Table of Contents
1 GS2 VFD
This is a userspace HAL program for the GS2 series of VFD's at Automation Direct.
This component is loaded using the halcmd "loadusr" command:
loadusr -Wn spindle-vfd gs2_vfd -n spindle-vfd
(loadusr, wait for named to load, component gs2_vfd, named spindle-vfd)
The command-line options are:
Pins where <name> is the name given during loading with the -n option.
Parameters where <name> is the name given during loading with the -n option.
An example of using this component to drive a spindle is in the Hardware Examples section of this manual.
