999 moves only 0.001 degrees backward - both land on the same angle, 359.999. Use this when sign convention must select rotation direction explicitly, similar to a wrapped rotary axis or to Heidenhain M127 / Siemens ACP/ACN behavior on a modulo axis.
M26 and M27 are modal (modal group 3) and persist until the other code is programmed or the program ends. They have no effect on rotary axes that are not flagged ROTARY_MODULO, on incremental moves (G91), or on parameter readout (#5423/#5424/#5425 continue to report the wrapped value). Moves to a stored position that carries no programmed sign (G28, G30, the tool change position) always take the shortest path, M27 or not.
Typical usage:
(at this point absolute A moves take the shortest path)
M27         (enter sign-direction mode for the section that follows)
G1 A45      (forward to 45 degrees within the current turn)
G1 A-90     (backward to 90 degrees, taking the long way round)
M26         (restore shortest path for the rest of the program)
G0 A0       (now resolves to the nearest equivalent angle)
For multi-turn motion (helical winding, wire wrapping, etc.), use G91 incremental mode. G91 A7200 performs twenty turns regardless of ROTARY_MODULO or M26/M27 state, and matches the recommended idiom on Heidenhain (IA+) and Siemens controls.
M26 and M27 are saved and restored by M70/M72/M73 alongside the other modal M-codes.
See also: ROTARY_MODULO in [AXIS_<L>] Section.
10. M48, M49 Speed and Feed Override Control
  • M48 - enable the spindle speed and feed rate override controls.
  • M49 - disable both controls.
These commands also take an optional $ parameter to determine which spindle they operate on.
It is OK to enable or disable the controls when they are already enabled or disabled. See the Feed Rate section for more details.
They also can be be toggled individually using M50 and M51, see below.
11. M50 Feed Override Control
  • M50 <P1> - enable the feed rate override control. The P1 is optional.
  • M50 P0 - disable the feed rate control.
While disabled the feed override will have no influence, and the motion will be executed at programmed feed rate. (unless there is an adaptive feed rate override active).
12. M51 Spindle Speed Override Control
  • M51 <P1> <$→- enable the spindle speed override control for the selected spindle. The P1 is optional.
  • M51 P0 <$→ - disable the spindle speed override control program.
Mientras está deshabilitado, el ajuste de velocidad del husillo no tendrá influencia, y la velocidad del husillo tendrá el valor exacto de programa especificado de la palabra-S (descrita en la sección Velocidad del Husillo).
The override is also suspended for the duration of a G33 move, and held at the value the cycle started with for the duration of a G76 cycle, whatever M48, M49 or M51 last selected. That selection is restored afterwards.
13. Control de avance adaptativo M52
  • M52 <P1> - use an adaptive feed. The P1 is optional.
  • M52 P0 - stop using adaptive feed.
When adaptive feed is enabled, some external input value is used together with the user interface feed override value and the commanded feed rate to set the actual feed rate. In LinuxCNC, the HAL pin motion.adaptive-feed is used for this purpose. The range for motion.adaptive-feed is defined by the MAX_FEED_OVERRIDE value in the [DISPLAY] section of the ini file and will be limited to a range of -MAX_FEED_OVERRIDE to MAX_FEED_OVERRIDE. 0 is equivalent to feed-hold.
Note
The use of negative adaptive-feed for reverse run is a new feature and is not very well tested as yet. The intended use is for plasma cutters and wire spark eroders but it is not limited to such applications.
14. M53 Feed Stop Control
  • M53 <P1> - enable the feed stop switch. The P1 is optional. Enabling the feed stop switch will allow motion to be interrupted by means of the feed stop control. In LinuxCNC, the HAL pin motion.feed-hold is used for this purpose. A true value will cause the motion to stop when M53 is active.
  • M53 P0 - disable the feed stop switch. The state of motion.feed-hold will have no effect on feed when M53 is not active.
15. M61 Set Current Tool
  • M61 Q- - change the current tool number while in MDI or Manual mode without a tool change. One use is when you power up LinuxCNC with a tool currently in the spindle you can set that tool number without doing a tool change.
Warning
The tool length offset is not changed by M61, use G43 after the M61 to change the tool length offset.
Es un error si:
  • Q- is not 0 or greater
16. M62 - M65 Digital Output Control
  • M62 P- - activa la salida digital sincronizada con el movimiento.
  • M63 P- - apaga la salida digital sincronizada con el movimiento.
  • M64 P- - activa la salida digital de inmediato.
  • M65 P- - apaga la salida digital inmediatamente.
The P- word specifies the digital output number. The P-word ranges from 0 to a default value of 3. If needed the the number of I/O can be increased by using the num_dio parameter when loading the motion controller. See the Motion section for more information. A P-word for an output that the motion controller does not have is an error: the command is refused and a running program is stopped.
Los comandos M62 y M63 se pondrán en cola. Comandos posteriores referentes al mismo número de salida sobrescribirá la configuración anterior. Se puede especificar mas de un cambio de salida emitiendo más de un comando M62/M63.
The actual change of the specified outputs will happen at the beginning of the next motion command. If there is no subsequent motion command, the queued output changes won’t happen. It’s best to always program a motion G-code (G0, G1, etc) right after the M62/63.
M64 y M65 suceden inmediatamente cuando son recibidos por el controlador de movimiento. No están sincronizados con el movimiento, y romperán la mezcla.
Note
M62-65 will not function unless the appropriate motion.digital-out-nn pins are connected in your HAL file to outputs.
17. M66 Wait on Input
M66 P- | E- <L->
  • P- - especifica el número de entrada digital de 0 a 3. (Ajustable desde motmod con argumento num_dio)
  • E- - especifica el número de entrada analógica de 0 a 3. (Ajustable desde motmod con el argumento num_aio)
  • L- - specifies the wait mode type.
    • Mode 0: IMMEDIATE - no waiting, returns immediately. The current value of the input is stored in parameter #5399
    • Mode 1: RISE - waits for the selected input to perform a rise event.
    • Mode 2: FALL - waits for the selected input to perform a fall event.
    • Mode 3: HIGH - waits for the selected input to go to the HIGH state.
    • Mode 4: LOW - waits for the selected input to go to the LOW state.
  • Q- - specifies the timeout in seconds for waiting. If the timeout is exceeded, the wait is interrupt, and the variable #5399 will be holding the value -1. The Q value is ignored if the L-word is zero (IMMEDIATE). A Q value of zero is an error if the L-word is non-zero.
  • Mode 0 is the only one permitted for an analog input.
M66 Example Lines
M66 P0 L3 Q5 (wait up to 5 seconds for digital input 0 to turn on)
M66 wait on an input stops further execution of the program, until the selected event (or the programmed timeout) occurs.
It is an error to program M66 with both a P-word and an E-word (thus selecting both an analog and a digital input). In LinuxCNC these inputs are not monitored in real time and thus should not be used for timing-critical applications.
El número de E/S se puede aumentar utilizando el parámetro num_dio o num_aio al cargar el controlador de movimiento. Vea la sección Movimiento para mas información.
Note
M66 will not function unless the appropriate motion.digital-in-nn pins or motion.analog-in-nn pins are connected in your HAL file to an input.
Example HAL Connection
net signal-name motion.digital-in-00 <= parport.0.pin10-in
18. M67 Analog Output, Synchronized
M67 E- Q-
  • M67 - set an analog output synchronized with motion.
  • E- - número de salida de 0 a 3 (Ajustable desde motmod con el argumento num_aio)
  • Q- - is the value to set (set to 0 to turn off).
The actual change of the specified outputs will happen at the beginning of the next motion command. If there is no subsequent motion command, the queued output changes won’t happen. It’s best to always program a motion G-code (G0, G1, etc) right after the M67. M67 functions the same as M62-63.
The number of I/O can be increased by using the num_dio or num_aio parameter when loading the motion controller. See the Motion section for more information. An E-word for an output that the motion controller does not have is an error: the command is refused and a running program is stopped.
Note
M67 will not function unless the appropriate motion.analog-out-nn pins are connected in your HAL file to outputs.
19. M68 Analog Output, Immediate
M68 E- Q-
  • M68 - set an analog output immediately.
  • E- - número de salida que va de 0 a 3. (Ajustable desde motmod con el argumento num_aio)
M68 output happen immediately as they are received by the motion controller. They are not synchronized with movement, and they will break blending. M68 functions the same as M64-65.
Note
M68 will not function unless the appropriate motion.analog-out-nn pins are connected in your HAL file to outputs.
20. M70 Save Modal State
To explicitly save the modal state at the current call level, program M70. Once modal state has been saved with M70, it can be restored to exactly that state by executing an M72.
Un par de instrucciones M70 y M72 generalmente se utilizarán para proteger un programa contra cambios modales involuntarios dentro de subrutinas.
M70 Saved state
The state saved consists of:
  • current G20/G21 settings (imperial/metric)
  • selected plane (G17/G18/G19 G17.1,G18.1,G19.1)
  • status of cutter compensation (G40,G41,G42,G41.1,G42,1)
  • distance mode - relative/absolute (G90/G91)
  • feed mode (G93/G94,G95)
  • current coordinate system (G54-G59.3)
  • tool length compensation status (G43,G43.1,G49)
  • retract mode (G98,G99)
  • spindle mode (G96-css or G97-RPM)
  • arc distance mode (G90.1, G91.1)
  • lathe radius/diameter mode (G7,G8)
  • path control mode (G61, G61.1, G64)
  • current feed and speed (F and S values)
  • spindle status (M3,M4,M5) - on/off and direction
  • mist (M7) and flood (M8) status
  • speed override (M51) and feed override (M50) settings
  • adaptive feed setting (M52)
  • feed hold setting (M53)
Note that in particular, the motion mode (G1 etc) is NOT restored.
current call level means either:
  • executing in the main program. There is a single storage location for state at the main program level; if several M70 instructions are executed in turn, only the most recently saved state is restored when an M72 is executed.
  • executing within a G-code subroutine. The state saved with M70 within a subroutine behaves exactly like a local named parameter - it can be referred to only within this subroutine invocation with an M72 and when the subroutine exits, the parameter goes away.
A recursive invocation of a subroutine introduces a new call level.
21. M71 Invalidate Stored Modal State
Modal state saved with an M70 or by an M73 at the current call level is invalidated (cannot be restored from anymore).
A subsequent M72 at the same call level will fail.
If executed in a subroutine which protects modal state by an M73, a subsequent return or endsub will not restore modal state.
The usefulness of this feature is dubious. It should not be relied upon as it might go away.
22. M72 Restore Modal State
Modal state saved with an M70 code can be restored by executing an M72.
The handling of G20/G21 is specially treated as feeds are interpreted differently depending on G20/G21: if length units (mm/in) are about to be changed by the restore operation, 'M72 'will restore the distance mode first, and then all other state including feed to make sure the feed value is interpreted in the correct unit setting.
It is an error to execute an M72 with no previous M70 save operation at that level.
The following example demonstrates saving and explicitly restoring modal state around a subroutine call using M70 and M72. Note that the imperialsub subroutine is not "aware" of the M7x features and can be used unmodified:
O<showstate> sub
(DEBUG, imperial=#<_imperial> absolute=#<_absolute> feed=#<_feed> rpm=#<_rpm>)
O<showstate> endsub
O<imperialsub> sub
g20 (imperial)
g91 (relative mode)
F5 (low feed)
S300 (low rpm)
(debug, in subroutine, state now:)
o<showstate> call
O<imperialsub> endsub
; main program
g21 (metric)
g90 (absolute)
f200 (fast speed)
S2500 (high rpm)
(debug, in main, state now:)
o<showstate> call
M70 (save caller state in at global level)
O<imperialsub> call
M72 (explicitly restore state)
(debug, back in main, state now:)
o<showstate> call
m2
23. M73 Save and Autorestore Modal State
To save modal state within a subroutine, and restore state on subroutine endsub or any return path, program M73.
Aborting a running program in a subroutine which has an M73 operation will not restore state .
Also, the normal end (M2) of a main program which contains an M73 will not restore state.
The suggested use is at the beginning of a O-word subroutine as in the following example. Using M73 this way enables designing subroutines which need to modify modal state but will protect the calling program against inadvertent modal changes. Note the use of predefined named parameters in the showstate subroutine.
O<showstate> sub
O<showstate> endsub
O<imperialsub> sub
M73 (save caller state in current call context, restore on return or endsub)
g20 (imperial)
g91 (relative mode)
F5 (low feed)
S300 (low rpm)
o<showstate> call
; note - no M72 is needed here - the following endsub or an
; explicit 'return' will restore caller state
; main program
g21 (metric)
g90 (absolute)
f200 (fast speed)
S2500 (high rpm)
o<showstate> call
o<imperialsub> call
o<showstate> call
m2
24. M98 and M99
The interpreter supports Fanuc-style main- and sub-programs with the M98 and M99 M-codes. See Fanuc-Style Programs.
24.1. Selectively Restoring Modal State
Executing an M72 or returning from a subroutine which contains an M73 will restore all modal state saved.
Si solo se deben preservar algunos aspectos del estado modal, una alternativa es el uso de parámetros con nombre predefinido, parámetros locales y declaraciones condicionales. La idea es recordar los modos que se restaurarán en el comienzo de la subrutina y restaurar estos antes de salir. Aquí está un ejemplo, basado en el fragmento de nc_files/tool-length-probe.ngc:
O<measure> sub   (measure reference tool)
#<absolute> = #<_absolute>  (remember in local variable if G90 was set)
g30 (above switch)
g38.2 z0 f15 (measure)
g91 g0z.2 (off the switch)
#1000=#5063 (save reference tool length)
(print,reference length is #1000)
O<restore_abs> if [#<absolute>]
    g90 (restore G90 only if it was set on entry:)
O<restore_abs> endif
O<measure> endsub
25. M100-M199 Comandos definidos por el usuario
M1-- <P- Q->
  • M1-- - an integer in the range of 100 - 199.
  • P- - a number passed to the file as the first parameter.
  • Q- - a number passed to the file as the second parameter.
Note
After creating a new M1nn file you must restart the GUI so it is aware of the new file, otherwise you will get an Unknown m code error.
El programa externo llamado M100 a M199 (sin extensión, M mayúscula, que se encuentra en el directorio señalado en el parámetro [DISPLAY] PROGRAM_PREFIX del archivo INI) se ejecuta con los valores opcionales P y Q como sus dos argumentos.
Execution of the G-code file pauses until the external program exits. If the external program exits with exit code other than 0 G-code program execution is stopped. Any valid executable file can be used. The file must be located in the search path specified in the INI file configuration. See the Display section for more information on search paths.
After creating a new M1nn program, the GUI should be restarted so that the new program is taken into account, otherwise a Unknown M-code error will occur.
Warning
Do not use a word processor to create or edit the files. A word processor will leave unseen codes that will cause problems and may prevent a bash or python file from working. Use a text editor like Geany in Debian or Notepad++ in other operating systems to create or edit the files.
El error Código M desconocido utilizado denota uno de los siguientes:
  • El comando definido por el usuario no existe.
  • El archivo no es ejecutable.
  • El nombre del archivo tiene una extensión.
  • El nombre del archivo no sigue este formato Mnnn donde nnn = 100 a 199.
  • El nombre del archivo utiliza una M minúscula.
For example to open and close a collet closer that is controlled by a parallel port pin using a bash script file using M101 and M102. Create two files named M101 and M102. Set them as executable files (typically right click/properties/permissions) before running LinuxCNC. Make sure the parallel port pin is not connected to anything in a HAL file.
M101 Example File
#!/bin/bash
# file to turn on parport pin 14 to open the collet closer
halcmd setp parport.0.pin-14-out True
exit 0
M102 Example File
#!/bin/bash
# file to turn off parport pin 14 to open the collet closer
halcmd setp parport.0.pin-14-out False
exit 0
To pass a variable to a M1nn file you use the P and Q option like this:
M100 P123.456 Q321.654
M100 Example file
#!/bin/bash
voltage=$1
feedrate=$2
halcmd setp thc.voltage $voltage
halcmd setp thc.feedrate $feedrate
exit 0
To display a graphic message and stop until the message window is closed use a graphic display program like Eye of Gnome to display the graphic file. When you close it the program will resume.
M110 Example file
#!/bin/bash
eog /home/john/linuxcnc/nc_files/message.png
exit 0
To display a graphic message and continue processing the G-code file suffix an ampersand to the command.
M110 Example display and keep going
#!/bin/bash
eog /home/john/linuxcnc/nc_files/message.png &
exit 0
