1. Commands and Userspace Components
All of the commands in the following list have man pages. Some will have expanded descriptions, some will have limited descriptions. Also, all of the components listed below have man pages. From these two lists you know what components exist, and you can use man n name to get additional information. To view the information in the man page, in a terminal window type:
man axis (or perhaps 'man 1 axis' if your system requires it.)
axis
AXIS LinuxCNC (The Enhanced Machine Controller) Graphical User Interface. |
axis-remote
AXIS Remote Interface. |
comp
Build, compile and install LinuxCNC HAL components. |
emc
LinuxCNC (The Enhanced Machine Controller). |
gladevcp
Virtual Control Panel for LinuxCNC based on Glade, Gtk and HAL widgets. |
gs2
HAL userspace component for Automation Direct GS2 VFD’s. |
halcmd
Manipulate the Enhanced Machine Controller HAL from the command line. |
hal_input
Control HAL pins with any Linux input device, including USB HID devices. |
halmeter
Observe HAL pins, signals, and parameters. |
halrun
halsampler
Sample data from HAL in realtime. |
halstreamer
Stream file data into HAL in real time. |
halui
Observe HAL pins and command LinuxCNC through NML. |
io
Accepts NML I/O commands, interacts with HAL in userspace. |
iocontrol
pyvcp
Virtual Control Panel for LinuxCNC. |
shuttlexpress
control HAL pins with the ShuttleXpress device made by Contour Design. |
2. Realtime Components
Some of these will have expanded descriptions from the man pages. Some will have limited descriptions. All of the components have man pages. From this list you know what components exist and can use man n name to get additional information in a terminal window.
abs
and2
Two-input AND gate. For out to be true both inputs must be true. |
at_pid
Proportional/integral/derivative controller with auto tuning. |
axis
Accepts NML motion commands, interacts with HAL in realtime. |
biquad
Biquad IIR filter |
bldc_hall3
3-wire Bipolar trapezoidal commutation BLDC motor driver using Hall sensors. |
blend
Perform linear interpolation between two values. |
charge_pump
Create a square-wave for the charge pump input of some controller boards. |
clarke2
Two input version of Clarke transform. |
clarke3
Clarke (3 phase to cartesian) transform. |
clarkeinv
Inverse Clarke transform. |
classicladder
Realtime software PLC based on ladder logic. See Classic Ladder manual for more information. |
comp
Two input comparator with hysteresis. |
constant
Use a parameter to set the value of a pin. |
conv_bit_s32
Convert a value from bit to s32. |
conv_bit_u32
Convert a value from bit to u32. |
conv_float_s32
Convert a value from float to s32. |
conv_float_u32
Convert a value from float to u32. |
conv_s32_bit
Convert a value from s32 to bit. |
conv_s32_float
Convert a value from s32 to float. |
conv_s32_u32
Convert a value from s32 to u32. |
conv_u32_bit
Convert a value from u32 to bit. |
conv_u32_float
Convert a value from u32 to float. |
conv_u32_s32
Convert a value from u32 to s32. |
counter
Counts input pulses (deprecated). Use the encoder component See [sec:Encoder]. |
ddt
Compute the derivative of the input function. |
deadzone
Return the center if within the threshold. |
debounce
Filter noisy digital inputs, for more information see [sec:Debounce]. |
edge
Edge detector. |
encoder
Software counting of quadrature encoder signals, for more information see [sec:Encoder]. |
encoder_ratio
An electronic gear to synchronize two axes. |
estop_latch
ESTOP latch. |
feedcomp
Multiply the input by the ratio of current velocity to the feed rate. |
flipflop
D type flip-flop. |
freqgen
Software step pulse generation. |
gantrykins
A kinematics module that maps one axis to multiple joints. |
gearchange
Select from one of two speed ranges. |
genhexkins
Gives six degrees of freedom in position and orientation (XYZABC). The location of the motors is defined at compile time. |
genserkins
Kinematics that can model a general serial-link manipulator with up to 6 angular joints. |
gladevcp
Displays Virtual Control Panels built with GTK/Glade. |
hm2_7i43
HAL driver for the Mesa Electronics 7i43 EPP Anything IO board with HostMot2. |
hm2_pci
HAL driver for the Mesa Electronics 5i20, 5i22, 5i23, 4i65, and 4i68 Anything I/O boards, with HostMot2 firmware. |
hostmot2
HAL driver for the Mesa Electronics HostMot2 firmware. |
hypot
Three-input hypotenuse (Euclidean distance) calculator. |
ilowpass
Low-pass filter with integer inputs and outputs. |
integ
Integrator. |
invert
Compute the inverse of the input signal. |
joyhandle
Sets nonlinear joypad movements, deadbands and scales. |
kins
kinematics definitions for LinuxCNC. |
knob2float
Convert counts (probably from an encoder) to a float value. |
limit1
Limit the output signal to fall between min and max. |
limit2
Limit its slew rate to less than maxv per second. |
limit3
Limit its second derivative to less than MaxA per second squared. |
logic
Experimental general logic function component. |
lowpass
Low-pass filter |
lut5
Arbitrary 5-input logic function based on a look-up table. |
maj3
Compute the majority of 3 inputs. |
match8
8-bit binary match detector. |
maxkins
Kinematics for a tabletop 5 axis mill named max with tilting head (B axis) and horizontal rotary mounted to the table (C axis). Provides UVW motion in the rotated coordinate system. The source file, maxkins.c, may be a useful starting point for other 5-axis systems. |
mesa_7i65
Support for the Mesa 7i65 eight-axis servo card. |
minmax
Track the minimum and maximum values of the input to the outputs. |
motion
mult2
Product of two inputs. |
mux16
Select from one of sixteen input values. |
mux2
Select from one of two input values. |
mux4
Select from one of four input values. |
mux8
Select from one of eight input values. |
near
Determine whether two values are roughly equal. |
not
Inverter. |
offset
Adds an offset to an input, and subtracts it from the feedback value. |
oneshot
One-shot pulse generator. |
or2
Two-input OR gate. |
pid
Proportional/integral/derivative controller, for more information see [sec:PID]. |
pluto_servo
Hardware driver and firmware for the Pluto-P parallel-port FPGA, for use with servos. |
pluto_step
Hardware driver and firmware for the Pluto-P parallel-port FPGA, for use with steppers. |
pumakins
Kinematics for PUMA-style robots. |
pwmgen
Software PWM/PDM generation, for more information see [sec:PWMgen]. |
rotatekins
The X and Y axes are rotated 45 degrees compared to the joints 0 and 1. |
sample_hold
Sample and Hold. |
sampler
Sample data from HAL in real time. |
scale
Applies a scale and offset to its input. |
scarakins
Kinematics for SCARA-type robots. |
select8
serport
Hardware driver for the digital I/O bits of the 8250 and 16550 serial port. |
siggen
Signal generator, for more information see [sec:Siggen]. |
sim_encoder
Simulated quadrature encoder, for more information see [sec:Simulated-Encoder]. |
sphereprobe
Probe a pretend hemisphere. |
stepgen
Software step pulse generation, for more information see [sec:Stepgen]. |
steptest
Used by Stepconf to allow testing of acceleration and velocity values for an axis. |
streamer
sum2
Sum of two inputs (each with a gain) and an offset. |
supply
Set output pins with values from parameters (deprecated). |
thc
Torch Height Control using a Mesa THC card. |
threads
Creates hard realtime HAL threads. |
threadtest
Component for testing thread behavior. |
time
Accumulated run-time timer counts HH:MM:SS of active input. |
timedelay
The equivalent of a time-delay relay. |
timedelta
Component that measures thread scheduling timing behavior. |
toggle2nist
Toggle button to nist logic. |
toggle
Push-on, push-off from momentary pushbuttons. |
tripodkins
The joints represent the distance of the controlled point from three predefined locations (the motors), giving three degrees of freedom in position (XYZ). |
tristate_bit
Place a signal on an I/O pin only when enabled, similar to a tristate buffer in electronics. |
tristate_float
trivkins
There is a 1:1 correspondence between joints and axes. Most standard milling machines and lathes use the trivial kinematics module. |
updown
Counts up or down, with optional limits and wraparound behavior. |
watchdog
Monitor one to thirty-two inputs for a heartbeat. |
wcomp
Window comparator. |
weighted_sum
Convert a group of bits to an integer. |
xor2
Two-input XOR (exclusive OR) gate. |
3. HAL API calls
hal_add_funct_to_thread.3hal hal_bit_t.3hal hal_create_thread.3hal hal_del_funct_from_thread.3hal hal_exit.3hal hal_export_funct.3hal hal_float_t.3hal hal_get_lock.3hal hal_init.3hal hal_link.3hal hal_malloc.3hal hal_param_bit_new.3hal hal_param_bit_newf.3hal hal_param_float_new.3hal hal_param_float_newf.3hal hal_param_new.3hal hal_param_s32_new.3hal hal_param_s32_newf.3hal hal_param_u32_new.3hal hal_param_u32_newf.3hal hal_parport.3hal hal_pin_bit_new.3hal hal_pin_bit_newf.3hal hal_pin_float_new.3hal hal_pin_float_newf.3hal hal_pin_new.3hal hal_pin_s32_new.3hal hal_pin_s32_newf.3hal hal_pin_u32_new.3hal hal_pin_u32_newf.3hal hal_ready.3hal hal_s32_t.3hal hal_set_constructor.3hal hal_set_lock.3hal hal_signal_delete.3hal hal_signal_new.3hal hal_start_threads.3hal hal_type_t.3hal hal_u32_t.3hal hal_unlink.3hal intro.3hal undocumented.3hal
4. RTAPI calls
EXPORT_FUNCTION.3rtapi MODULE_AUTHOR.3rtapi MODULE_DESCRIPTION.3rtapi MODULE_LICENSE.3rtapi RTAPI_MP_ARRAY_INT.3rtapi RTAPI_MP_ARRAY_LONG.3rtapi RTAPI_MP_ARRAY_STRING.3rtapi RTAPI_MP_INT.3rtapi RTAPI_MP_LONG.3rtapi RTAPI_MP_STRING.3rtapi intro.3rtapi rtapi_app_exit.3rtapi rtapi_app_main.3rtapi rtapi_clock_set_period.3rtapi rtapi_delay.3rtapi rtapi_delay_max.3rtapi rtapi_exit.3rtapi rtapi_get_clocks.3rtapi rtapi_get_msg_level.3rtapi rtapi_get_time.3rtapi rtapi_inb.3rtapi rtapi_init.3rtapi rtapi_module_param.3rtapi RTAPI_MP_ARRAY_INT.3rtapi RTAPI_MP_ARRAY_LONG.3rtapi RTAPI_MP_ARRAY_STRING.3rtapi RTAPI_MP_INT.3rtapi RTAPI_MP_LONG.3rtapi RTAPI_MP_STRING.3rtapi rtapi_mutex.3rtapi rtapi_outb.3rtapi rtapi_print.3rtap rtapi_prio.3rtapi rtapi_prio_highest.3rtapi rtapi_prio_lowest.3rtapi rtapi_prio_next_higher.3rtapi rtapi_prio_next_lower.3rtapi rtapi_region.3rtapi rtapi_release_region.3rtapi rtapi_request_region.3rtapi rtapi_set_msg_level.3rtapi rtapi_shmem.3rtapi rtapi_shmem_delete.3rtapi rtapi_shmem_getptr.3rtapi rtapi_shmem_new.3rtapi rtapi_snprintf.3rtapi rtapi_task_delete.3rtpi rtapi_task_new.3rtapi rtapi_task_pause.3rtapi rtapi_task_resume.3rtapi rtapi_task_start.3rtapi rtapi_task_wait.3rtapi undocumented.3rtapi
