Libraries are prebuilt Python modules that give added features to QtVCP. In this way you can select what features you want - yet don’t have to build common ones yourself.
1. Status
Status is a library that sends GObject messages based on LinuxCNC’s current state. It is an extension of GladeVCP’s GStat object.
It also has some functions to report status on such things as internal jog rate.
You connect a function call to the STATUS message you are interested in, and QtVCP will call this function when the message is sent from STATUS.
1.1. Использование
Import
Statusmodules
Добавьте этот код Python в раздел импорта:############################ # **** IMPORT SECTION **** # ############################ from qtvcp.core import Status
Instantiate
Statusmodule
Добавьте этот код Python в раздел создания экземпляра:STATUS = Status()
Connect to
STATUSmessages
Use GObject syntax.
1.2. Пример
For example, you can catch machine on and off messages.
 Note
The example below shows the two common ways of connecting signals, one of them using lambda. lambda is used to strip off or manipulate arguments from the status message before calling the function. You can see the difference in the called function signature: The one that uses lambda does not accept the status object - lambda did not pass it to the function. |
Place these commands into the
[INITIALIZE]section of the Python handler file:STATUS.connect('state-on', self.on_state_on) STATUS.connect('state-off', lambda: w, self.on_state_off())
In this example code, when LinuxCNC is in "machine on" state the function
self.on_state_onwill be called.
When LinuxCNC is in "machine off" state the functionself.on_state_offwill be called. -
These would call functions that looks like these:
def on_state_on(self, status_object): print('LinuxCNC machine is on') def on_state_off(self): print('LinuxCNC machine is off')
2. Info
Info— это библиотека для сбора и фильтрации данных из INI-файла.
2.1. Available data and defaults
LINUXCNC_IS_RUNNING
LINUXCNC_VERSION
INIPATH
INI = linuxcnc.ini(INIPATH)
MDI_HISTORY_PATH = '~/.axis_mdi_history'
QTVCP_LOG_HISTORY_PATH = '~/qtvcp.log'
MACHINE_LOG_HISTORY_PATH = '~/.machine_log_history'
PREFERENCE_PATH = '~/.Preferences'
SUB_PATH = None
SUB_PATH_LIST = []
self.MACRO_PATH = None
MACRO_PATH_LIST = []
INI_MACROS = self.INI.findall("DISPLAY", "MACRO")
IMAGE_PATH = IMAGEDIR
LIB_PATH = os.path.join(HOME, "share","qtvcp")
PROGRAM_FILTERS = None
PARAMETER_FILE = None
MACHINE_IS_LATHE = False
MACHINE_IS_METRIC = False
MACHINE_UNIT_CONVERSION = 1
MACHINE_UNIT_CONVERSION_9 = [1]*9
TRAJ_COORDINATES =
JOINT_COUNT = int(self.INI.find("KINS","JOINTS")or 0)
AVAILABLE_AXES = ['X','Y','Z']
AVAILABLE_JOINTS = [0,1,2]
GET_NAME_FROM_JOINT = {0:'X',1:'Y',2:'Z'}
GET_JOG_FROM_NAME = {'X':0,'Y':1,'Z':2}
NO_HOME_REQUIRED = False
HOME_ALL_FLAG
JOINT_TYPE = self.INI.find(section, "TYPE") or "LINEAR"
JOINT_SEQUENCE_LIST
JOINT_SYNC_LIST
JOG_INCREMENTS = None
ANGULAR_INCREMENTS = None
GRID_INCREMENTS
DEFAULT_LINEAR_JOG_VEL = 15 units per minute
MIN_LINEAR_JOG_VEL = 60 units per minute
MAX_LINEAR_JOG_VEL = 300 units per minute
DEFAULT_ANGULAR_JOG_VEL =
MIN_ANGULAR_JOG_VEL =
MAX_ANGULAR_JOG_VEL =
MAX_FEED_OVERRIDE =
MAX_TRAJ_VELOCITY =
AVAILABLE_SPINDLES = int(self.INI.find("TRAJ", "SPINDLES") or 1)
DEFAULT_SPINDLE_0_SPEED = 200
MAX_SPINDLE_0_SPEED = 2500
MAX_SPINDLE_0_OVERRIDE = 100
MIN_SPINDLE_0_OVERRIDE = 50
MAX_FEED_OVERRIDE = 1.5
MAX_TRAJ_VELOCITY
2.2. User message dialog info
USRMESS_BOLDTEXT = self.INI.findall("DISPLAY", "MESSAGE_BOLDTEXT")
USRMESS_TEXT = self.INI.findall("DISPLAY", "MESSAGE_TEXT")
USRMESS_TYPE = self.INI.findall("DISPLAY", "MESSAGE_TYPE")
USRMESS_PINNAME = self.INI.findall("DISPLAY", "MESSAGE_PINNAME")
USRMESS_DETAILS = self.INI.findall("DISPLAY", "MESSAGE_DETAILS")
USRMESS_ICON = self.INI.findall("DISPLAY", "MESSAGE_ICON")
ZIPPED_USRMESS =
self.GLADEVCP = (self.INI.find("DISPLAY", "GLADEVCP")) or None
2.3. Embedded program info
TAB_NAMES = (self.INI.findall("DISPLAY", "EMBED_TAB_NAME")) or None
TAB_LOCATION = (self.INI.findall("DISPLAY", "EMBED_TAB_LOCATION")) or []
TAB_CMD = (self.INI.findall("DISPLAY", "EMBED_TAB_COMMAND")) or None
ZIPPED_TABS =
MDI_COMMAND_LIST =      (heading: [MDI_COMMAND_LIST], title: MDI_COMMAND")
TOOL_FILE_PATH =        (heading: [EMCIO], title:TOOL_TABLE)
POSTGUI_HALFILE_PATH =  (heading: [HAL], title: POSTGUI_HALFILE)
2.4. Helpers
There are some helper functions - mostly used for widget support:
get_error_safe_setting(_self_, _heading_, _detail_, default=_None_) -
convert_metric_to_machine(_data_) -
convert_imperial_to_machine(_data_) -
convert_9_metric_to_machine(_data_) -
convert_9_imperial_to_machine(_data_) -
convert_units(_data_) -
convert_units_9(_data_) -
get_filter_program(_fname_) -
get_qt_filter_extensions() -
Get filter extensions in Qt format.
2.5. Использование
Import
Infomodule
Добавьте этот код Python в раздел импорта:############################ # **** IMPORT SECTION **** # ############################ from qtvcp.core import Info
Instantiate
Infomodule.
добавьте этот код Python в раздел создания экземпляра:########################################### # **** INSTANTIATE LIBRARIES SECTION **** # ########################################### INFO = Info()
Для доступа к информации
INFOиспользуйте следующий общий синтаксис:home_state = INFO.NO_HOME_REQUIRED if INFO.MACHINE_IS_METRIC is True: print('Metric based')
3. Action
Action библиотека используется для управления контроллером движения LinuxCNC.
It tries to hide incidental details and add convenience methods for developers.
3.1. Helpers
There are some helper functions, mostly used for this library’s support:
get_jog_info (_num_) -
jnum_check(_num_) -
ensure_mode(_modes_) -
open_filter_program(_filename_, _filter_) -
Open G-code filter program.
3.2. Использование
Import
Actionmodule
добавьте этот код Python в раздел импорта:############################ # **** IMPORT SECTION **** # ############################ from qtvcp.core import Action
Instantiate
Actionmodule
добавьте этот код Python в раздел создания экземпляра:########################################### # **** INSTANTIATE LIBRARIES SECTION **** # ########################################### ACTION = Action()
Access
ACTIONcommands
Используйте общий синтаксис, например:ACTION.SET_ESTOP_STATE(state) ACTION.SET_MACHINE_STATE(state) ACTION.SET_MACHINE_HOMING(joint) ACTION.SET_MACHINE_UNHOMED(joint) ACTION.SET_LIMITS_OVERRIDE() ACTION.SET_MDI_MODE() ACTION.SET_MANUAL_MODE() ACTION.SET_AUTO_MODE() ACTION.SET_LIMITS_OVERRIDE() ACTION.CALL_MDI(code) ACTION.CALL_MDI_WAIT(code) ACTION.CALL_INI_MDI(number) ACTION.CALL_OWORD() ACTION.OPEN_PROGRAM(filename) ACTION.SAVE_PROGRAM(text_source, fname): ACTION.SET_AXIS_ORIGIN(axis,value) ACTION.SET_TOOL_OFFSET(axis,value,fixture = False) ACTION.RUN() ACTION.ABORT() ACTION.PAUSE() # Toggles pause/resume ACTION.PAUSE_MACHINE() ACTION.RESUME() ACTION.SET_MAX_VELOCITY_RATE(rate) ACTION.SET_RAPID_RATE(rate) ACTION.SET_FEED_RATE(rate) ACTION.SET_SPINDLE_RATE(rate) ACTION.SET_JOG_RATE(rate) ACTION.SET_JOG_INCR(incr) ACTION.SET_JOG_RATE_ANGULAR(rate) ACTION.SET_JOG_INCR_ANGULAR(incr, text) ACTION.SET_SPINDLE_ROTATION(direction = 1, rpm = 100, number = 0) ACTION.SET_SPINDLE_FASTER(number = 0) ACTION.SET_SPINDLE_SLOWER(number = 0) ACTION.SET_SPINDLE_STOP(number = 0) ACTION.SET_USER_SYSTEM(system) ACTION.ZERO_G92_OFFSET() ACTION.ZERO_ROTATIONAL_OFFSET() ACTION.ZERO_G5X_OFFSET(num) ACTION.RECORD_CURRENT_MODE() ACTION.RESTORE_RECORDED_MODE() ACTION.SET_SELECTED_AXIS(jointnum) ACTION.DO_JOG(jointnum, direction) ACTION.JOG(jointnum, direction, rate, distance=0) ACTION.TOGGLE_FLOOD() ACTION.SET_FLOOD_ON() ACTION.SET_FLOOD_OFF() ACTION.TOGGLE_MIST() ACTION.SET_MIST_ON() ACTION.SET_MIST_OFF() ACTION.RELOAD_TOOLTABLE() ACTION.UPDATE_VAR_FILE() ACTION.TOGGLE_OPTIONAL_STOP() ACTION.SET_OPTIONAL_STOP_ON() ACTION.SET_OPTIONAL_STOP_OFF() ACTION.TOGGLE_BLOCK_DELETE() ACTION.SET_BLOCK_DELETE_ON() ACTION.SET_BLOCK_DELETE_OFF() ACTION.RELOAD_DISPLAY() ACTION.SET_GRAPHICS_VIEW(view) ACTION.UPDATE_MACHINE_LOG(text, option=None): ACTION.CALL_DIALOG(command): ACTION.HIDE_POINTER(state): ACTION.PLAY_SOUND(path): ACTION.PLAY_ERROR(): ACTION.PLAY_DONE(): ACTION.PLAY_READY(): ACTION.PLAY_ATTENTION(): ACTION.PLAY_LOGIN(): ACTION.PLAY_LOGOUT(): ACTION.SPEAK(speech): ACTION.BEEP(): ACTION.BEEP_RING(): ACTION.BEEP_START(): ACTION.SET_DISPLAY_MESSAGE(string) ACTION.SET_ERROR_MESSAGE(string) ACTION.TOUCHPLATE_TOUCHOFF(search_vel, probe_vel, max_probe, z_offset, retract_distance, z_safe_travel, rtn_method=None, error_rtn = None)
4. Qhal
A library for HAL component/system interactions.
4.1. Attributes
Вот функции, которые можно вызвать для объекта Qhal:
setUpdateRate(cyclerate) -
Set cycle rate in ms
newPin(name, pin type constant, pin direction constant) -
returns a new QPin object
getPinObject(name) -
returns an existing named QPin object
getValue(name) -
returns the named pin, signal, or parameter’s value, use the full component.pin name.
setPin(name,value) -
sets the named pin’s value, use the full component.pin name.
setSignal(name,value) -
sets the named signal’s value, use the full component.pin name.
makeUniqueName(name) -
returns an unique HAL pin name string by adding -x (a number) to the given pin name string
exit() -
выгрузка компонента
4.2. Constants
Вот доступные константы:
HAL_BIT
HAL_FLOAT
HAL_S32
HAL_U32
HAL_IN
HAL_OUT
HAL_IO
HAL_RO
HAL_RW
4.3. Рекомендации
Available object references:
comp компонентный объект
hal the hal library object
5. QPin
A wrapper class around HAL pins
5.1. Сигналы
There are 3 Qt signals that the QPin pin can be connect to:
value_changed will call a named function with an argument of the current value (depreciated)
pinValueChanged will call a named function with arguments of the pin object and the current value
isDrivenChanged will call a named function with arguments of the pin object and current state when the pin is (un)connected to a driving pin
5.2. Attributes
Вот функции, которые можно вызвать для объекта QPin:
<Pin object>.get() returns the current value of the pin object
<Pin object>.set(X) sets the value of the pin object to the value X
<Pin object>.text() returns the pin name string
5.3. Рекомендации
5.4. Пример
from qtvcp.core import Qhal QHAL = Qhal() ########################################## # Special Functions called from QtVCP ########################################## # at this point: # the widgets are instantiated. # the HAL pins are built but HAL is not set ready def initialized__(self): self.pin_button_in = QHAL.newpin('cycle-start-in',QHAL.HAL_BIT, QHAL.HAL_IN) self.pin_button_in.pinValuechanged.connect(self.buttonChanged) self.pin_button_in.isDrivenChanged.connect(lambda p,s: self.buttonDriven(p,s)) def buttonChanged(self, pinObject, value): print('Pin name:{} changed value to {}'.format(pinObject.text(), value)) def buttonDriven(self, pinObject, state): message = 'not driven by an output pin' if state: message = 'is driven by an output pin' print('Pin name:{} is {}'.format(pinObject.text(), message))
6. Tool
This library handles tool offset file changes.
 Warning
LinuxCNC doesn’t handle third party manipulation of the tool file well. |
6.1. Helpers
GET_TOOL_INFO(_toolnumber_) -
This will return a Python list of information on the requested tool number.
GET_TOOL_ARRAY() -
This return a single Python list of Python lists of tool information.
This is a raw list formed from the system tool file.
ADD_TOOL(_newtool_ = [_-99, 0,'0','0','0','0','0','0','0','0','0','0','0','0', 0,'New Tool'_]) -
This will return a Python tuple of two Python lists of Python lists of tool information:
[0]will be real tools information -
[1]will be wear tools information (tool numbers will be over 10000; Fanuc style tool wear)
By default, adds a blank tool entry with tool number -99.
You can preload thenewtoolarray with tool information. -
DELETE_TOOLS(_toolnumber_) -
Delete the numbered tool.
SAVE_TOOLFILE(_toolarray_) -
This will parse the
toolarrayand save it to the tool file specified in the INI file as the tool path.This tool array must contain all the available tools information.
This array is expected to use the LinuxCNC raw tool array, i.e. it does not feature tool wear entries.
It will return True if there was an error.
CONVERT_TO_WEAR_TYPE(_toolarray_) -
This function converts a LinuxCNC raw tool array to a QtVCP tool array.
QtVCP’s tool array includes entries for X and Z axis tool wear.
LinuxCNC supports tool wear by adding tool wear information into tool entries above 10000.
NoteThis also requires remap code to add the wear offsets at tool change time.  -
CONVERT_TO_STANDARD_TYPE(_toolarray_) -
This function converts QtVCP’s tool array into a LinuxCNC raw tool array.
QtVCP’s array includes entries for X and Z axis tool wear.
NoteThis also requires remap code to add the wear offsets t tool change time.
7. Path
Path module gives reference to important files paths.
7.1. Referenced Paths
PATH.PREFS_FILENAME -
The preference file path.
PATH.WORKINGDIR -
The directory QtVCP was launched from.
PATH.IS_SCREEN -
Is this a screen or a VCP?
PATH.CONFIGPATH -
Launched configuration folder.
PATH.RIPCONFIGDIR -
The Run-in-place config folder for QtVCP screens.
PATH.BASEDIR -
Base folder for LinuxCNC.
PATH.BASENAME -
The Qt Designer files name (no ending).
PATH.IMAGEDIR -
The QtVCP image folder.
PATH.SCREENDIR -
The QtVCP builtin Screen folder.
PATH.PANELDIR -
The QtVCP builtin VCP folder.
PATH.HANDLER -
Handler file Path.
PATH.HANDLERDIR -
Directory where the Python handler file was found.
PATH.XML -
QtVCP UI file path.
PATH.HANDLERDIR -
Directory where the UI file was found.
PATH.QSS -
QtVCP QSS file path.
PATH.PYDIR -
LinuxCNC’s Python library.
PATH.LIBDIR -
The QtVCP library folder.
PATH.WIDGET -
The QtVCP widget folder.
PATH.PLUGIN -
The QtVCP widget plugin folder.
PATH.VISMACHDIR -
Directory where prebuilt Vismach files are found.
Not currently used:
PATH.LOCALEDIR -
Locale translation folder.
PATH.DOMAIN -
Translation domain.
7.2. Helpers
There are some helper functions available:
file_list = PATH.find_vismach_files() directory_list = PATH.find_screen_dirs() directory_list = PATH.find_panel_dirs()
7.3. Использование
Import
Pathmodule
Добавьте этот код Python в раздел импорта:############################ # **** IMPORT SECTION **** # ############################ from qtvcp.core import Path
Instantiate
Pathmodule
Добавьте этот код Python в раздел создания экземпляра:########################################### # **** INSTANTIATE LIBRARIES SECTION **** # ########################################### PATH = Path()
8. VCPWindow
VCPWindow module gives reference to the MainWindow and widgets.
Typically this would be used for a library (e.g., the toolbar library uses it) as the widgets get a reference to the MainWindow from the _hal_init() function.
8.1. Использование
Import
VCPWindowmodule
Добавьте этот код Python в раздел импорта:############################ # **** IMPORT SECTION **** # ############################ from qtvcp.qt_makegui import VCPWindow
Чтобы создать экземпляр
VCPWindowмодуля
добавьте этот код Python в раздел создания экземпляра:########################################### # **** INSTANTIATE LIBRARIES SECTION **** # ########################################### WIDGETS = VCPWindow()
9. Aux_program_loader
Aux_program_loader module allows an easy way to load auxiliary programs LinuxCNC often uses.
9.1. Helpers
load_halmeter() -
Halmeter is used to display one HAL pin data.
Load ahalmeterwith:AUX_PRGM.load_halmeter()
load_ladder() -
Load ClassicLadder PLC program:
AUX_PRGM.load_ladder()
load_status() -
Load LinuxCNC
statusprogram:AUX_PRGM.load_status()
load_halshow() -
Load HALshow, configure display program:
AUX_PRGM.load_halshow()
load_halscope() -
Load HALscope program:
AUX_PRGM.load_halscope()
load_tooledit() -
Load Tooledit program:
AUX_PRGM.load_tooledit(<TOOLEFILE_PATH>)
load_calibration() -
Load Calibration program:
AUX_PRGM.load_calibration()
keyboard_onboard() -
Load onboard/Matchbox keyboard
AUX_PRGM.keyboard_onboard(<ARGS>)
9.2. Использование
Import
Aux_program_loadermodule
############################ # **** IMPORT SECTION **** # ############################ from qtvcp.lib.aux_program_loader import Aux_program_loader
Instantiate
########################################### # **** INSTANTIATE LIBRARIES SECTION **** # ########################################### AUX_PRGM = Aux_program_loader()
10. Keylookup
Keylookup module is used to allow keypresses to control behaviors such as jogging.
It’s used inside the handler file to facilitate creation of key bindings such as keyboard jogging, etc.
10.1. Использование
Keylookup moduleЧтобы импортировать эти модули, добавьте этот код Python в раздел импорта:
############################ # **** IMPORT SECTION **** # ############################ from qtvcp.lib.keybindings import Keylookup
Keylookup moduleTo instantiate Keylookup module* so you can use it, add this Python code to your instantiate section:
########################################### # **** INSTANTIATE LIBRARIES SECTION **** # ########################################### KEYBIND = Keylookup()
 Note
 Add Key Bindings Keylookup requires code under the processed_key_event function to call KEYBIND.call().Most handler files already have this code.  |
In the handler file, under the initialized function use this general syntax to create keybindings:
KEYBIND.add_call("DEFINED_KEY","FUNCTION TO CALL", USER DATA)
Here we add a keybinding for F10, F11 and F12:
########################################## # Special Functions called from QtVCP ########################################## # at this point: # the widgets are instantiated. # the HAL pins are built but HAL is not set ready def initialized__(self): KEYBIND.add_call('Key_F10','on_keycall_F10',None) KEYBIND.add_call('Key_F11','on_keycall_override',10) KEYBIND.add_call('Key_F12','on_keycall_override',20)
And then we need to add the functions that get called.
In the handler file, under the KEY BINDING CALLS section, add this:
##################### # KEY BINDING CALLS # ##################### def on_keycall_F12(self,event,state,shift,cntrl,value): if state: print('F12 pressed') def on_keycall_override(self,event,state,shift,cntrl,value): if state: print('value = {}'.format(value))
10.2. Key Defines
Here is a list of recognized key words. Use the quoted text.
Letter keys use Key_ with the upper or lower letter added.
e.g., Key_a and Key_A.
keys = { Qt.Key_Escape: "Key_Escape", Qt.Key_Tab: "Key_Tab", Qt.Key_Backtab: "Key_Backtab", Qt.Key_Backspace: "Key_Backspace", Qt.Key_Return: "Key_Return", Qt.Key_Enter: "Key_Enter", Qt.Key_Insert: "Key_Insert", Qt.Key_Delete: "Key_Delete", Qt.Key_Pause: "Key_Pause", Qt.Key_Print: "Key_Print", Qt.Key_SysReq: "Key_SysReq", Qt.Key_Clear: "Key_Clear", Qt.Key_Home: "Key_Home", Qt.Key_End: "Key_End", Qt.Key_Left: "Key_Left", Qt.Key_Up: "Key_Up", Qt.Key_Right: "Key_Right", Qt.Key_Down: "Key_Down", Qt.Key_PageUp: "Key_PageUp", Qt.Key_PageDown: "Key_PageDown", Qt.Key_Shift: "Key_Shift", Qt.Key_Control: "Key_Control", Qt.Key_Meta: "Key_Meta", # Qt.Key_Alt: "Key_Alt", Qt.Key_AltGr: "Key_AltGr", Qt.Key_CapsLock: "Key_CapsLock", Qt.Key_NumLock: "Key_NumLock", Qt.Key_ScrollLock: "Key_ScrollLock", Qt.Key_F1: "Key_F1", Qt.Key_F2: "Key_F2", Qt.Key_F3: "Key_F3", Qt.Key_F4: "Key_F4", Qt.Key_F5: "Key_F5", Qt.Key_F6: "Key_F6", Qt.Key_F7: "Key_F7", Qt.Key_F8: "Key_F8", Qt.Key_F9: "Key_F9", Qt.Key_F10: "Key_F10", Qt.Key_F11: "Key_F11", Qt.Key_F12: "Key_F12", Qt.Key_F13: "Key_F13", Qt.Key_F14: "Key_F14", Qt.Key_F15: "Key_F15", Qt.Key_F16: "Key_F16", Qt.Key_F17: "Key_F17", Qt.Key_F18: "Key_F18", Qt.Key_F19: "Key_F19", Qt.Key_F20: "Key_F20", Qt.Key_F21: "Key_F21", Qt.Key_F22: "Key_F22", Qt.Key_F23: "Key_F23", Qt.Key_F24: "Key_F24", Qt.Key_F25: "Key_F25", Qt.Key_F26: "Key_F26", Qt.Key_F27: "Key_F27", Qt.Key_F28: "Key_F28", Qt.Key_F29: "Key_F29", Qt.Key_F30: "Key_F30", Qt.Key_F31: "Key_F31", Qt.Key_F32: "Key_F32", Qt.Key_F33: "Key_F33", Qt.Key_F34: "Key_F34", Qt.Key_F35: "Key_F35", Qt.Key_Super_L: "Key_Super_L", Qt.Key_Super_R: "Key_Super_R", Qt.Key_Menu: "Key_Menu", Qt.Key_Hyper_L: "Key_HYPER_L", Qt.Key_Hyper_R: "Key_Hyper_R", Qt.Key_Help: "Key_Help", Qt.Key_Direction_L: "Key_Direction_L", Qt.Key_Direction_R: "Key_Direction_R", Qt.Key_Space: "Key_Space", Qt.Key_Any: "Key_Any", Qt.Key_Exclam: "Key_Exclam", Qt.Key_QuoteDbl: "Key_QuoteDdl", Qt.Key_NumberSign: "Key_NumberSign", Qt.Key_Dollar: "Key_Dollar", Qt.Key_Percent: "Key_Percent", Qt.Key_Ampersand: "Key_Ampersand", Qt.Key_Apostrophe: "Key_Apostrophe", Qt.Key_ParenLeft: "Key_ParenLeft", Qt.Key_ParenRight: "Key_ParenRight", Qt.Key_Asterisk: "Key_Asterisk", Qt.Key_Plus: "Key_Plus", Qt.Key_Comma: "Key_Comma", Qt.Key_Minus: "Key_Minus", Qt.Key_Period: "Key_Period", Qt.Key_Slash: "Key_Slash", Qt.Key_0: "Key_0", Qt.Key_1: "Key_1", Qt.Key_2: "Key_2", Qt.Key_3: "Key_3", Qt.Key_4: "Key_4", Qt.Key_5: "Key_5", Qt.Key_6: "Key_6", Qt.Key_7: "Key_7", Qt.Key_8: "Key_8", Qt.Key_9: "Key_9", Qt.Key_Colon: "Key_Colon", Qt.Key_Semicolon: "Key_Semicolon", Qt.Key_Less: "Key_Less", Qt.Key_Equal: "Key_Equal", Qt.Key_Greater: "Key_Greater", Qt.Key_Question: "Key_Question", Qt.Key_At: "Key_At", Qt.Key_BracketLeft: "Key_BracketLeft", Qt.Key_Backslash: "Key_Backslash", Qt.Key_BracketRight: "Key_BracketRight", Qt.Key_AsciiCircum: "Key_AsciiCircum", Qt.Key_Underscore: "Key_Underscore", Qt.Key_QuoteLeft: "Key_QuoteLeft", Qt.Key_BraceLeft: "Key_BraceLeft", Qt.Key_Bar: "Key_Bar", Qt.Key_BraceRight: "Key_BraceRight", Qt.Key_AsciiTilde: "Key_AsciiTilde", }
11. Messages
Messages module is used to display pop up dialog messages on the screen.
These messages are:
defined in the INI file under the
[DISPLAY]heading, and -
controlled by HAL pins.
Use this style if you need independent HAL pins for each dialog message.
11.1. Свойства
BOLDTEXT -
Generally is a title.
TEXT -
Text below title, and usually longer.
DETAIL -
Text hidden unless clicked on.
PINNAME -
Basename of the HAL pin(s).
TYPE -
Specifies whether it is a (can have dialog and status options together): status - shown in the status bar and the notify dialog.
Requires no user intervention.-
nonedialog - specifically does not show a dialog.
okdialog - requiring the user to click OK to close the dialog.
OK messages have two HAL pins:-
One HAL pin to launch the dialog, and
one to signify it is waiting for a response. yesnodialog - requiring the user to select yes or no buttons to close the dialog.
Yes/No messages have three HAL pins: -
Один для показа диалога,
One for waiting, and
one for the answer. okcanceldialog - requiring the user to select ok or cancel
Ok/Cancel messages have _three HAL pins: -
one for the answer.
closepromptdialog - requiring the user to select
By default, STATUS messages for focus_overlay and alert sound will be sent when the dialog shows.
This allows screen focus dimming/blurring and sounds to be added to alerts.
11.2. HAL Контакты
Названия контактов HAL будут использовать эти шаблоны:
- <SCREEN BASENAME>.<PINNAME>
вызывая s32 контакт
 - <SCREEN BASENAME>.<PINNAME>-waiting
Waiting for the user’s response output bit pin
 - <SCREEN BASENAME>.<PINNAME>-response
Контакт выходного бита Ответ пользователя
 - <SCREEN BASENAME>.<PINNAME>-response-s32
The user response output s32 pin
11.3. Examples
Here are sample INI message definition code blocks that would be found under the [DISPLAY] heading:
Status bar and desktop notify pop up message:
MESSAGE_BOLDTEXT = NONE MESSAGE_TEXT = This is a statusbar test MESSAGE_DETAILS = STATUS DETAILS MESSAGE_TYPE = status MESSAGE_PINNAME = statustest
Pop up dialog asking a Yes/No question:
MESSAGE_BOLDTEXT = NONE MESSAGE_TEXT = This is a yes no dialog test MESSAGE_DETAILS = Y/N DETAILS MESSAGE_TYPE = yesnodialog MESSAGE_PINNAME = yndialogtest
Pop up dialog asking an OK answer + Status bar and desktop notification:
MESSAGE_BOLDTEXT = This is the short text MESSAGE_TEXT = This is the longer text of the both type test. It can be longer then the status bar text MESSAGE_DETAILS = BOTH DETAILS MESSAGE_TYPE = okdialog status MESSAGE_PINNAME = bothtest
The ScreenOptions widget can automatically set up the message system.
12. multimessages
These messages are:
controlled by one s32 HAL pin per defined id.
each message is called by a corresponding number on the s32 pin.
Use this style of user messages for instance when a VFD sends error messages encoded as numbers.
It uses common invoke/response/wait HAL pins for all (per ID name) multimessage dialogs. The HAL pin names would use these patterns:
- <SCREEN BASENAME>.<ID NAME>
вызывая s32 контакт
 - <SCREEN BASENAME>.<ID NAME>-waiting
 - <SCREEN BASENAME>.<ID NAME>-response
 - <SCREEN BASENAME>.<ID NAME>-response-s32
12.1. Свойства
TITLE -
This is the title shown on the dialog window.
TEXT -
DETAIL -
TYPE -
Specifies type of message the user sees (can have dialog and status options together): status - shown in the status bar and the notify dialog.
OK messages use two HAL pins:-
one to signify it’s waiting for response. yesnodialog - requiring the user to select yes or no buttons to close the dialog.
Yes/No messages use three HAL pins: -
one for the answer.
12.2. Examples
[DISPLAY] MULTIMESSAGE_ID = VFD MULTIMESSAGE_VFD_NUMBER = 1 MULTIMESSAGE_VFD_TYPE = okdialog status MULTIMESSAGE_VFD_TITLE = VFD Error: 1 MULTIMESSAGE_VFD_TEXT = This is the longer text FOR MESSAGE NUMBER 1 MULTIMESSAGE_VFD_DETAILS = DETAILS for VFD error 1 MULTIMESSAGE_VFD_ICON = WARNING MULTIMESSAGE_VFD_NUMBER = 2 MULTIMESSAGE_VFD_TYPE = nonedialog status MULTIMESSAGE_VFD_TITLE = VFD Error: 2 MULTIMESSAGE_VFD_TEXT = This is the longer text FOR MESSAGE NUMBER 2 MULTIMESSAGE_VFD_DETAILS = DETAILS for VFD error 2 MULTIMESSAGE_VFD_ICON = INFO
13. Notify
Notify module is used to send messages that are integrated into the desktop.
It uses the pynotify library.
Ubuntu/Mint does not follow the standard so you can’t set how long the message stays up for.
I suggest fixing this with the notify-osd package available from this PPA (DISCONTINUED due to move of Ubuntu to Gnome).
Notify keeps a list of all the alarm messages since starting in self.alarmpage.
If you click 'Show all messages' in the notify popup, it will print them to the terminal.
The ScreenOptions widget can automatically set up the notify system.
Typically STATUS messages are used to sent notify messages.
13.1. Свойства
You can set the:
title -
Notification message title text.
message -
Notification message content text.
icon -
Notification message icon.
timeout -
How long the message stays up for.
14. Preferences
Preferences module allows one to load and save preference data permanently to storage media.
The ScreenOptions widget can automatically set up the preference system.
QtVCP searches for the ScreenOptions widget first and, if found, calls _pref_init().
This will create the preferences object and return it to QtVCP to pass to all the widgets and add it to the window object attributes.
In this case the preferences object would be accessible from the handler file’s initialized_ method as self.w.PREFS_.
Also all widgets can have access to a specific preferences file at initialization time.
The ScreenOptions widget can automatically set up the preference file.
15. Player
This module allows playing sounds using Gstreamer, beep and Espeak.
It can:
play sound/music files using Gstreamer (non blocking),
play sounds using the
beeplibrary (currently blocks while beeping), -
speak words using the
espeaklibrary (non blocking while speaking).
There are default alert sounds using Mint or FreeDesktop default sounds.
You can play arbitrary sounds or even songs by specifying the path.
STATUS has messages to control Player module.
The ScreenOptions widget can automatically set up the audio system.
15.1. Sounds
There are default alerts to choose from:
ERROR -
READY -
ATTENTION -
RING -
DONE -
LOGIN -
LOGOUT
There are three beeps:
BEEP_RING -
BEEP_START -
BEEP
15.2. Использование
Import
Playermodule
Добавьте этот код Python в раздел импорта:############################ # **** IMPORT SECTION **** # ############################ from qtvcp.lib.audio_player import Player
Instantiate
Playermodule
Добавьте этот код Python в раздел создания экземпляра:########################################### # **** INSTANTIATE LIBRARIES SECTION **** # ########################################### SOUND = Player() SOUND._register_messages()
The
_register_messages()function connects the audio player to theSTATUSlibrary so sounds can be played with theSTATUSmessage system.
15.3. Пример
To play sounds upon STATUS messages, use these general syntaxes:
STATUS.emit('play-alert','LOGOUT') STATUS.emit('play-alert','BEEP') STATUS.emit('play-alert','SPEAK This is a test screen for Q t V C P') STATUS.emit('play-sound', 'PATH TO SOUND')
16. Virtual Keyboard
17. Toolbar Actions
This library supplies prebuilt submenus and actions for toolbar menus and toolbar buttons.
Toolbuttons, menu and toolbar menus are:
built in Qt Designer, and
assigned actions/submenus in the handler file.
17.1. Actions
estop -
power -
load -
reload -
gcode_properties -
run -
pause -
abort -
block_delete -
optional_stop -
touchoffworkplace -
touchofffixture -
runfromline -
load_calibration -
load_halmeter -
load_halshow -
load_status -
load_halscope -
about -
zoom_in -
zoom_out -
view_x -
view_y -
view_y2 -
view_z -
view_z2 -
view_p -
view_clear -
show_offsets -
quit -
system_shutdown -
tooloffsetdialog -
originoffsetdialog -
calculatordialog -
alphamode -
inhibit_selection -
show_dimensions -
Toggles dimensions display.
17.2. Submenus
recent_submenu -
home_submenu -
unhome_submenu -
zero_systems_submenu -
grid_size_submenu -
Menu to set graphic grid size
17.3. Использование
Here is the typical code to add to the relevant handler file sections:
############################ # **** IMPORT SECTION **** # ############################ from qtvcp.lib.toolbar_actions import ToolBarActions ########################################### # **** instantiate libraries section **** # ########################################### TOOLBAR = ToolBarActions()
17.4. Examples
Assigning Tool Actions To Toolbar Buttons
########################################## # Special Functions called from QtVCP ########################################## # At this point: # * the widgets are instantiated, # * the HAL pins are built but HAL is not set ready. def initialized__(self): TOOLBAR.configure_submenu(self.w.menuHoming, 'home_submenu') TOOLBAR.configure_action(self.w.actionEstop, 'estop') TOOLBAR.configure_action(self.w.actionQuit, 'quit', lambda d:self.w.close()) TOOLBAR.configure_action(self.w.actionEdit, 'edit', self.edit) # Add a custom function TOOLBAR.configure_action(self.w.actionMyFunction, 'my_Function', self.my_function)
Add a custom toolbar function:
##################### # GENERAL FUNCTIONS # ##################### def my_function(self, widget, state): print('My function State = ()'.format(state))
18. Qt Vismach Machine Graphics library
Qt_vismach is a set of Python functions that can be used to create and animate models of machines.
Vismach:
displays the model in a 3D viewport
animates the model parts as the values of associated HAL pins change.
This is the Qt based version of the library, there is also a tkinter version available in LinuxCNC.
The Qt version allows embedding the simulation in other screens.
18.1. Builtin Samples
There are included sample panels in QtVCP for:
a 3-Axis XYZ mill,
a 5-Axis gantry mill,
a 3-Axis mill with an A axis/spindle, and
a scara mill.
Most of these samples, if loaded after a running LinuxCNC configuration (including non-QtVCP based screens), will react to machine movement.
Some require HAL pins to be connected for movement.
From a terminal (pick one):
qtvcp vismach_mill_xyz
qtvcp vismach_scara
qtvcp vismach_millturn
qtvcp vismach_5axis_gantry
18.2. Primitives Library
Provides the basic building blocks of a simulated machine.
Collection -
A
collectionis an object of individual machine parts.This holds a hierarchical list of primitive shapes or STL objects that operations can be applied to.
Translate -
This object will perform an OpenGL translation calculation on a Collection object.
Translation refers to moving an object in straight line to a different position on screen.
Scale -
This object will perform an OpenGL scale function on a collection object.
HalTranslate -
This object will perform an OpenGL translation calculation on a Collection object, offset by the HAL pin value.
You can either:
read a pin from a component owned by the Vismach object, or
read a HAL system pin directly if the component argument is set to
None.
Rotate -
This object will perform an OpenGL rotation calculation on a Collection object.
HalRotate -
This object will perform an OpenGL rotation calculation on a Collection object, offset by the HAL pin value.
You can either:
read a pin from a component owned by the vismach object, or
None.
HalToolCylinder -
This object will build a CylinderZ object that will change size and length based on loaded tool dimensition (from the tool table)
It reads the
halui.tool.diameterandmotion.tooloffset.zHAL pins.Example from mill_xyz sample:
toolshape = CylinderZ(0) toolshape = Color([1, .5, .5, .5], [toolshape]) tool = Collection([ Translate([HalTranslate([tooltip], None, "motion.tooloffset.z", 0, 0, -MODEL_SCALING)], 0, 0, 0), HalToolCylinder(toolshape) ])
Track -
Move and rotate an object to point from one
capture()'d coordinate system to another.Base object to hold coordinates for primitive shapes.
CylinderX,CylinderY,CylinderZ -
Build a cylinder on the X, Y or Z axis by giving endpoint (X, Y, or Z) and radii coordinates.
Sphere -
Build a sphere from center and radius coordinates.
TriangleXY,TriangleXZ,TriangleYZ -
Build a triangle in the specified plane by giving the corners Z coordinates for each side.
ArcX -
Build an arc by specifying
Box -
Build a box specified by the 6 vertex coordinates.
BoxCentered -
Build a box centered on origin by specifying the width in X and Y, and the height in Z.
BoxCenteredXY -
Build a box centered in X and Y, and running from Z=0, by specifying the width in X and Y, and running up or down to the specified height in Z.
Capture -
Capture current transformation matrix of a collection.
NoteThis transforms from the current coordinate system to the viewport system, NOT to the world system.  -
Hud -
Heads up display draws a semi-transparent text box.
Use:
HUD.strsfor things that must be updated constantly, -
HUD.show("stuff")for one-shot things like error messages.
Color -
Applies a color to the parts of a collection.
AsciiSTL,AsciiOBJ -
Loads a STL or OBJ data file as a Vismach part.
18.3. Использование
Here is how one might import the XYZ_mill simulation in a QtVCP panel or screen handler file.
############################ # **** IMPORT SECTION **** # ############################ import mill_xyz as MILL
Instantiate the simulation widget and add it to the screen’s main layout:
########################################## # Special Functions called from QtVCP ########################################## # At this point: # * the widgets are instantiated, # * the HAL pins are built but HAL is not set ready. def initialized__(self): machine = MILL.Window() self.w.mainLayout.addWidget(machine)
18.4. More Information
More information on how to build a custom machine simulation in the Qt Vismach chapter.
