1. What is GladeVCP?
GladeVCP is an LinuxCNC component which adds the ability to add a new user interface panel to LinuxCNC user interfaces like:
-Axis
-Touchy
-Gscreen
-GmoccapyUnlike PyVCP, GladeVCP is not limited to displaying and setting HAL pins, as arbitrary actions can be executed in Python code - in fact, a complete LinuxCNC user interface could be built with GladeVCP and Python.
GladeVCP uses the Glade WYSIWYG user interface editor, which makes it easy to create visually pleasing panels. It relies on the PyGTK bindings to the rich GTK+ widget set, and in fact all of these may be used in a GladeVCP application - not just the specialized widgets for interacting with HAL and LinuxCNC, which are documented here.
1.1. PyVCP versus GladeVCP at a glance
Both support the creation of panels with HAL widgets - user interface elements like LED’s, buttons, sliders etc whose values are linked to a HAL pin, which in turn interfaces to the rest of LinuxCNC.
PyVCP:
widget set: uses TkInter widgets
user interface creation: "edit XML file / run result / evaluate looks" cycle
no support for embedding user-defined event handling
no LinuxCNC interaction beyond HAL pin I/O supported
GladeVCP:
widget set: relies on the GTK+ widget set.
user interface creation: uses the Glade WYSIWYG user interface editor
any HAL pin change may be directed to call back into a user-defined Python event handler
any GTK signal (key/button press, window, I/O, timer, network events) may be associated with user-defined handlers in Python
direct LinuxCNC interaction: arbitrary command execution, like initiating MDI commands to call a G-code subroutine, plus support for status change operations through Action Widgets
several independent GladeVCP panels may be run in different tabs
separation of user interface appearance and functionality: change appearance without touching any code
2. A Quick Tour with the Example Panel
GladeVCP panel windows may be run in three different setups:
always visible integrated into Axis at the right side, exactly like PyVCP panels
as a tab in Axis,Touchy, Gscreen, or Gmoccapy; in Axis this would create a third tab besides the Preview and DRO tabs which must be raised explicitly
as a standalone toplevel window, which can be iconifyed/deiconified independent of the main window.
If you’re using an installed version of LinuxCNC the examples shown below are in the configuration picker in the Sample Configurations > apps > gladevcp branch.
The following instructions only apply if you’re using a git checkout. Open a terminal and change to the directory created by git then issue the commands as shown.
| Note | For the following commands to work on your git checkout you must first run make then run sudo make setuid then run . ./scripts/rip-environment. More information about a git checkout is on the linuxcnc wiki page. |
Run the sample GladeVCP panel integrated into Axis like PyVCP as follows:
$ cd configs/sim/axis/gladevcp
$ linuxcnc gladevcp_panel.ini
Run the same panel, but as a tab inside Axis:
$ linuxcnc gladevcp_tab.ini
To run this panel inside Touchy:
$ cd configs/sim/touchy/gladevcp
$ linuxcnc gladevcp_touchy.ini
Functionally these setups are identical - they only differ in screen real estate requirements and visibility. Since it is possible to run several GladeVCP components in parallel (with different HAL component names), mixed setups are possible as well - for instance a panel on the right hand side, and one or more tabs for less-frequently used parts of the interface.
2.1. Exploring the example panel
While running configs/sim/axis/gladevcp_panel.ini or configs/sim/axis/gladevcp_tab.ini, explore Show HAL Configuration - you will find the gladevcp HAL component and may observe their pin values while interacting with the widgets in the panel. The HAL setup can be found in configs/axis/gladevcp/manual-example.hal.
The example panel has two frames at the bottom. The panel is configured so that resetting ESTOP activates the Settings frame and turning the machine on enables the Commands frame at the bottom. The HAL widgets in the Settings frame are linked to LEDs and labels in the Status frame, and to the current and prepared tool number - play with them to see the effect. Executing the T<toolnumber> and M6 commands in the MDI window will change the current and prepared tool number fields.
The buttons in the Commands frame are MDI Action widgets - pressing them will execute an MDI command in the interpreter. The third button Execute Oword subroutine is an advanced example - it takes several HAL pin values from the Settings frame, and passes them as parameters to the Oword subroutine. The actual parameters received by the routine are displayed by (DEBUG, ) commands - see ../../nc_files/oword.ngc for the subroutine body.
To see how the panel is integrated into Axis, see the [DISPLAY]GLADEVCP statement in configs/sim/axis/gladevcp/gladevcp_panel.ini, the [DISPLAY]EMBED* statement in configs/sim/axis/gladevcp/gladevcp_tab.ini and [HAL]POSTGUI_HALFILE statements in both configs/sim/axis/gladevcp/gladevcp_tab.ini and configs/sim/axis/gladevcp/gladevcp_panel.ini
2.2. Exploring the User Interface description
The user interface is created with the glade UI editor - to explore it, you need to have glade installed. To edit the user interface, run the command
$ glade configs/axis/gladevcp/manual-example.ui(The required glade program may be named glade-gtk2 on more recent systems.)
The center window shows the appearance of the UI. All user interface objects and support objects are found in the right top window, where you can select a specific widget (or by clicking on it in the center window). The properties of the selected widget are displayed, and can be changed, in the right bottom window.
To see how MDI commands are passed from the MDI Action widgets, explore the widgets listed under Actions in the top right window, and in the right bottom window, under the General tab, the MDI command property.
2.3. Exploring the Python callback
See how a Python callback is integrated into the example:
in glade, see the hitslabel widget (a plain GTK+ widget)
in the button1widget, look at the Signals tab, and find the signal pressed associated with the handler on_button_press
in hitcounter.py, see the method on_button_press and see how it sets the label property in the hits object
The is just touching upon the concept - the callback mechanism will be handled in more detail in the GladeVCP Programming section.
3. Creating and Integrating a Glade user interface
3.1. Prerequisite: Glade installation
To view or modify Glade UI files, you need glade 3.8.0 installed - it is not needed just to run a GladeVCP panel. If the glade command is missing, install it with the command:
$ sudo apt-get install glade-gtk2Verify the version number to be 3.8.0 or less
 $ glade-gtk2 --version
glade3 3.8.03.2. Running Glade to create a new user interface
This section just outlines the initial LinuxCNC-specific steps. For more information and a tutorial on glade, see http://glade.gnome.org. Some glade tips & tricks may also be found on youtube.
Either modify an existing UI component by running glade <file>.ui
or start a new one by just running the glade command from the shell.
If LinuxCNC was not installed from a package, the LinuxCNC shell environment needs to be set up with . <linuxcncdir>/scripts/rip-environment, otherwise glade won’t find the LinuxCNC-specific widgets.
When asked for unsaved Preferences, just accept the defaults and hit Close.
From Toplevel (left pane), pick Window (first icon) as top level window, which by default will be named window1. Do not change this name - GladeVCP relies on it.
In the left tab, scroll down and expand HAL Python and VCP Actions.
add a container like a HAL_Box or a HAL_Table from HAL Python to the frame
pick and place some elements like LED, button, etc. within a container
This will look like so:
Glade tends to write a lot of messages to the shell window, which mostly can be ignored. Select File→Save as, give it a name like myui.ui and make sure it’s saved as GtkBuilder file (radio button left bottom corner in Save dialog). GladeVCP will also process the older libglade format correctly but there is no point in using it. The convention for GtkBuilder file extension is .ui.
3.3. Testing a panel
You’re now ready to give it a try (while LinuxCNC, e.g. Axis is running) it with:
gladevcp myui.uiGladeVCP creates a HAL component named like the basename of the UI
file - myui in this case - unless overridden by the -c <component
name> option.  If running Axis, just try Show HAL configuration and
inspect its pins.
You might wonder why widgets contained a HAL_Hbox or HAL_Table appear
greyed out (inactive). HAL containers have an associated HAL pin which
is off by default, which causes all contained widgets to render
inactive. A common use case would be to associate these container HAL
pins with halui.machine.is-on or one of the halui.mode. signals,
to assure some widgets appear active only in a certain state.
To just activate a container, execute the HAL command setp gladevcp.<container-name> 1.
3.4. Preparing the HAL command file
The suggested way of linking HAL pins in a GladeVCP panel is to
collect them in a separate file with extension .hal. This file is
passed via the POSTGUI_HALFILE= option in the HAL section of your
ini file.
| Caution | Do not add the GladeVCP HAL command file to the Axis [HAL]HALFILE=ini
section, this will not have the desired effect - see the following sections. |
3.5. Integrating into Axis like PyVCP
Place the GladeVCP panel in the righthand side panel by specifying the following in the ini file:
[DISPLAY] # add GladeVCP panel where PyVCP used to live: GLADEVCP= -u ./hitcounter.py ./manual-example.ui [HAL] # HAL commands for GladeVCP components in a tab must be executed via POSTGUI_HALFILE POSTGUI_HALFILE = ./manual-example.hal [RS274NGC] # gladevcp Demo specific Oword subs live here SUBROUTINE_PATH = ../../nc_files/gladevcp_lib
The default HAL component name of a GladeVCP application started with the GLADEVCP option is:  gladevcp.
The command line actually run by Axis in the above configuration is as follows:
halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x {XID} -u ./hitcounter.py ./manual-example.uiYou may add arbitrary gladevcp options here, as long as they dont collide with the above command line options.
It is possible to create a custom HAL component name by adding the -c option:
[DISPLAY] # add GladeVCP panel where PyVCP used to live: GLADEVCP= -c example -u ./hitcounter.py ./manual-example.ui
The command line actually run by Axis for the above is:
halcmd loadusr -Wn example gladevcp -c example -x {XID} -u ./hitcounter.py ./manual-example.ui| Note | The file specifiers like ./hitcounter.py, ./manual-example.ui, etc. indicate that the files are located in the same directory as the ini file. You might have to copy them to you directory (alternatively, specify a correct absolute or relative path to the file(s)) |
| Note | The [RS274NGC]SUBROUTINE_PATH=option is only set so the example
panel will find the Oword subroutine (oword.ngc) for the MDI Command widget. It
might not be needed in your setup.  The relative path specifier ../../nc_files/gladevcp_lib
is constructed to work with directories copied by the configuration picker and when
using a run-in-place setup. |
3.6. Embeding as a Tab
To do so, edit your .ini file and add to the DISPLAY and HAL sections of ini file as follows:
[DISPLAY] # add GladeVCP panel as a tab next to Preview/DRO: EMBED_TAB_NAME=GladeVCP demo EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x {XID} -u ./gladevcp/hitcounter.py ./gladevcp/manual-example.ui [HAL] # HAL commands for GladeVCP components in a tab must be executed via POSTGUI_HALFILE POSTGUI_HALFILE = ./gladevcp/manual-example.hal [RS274NGC] # gladevcp Demo specific Oword subs live here SUBROUTINE_PATH = ../../nc_files/gladevcp_lib
Note the halcmd loadusr way of starting the tab command - this assures that POSTGUI_HALFILE will only be run after the HAL component is ready. In rare cases you might run a a command here which uses a tab but does not have an associated HAL component. Such a command can be started without halcmd loadusr, and this signifies to Axis that it does not have to wait for a HAL component since there is none.
When changing the component name in the above example, note that the
names used in -Wn <component> and -c <component> must be
identical.
Try it out by running Axis - there should be a new tab called GladeVCP demo near the DRO tab. Select that tab, you should see the example panel nicely fit within Axis.
| Note | Make sure the UI file is the last option passed to GladeVCP in
both the GLADEVCP=andEMBED_TAB_COMMAND=statements. |
3.7. Integrating into Touchy
To do add a GladeVCP tab to Touchy, edit your .ini file as follows:
[DISPLAY] # add GladeVCP panel as a tab EMBED_TAB_NAME=GladeVCP demo EMBED_TAB_COMMAND=gladevcp -c gladevcp -x {XID} -u ./hitcounter.py -H ./gladevcp-touchy.hal ./manual-example.ui [RS274NGC] # gladevcp Demo specific Oword subs live here SUBROUTINE_PATH = ../../nc_files/gladevcp_lib
Note the following differences to the Axis tab setup:
The HAL command file is slightly modified since Touchy does not use the halui components so its signals are not available and some shortcuts have been taken.
there is no POSTGUI_HALFILE= ini option, but passing the HAL command file on the EMBED_TAB_COMMAND= line is ok
the halcmd loaduser -Wn … incantation is not needed.
4. GladeVCP command line options
See also man gladevcp . These are the gladevcp command line options:
Usage: gladevcp [options] myfile.ui
Options:
- -h, --help
show this help message and exit
- -c NAME
Set component name to NAME. Default is base name of UI file
- -d
Enable debug output
- -g GEOMETRY
Set geometry WIDTHxHEIGHT+XOFFSET+YOFFSET. Values are in pixel units, XOFFSET/YOFFSET is referenced from top left of screen. Use -g WIDTHxHEIGHT for just setting size or -g +XOFFSET+YOFFSET for just position
- -H FILE
execute hal statements from FILE with halcmd after the component is set up and ready
- -m MAXIMUM
force panel window to maximize. Together with the -g geometry option one can move the panel to a second monitor and force it to use all of the screen
- -t THEME
set gtk theme. Default is system theme. Different panels can have different themes. An example theme can be found in the EMC Wiki.
- -x XID
Re-parent GladeVCP into an existing window XID instead of creating a new top level window
- -u FILE
Use File’s as additional user defined modules with handlers
- -U USEROPT
pass USEROPTs to Python modules
5. Understanding the gladeVCP startup process
The integration steps outlined above look a bit tricky, and they are. It does therefore help to understand the startup process of LinuxCNC and how this relates to gladeVCP.
The normal LinuxCNC startup process does the following:
the realtime environment is started
all HAL components are loaded
the HAL components are linked together through the .hal cmd scripts
task, iocontrol and eventually the user interface is started
pre-gladeVCP the assumption was: by the time the UI starts, all of HAL is loaded, plumbed and ready to go
The introduction of gladeVCP brought the following issue:
gladeVCP panels need to be embedded in a master GUI window setup, e.g. Axis, or Touchy, Gscreen, or Gmoccapy (embedded window or as an embedded tab)
this requires the master GUI to run before the gladeVCP window can be hooked into the master GUI
however gladeVCP is also a HAL component, and creates HAL pins of its own.
as a consequence, all HAL plumbing involving gladeVCP HAL pins as source or destination must be run after the GUI has been set up
This is the purpose of the POSTGUI_HALFILE. This ini option is
inspected by the GUIs. If a GUI detects this option, it runs the
corresponding HAl file after any embedded gladVCP panel is set
up. However, it does not check whether a gladeVCP panel is actually
used, in which case the HAL cmd file is just run normally. So if you
do NOT start gladeVCP through GLADEVCP or EMBED_TAB etc, but later
in a separate shell window or some other mechanism, a HAL
command file in POSTGUI_HALFILE will be executed too early. Assuming
gladeVCP pins are referenced herein, this will fail with an error
message indicating that the gladeVCP HAL component is not available.
So, in case you run gladeVCP from a separate shell window (i.e. not started by the GUI in an embedded fashion):
you cannot rely on the POSTGUI_HALFILEini option causing the HAL commands being run at the right point in time, so comment that out in the ini file
explicitly pass the HAL command file which refers to gladeVCP pins to gladeVCP with the -H <halcmd file> option (see previous section).
6. HAL Widget reference
GladeVcp includes a collection of Gtk widgets with attached HAL pins called HAL Widgets, intended to control, display or otherwise interact with the LinuxCNC HAL layer. They are intended to be used with the Glade user interface editor. With proper installation, the HAL Widgets should show up in Glade’s HAL Python widget group. Many HAL specific fields in the Glade General section have an associated mouse-over tool tip.
HAL signals come in two variants, bits and numbers. Bits are off/on signals. Numbers can be "float", "s32" or "u32". For more information on HAL data types see the HAL manual. The GladeVcp widgets can either display the value of the signal with an indicator widget, or modify the signal value with a control widget. Thus there are four classes of GladeVcp widgets that you can connect to a HAL signal. Another class of helper widgets allow you to organize and label your panel.
Widgets for indicating "bit" signals: HAL_LED
Widgets for controlling "bit" signals: HAL_Button HAL_RadioButton HAL_CheckButton
Widgets for indicating "number" signals: HAL_Label, HAL_ProgressBar, HAL_HBar and HAL_VBar, HAL_Meter
Widgets for controlling "number" signals: HAL_SpinButton, HAL_HScale and HAL_VScale, Jog Wheel, Speed Control
Sensitive control widgets: State_Sensitive_Table HAL_Table and HAL_HBox
Tool Path preview: HAL_Gremlin
Widgets to show axis positions: DRO Widget, Combi DRO Widget
Widgets for file handling: IconView File Selection
Widgets for display/edit of all axes offsets: OffsetPage
Widgets for display/edit of all tool offsets: Tooloffset editor
Widget for Gcode display and edit: HAL_Sourceview
widget for MDI input and history display: MDI History
6.1. Widget and HAL pin naming
Most HAL widgets have a single associated HAL pin with the same HAL name as the widget (glade: General→Name).
Exceptions to this rule currently are.
HAL_Spinbutton and HAL_ComboBox, which have two pins: a <widgetname>-f(float) and a<widgetname>-s(s32) pin
HAL_ProgressBar, which has a <widgetname>-valueinput pin, and a<widgetname>-scaleinput pin.
6.2. Python attributes and methods of HAL Widgets
HAL widgets are instances of GtKWidgets and hence inherit the methods, properties and signals of the applicable GtkWidget class. For instance, to figure out which GtkWidget-related methods, properties and signals a HAL_Button has, lookup the description of GtkButton in the PyGtk Reference Manual.
An easy way to find out the inheritance relationship of a given HAL widget is as follows: run glade, place the widget in a window, and select it; then choose the Signals tab in the Properties window. For example, selecting a HAL_LED widget, this will show that a HAL_LED is derived from a GtkWidget, which in turn is derived from a GtkObject, and eventually a GObject.
HAL Widgets also have a few HAL-specific Python attributes:
- hal_pin
the underlying HAL pin Python object in case the widget has a single pin type
- hal_pin_s, hal_pin_f
the S32 and float pins of the HAL_Spinbutton and HAL_ComboBox widgets - note these widgets do not have a hal_pin attribute!
- hal_pin_scale
the float input pin of HAL_ProgressBar widget representing the maximum absolute value of input.
The are several HAL-specific methods of HAL Widgets, but the only relevant method is:
- <halpin>.get()
Retrieve the value of the current HAL pin, where <halpin> is the applicable HAL pin name listed above.
6.3. Setting pin and widget values
As a general rule, if you need to set a HAL output widget’s value from
Python code, do so by calling the underlying Gtk setter (e.g.
set_active(), set_value()) - do not try to set the associated pin’s
value by halcomp[pinname] = value directly because the widget will not
take notice of the change!.
It might be tempting to set HAL widget input pins programmatically. Note this defeats the purpose of an input pin in the first place - it should be linked to, and react to signals generated by other HAL components. While there is currently no write protection on writing to input pins in HAL Python, this doesn’t make sense. You might use setp pinname value in the associated halfile for testing though.
It is perfectly OK to set an output HAL pin’s value with
halcomp[pinname] = value provided this HAL pin is not associated with a
widget, that is, has been created by the
hal_glib.GPin(halcomp.newpin(<name>,<type>,<direction>) method (see
GladeVCP Programming for an example).
6.4. The hal-pin-changed signal
Event-driven programming means that the UI tells your code when "something happens" - through a callback, like when a button was pressed. The output HAL widgets (those which display a HAL pin’s value) like LED, Bar, VBar, Meter etc, support the hal-pin-changed signal which may cause a callback into your Python code when - well, a HAL pin changes its value. This means there’s no more need for permanent polling of HAL pin changes in your code, the widgets do that in the background and let you know.
Here is an example how to set a hal-pin-changed signal for a HAL_LED
in the Glade UI editor:
The example in configs/apps/gladevcp/complex shows how
this is handled in Python.
6.5. Buttons
This group of widgets are derived from various Gtk buttons and consists of HAL_Button, HAL_ToggleButton, HAL_RadioButton and CheckButton widgets. All of them have a single output BIT pin named identical to the widget. Buttons have no additional properties compared to their base Gtk classes.
HAL_Button: instantaneous action, does not retain state. Important signal: pressed
HAL_ToggleButton, HAL_CheckButton: retains on/off state. Important signal: toggled
HAL_RadioButton: a one-of-many group. Important signal: toggled(per button).
Important common methods: set_active(),get_active()
Important properties: label,image
Check button:
Radio buttons:
Toggle button:
| Tip | Defining radio button groups in Glade: - decide on default active button - in the other button’s General→Group select the default active button’s name in the Choose a Radio Button in this project dialog. See configs/apps/gladevcp/by-widget/for a GladeVCP applications
and UI file for working with radio buttons. |
6.6. Scales
HAL_HScale and HAL_VScale are derived from the GtkHScale and GtkVScale
respectively.
- <widgetname>
out FLOAT pin
- <widgetname>-s
out S32 pin
To make a scale useful in Glade, add an Adjustment
(General→Adjustment→New or existing adjustment) and edit the
adjustment object. It defines the default/min/max/increment
values. Also, set adjustment Page size and Page increment to zero
to avoid warnings.
Example HAL_HScale:
6.7. SpinButton
HAL SpinButton is derived from GtkSpinButton and holds two pins:
- <widgetname>-f
out FLOAT pin
- <widgetname>-s
out S32 pin
To be useful, Spinbuttons need an adjustment value like scales, see above.
Example SpinButton:
6.8. Hal_Dial
The hal_dial widget simulates a jogwheel or adjustment dial.
It can be operated with the mouse. You can just use the mouse wheel, while the mouse cursor is over the Hal_Dial widget,
or you hold the left mouse button and move the cursor in circular direction to increase or degrease the counts.
By double clicking the left or right button the scale factor can be increased or decreased.
Counterclockwise = reduce counts
Clockwise = increase counts
Wheel up = increase counts
Wheel down = reduce counts
left Double Click = x10 scale
Right Double Click = /10 scale
Hal_Dial exports it's count value as hal pins:
<widgetname>::
   out S32 pin
<widgetname>-scaled::
   out FLOAT pin
<widgetname>-delta-scaled::
   out FLOAT pinIt has the following properties:
- cpr
Sets the Counts per Revolution, allowed values are in the range from 25 to 360
 default = 100
- show_counts
Set this to False, if you want to hide the counts display in the middle of the widget.
 default = True
- label
Set the content of the label witch may be shown over the counts value.
 If the label given is longer than 15 Characters, it will be cut to 15 Characters.
 default = blank
- center_color
This allows one to change the color of the wheel. It uses a GDK color string.
 default = #bdefbdefbdef (gray)
- count_type_shown
There are three counts available 0) Raw CPR counts 1) Scaled counts 2) Delta scaled counts.
 default = 1-
count is based on the CPR selected - it will count positive and negative. It is available as a S32 pin.
Scaled-count is CPR count times the scale - it can be positive and negative.
 If you change the scale the output will immediately reflect the change. It is available as a FLOAT pin.
Delta-scaled-count is cpr count CHANGE, times scale.
 If you change the scale, only the counts after that change will be scaled and then added to the current value.
- scale_adjustable
Set this to False if you want to disallow scale changes by double clicking the widget.
 If this is false the scale factor will not show on the widget.
 default = True
- scale
Set this to scale the counts.
 default = 1.0
- Direct program control
There are ways to directly control the widget using Python. Using goobject to set the above listed properties: [widget name].set_property("cpr",int(value)) [widget name].set_property("show_counts, True) [widget name].set_property("center_color",gtk.gdk.Color('#bdefbdefbdef')) [widget name].set_property('label', 'Test Dial 12345') [widget name].set_property('scale_adjustable', True) [widget name].set_property('scale', 10.5) [widget name].set_property('count_type_shown', 0)There are python methods: [widget name].get_value() Will return the counts value as a s32 integer [widget name].get_scaled_value() Will return the counts value as a float [widget name].get_delta_scaled_value() Will return the counts value as a float [widget name].set_label("string") Sets the label content with "string"There are two GObject signals emitted: count_changed emitted when the widget's count changes eg. from being wheel scrolled. scale_changed emitted when the widget's scale changes eg. from double clicking. + connect to these like so: [widget name].connect('count_changed', [count function name]) [widget name].connect('scale_changed', [scale function name]) + The callback functions would use this pattern: def [count function name](widget, count,scale,delta_scale): This will return: the widget, the current count, scale and delta scale of that widget.
Example Hal_Dial:
6.9. Jog Wheel
The jogwheel widget simulates a real jogwheel.
It can be operated with the mouse. You can just use the mouse wheel, while the mouse cursor is over the JogWheel widget,
or you push the left mouse button and move the cursor in circular direction to increase or degrease the counts.
As moving the mouse the drag and drop way may be faster than the widget can update itself, you may loose counts turning to fast. It is recommended to use the mouse wheel, and only for very rough movements the drag and drop way.
JogWheel exports it’s count value as hal pin:
- <widgetname>-s
out S32 pin
- size
Sets the size in pixel of the widget, allowed values are in the range of 100 to 500 default = 200
- cpr
Sets the Counts per Revolution, allowed values are in the range from 25 to 100 default = 40
- show_counts
- label
Set the content of the label witch may be shown over the counts value. The purpose is to give the user an idea about the usage of that jogwheel. If the label given is longer than 12 Characters, it will be cut to 12 Characters.
There a couple ways to directly control the widget using Python. Using gobject to set the above listed properties: [widget name].set_property("size",int(value)) [widget name].set_property("cpr",int(value)) [widget name].set_property("show_counts, True)There are two python methods: [widget name].get_value() Will return the counts value as integer [widget name].set_label("string") Sets the label content with "string"
Example JogWheel:
6.10. Speed Control
SpeedControl is a widget specially made to control an adjustment with a touch screen. It is a replacement to the normal scale widget witch is difficult to slide on a touch screen.
The value is controlled with two button to increase or decrease the value. The Increment will change as long a button is pressed. The value of each increment as well as the time between two changes can be set using the widget properties.
SpeedControl offers some hal pin:
- <widgetname>-value
out float pin The shown value of the widget
- <widgetname>-scaled-value
out float pin The shown value divided by the scale value, this is very useful, if the velocity is shown in units / min, but linuxcnc expects it to be in units / second
in float pin The scale to apply Default is 60
- <widgetname>-increase
in bit pin As long as the pin is true, the value will increase Very handy with connected momentary switch
- <widgetname>-decrease
in bit pin As long as the pin is true, the value will decrease Very handy with connected momentary switch
- height
integer The height of the widget in pixel allowed values are 24 to 96 default is 36
- value
float The start value to set allowed values are in the range from 0.001 to 99999.0 default is 10.0
- min
float The min allowed value allowed values are 0.0 to 99999.0 default is 0.0 If you change this value, the increment will be reseted to default, so it might be necessary to set afterwards a new increment.
- max
float The max allowed value allowed values are 0.001 to 99999.0 default is 100.0 If you change this value, the increment will be reseted to default, so it might be necessary to set afterwards a new increment.
- increment
float sets the applied increment per mouse click allowed values are 0.001 to 99999.0 and -1 default is -1 resulting in 100 increments from min to max
- inc_speed
integer Sets the timer delay for the increment speed holding pressed the buttons allowed values are 20 to 300 default is 100
- unit
string Sets the unit to be shown in the bar after the value any string is allowed default is ""
- color
Color Sets the color of the bar any hex color is allowed default is "#FF8116"
- template
String Text template to display the value Python formatting is used Any allowed format default is "%.1f"
- do_hide_button
Boolean Whether to show or hide the increment an decrement button True or False Default = False
There a couple ways to directly control the widget using Python. Using gobject to set the above listed properties: [widget name].set_property("do_hide_button",bool(value)) [widget name].set_property("color","#FF00FF") [widget name].set_property("unit", "mm/min") etc.There are also python methods to modify the widget: [widget name].set_adjustment(gtk-adjustment) You can assign a existing adjustment to the control, that way it is easy to replace existing sliders without many code changes. Be aware, that after changing the adjustment you may need to set a new increment, as it will be reseted to its default (100 steps from MIN to MAX) [widget name].get_value() Will return the counts value as float [widget name].set_value(float(value)) Sets the widget to the commanded value [widget name].set_digits(int(value)) Sets the digits of the value to be used [widget name].hide_button(bool(value)) Hide or show the button
Example Speedcontrol:
6.11. Label
HAL_Label is a simple widget based on GtkLabel which represents a HAL pin value in a user-defined format.
- label_pin_type
The pin’s HAL type (0:S32, 1:float, 2:U32), see also the tooltip on 'General→HAL pin type '(note this is different from PyVCP which has three label widgets, one for each type).
- text_template
Determines the text displayed - a Python format string to convert the pin value to text. Defaults to %s(values are converted by the str() function) but may contain any legit as an argument to Pythons format() method.
 Example:Distance: %.03fwill display the text and the pin value with 3 fractional digits padded with zeros for a FLOAT pin.
6.12. Containers
HAL_HideTable
HAL_Table State_Sensitive_Table
HAL_HBox
These containers are meant to be used to sensitize (grey out) or hide their children.
Insensitived children will not respond to input.
HAL_HideTable has one HAL BIT input pin which controls if it’s child widgets are hidden or not.
- <Panel_basename>.<widgetname>
If the pin is low then child widgets are visible which is the default state.
HAL_Table and HAL_Hbox have one HAL BIT input pin which controls if their child widgets are sensitive or not.
These widgets’s pin name uses the convention:
If the pin is low then child widgets are inactive which is the default state.
State_Sensitive_table responds to the state to linuxcnc’s interpreter.
optionally selectable to respond to must-be-all-homed,must-be-on and must-be-idle
You can combine them. It will always be insensitive at Estop.
* HAL_Hbox is depreceiated - use HAL_Table.
If current panels use it it won’t fail. You just won’t find it in the GLADE editor anymore.
Future vesions of gladeVCP may remove this widget completely and then you will need to update the panel.
| Tip | If you find some part of your GladeVCP application is grayed out (insensitive), see whether a HAL_Table pin is unset or unconnected. |
6.13. LED
The hal_led simulates a real indicator LED.
It has a single input BIT pin which controls it’s state: ON or OFF.
LEDs have several properties which control their look and feel:
- on_color
a String defining ON color of LED. May be any valid gtk.gdk.Color name. Not working on Ubuntu 8.04.
- off_color
String defining OFF color of LED. May be any valid gtk.gdk.Color name or special value dark.darkmeans that OFF color will be set to 0.4 value of ON color. Not working on Ubuntu 8.04.
- pick_color_on, pick_color_off
Colors for ON and OFF states may be represented as #RRRRGGGGBBBBstrings. These are optional properties which have precedence overon_colorandoff_color.
- led_size
LED radius (for square - half of LED’s side)
- led_shape
LED Shape. Valid values are 0 for round, 1 for oval and 2 for square shapes.
- led_blink_rate
if set and LED is ON then it’s blinking. Blink period is equal to "led_blink_rate" specified in milliseconds.
- create hal pin
select/deselect making of HAL pin to control LED. With no HAL pin created LED can be controlled with a python function. As an input widget, LED also supports the hal-pin-changed signal. If you want to get a notification in your code when the LED’s HAL pin was changed, then connect this signal to a handler, for exampleon_led_pin_changedand provide the handler as follows:
def on_led_pin_changed(self,hal_led,data=None): print "on_led_pin_changed() - HAL pin value:",hal_led.hal_pin.get()
This will be called at any edge of the signal and also during program start up to report the current value.
Example LEDs:
6.14. ProgressBar
| Note | This widget might go away. Use the HAL_HBar and HAL_VBar widgets instead. |
The HAL_ProgressBar is derived from gtk.ProgressBar and has two float HAL input pins:
- <widgetname>
the current value to be displayed
- scale
value scale. set maximum absolute value of input. Same as setting the <widgetname>.scale pin. A float, range from -224 to +224.
- green_limit
green zone limit lower limit
- yellow_limit
yellow zone limit lower limit
- red_limit
red zone limit lower limit
- text_template
Text template to display the current value of the <widgetname>pin. Python formatting may be used for dict{"value":value}
Example HAL_ProgressBar:
6.15. ComboBox
HAL_ComboBox is derived from gtk.ComboBox. It enables choice of a value from a dropdown list.
It exports two HAL pins:
- <widgetname>-f
the current value, type FLOAT
- <widgetname>-s
the current value, type S32
It has the following property which can be set in Glade:
- column
the column index, type S32, defaults to -1, range from -1..100 .
In default mode this widgets sets the pins to the index of the chosen list entry. So if your widget has three labels, it may only assume values 0,1 and 2.
In column mode (column > -1), the value reported is chosen from the ListStore array as defined in Glade. So typically your widget definition would have two columns in the ListStore , one with text displayed in the dropdown, and an int or float value to use for that choice.
There’s an example in
configs/apps/by-widget/combobox.{py,ui} which uses column
mode to pick a float value from the ListStore.
If you’re confused like me about how to edit ComboBox ListStores and CellRenderer, see http://www.youtube.com/watch?v=Z5_F-rW2cL8.
6.16. Bars
HAL Bar and VBar widgets for horizontal and vertical bars representing float values. They have one input FLOAT hal pin. Both bars have the following properties:
- invert
Swap min and max direction. An inverted HBar grows from right to left, an inverted VBar from top to bottom.
- min, max
Minimum and maximum value of desired range. It is not an error condition if the current value is outside this range.
- show limits
Used to select/deselect the limits text on bar.
- zero
Zero point of range. If it’s inside of min/max range then the bar will grow from that value and not from the left (or right) side of the widget. Useful to represent values that may be both positive or negative.
- force_width, force_height
Forced width or height of widget. If not set then size will be deduced from packing or from fixed widget size and bar will fill whole area.
- text_template
Like in Label sets text format for min/max/current values. Can be used to turn off value display.
- value
Sets the bar display to the value entered: used only for testing in GLADE editor. The vaue will be set from A HAL pin.
- target value
Sets the target line to the value entered: used only for testing in GLADE editor. The value will can be set in a Python function
- target_width
Width of the line that marks the target value.
- bg_color
Background (inactive) color of bar.
- target_color
Color of the the target line.
- z0_color, z1_color, z2_color
Colors of different value zones. Defaults are green,yellowandred. For description of zones seez*_borderproperties.
- z0_border, z1_border
Define up bounds of color zones. By default only one zone is enabled. If you want more then one zone set z0_borderandz1_borderto desired values so zone 0 will fill from 0 to first border, zone 1 will fill from first to second border and zone 2 — from last border to 1. Borders are set as fractions, values from 0 to 1.
Horizontal bar:
 Vertical bar:
Vertical bar:
6.17. Meter
HAL Meter is a widget similar to PyVCP meter - it represents a float value and has one input FLOAT hal pin. HAL Meter has the following properties:
- min, max
- force_size
Forced diameter of widget. If not set then size will be deduced from packing or from fixed widget size and meter will fill all available space with respect to aspect ratio.
- text_template
Like in Label sets text format for current value. Can be used to turn off value display.
- label
Large label above center of meter.
- sublabel
Small label below center of meter.
- bg_color
Background color of meter.
Define up bounds of color zones. By default only one zone is enabled. If you want more then one zone set z0_borderandz1_borderto desired values so zone 0 will fill from min to first border, zone 1 will fill from first to second border and zone 2 — from last border to max. Borders are set as values in range min-max.
Example HAL Meters:
6.18. HAL_Graph
This widget is for plotting values over time.
6.19. Gremlin tool path preview for .ngc files
Gremlin is a plot preview widget similar to the Axis preview window. It assumes a running LinuxCNC environment like Axis or Touchy. To connect to it, inspects the INI_FILE_NAME environment variable. Gremlin displays the current .ngc file - it does monitor for changes and reloads the ngc file if the file name in Axis/Touchy changes. If you run it in a GladeVCP application when LinuxCNC is not running, you might get a traceback because the Gremlin widget can’t find LinuxCNC status, like the current file name.
Gremlin does not export any HAL pins. It has the following properties:
- show tool speed
This displays the tool speed. Defaults true
- show commanded
This selects the DRO to use commanded or actual values. Defaults true
- use metric units
This selects the DRO to use metric or imperial units. Defaults true
- show rapids
This tells the plotter to show the rapid moves. Defaults true
- show DTG
This selects the DRO to display the distance-to-go value. Defaults true
- show relative
This selects the DRO to show values relative to user system or machine cordinates. Defaults true
- show live plot
This tells the plotter to draw or not. Defaults true
- show limits
This tells the plotter to show the machine’s limits. Defaults true
- show lathe radius
This selects the DRO to display the X axis in radius or diameter, if in lathe mode (selectable in the INI file with LATHE = 1). Defaults false
- show extents
This tells the plotter to show the extents. Defaults true
- show tool
This tells the plotter to draw the tool. Defaults true
- show program
TODO
- use joints mode
Used in non trivialkins machines (eg robots). Defaults false
- grid size
Sets the size of the grid. which is only visible in the X, Y and Z view. Defaults to 0
- use default mouse controls
This disables the default mouse controls. This is most useful when using a touchscreen as the default controls do not work well. You can programically add controls using python and the handler file technique. Defaults to True
- view
may be any of x,y, y2 ,z, z2 ,p(perspective) . Defaults tozview.
- enable_dro
boolean; whether to draw a DRO on the plot or not. Defaults to True
- mouse_btn_mode
integer; mouse button handling, leads to different functions of the button 0 = default: left rotate, middle move, right zoom 1 = left zoom, middle move, right rotate 2 = left move, middle rotate, right zoom 3 = left zoom, middle rotate, right move 4 = left move, middle zoom, right rotate 5 = left rotate, middle zoom, right move 6 = left move, middle zoom, right zoom mode 6 is reccomended for plasmas and lathes, as rotation is not needed for such machines
There a couple ways to directly control the widget using Python. Using goobject to set the above listed properties: [widget name].set_property('view','P') [widget name].set_property('metric_units',False) [widget name].set_property('use_default_controls',False) [widget name].set_property('enable_dro' False)) [widget name].set_property('show_program', False) [widget name].set_property('show_limits', False) [widget name].set_property('show_extents_option', False) [widget name].set_property('show_live_plot', False) [widget name].set_property('show_tool', False) [widget name].set_property('show_lathe_radius',True) [widget name].set_property('show_dtg',True) [widget name].set_property('show_velocity',False) [widget name].set_property('mouse_btn_mode', 4)There are python methods: [widget name].show_offsets = True [widget name].grid_size = .75 [widget name].select_fire(event.x,event.y) [widget name].select_prime(event.x,event.y) [widget name].start_continuous_zoom(event.y) [widget name].set_mouse_start(0,0) [widget name].gremlin.zoom_in() [widget name].gremlin.zoom_out() [widget name].get_zoom_distance() [widget name].set_zoom_distance(dist) [widget name].clear_live_plotter() [widget name].rotate_view(x,y) [widget name].pan(x,y)
- Hints
If you set all the plotting options false but show_offsets true you get an offsets page instead of a graphics plot.
If you get the zoom distance before changing the view then reset the zoom distance, it’s much more user friendly.
if you select an element in the preview, the selected element will be used as rotation center point
Example:
6.20. HAL_Offset
The HAL_Offset widget is used to display the offset of a single axis. It has the following properties:
- Joint Number
Used to select which axis (technically which joint) is displayed. On a trivialkins machine (mill, lathe, router) axis vrs joint number are: 0:X 1:Y 2:Z 3:A 4:B 5:C 6:U 7:V 8:W Text template for metric units:: You can use python formatting to display the position with different precision. Text template for imperial units:: You can use python formatting to display the position with different precision. Reference Type:: 0:G5x 1:tool 2:G92 3:Rotation around Z
6.21. DRO widget
The DRO widget is used to display the current axis position. It has the following properties:
- Actual Position
select actual (feedback) position or commanded position.
- Text template for metric units
- Text template for imperial units
- Reference Type
Absolute (machine origin), Relative (to current user coordinate origin - G5x) or Distance-to-go (relative to current user coordinate origin)
- Joint Number
- Display units
Used to toggle the display units between metric and imperial.
- Hints
If you want the display to be right justified, set the X align to 1.0
If you want different colors or size or text change the attributes in the glade editor (eg scale is a good way to change the size of the text)
The background of the widget is actually see through - so if you place if over an image the DRO numbers will show on top of it with no backgroud. There is a special technique to do this. See the animated function diagrams below.
The DRO widget is a modified gtk label widget. As such much or what can be done to a gtk label can be done to DRO widget.
There a couple ways to directly control the widget using Python. Using goobject to set the above listed properties: [widget name].set_property("display_units_mm",True) [widget name].set_property("actual",True) [widget name].set_property("mm_text_template","%f") [widget name].set_property("imperial_text_template","%f") [widget name].set_property("Joint_number",3) [widget name].set_property("reference_type",3)There are two python methods: [widget name].set_dro_inch() [widget name].set_dro_metric()
6.22. Combi_DRO widget
The Combi_DRO widget is used to display the current , the relative axis position and the distance to go in one DRO.
By clicking on the DRO the Order of the DRO will toggle around.
In Relative Mode the actual coordinate system will be displayed.
- joint_number
 On a trivialkins machine (mill, lathe, router) axis vrs. joint number are:
 0:X 1:Y 2:Z etc
- actual
select actual (feedback) or commanded position.
- metric_units
- auto_units
Units will toggle between metric and imperial according to the active gcode being G20 or G21
 default is TRUE
- diameter
Whether to display position as diameter or radius, in diameter mode the DRO will display the joint value multiplied by 2
- mm_text_template
 default is "%10.3f"
- imperial_text_template
 default is "%9.4f"
- homed_color
The foreground color of the DRO numbers if the joint is homed
 default is green
- unhomed_color
The foreground color of the DRO numbers if the joint is not homed
 default is red
- abs_color
the background color of the DRO, if main DRO shows absolute coordinates
 default is blue
- rel_color
the background color of the DRO, if main DRO shows relative coordinates
 default is black
- dtg_color
the background color of the DRO, if main DRO shows distance to go
 default is yellow
- font_size
The font size of the big numbers, the small ones will be 2.5 times smaller, the value must be an integer in the range of 8 to 96,
 default is 25
- toggle_readout
A left mouse click will toggle the DRO readout through the different modes ["Rel", "Abs", "DTG"].
 By unchecking the box you can disable that behavior. The toggling can still be done with [widget name].toggle_readout()
 Value must be bool
 default is TRUE
- cycle_time
The time the DRO waits between two polls, the value must be an integer in the range of 100 to 1000,
 default is 150, this setting should only be changed if you use more
 than 5 DRO at the same time, i.e. on a 6 axis config, to avoid, that
 the DRO slows down the main application too much.
Using gobject to set the above listed properties: [widget name].set_property(property, value)
There are several python methods to control the widget:
[widget name].set_to_inch(state)
    sets the DRO to show imperial units
    state = boolean (True or False)[widget name].set_auto_units(state)
    if True the DRO will change units according to active gcode (G20 / G21)
    Default is True[widget name].set_to_diameter(state)
    if True the DRO will show the diameter not the radius, specially needed for lathes
    the DRO will display the axis value multiplied by 2
    Default is False[widget name].toggle_readout()
    toggles the order of the DRO in the widget[widget name].change_axisletter(letter)
    changes the automatically given axis letter
    very useful to change an lathe DRO from X to R or D
    letter = string[widget name].get_order()
    returns the order of the DRO in the widget mainly used to maintain them consistent
    the order will also be transmitted with the clicked signal
    returns a list containing the order[widget name].set_order(order)
    sets the order of the DRO, mainly used to maintain them consistent
    order = list object, must be one of
      ["DTG", "Rel", "Abs"]
      ["Abs", "DTG", "Rel"]
    Default = ["Rel", "Abs", "DTG"][widget name].get_position()
    returns the position of the DRO as a list of floats
    the order is independent of the order shown on the DRO
    and will be given as [Absolute , relative , DTG]
    Absolute = the machine coordinates, depends on the actual property
             will give actual or commanded position
    Relative = will be the coordinates of the actual coordinate system
    DTG = the distance to go, will mostly be 0, as this function should not be used
        while the machine is moving, because of time delaysThe widget will emit the following signals:
clicked
    This signal is emitted, when the user has clicked on the Combi_DRO widget,
    it will send the following data:
    widget = widget object = The widget object that sends the signal
    joint_number = integer = The joint number of the DRO, where '0:X  1:Y  2:Z  etc'
    order = list object = the order of the DRO in that widget
                          the order may be used to set other Combi_DRO widgets to the same order with [widget name].set_order(order)units_changed
    This signal is emitted, if the DRO units are changed, it will send the following data:
    metric_units = boolean = True if the DRO does display metric units, False in case of imperial displaysystem_changed
    system = string = The actual coordinate system. Will be one of
                      G54 G55 G56 G57 G58 G59 G59.1 G59.2 G59.3
                      or Rel if non has been selected at all, what will only happen in Glade with no linuxcnc runningThere are some information you can get through commands, witch may be of interest for you:
[widget name].system
    The actual system, as mentioned in the system_changed signal[widget name].homed
    True if the joint is homed[widget name].machine_units
    0 if Imperial, 1 if MetricExample, Three Combi_DRO in a window
X = Relative Mode
Y = Absolute Mode
Z = DTG Mode
6.23. IconView (File Select)
This is touch screen friendly widget to select a file and to change directories.
The widget has the following properties:
- icon_size
Sets the size of the displayed icon.
 Allowed values are integers in the range from 12 to 96
 default is 48
- start_dir
Sets the directory to start in when the widget is shown first time,
 must be a string, containing a valid directory path,
 default is "/"
- jump_to_dir
Sets the directory "jump to" directory, witch is selected by the corresponding button in the bottom button list, the 5th button counting from the left,
 default is "~"
- filetypes
Sets the file filter for the objects to be shown
 Must be a string containing a comma separated list of extensions to be shown
 Default is "ngc,py"
- sortorder
Sets the sorting order of the displayed icon must be an integer value from 0 to 3, where
 0 = ASCENDING (sorted according to file names)
 1 = DESCENDING (sorted according to file names)
 2 = FOLDERFIRST (show the folders first, then the files)
 3 = FILEFIRST (show the files first, then the folders),
 Default = 2 = FOLDERFIRST
Using goobject to set the above listed properties: [widget name].set_property(property,Value)
There are python methods to control the widget:
[widget name].show_buttonbox(state)
    if False the bottom button box will be hidden, this is helpful in custom screens,
    with special buttons layouts to not alter the layout of the GUI, good example
    for that is gmoccapy
    Default is True[widget name].show_filelabel(state)
    if True the file label (between the IconView window and the bottom button box will be shown.
    Hiding this label may save place, but showing it is very useful for debugging reasons,
    Default is True[widget name].set_icon_size(iconsize)
    sets the icon size
    must be an integer in the range from 12 to 96
    Default = 48[widget name].set_directory(directory)
    Allows to set an directory to be shown
    directory = string (a valid file path)[widget name].set_filetypes(filetypes)
    sets the file filter to be used, only files with the given extensions will be shown
    filetypes = string containing a comma separated list of extensions
    Default = "ngc,py"[widget name].get_selected()
    Returns the path of the selected file, or None if an directory has been selected[widget name].refresh_filelist()
    Refreshes the filelist, needed if you add a file without changing the directoryIf the button box has been hidden, you can reach the functions of this button through it’s clicked signals like so:
[widget name].btn_home.emit("clicked")
[widget name].btn_jump_to.emit("clicked")
[widget name].btn_sel_prev.emit("clicked")
[widget name].btn_sel_next.emit("clicked")
[widget name].btn_get_selected.emit("clicked")
[widget name].btn_dir_up.emit("clicked")
[widget name].btn_exit.emit("clicked")The widget will emit the following signals:
selected
    This signal is emitted, when the user selects an icon, it will return a string containing a
    file path if a file has been selected, or None if an directory has been selected
sensitive
    This signal is emitted, when the buttons change there state from sensitive to not sensitive or vice versa.
    This signal is useful to maintain surrounding GUI synchronized with the button of the widget. See gmoccapy as example.
    It will return the buttonname and the new state. Buttonname is one of "btn_home", "btn_dir_up", "btn_sel_prev",
    "btn_sel_next", "btn_jump_to" or "btn_select". State is a boolean and will be True or False.
exit
    This signal is Emmit, when the exit button has been pressed to close the IconView
    mostly needed if the application is started as stand alone.Example:
6.24. Calculator widget
This is a simple calculator widget, that can be used for numerical input.
You can preset the display and retrieve the result or that preset value.
- Is editable
This allows the entry display to be typed into from a keyboard.
- Set Font
This allows you to set the font of the display.
There a couple ways to directly control the widget using Python. Using goobject to set the above listed properties: [widget name].set_property("is_editable",True) [widget name].set_property("font","sans 25")There are python methods: [widget name].set_value(2.5) This presets the display and is recorded. [widget name].set_font("sans 25") [widget name].set_editable(True) [widget name].get_value() Returns the calculated value - a float. [widget name].set_editable(True) [widget name].get_preset_value() Returns the recorded value: a float.
6.25. Tooleditor widget
This is a tooleditor widget for displaying and modifying a tool editor file.
If in lathe mode, it will display wear offsets and tool offsets separately.
Wear offsets are designated by tool number above 10000 (Fanuc style)
Note linuxcnc requires remapping of tool calls to actually use wear offsets
It checks the current file once a second to see if linuxcnc updated it.
- Hidden Columns
This will hide the given columns: The columns are designated (in order) as such:
 s,t,p,x,y,z,a,b,c,u,v,w,d,i,j,q,;
 You can hide any number of columns including the select and comments
There a couple ways to directly control the widget using Python. using goobject to set the above listed properties: [widget name].set_properties('hide_columns','uvwijq') This would hide the uvwij and q columns and show all others.There are python methods: [widget name].set_visible("ijq",False) Would hide ij and Q columns and leave the rest as they were. [widget name].set_filename(path_to_file) Sets and loads the tool file. [widget name].reload(None) Reloads the current toolfile [widget name].set_font('sans 16,tab='1') Sets the (Pango) font on the Tab, column title, and tool data. The all_offsets, wear_offsets, tool_offsets can be set at the same time by adding 1,2 and/or 3 to the tab string. Default is all the tabs set. [widget name].set_title_font('sans 16,tab='1') Sets the (Pango) font on the column titles only. The all_offsets, wear_offsets, tool_offsets can be set at the same time by adding 1,2 and/or 3 to the tab string. Default is all the tabs set. [widget name].set_tab_font('sans 16,tab='1') Sets the (Pango) font on the tabs only. The all_offsets, wear_offsets, tool_offsets can be set at the same time by adding 1,2 and/or 3 to the tab string. Default is all the tabs set. [widget name].set_col_visible("abcUVW", False, tab='1') This would hide (False) the abcuvw columns on tab 1 (all_offsets) [widget name].set_lathe_display(value) hides or shows the wear and tool offset tabs used for lathes [widget name].get_toolinfo(toolnum) Returns the tool information array of the requested toolnumber or current tool if no tool number is specified returns None if tool not found in table or if there is no current tool [widget name].hide_buttonbox(self, True) 'convenience' method to hide buttons you must call this after show_all() [widget name].get_selected_tool() return the user selected (highlighted) tool number [widget name].set_selected_tool(toolnumber) Selects (highlights) the requested tool
6.26. Offsetpage
The Offsetpage widget is used to display/edit the offsets of all the axes.
It has convenience buttons for zeroing G92 and Rotation-Around-Z offsets.
It will only allow you to select the edit mode when the machine is on and idle.
You can directly edit the offsets in the table at this time. Unselect the edit
button to allow the OffsetPage to reflect changes.
- Hidden Columns
A no-space list of columns to hide: The columns are designated (in order) as such:
 xyzabcuvwt
 You can hide any of the columns.
- Hidden Rows
A no-space list of rows to hide: the rows are designated (in order) as such
 0123456789abc
 You can hide any of the rows.
- Pango Font
Sets text font type and size
- HighLight color
when editing this is the high light color
- Active color
when OffsetPage detects an active user coordinate system it will use this
 color for the text
There a couple ways to directly control the widget using Python. Using goobject to set the above listed properties: [widget name].set_property("highlight_color",gtk.gdk.Color('blue')) [widget name].set_property("foreground_color",gtk.gdk.Color('black')) [widget name].set_property("hide_columns","xyzabcuvwt") [widget name].set_property("hide_rows","123456789abc") [widget name].set_property("font","sans 25")There are python methods to control the widget: [widget name].set_filename("../../../configs/sim/gscreen/gscreen_custom/sim.var") [widget name].set_col_visible("Yabuvw",False) [widget name].set_row_visible("456789abc",False) [widget name].set_to_mm() [widget name].set_to_inch() [widget name].hide_button_box(True) [widget name].set_font("sans 20") [widget name].set_highlight_color("violet") [widget name].set_foreground_color("yellow") [widget name].mark_active("G55") Allows you to directly set a row to highlight. (eg in case you wish to use your own navigation controls. See <<cha:gmoccapy,Gmoccapy Chapter>> [widget name].selection_mask = ("Tool","Rot","G5x") These rows are NOT selectable in edit mode. [widget name].set_names([['G54','Default'],["G55","Vice1"],['Rot','Rotational']]) This allows you to set the text of the 'T' column of each/any row. This is a list of a list of offset-name/user-name pairs. The default text is the same as the offset name. [widget name].get_names() This returns a list of a list of row-keyword/user-name pairs. The user name column is editable, so saving this list is user friendly. see set_names above.
6.27. HAL_sourceview widget
This is for displaying and simple editing of Gcode.
It looks for .ngc highlight specs in ~/share/gtksourceview-2.0/language-specs/
The current running line will be highlighted.
With external python glue code:
    *It can search for text, undo and redo changes.
    *It can be used for program line selection.
There are python methods to control the widget: [widget name].redo() redo one level of changes. [widget name].undo() undo one level of changes [widget name].text_search(direction=True,mixed_case=True,text='G92') Searches forward (direction = True) or back, + Searches with mixed case (mixed_case = True) or exact match [widget name].set_line_number(linenumber) Sets the line to high light. Uses the sourceview line numbers. [widget name].get_line_number() returns the currently high lighted line. [widget name].line_up() Moves the High lighted line up one line [widget name].line_down() Moves the High lighted line down one line [widget name].load_file('filename') loads a file. Using None (not a filename string) will reload the same program. [widget name].get_filename()
6.28. MDI history
This is for displaying and entering MDI codes.
It will automatically gray out when MDI is not available.
Eg during Estop and program running.
- font_size_tree
a integer value between 8 and 96+ will modify the default font size of the treeview
 to the selected value
- font_size_entry
a integer value between 8 and 96+ will modify the default font size of the entry
- use_double_click
True or False, setting this to True will enable the mouse double click
 feature and a double click on an entry will submit that command
 It is not recommended to use this feature on real machines, as a double
 click on a wrong entry may cause dangerous situations
- Using goobject to set the above listed properties
Using goobject to set the listed properties: [widget name].set_property("font_size_tree", 10) [widget name].set_property("font_size_entry", 20) [widget name].set_property("use_double_click", False)
6.29. Animated function diagrams: HAL widgets in a bitmap
For some applications it might be desirable to have background image - like a functional diagram - and position widgets at appropriate places in that diagram. A good combination is setting a bitmap background image, like from a .png file, making the gladevcp window fixed-size, and use the glade Fixed widget to position widgets on this image.
The code for the below example can be found in configs/apps/gladevcp/animated-backdrop:
7. Action Widgets reference
GladeVcp includes a collection of "canned actions" called VCP Action Widgets for the Glade user interface editor. Other than HAL widgets, which interact with HAL pins, VCP Actions interact with LinuxCNC and the G-code interpreter.
VCP Action Widgets are derived from the Gtk.Action widget. The Action widget in a nutshell:
it is an object available in Glade
it has no visual appearance by itself
it’s purpose: associate a visible, sensitive UI component like menu, toolbutton, button with a command. See these widget’s General→Related Action property.
the "canned action" will be executed when the associated UI component is triggered (button press, menu click..)
it provides an easy way to execute commands without resorting to Python programming.
The appearance of VCP Actions in Glade is roughly as follows:
Tooltip hovers provide a description.
7.1. VCP Action widgets
VCP Action widgets are one-shot type widgets. They implement a single action and are for use in simple buttons, menu entries or radio/check groups.
7.2. VCP Action python
This widget is used to execute small arbitrary python code.
The command string may use special keywords to access important functions.
GSTAT for access to the Gstat library that is used for linuxcnc status
STAT for access to linuxcnc’s status via the linuxcnc python module
CMD for access to linuxcnc’s commands via the linuxcnc python module
EXT for access to the handler file functions if available
linuxcnc for access to the linuxcnc python module
self for access to the widget instance
There are options to select when the widget will be active.
There are options to set the mode before the command is executed.
example command to just print a message to the terminal:
print('action activated')
example command to set the machine to off state:
CMD.state(linuxcnc.STATE_OFF)
example command to call a handler function that passes data:
EXT.on_button_press(self, 100)
You can use a colon to separate multiple commands.
print('Set Machine Off');CMD.state(linuxcnc.STATE_OFF)
7.3. VCP ToggleAction widgets
These are bi-modal widgets. They implement two actions or use a second (usually pressed) state to indicate that currently an action is running. Toggle actions are aimed for use in ToggleButtons, ToggleToolButtons or toggling menu items. A simplex example is the ESTOP toggle button.
Currently the following widgets are available:
The ESTOP toggle sends ESTOP or ESTOP_RESET commands to LinuxCNC depending on it’s state.
The ON/OFF toggle sends STATE_ON and STATE_OFF commands.
Pause/Resume sends AUTO_PAUSE or AUTO_RESUME commands.
The following toggle actions have only one associated command and use the pressed state to indicate that the requested operation is running:
The Run toggle sends an AUTO_RUN command and waits in the pressed state until the interpreter is idle again.
The Stop toggle is inactive until the interpreter enters the active state (is running G-code) and then allows user to send AUTO_ABORT command.
The MDI toggle sends given MDI command and waits for its completion in pressed inactive state.
7.4. The Action_MDI Toggle and Action_MDI widgets
These widgets provide a means to execute arbitrary MDI commands. The Action_MDI widget does not wait for command completion as the Action_MDI Toggle does, which remains disabled until command complete.
7.5. A simple example: Execute MDI command on button press
configs/apps/gladevcp/mdi-command-example/whoareyou.ui is a Glade UI file which conveys the basics:
Open it in Glade and study how it’s done. Start Axis, and then start
this from a terminal window with gladevcp whoareyou.ui. See the
hal_action_mdi1 Action and it’s MDI command property - this just
executes (MSG, "Hi, I’m an VCP_Action_MDI") so there should be a
message popup in Axis like so:
You’ll notice that the button associated with the Action_MDI action is grayed out if the machine is off, in E-Stop or the interpreter is running. It will automatically become active when the machine is turned on and out of E-Stop, and the program is idle.
7.6. Parameter passing with Action_MDI and ToggleAction_MDI widgets
Optionally, MDI command strings may have parameters substituted before they are passed to the interpreter. Parameters currently may be names of HAL pins in the GladeVCP component. This is how it works:
assume you have a HAL SpinBox named speed, and you want to pass it’s current value as a parameter in an MDI command.
The HAL SpinBox will have a float-type HAL pin named speed-f (see HalWidgets description).
To substitute this value in the MDI command, insert the HAL pin name enclosed like so: ${pin-name}
for the above HAL SpinBox, we could use (MSG, "The speed is: ${speed-f}")just to show what’s happening.
The example UI file is configs/apps/gladevcp/mdi-command-example/speed.ui. Here’s what you get when running it:
7.7. An advanced example: Feeding parameters to an O-word subroutine
It’s perfectly OK to call an O-word subroutine in an MDI command, and
pass HAL pin values as actual parameters. An example UI file
is in configs/apps/gladevcp/mdi-command-example/owordsub.ui.
Place nc_files/gladevcp_lib/oword.ngc so Axis can find it, and run gladevcp owordsub.ui from
a terminal window. This looks like so:
7.8. Preparing for an MDI Action, and cleaning up afterwards
The LinuxCNC G-Code interpreter has a single global set of variables, like feed, spindle speed, relative/absolute mode and others. If you use G code commands or O-word subs, some of these variables might get changed by the command or subroutine - for example, a probing subroutine will very likely set the feed value quite low. With no further precautions, your previous feed setting will be overwritten by the probing subroutine’s value.
To deal with this surprising and undesirable side effect of a given
O-word subroutine or G-code statement executed with an LinuxCNC
ToggleAction_MDI, you might associate pre-MDI and post-MDI handlers
with a given LinuxCNC ToggleAction_MDI. These handlers are optional and
provide a way to save any state before executing the MDI Action, and to
restore it to previous values afterwards. The signal names are mdi-command-start
and mdi-command-stop; the handler names can be set in Glade like any
other handler.
Here’s an example how a feed value might be saved and restored by such
handlers (note that LinuxCNC command and status channels are available as
self.linuxcnc and self.stat through the VCP_ActionBase class:
def on_mdi_command_start(self, action, userdata=None): action.stat.poll() self.start_feed = action.stat.settings[1] def on_mdi_command_stop(self, action, userdata=None): action.linuxcnc.mdi('F%.1f' % (self.start_feed)) while action.linuxcnc.wait_complete() == -1: pass
Only the Action_MDI Toggle widget supports these signals.
| Note | In a later release of LinuxCNC, the new M-codes M70-M72 are available which make it saving state before a subroutine call, and restoring state on return much easier. |
7.9. Using the LinuxCNC Stat object to deal with status changes
Many actions depend on LinuxCNC status - is it in manual, MDI or auto mode? is a program running, paused or idle? You cannot start an MDI command while a G-code program is running, so this needs to be taken care of. Many LinuxCNC actions take care of this themselves, and related buttons and menu entries are deactivated when the operation is currently impossible.
When using Python event handlers - which are at a lower level than Actions - one needs to take care of dealing with status dependencies oneself. For this purpose, there’s the LinuxCNC Stat widget: to associate LinuxCNC status changes with event handlers.
LinuxCNC Stat has no visible component - you just add it to your UI with Glade. Once added, you can associate handlers with its following signals:
state-related: emitted when E-Stop condition occurs, is reset, machine is turned on, or is turned off -
state-estop
state-estop-reset
state-on,
state-off
mode-related: emitted when LinuxCNC enters that particular mode -
mode-manual
mode-mdi
mode-auto
interpreter-related: emitted when the G-code interpreter changes into that mode -
interp-run
interp-idle
interp-paused
interp-reading
interp-waiting
file-loaded
line-changed
homing-related: emitted when linuxcnc is homed or not -
all-homed
not-all-homed
8. GladeVCP Programming
8.1. User Defined Actions
Most widget sets, and their associated user interface editors, support the concept of callbacks - functions in user-written code which are executed when something happens in the UI - events like mouse clicks, characters typed, mouse movement, timer events, window hiding and exposure and so forth.
HAL output widgets typically map input-type events like a button press to a value change of the associated HAL pin by means of such a - predefined - callback. Within PyVCP, this is really the only type of event handling supported - doing something more complex, like executing MDI commands to call a G-code subroutine, is not supported.
Within GladeVCP, HAL pin changes are just one type of the general class of events (called signals) in GTK+. Most widgets may originate such signals, and the Glade editor supports associating such a signal with a Python method or function name.
If you decide to use user-defined actions, your job is to write a Python module whose class methods - or in the simple case, just functions - can be referred to in Glade as event handlers. GladeVCP provides a way to import your module(s) at startup and will automatically link your event handlers with the widget signals as set in the Glade UI description.
8.2. An example: adding custom user callbacks in Python
This is just a minimal example to convey the idea - details are laid out in the rest of this section.
GladeVCP can not only manipulate or display HAL pins, you can also write regular event handlers in Python. This could be used, among others, to execute MDI commands. Here’s how you do it:
Write a Python module like so and save as e.g. handlers.py:
nhits = 0 def on_button_press(gtkobj,data=None): global nhits nhits += 1 gtkobj.set_label("hits: %d" % nhits)
In Glade, define a button or HAL button, select the Signals tab, and in the GtkButton properties select the pressed line. Enter on_button_press there, and save the Glade file.
Then add the option -u handlers.py to the gladevcp command line. If your event handlers are spread over several files, just add multiple -u <pyfilename> options.
Now, pressing the button should change its label since it’s set in the callback function.
What the -u flag does: all Python functions in this file are
collected and setup as potential callback handlers for your Gtk widgets
- they can be referenced from Glade Signals tabs. The callback
handlers are called with the particular object instance as parameter,
like the GtkButton instance above, so you can apply any GtkButton
method from there.
Or do some more useful stuff, like calling an MDI command!
8.3. HAL value change events
HAL input widgets, like a LED, automatically associate their HAL pin state (on/off) with the optical appearance of the widget (LED lit/dark).
Beyond this built-in functionality, one may associate a change callback with any HAL pin, including those of predefined HAL widgets. This fits nicely with the event-driven structure of a typical widget application: every activity, be it mouse click, key, timer expired, or the change of a HAL pin’s value, generates a callback and is handled by the same orthogonal mechanism.
For user-defined HAL pins not associated with a particular HAL widget, the signal name is value-changed. See the Adding HAL pins section below for details.
HAL widgets come with a pre-defined signal called hal-pin-changed. See the Hal Widgets section for details.
8.4. Programming model
The overall approach is as follows:
design your UI with Glade, and set signal handlers where you want actions associated with a widget
write a Python module which contains callable objects (see handler models below)
pass your module’s path name to gladevcp with the -u <module> option
gladevcp imports the module, inspects it for signal handlers and connects them to the widget tree
the main event loop is run.
For simple tasks it’s sufficient to define functions named after the Glade signal handlers. These will be called when the corresponding event happens in the widget tree. Here’s a trivial example - it assumes that the pressed signal of a Gtk Button or HAL Button is linked to a callback called on_button_press:
Add this function to a Python file and run as follows:
gladevcp -u <myhandler>.py mygui.uiNote communication between handlers has to go through global variables, which does not scale well and is positively un-pythonic. This is why we came up with the class-based handler model.
The idea here is: handlers are linked to class methods. The underlying class(es) are instantiated and inspected during GladeVCP startup and linked to the widget tree as signal handlers. So the task now is to write:
one or more several class definition(s) with one or several methods, in one module or split over several modules,
a function get_handlers in each module which will return a list of class instances to GladeVCP - their method names will be linked to signal handlers
Here is a minimum user-defined handler example module:
class MyCallbacks : def on_this_signal(self,obj,data=None): print "this_signal happened, obj=",obj def get_handlers(halcomp,builder,useropts): return [MyCallbacks ()]
Now, on_this_signal will be available as signal handler to your widget tree.
For GladevCP panel which respond to HAL inputs it may be important that the handler code can tell that the GladeVCP panel is currently active and displayed. For example a panel inside the Touchy interface might well need to perform an action when the switch connected to touchy.cycle-start is operated (in the same way that the native tabs respond differently to the same button.) To make this possible a signal is sent from the GUI (at the time of writing, only Touchy) to the embedded tab. The signal is of type "Gladevcp" and the two messages sent are "Visible" and "Hidden". (Note that the signals have a fixed length of 20 characters so only the first characters should be used in any comparison, hence the [:7] below.) A sample handler for these signals is:
# This catches our messages from another program def event(self,w,event): print event.message_type,event.data if event.message_type == 'Gladevcp': if event.data[:7] == 'Visible': self.active = True else: self.active = False # connect to client-events from the host GUI def on_map_event(self, widget, data=None): top = widget.get_toplevel() print "map event" top.connect('client-event', self.event)
If during module inspection GladeVCP finds a function get_handlers,
it calls it as follows:
get_handlers(halcomp,builder,useropts)the arguments are:
halcomp - refers to the HAL component under construction
builder - widget tree - result of reading the UI definition (either referring to a GtkBuilder or libglade-type object)
useropts - a list of strings collected from the gladevcp command line -U <useropts>option
GladeVCP then inspects the list of class instances and retrieves their method names. Qualifying method names are connected to the widget tree as signal handlers. Only method names which do not begin with an _ (underscore) are considered.
Note that regardless whether you’re using the libglade or the new
GtkBuilder format for your Glade UI, widgets can always be referred to
as builder.get_object(<widgetname>). Also, the complete list of
widgets is available as builder.get_objects() regardless of UI
format.
8.5. Initialization sequence
It is important to know in which state of affairs your get_handlers()
function is called so you know what is safe to do there and what not.
First, modules are imported and initialized in command line order.
After successful import, get_handlers() is called in the following
state:
the widget tree is created, but not yet realized (no toplevel window.show()has been executed yet)
the halcomp HAL component is set up and all HAL widget’s pins have already been added to it
it is safe to add more HAL pins because halcomp.ready()has not yet been called at this point, so you may add your own pins, for instance in the class__init__()method.
Once all modules have been imported and method names extracted, the following steps happen:
all qualifying method names will be connected to the widget tree with connect_signals()/signal_autoconnect()(depending on the type of UI imported - GtkBuilder vs the old libglade format).
the HAL component is finalized with halcomp.ready()
if a window ID was passed as argument, the widget tree is re-parented to run in this window, and Glade’s toplevel window1 is abandoned (see FAQ)
if a HAL command file was passed with -H halfile, it is executed with halcmd
the Gtk main loop is run.
So when your handler class is initialized, all widgets are existent
but not yet realized (displayed on screen). And the HAL component isn’t
ready as well, so its unsafe to access pins values in your __init__()
method.
If you want to have a callback to execute at program start after it is safe to access HAL pins, then a connect a handler to the realize signal of the top level window1 (which might be its only real purpose). At this point GladeVCP is done with all setup tasks, the halfile has been run, and GladeVCP is about to enter the Gtk main loop.
8.6. Multiple callbacks with the same name
Within a class, method names must be unique. However, it is OK to have
multiple class instances passed to GladeVCP by get_handlers() with
identically named methods. When the corresponding signal occurs, these
methods will be called in definition order - module by module, and
within a module, in the order class instances are returned by
get_handlers().
8.7. The GladeVCP -U <useropts> flag
Instead of extending GladeVCP for any conceivable option which could
potentially be useful for a handler class, you may use the -U
<useroption> flag (repeatedly if you wish). This flag collects a list
of <useroption> strings. This list is passed to the get_handlers()
function (useropts argument). Your code is free to interpret these
strings as you see fit. An possible usage would be to pass them to the
Python exec function in your get_handlers() as follows:
debug = 0 ... def get_handlers(halcomp,builder,useropts): ... global debug # assuming there's a global var for cmd in useropts: exec cmd in globals()
This way you can pass arbitrary Python statements to your module through the gladevcp -U option, for example:
gladevcp -U debug=42 -U "print 'debug=%d' % debug" ...This should set debug to 2 and confirm that your module actually did it.
8.8. Persistent variables in GladeVCP
A annoying aspect of GladeVCP in its earlier form and pyvcp is the fact that you may change values and HAL pins through text entry, sliders, spin boxes, toggle buttons etc, but their settings are not saved and restored at the next run of LinuxCNC - they start at the default value as set in the panel or widget definition.
GladeVCP has an easy-to-use mechanism to save and restore the state of HAL widgets, and program variables (in fact any instance attribute of type int, float, bool or string).
This mechanism uses the popular .ini file format to save and reload persistent attributes.
Imagine renaming, adding or deleting widgets in Glade: an .ini file lying around from a previous program version, or an entirely different user interface, would be not be able to restore the state properly since variables and types might have changed.
GladeVCP detects this situation by a signature which depends on all object names and types which are saved and to be restored. In the case of signature mismatch, a new .ini file with default settings is generated.
8.9. Using persistent variables
If you want any of Gtk widget state, HAL widgets output pin’s values and/or class attributes of your handler class to be retained across invocations, proceed as follows:
import the gladevcp.persistencemodule
decide which instance attributes, and their default values you want to have retained, if any
decide which widgets should have their state retained
describe these decisions in your handler class' init()method through a nested dictionary as follows:
def __init__(self, halcomp,builder,useropts): self.halcomp = halcomp self.builder = builder self.useropts = useropts self.defaults = { # the following names will be saved/restored as method attributes # the save/restore mechanism is strongly typed - the variables type will be derived from the type of the # initialization value. Currently supported types are: int, float, bool, string IniFile.vars : { 'nhits' : 0, 'a': 1.67, 'd': True ,'c' : "a string"}, # to save/restore all widget's state which might remotely make sense, add this: IniFile.widgets : widget_defaults(builder.get_objects()) # a sensible alternative might be to retain only all HAL output widgets' state: # IniFile.widgets: widget_defaults(select_widgets(self.builder.get_objects(), hal_only=True,output_only = True)), }
Then associate an .ini file with this descriptor:
self.ini_filename = __name__ + '.ini' self.ini = IniFile(self.ini_filename,self.defaults,self.builder) self.ini.restore_state(self)
After restore_state(), self will have attributes set if as running the
following:
self.nhits = 0 self.a = 1.67 self.d = True self.c = "a string"
Note that types are saved and preserved on restore. This example assumes that the ini file didn’t exist or had the default values from self.defaults.
After this incantation, you can use the following IniFil methods:
- ini.save_state(obj)
saves objs’s attributes as per IniFil.vars dictionary and the widget state as described in IniFile.widgets in self.defaults
- ini.create_default_ini()
create a .ini file with default values
- ini.restore_state(obj)
restore HAL out pins and obj’s attributes as saved/initialized to default as above
8.10. Saving the state on Gladvcp shutdown
To save the widget and/or variable state on exit, proceed as follows:
select some interior widget (type is not important, for instance a table).
in the Signals tab, select GtkObject. It should show a destroy signal in the first column.
add the handler name, e.g. on_destroy to the second column.
add a Python handler like below:
import gtk ... def on_destroy(self,obj,data=None): self.ini.save_state(self)
This will save state and shutdown GladeVCP properly, regardless whether the panel is embedded in Axis, or a standalone window.
| Caution | Do not use window1(the toplevel window) to connect adestroyevent. Due to the way a GladeVCP panel interacts with Axis
if a panel is embedded within Axis, window1 will not receive destroy
events properly. However, since on shutdown all widgets are
destroyed, anyone will do. Recommended: use a second-level widget -
for instance, if you have a table container in your panel, use
that. |
Next time you start the GladeVCP application, the widgets should come up in the state when the application was closed.
| Caution | The GtkWidget line has a similarly sounding destroy-event - dont use that to connect to the on_destroy handler, it wont work - make sure you use the destroy event from the GtkObject line. |
8.11. Saving state when Ctrl-C is pressed
By default, the reaction of GladeVCP to a Ctrl-C event is to just exit
- without saving state. To make sure that this case is covered, add
a handler call on_unix_signal which will be automatically be called
on Ctrl-C (actuall on the SIGINT and SIGTERM signals). Example
def on_unix_signal(self,signum,stack_frame): print "on_unix_signal(): signal %d received, saving state" % (signum) self.ini.save_state(self)
8.12. Hand-editing .ini files
You can do that, but note that the values in self.defaults override your edits if there is a syntax or type error in your edit. The error is detected, a console message will hint about that happened, and the bad inifile will be renamed to have the .BAD suffix. Subsequent bad ini files overwrite earlier .BAD files.
8.13. Adding HAL pins
If you need HAL pins which are not associated with a specific HAL widget, add them as follows:
import hal_glib ... # in your handler class __init__(): self.example_trigger = hal_glib.GPin(halcomp.newpin('example-trigger', hal.HAL_BIT, hal.HAL_IN))
To get a callback when this pin’s value changes, associate a
value-change callback with this pin, add:
self.example_trigger.connect('value-changed', self._on_example_trigger_change)
and define a callback method (or function, in this case leave out the
self parameter):
# note '_' - this method will not be visible to the widget tree def _on_example_trigger_change(self,pin,userdata=None): print "pin value changed to:" % (pin.get())
8.14. Adding timers
Since GladeVCP uses Gtk widgets which rely on the GObject base class, the full glib functionally is available. Here is an example for a timer callback:
def _on_timer_tick(self,userdata=None): ... return True # to restart the timer; return False for on-shot ... # demonstrate a slow background timer - granularity is one second # for a faster timer (granularity 1 ms), use this: # glib.timeout_add(100, self._on_timer_tick,userdata) # 10Hz glib.timeout_add_seconds(1, self._on_timer_tick)
8.15. Setting HAL widget properties programmatically
With glade, widget properties are typically set fixed while editing. You can, however, set widget properties at runtime, for instance from ini file values, which would typically be done in the handler initialization code. Setting properties from HAL pin values is possible, too.
In the following example (assuming a HAL Meter widget called meter), the
meter’s min value is set from an INI file parameter at startup, and the max value
is set via a HAL pin, which causes the widget’s scale to readjust dynamically:
import linuxcnc import os import hal import hal_glib class HandlerClass: def _on_max_value_change(self,hal_pin,data=None): self.meter.max = float(hal_pin.get()) self.meter.queue_draw() # force a widget redraw def __init__(self, halcomp,builder,useropts): self.builder = builder # hal pin with change callback. # When the pin's value changes the callback is executed. self.max_value = hal_glib.GPin(halcomp.newpin('max-value', hal.HAL_FLOAT, hal.HAL_IN)) self.max_value.connect('value-changed', self._on_max_value_change) inifile = linuxcnc.ini(os.getenv("INI_FILE_NAME")) mmin = float(inifile.find("METER", "MIN") or 0.0) self.meter = self.builder.get_object('meter') self.meter.min = mmin def get_handlers(halcomp,builder,useropts): return [HandlerClass(halcomp,builder,useropts)]
8.16. Examples, and rolling your own GladeVCP application
Visit linuxcnc_root_directory/configs/apps/gladevcp for running
examples and starters for your own projects.
9. FAQ
I get an unexpected unmap event in my handler function right after startup. What’s this? This is a consequence of your Glade UI file having the window1 Visible property set to True, together with re-parenting the GladeVCP window into Axis or touchy. The GladeVCP widget tree is created, including a top level window, and then reparented into Axis, leaving that toplevel window laying around orphaned. To avoid having this useless empty window hanging around, it is unmapped (made invisible), which is the cause of the unmap signal you get. Suggested fix: set window1.visible to False, and ignore an initial unmap event.
My GladeVCP program starts, but no window appears where I expect it to be? The window Axis allocates for GladeVCP will obtain the natural size of all its child widgets combined. It’s the child widget’s job to request a size (width and/or height). However, not all widgets do request a width greater than 0, for instance the Graph widget in its current form. If there’s such a widget in your Glade file and it’s the one which defines the layout you might want to set its width explicitly. Note that setting the window1 width and height properties in Glade does not make sense because this window will be orphaned during re-parenting and hence its geometry will have no impact on layout (see above). The general rule is: if you manually run a UI file with gladevcp <uifile> and its window has reasonable geometry, it should come up in Axis properly as well.
I want a blinking LED, but it wont blink I ticked the checkbutton to let it blink with 100 msec interval. It wont blink, and I get a startup warning: Warning: value "0" of type ‘gint’ is invalid or out of range for property ‘led-blink-rate’ of type ‘gint’? This seems to be a glade bug. Just type over the blink rate field, and save again - this works for me.
My gladevcp panel in Axis doesn’t save state when I close Axis, although I defined an on_destroy handler linked to the window destroy signal Very likely this handler is linked to window1, which due to reparenting isn’t usable for this purpose. Please link the on_destroy handler to the destroy signal of an interior window. For instance, I have a notebook inside window1, and linked on_destroy to the notebooks destroy signal, and that works fine. It doesn’t work for window1.
I want to set the background color or text of a HAL_Label widget depending on its HAL pin value See the example in configs/apps/gladevcp/colored-label. Setting the background color of a GtkLabel widget (and HAL_Label is derived from GtkLabel) is a bit tricky. The GtkLabel widget has no window object of its own for performance reasons, and only window objects can have a background color. The solution is to enclose the Label in an EventBox container, which has a window but is otherwise invisible - see the coloredlabel.ui file.
I defined a hal_spinbuttonwidget in glade, and set a defaultvalueproperty in the corresponding adjustment. It comes up with zero?this is due to a bug in the old Gtk version distributed with Ubuntu 8.04 and 10.04, and is likely to be the case for all widgets using adjustment. The workaround mentione for instance in http://osdir.com/ml/gtk-app-devel-list/2010-04/msg00129.html does not reliably set the HAL pin value, it is better to set it explicitly in an on_realizesignal handler during widget creation. See the example inconfigs/apps/gladevcp/by-widget/spinbutton.{ui,py}.
10. Troubleshooting
make sure you have the development version of LinuxCNC installed. You don’t need the axisrc file any more, this was mentioned in the old GladeVcp wiki page.
run GladeVCP or Axis from a terminal window. If you get Python errors, check whether there’s still a /usr/lib/python2.6/dist-packages/hal.sofile lying around besides the newer/usr/lib/python2.6/dist-packages/_hal.so(note underscore); if yes, remove thehal.sofile. It has been superseded by hal.py in the same directory and confuses the import mechanism.
if you’re using run-in-place, do a make clean to remove any accidentally left over hal.so file, then make.
if you’re using HAL_table or HAL_HBox widgets, be aware they have an HAL pin associated with it which is off by default. This pin controls whether these container’s children are active or not.
11. Implementation note: Key handling in Axis
We believe key handling works OK, but since it is new code, we’re telling about it you so you can watch out for problems; please let us know of errors or odd behavior. This is the story:
Axis uses the TkInter widget set. GladeVCP applications use Gtk widgets and run in a separate process context. They are hooked into Axis with the Xembed protocol. This allows a child application like GladeVCP to properly fit in a parent’s window, and - in theory - have integrated event handling.
However, this assumes that both parent and child application properly support the Xembed protocol, which Gtk does, but TkInter doesn’t. A consequence of this is that certain keys would not be forwarded from a GladeVCP panel to Axis properly under all circumstances. One of these situations was the case when an Entry, or SpinButton widget had focus: in this case, for instance an Escape key would not have been forwarded to Axis and cause an abort as it should, with potentially disastrous consequences.
Therefore, key events in GladeVCP are explicitly handled, and
selectively forwarded to Axis, to assure that such situations cannot
arise. For details, see the keyboard_forward() function in
lib/python/gladevcp/xembed.py.
12. Adding Custom Widgets
The LinuxCNC Wiki has information on adding custom widgets to GladeVCP. GladeVCP Custom Widgets
13. Auxiliary Gladevcp Applications
Support is provided for independently installed gladevcp applications that conform to system directory placements as defined by the LINUXCNC_AUX_GLADEVCP and LINUXCNC_AUX_EXAMPLES items reported by the script linuxcnc_var:
$ linuxcnc_var LINUXCNC_AUX_GLADEVCP
/usr/share/linuxcnc/aux_gladevcp
$ linuxcnc_var LINUXCNC_AUX_EXAMPLES
/usr/share/linuxcnc/aux_examplesThe system directory defined by LINUXCNC_AUX_GLADEVCP (/usr/share/linuxcnc/aux_gladevcp) specifies the location for a gladevcp-compatible python file(s) and related subdirectories. The python file is imported at gladevcp startup and made available to subsequent gladevcp applications including embedded usage in supporting guis.
The system directory defined by LINUXCNC_AUX_EXAMPLES (/usr/share/linuxcnc/aux_examples) specifies the location of example configuration subdirectories used for auxiliary applications. See the getting-started/running-linuxcnc section for Adding Configuration Selection Items.
For testing, a runtime specification of auxiliary applications may be specified using the exported environmental variable: GLADEVCP_EXTRAS. This variable should be a path list of one or more configuration directories separated by a (:). Typically, this variable would be set in a shell starting linuxcnc or in a user’s ~/.profile startup script. Example:
export GLADEVCP_EXTRAS=~/mygladevcp:/opt/othergladevcpFiles found in directories specified with the environmental variable GLADEVCP_EXTRAS supersede identically-named files within subdirectories of the system directory specified by LINUXNC_AUX_GLADEVCP (e.g., /usr/share/linuxcnc/aux_gladevcp). This provision allows a developer to test an application by exporting GLADEVCP_EXTRAS to specify a private application directory without removing a system-installed application directory. Messages inidicating rejected duplicates are printed to stdout.
| Note | Support for auxiliary gladevcp applications requires a python module named importlib. This module may not be available in older installations like Ubuntu-Lucid. |
