Note: This driver will not be compiled into images aimed at non-ARM CPUS. It is only really intended to work on the Raspberry Pi. It may, or may not, work on similar boards or direct clones.
1. Purpose
This driver allows the use of the Rapberry Pi GPIO pins in a way analagous to the parallel port driver on x86 PCs. It can use the same step generators, encoder counters and similar components.
2. Usage
loadrt hal_pi_gpio dir=0x13407 exclude=0x1F64BF8
The "dir" mask determines whether the pins are inputs and outputs, the exclude mask prevents the driver from using the pins (and so allows them to be used for their normal RPi purpses such as SPI or UART)
The mask can be in decimal or hexadecimal (hex may be easier as there will be no carries)
Add up the values for all pins that should be configured as output, and for all pins that should be excluded according to the following table.
GPIO Num
Decimal
Hex
Pin Num
2
1
0x00000001
3
3
2
0x00000002
5
4
4
0x00000004
7
5
8
0x00000008
29
6
16
0x00000010
31
7
32
0x00000020
26
8
64
0x00000040
24
9
128
0x00000080
21
10
256
0x00000100
19
11
512
0x00000200
23
12
1024
0x00000400
32
13
2048
0x00000800
33
14
4096
0x00001000
8
15
8192
0x00002000
10
16
16384
0x00004000
36
17
32768
0x00008000
11
18
65536
0x00010000
12
19
131072
0x00020000
35
20
262144
0x00040000
38
21
524288
0x00080000
40
22
1048576
0x00100000
15
23
2097152
0x00200000
16
24
4194304
0x00400000
18
25
8388608
0x00800000
22
26
16777216
0x01000000
37
27
33554432
0x02000000
13
Note that in the calculation of the masks the GPIO numbers are used. Whereas in the naming of the HAL pins it is the Raspberry Pi header pin numbers.
So, for example, if you enable GPIO 17 as an output (dir=0x200) then that output will be controlled by the hal pin hal_pi_gpio.pin-11-out.
3. Pins
  • hal_pi_gpio.pin-NN-out
  • hal_pi_gpio.pin-NN-in
Depending on the dir and exclude masks.
4. Parameters
Only the standard timing parameters which are created for all components exist.
*hal_pi_gpio.read.tmax *hal_pi_gpio.read.tmax-increased *hal_pi_gpio.write.tmax *hal_pi_gpio.write.tmax-increased
For unknown reasons the driver also creates HAL pins to indicate timing
*hal_pi_gpio.read.time *hal_pi_gpio.write.time
5. Functions
  • hal_pi_gpio.read - Add this to the base thread to update the HAL pin values to match the physical input values.
  • hal_pi_gpio.write - Add this to the base thread to update the physical pins to match the HAL values.
Typically the read function will be early in the call list, before any encoder counters and the write function will be later in the call list, after stepgen.make-pulses.
6. Pin Numbering
The GPIO connector and the pinout has been consistent since around 2015. These older Pi models are probably a poor choice for LinuxCNC anyway. However, this driver is designed to work with them, and will detect and correctly configure for the two alternative pinouts.
The current pinout mapping between GPIO numbers and connector pin numbers is included in the table above.
Note that the config string uses GPIO numbers, but once the driver is loaded the HAL pin names refer to connector pin numbers.
This may be more logical than it first appears. When setting up you need to configure enough pins of each type, whilst avoiding overwriting any other functions that your system needs. Then once the driver is loaded, in the HAL layer you just want to know where to connect the wires for each HAL pin.
7. Known Bugs
At the moment (2023-07-16) this driver only seems to work on Raspbian as the generic Debian image does not set up the correct interfaces in /dev/gpiomem and restricts access to the /sys/mem interface.
