This documentation describes the hal python module, which provides a Python API for creating and accessing HAL pins and signals.
1. Basic usage
#!/usr/bin/env python3
import hal, time
h = hal.component("passthrough")
h.newpin("in", hal.HAL_FLOAT, hal.HAL_IN)
h.newpin("out", hal.HAL_FLOAT, hal.HAL_OUT)
h.ready()
2. Functions
component
+ The component itself is created by a call to the constructor hal.component. The arguments are the HAL component name and (optionally) the prefix used for pin and parameter names. If the prefix is not specified, the component name is used.
.Example
newpin
+ Create new pin.
Arguments: pin name suffix, pin type, and pin direction. For parameters, the arguments are: parameter name suffix, parameter type, and parameter direction.
.Example:
ready
Tells the HAL system the component is initialized. Locks out adding pins.
unready
Allows a component to add pins after ready() has been called. One should call ready() on the component after.
component_exists
Does the specified component exist at this time.
Example
hal.component_exists("testpanel")
component_is_ready
Is the specified component ready at this time.
Example
hal.component_is_ready("testpanel")
get_msg_level
Get the current Realtime msg level.
set_msg_level
Set the current Realtime msg level. used for debugging information.
connect
Connect a pin to a signal.
Example
hal.connect("pinname","signal_name")
disconnect
Disconnect a pin from a signal.
Example
hal.disconnect("pinname")
get_value
Read a pin, param, or signal directly.
Example
value = hal.get_value("iocontrol.0.emc-enable-in")
get_info_pins()
Returns a list of dicts of all system pins.
listOfDicts = hal.get_info_pins()
pinName1 = listOfDicts[0].get('NAME')
pinValue1 = listOfDicts[0].get('VALUE')
pinType1 = listOfDicts[0].get('TYPE')
pinDirection1 = listOfDicts[0].get('DIRECTION')
get_info_signals()
Returns a list of dicts of all system signals.
listOfDicts = hal.get_info_signals()
signalName1 = listOfDicts[0].get('NAME')
signalValue1 = listOfDicts[0].get('VALUE')
driverPin1 = listOfDicts[0].get('DRIVER')
get_info_params()
Returns a list of dicts of all system parameters.
listOfDicts = hal.get_info_params()
paramName1 = listOfDicts[0].get('NAME')
paramValue1 = listOfDicts[0].get('VALUE')
paramDirection1 = listOfDicts[0].get('DIRECTION')
new_sig
Create a new signal of the type specified.
Example
hal.new_sig("signalname",hal.HAL_BIT)
pin_has_writer
Does the specified pin have a driving pin connected.
Returns True or False.
h.in.pin_has_writer()
get_name
Get the HAL object name.
Return a string.
h.in.get_name()
get_type
Get the HAL object’s type.
Returns an integer.
h.in.get_type()
get_dir
Get the HAL object direction type.
Returns an integer.
h.in.get_dir()
get
Get the HAL object value.
h.in.get()
set
Set the HAL object value.
h.out.set(10)
is_pin
Is the object a pin or parameter?
h.in.is_pin()
sampler_base
TODO
stream_base
TODO
stream
TODO
set_p
Set a pin value of any pin in the HAL system.
Example
hal.set_p("pinname","10")
