1. Введение
This document contains information for developers about LinuxCNC infrastructure, and describes the best practices for contributing code and documentation updates to the LinuxCNC project.
Throughout this document, "source" means both the source code to the programs and libraries, and the source text for the documentation.
2. Communication among LinuxCNC developers
The two main ways that project developers communicate with each other are:
3. The LinuxCNC Source Forge project
We use Source Forge for mailing lists.
4. The Git Revision Control System
All of the LinuxCNC source is maintained in the Git revision control system.
4.1. LinuxCNC official Git repo
The official LinuxCNC git repo is at https://github.com/linuxcnc/linuxcnc/
Anyone can get a read-only copy of the LinuxCNC source tree via git:
git clone https://github.com/linuxcnc/linuxcnc linuxcnc-dev
If you are a developer with push access, then follow github’s instructions for setting up a repository that you can push from.
Note that the clone command put the local LinuxCNC repo in a directory called linuxcnc-dev, instead of the default linuxcnc. This is because the LinuxCNC software by default expects configs and G-code programs in a directory called $HOME/linuxcnc, and having the git repo there too is confusing.
Issues and pull requests (abbreviated PRs) are welcome on GitHub: https://github.com/LinuxCNC/linuxcnc/issues https://github.com/LinuxCNC/linuxcnc/pulls
4.2. Use of Git in the LinuxCNC project
We use the "merging upwards" and "topic branches" git workflows described here:
У нас есть ветка разработки под названием «мастер» и одна или несколько стабильных веток с именами вроде «2.6» и «2.7», указывающими номер версии выпусков, которые мы делаем из нее.
Исправления идут в самой старой применимой стабильной ветке, и эта ветка объединяется со следующей, более новой стабильной веткой, и так далее до «мастера». Коммиттер исправления может сделать слияние самостоятельно или оставить слияние для кого-то другого.
Новые функции обычно помещаются в ветку master, но некоторые виды функций (в частности, хорошо изолированные драйверы устройств и документация) могут (по усмотрению менеджеров выпуска стабильной ветки) помещаться в стабильную ветку и объединяться, как это делается с исправлением ошибок.
4.3. git учебники
В Интернете есть много отличных бесплатных руководств по git.
Первое место, куда стоит заглянуть, это, вероятно, man-страница gittutorial. Доступ к этой справочной странице можно получить, запустив «man gittutorial» в терминале (если у вас установлены справочные страницы git). Gittutorial и последующая документация также доступны онлайн здесь:
Более подробную документацию по git см. в книге «Pro Git»: https://git-scm.com/book
Еще один рекомендуемый онлайн-учебник — «Git для ленивых»: https://wiki.spheredev.org/index.php/Git_for_the_lazy
5. Обзор процесса
Общий обзор того, как внести изменения в исходный код, выглядит следующим образом:
  • Communicate with the project developers and let us know what you’re hacking on. Explain what you are doing, and why.
  • Clone the git repo.
  • Make your changes in a local branch.
  • Добавление документации и Написание тестов — важная часть добавления новой функции. В противном случае другие не будут знать, как использовать вашу функцию, а если другие изменения сломают вашу функцию, это может остаться незамеченным без проверки.
  • Поделитесь своими изменениями с другими разработчиками проекта одним из следующих способов:
    • Push your branch to github and create a github pull request to https://github.com/linuxcnc/linuxcnc (this requires a github account), or
    • Push your branch to a publicly visible git repo (such as github, or your own publicly-accessible server, etc) and share that location on the emc-developers mailing list, or
    • Email your commits to the LinuxCNC-developers mailing list (<emc-developers@lists.sourceforge.net>) (use git format-patch to create the patches).
  • Advocate for your patch:
    • Explain what problem it addresses and why it should be included in LinuxCNC.
    • Будьте восприимчивы к вопросам и отзывам от сообщества разработчиков.
    • Патч нередко подвергается нескольким ревизиям, прежде чем он будет принят.
6. Конфигурация git
Чтобы коммиты рассматривались для включения в исходный код LinuxCNC, они должны иметь правильные поля Author, идентифицирующие автора коммита. Хороший способ убедиться в этом — настроить глобальную конфигурацию git:
git config --global user.name "Your full name"
git config --global user.email "you@example.com"
Используйте свое настоящее имя (не псевдоним) и незашифрованный адрес электронной почты.
7. Эффективное использование git
7.1. Содержимое коммита
Держите свои коммиты небольшими и по существу. Каждый коммит должен выполнять одно логическое изменение репо.
7.2. Пишите хорошие сообщения коммитов
Сохраняйте сообщения коммитов шириной около 72 столбцов (чтобы в окне терминала по умолчанию они не переносились при отображении с помощью git log).
Используйте первую строку как краткое изложение цели изменения (почти как строку темы электронного письма). За ним следует пустая строка, а затем более длинное сообщение, объясняющее изменение. Пример:
7.3. Коммит в нужную ветку
Исправления должны идти в самой старой применимой ветке. Новые функции должны идти в основной ветке. Если вы не уверены, куда относится изменение, спросите в irc или в списке рассылки.
7.4. Используйте несколько коммитов для организации изменений
Когда это уместно, организуйте свои изменения в ветку (серию коммитов), где каждый коммит является логическим шагом к вашей конечной цели. Например, сначала вынесите какой-нибудь сложный код в новую функцию. Затем, во втором коммите, исправьте базовую ошибку. Затем в третьем коммите добавьте новую функцию, которая упрощается благодаря рефакторингу и которая не работала бы без исправления этой ошибки.
Это полезно для рецензентов, потому что легче увидеть, что шаг «вынести код в новую функцию» был правильным, когда нет других смешанных правок; легче увидеть, что ошибка исправлена, когда исправляющее ее изменение отделено от новой функции; и так далее.
7.5. Следуйте стилю окружающего кода
Постарайтесь следовать преобладающему стилю отступов окружающего кода. В частности, изменения пробелов затрудняют другим разработчикам отслеживание изменений с течением времени. Когда необходимо выполнить переформатирование кода, делайте это как коммит отдельно от каких-либо семантических изменений.
7.6. Избавьтесь от RTAPI_SUCCESS, вместо этого используйте 0
Тест «retval < 0» должен показаться вам знакомым; это тот же тест, который вы используете в пользовательском пространстве (возвращает -1 в случае ошибки) и в пространстве ядра (возвращает -ERRNO в случае ошибки).
7.7. Упростите сложную историю, прежде чем делиться ею с другими разработчиками
С git можно записывать каждое редактирование и фальстарт как отдельный коммит. Это очень удобно как способ создания контрольных точек во время разработки, но часто вы не хотите делиться этими фальстартами с другими.
Git предоставляет два основных способа очистки истории, оба из которых можно использовать свободно, прежде чем делиться изменениями:
git commit --amend позволяет вам внести дополнительные изменения в последнюю вещь, которую вы закоммитили, а также при необходимости изменить сообщение коммита. Используйте это, если вы сразу поняли, что что-то упустили из коммита, или если вы опечатались в сообщении коммита.
git rebase --interactive upstream-branch позволяет вернуться к каждому коммиту, сделанному с тех пор, как вы разветвили свою ветку функций из восходящей ветки, возможно, отредактировав коммиты, отбросив коммиты или смешав (объединив) коммиты с другими. Rebase также можно использовать для разделения отдельных коммитов на несколько новых коммитов.
7.8. Убедитесь, что каждый коммит собирается
Если ваше изменение состоит из нескольких исправлений, можно использовать git rebase -i, чтобы переупорядочить эти исправления в последовательность коммитов, которая более четко описывает этапы вашей работы. Потенциальным последствием переупорядочивания патчей является то, что можно неправильно понять зависимости — например, ввести использование переменной, а объявление этой переменной следует только в более позднем патче.
Хотя ветвь HEAD будет собираться, не каждый коммит может быть собран в таком случае. Это ломает git bisect - то, что кто-то другой может использовать позже, чтобы найти фиксацию, которая привела к ошибке. Таким образом, помимо обеспечения сборки вашей ветки, важно также обеспечить сборку каждого отдельного коммита.
Существует автоматический способ проверки ветки для каждого коммита, который можно построить — см. https://dustin.sallings.org/2010/03/28/git-test-sequence.html и код на https://github.com/ dustin/bindir/blob/master/git-test-sequence. Используйте следующим образом (в этом случае тестируйте каждый коммит от origin/master до HEAD, включая выполнение регрессионных тестов):
cd linuxcnc-dev
git-test-sequence origin/master..  '(cd src && make && ../scripts/runtests)'
Это либо сообщит All is well, либо Broke on <commit>
7.9. Переименование файлов
Пожалуйста, используйте возможность переименования файлов очень осторожно. Подобно применению отступов для отдельных файлов, переименования по-прежнему затрудняют отслеживание изменений с течением времени. Как минимум, вы должны искать консенсус в irc или списке рассылки, что переименование является улучшением.
7.10. Предпочитаю "rebase"
Используйте git pull --rebase вместо простого git pull, чтобы сохранить красивую линейную историю. Когда вы перебазируете, вы всегда сохраняете свою работу как ревизии, которые опережают origin/master, поэтому вы можете делать такие вещи, как git format-patch, чтобы делиться ими с другими, не отправляя их в центральный репозиторий.
8. Переводы
Проект LinuxCNC использует gettext для перевода программного обеспечения на многие языки. Мы приветствуем вклад и помощь в этой области! Улучшать и расширять переводы легко: вам не нужно знать программирование, и вам не нужно устанавливать какие-либо специальные программы для перевода или другое программное обеспечение.
Самый простой способ помочь с переводами — использовать Weblate, веб-сервис с открытым исходным кодом. Наш переводческий проект находится здесь:
Документация по использованию Weblate находится здесь: https://docs.weblate.org/en/latest/user/basic.html
9. Другие способы внести свой вклад
Есть много способов внести свой вклад в LinuxCNC, которые не рассматриваются в этом документе. Эти способы включают в себя:
  • Отвечая на вопросы на форуме, в списках рассылки и в IRC
  • Сообщение об ошибках в системе отслеживания ошибок, на форуме, в списках рассылки или в IRC
  • Помощь в тестировании экспериментальных функций
