ver 3.4.8 - re-ordered settings pages to have all appearance-related on one page - add configuration for 800x600 screens - fix gremlin view p wasn't applied at startup ver 3.4.7.1 - Remember window size and position when switching back from fullscreen/maximized - Fix "window does not fit 1024x768 in fullscreen" ver 3.4.7 - Added setting to allow smaller width of virtual keyboard (for widescreens) - Fixed box_dro_side is displayed in the G-code editor (#2627) - Fixed error on error message when sound is not available (reported on Raspberry Pi) - Fixed increasing of window size when clicking edit button - Added setting for G-code theme (GtkSourceView) - Fixed error when trying to hide the turtle-jog button in gmoccapy ver 3.4.6 -- LinuxCNC 2.9.2 - added first steps to solve delay on sound use ver 3.4.4 - 8 and 9 axis made to much ref button due to a show all ccommand. This fixes #2387. - deleted unused code ver 3.4.3 - fix setting of themes - fix display of logo with "-logo" option - added embedded tab location "box_dro_side" - added setting to disable sound - added setting for "hide title bar" - replaced deprecated GTK widgets, mostly GtkTable and GtkAlignment - removed setting MAX_RAPID_OVERRIDE (#2392) - removed sound for calculator dialogs (except unlock code dialog) - transparent buttons for cooling and spindle, fixed spindle_stop/spindle_stop_on icon - fixed buttons in restart dialog (run from line) (side effect from #2381) - hal_mdihistory: scroll to last line on reload - fixed virtual keyboard did not expand (#2394) ver 3.4.2.1 - Replaced deprecated Gtk widgets in GladeVCP library (#2381, thanks phillc54) - Replaced deprecated Gtk widgets inside gmoccapy (reduced warnings) - Fixed default icon theme in lathe configs - Fixed DRO size after change in settings (#2374, thanks zz912 for reporting) ver 3.4.2 New: - Log levels can now be specified in the INI file (#2323, thanks Chris!) - Swapped position of settings button with user tabs button ver 3.4.1 New: - added possibility for sourcing an user defined file (rcfile) - added option to use external CSS file Fixes: - some optical fixes (button properties, left align text in notification) - fixed sensitizing of user tab button on toggling "edit offsets" (#2111) - fix error on creating new G-code file when RS274NGC_STARTUP_CODE is not set (#2057) ver 3.4.0 New features: - Icon Themes: * Implement icon theme switch logic (Peter Müller) * Add material and material-light icon themes (Peter Müller) * Optimized classic icons (Hans Unzner) - added setting for height of on-screen keyboard (Hans Unzner) - added some EMBED_TAB locations (Hans Unzner) - Added Gtk.Paned for upper main area (hbox2) (Hans Unzner) Optical fixes: - don't expand DRO (Hans Unzner) - center labels of multi-line buttons (Hans Unzner) - Fixed several typos (luz paz, Petter Reinholdtsen) - Added and fixed several tooltips (zz912) - fix translation strings of some tooltips and dialogs (Hans Unzner) Functional fixes: - fix "spindle speed override wasn't applied in reverse direction" (Hans Unzner) - fix attribute errors in tooltip (TRothfelder, Hans unzner) - fixed iconview/full screen bug (#1543) (Hans Unzner) - restore user tab when leaving settings page (Hans Unzner) - restore mode when leaving settings page (Hans Unzner) - prevent mode buttons from sensitizing when toggling on/off when in settings page (Hans Unzner) - fix button states when on settings page (Hans Unzner) - fix button states when entering settings from MDI or Auto mode (Hans Unzner) - fixed DRO unit switching (G20/G21) (Hans Unzner) - fixed got lost "touchoff tool z" button (Hans Unzner) - stop all jogging on focus-out-event (#1511) (Hans Unzner) - fix error when pressing "R" or "r" (Hans Unzner) - added confirm pins for toolchange and general warning dialogs, close toolchanger window on abort command (Hans Unzner) - sensitize save button after 'save as' (Hans Unzner) - fix detection of file change (Hans Unzner) - refresh limit override check box immediately (Hans Unzner) - enable limit override when limit tripped in machine off state (Hans Unzner) - enable limit override only when limit active (Hans Unzner) - enable limit override when machine is started with limit switch active (#1000) (Hans Unzner) - Error message when not existing tool is selected (Hans Unzner) - Fix jogging with max velocity (SHIFT + jog key) (Hans Unzner) GTK 3/Python 3 related fixes: - fixed DRO switching on G7/G8 + fixed active gcodes list (Hans Unzner) - wrong arguments in Button() causes gmoccapy to fail if 4_axis are used (Hans Unzner) - use python3 in all #!python lines (Jeff Epler) - fix various gtk3 deprecated warnings (Rene Hopf, Hans Unzner) - fixed setting "mouse button mode" (Hans Unzner) ver 3.1.3.10 - fix behavior in MDI mode running macro keyboard image This fixes issue #1180 ver 3.1.3.9 - added missing hal status signals to glade file to set button sensitive states in AUTO mode correct This fixes issue #1177 ver 3.1.3.8 (LinuxCNC 2.8.4 release) - jogging with max speed (with shift-key pressed) was reduced by halui setting - fixed bug in tooltip text for non-trivial or gantry configuration Thanks to chili023/TRothfelder for reporting/fixing - bug in spindle speed override: The override value wasn't applied when spindle turning in reverse direction Thanks Reinhard for reporting ver 3.1.3.8 (LinuxCNC 2.8.3 release) - fixed translation of some tooltips and a dialog message Thanks to zz912 - fixed detection of file change: - A cursor change in the G-code editor was detected as a file change. - After saving changes, a warning for unsaved changes still appeared. - fixed disabled save button after creating a new file and 'save as' ver 3.1.3.8 - changed the hide command to be able to hide any element of the GUI ver 3.1.3.7 - bug in embedded tabs, setting box_tool_and_gcode_info" as location did hide also the overrides, that was not correct. as we do need to hide them i.e. for plasma, I introduced a new feature. If you just enter hide as vommand in INI file, the corresponding widget will be hidden, without replacing the content. Thanks Jasen for reporting ver 3.3.3.4.2 - fixed some RGBA color bugs - closing onboard keyboard - dobble code line in gettext localisation - deprecated warning in timer.add ver 3.3.3.4.1 - exceptions dialog used deprecated format ver 3.3.3.4 - hide cursor now working - minor code corrections after fixing onboard ver 3.3.3.3.1 - onboard closing without error ver 3.3.3.3 - onboard did not close on closing gmoccapy ver 3.3.3.2 - edit button error corrected ver 3.3.3.1 - ** conversion to Gtk3/Python3 ** - changes release number to distinguish better - DRO now do react on changes from settings page - first changes to use RGBA not RGB - DRO Size can be adjusted - for preferences we use HEX colors, all other colors should be RGBA - introduced helper function to convert colors, IMHO should be in an own module - label for loaded file was not working - Key Control Mask corrected - pixbuf corrected to get icons on button - iconview corrected - Jog increment button corrected ver 3.1.3.6 - get rid o some "ERROR" strings in translation file as the error type is displayed as ICON in self._show_error Thanks to hansu for reporting ver 3.1.3.5 - wrong translation of "Follow System Theme" led to a wrong theme when loading the GUI. Will correct the translation files with a different commit Thanks to hansu for reporting ver 3.1.3.4 - PAUSE button was active, even if no program was running Thanks to hansu for reporting ver 3.1.3.3 - pause a program would not allow to jog through the gcode preview gcode preview will no be enabled if program is paused, only scrolling, it is not possible to edit or select a line! Thanks to hansu for reporting ver 3.1.3.2 - change og gmoccapy hal pin gmoccapy.jog.jog-inc-N led to an aboart() command, so changing that pin i.e. in AUTO mode stops Spindle and program execution. That is not the expected behavior. I changed this to not throw any error, just change silently the jog-increment to the selected one. Just not allowing this, would lead to an unsynchronized system between hardware and GUI Thanks to ZincBoy for reporting this misbehavior ver 3.1.3.1 - when used trivkins together with kinstype=BOTH, there was no joint jog buttons, as this way of using trivkins is not recommended nor useful. Even so a user might want to use that config so I changed gmoccapy to display in this case the joints jog button Thanks to Clive S and mucy007 for reporting ver 3.1.3 - added a dialog asking the user to save changes - when in min screen resolution the editing page was wrong formatted while using German language, because of too long strings Thanks to Hans470 for reporting this bugs ver 3.1.2.3 - when going back from file loading menu without selecting a file brought you into fullscreen view. Reported by: Hans (Hans470) Thanks for reporting ver 3.1.2.2 - bug while running a program it was possible to click the reload file button, resulting in an immediate reloading and stopping the running code. Button is no insensitive while running a file ver 3.1.2.1 - still a bug in handling ignore limits solved issue #1000 reported by Hans470 solved by using new hal status signal and deleted some unneeded code ver 3.1.2 - connecting macro button to physical button did send a clicked signal, but macro button did expect a pressed signal This bug has been reported from ulistermclame ver 3.1.1 - setting analog-enable hal pins signal always reset the jog vel of the slider. This has been reported from hans23 solved with this update ver 3.1.0 - added the ability to hide the tooltips to make the use with touch monitors more useful Thanks to neilwhelcher for the code and pointing this out ver 3.0.10 - bug in handling ignore limits solved issue #1000 reported by Hans470 solved by using new hal status signal and deleted some unneeded code ver 3.0.9.1 - bug in handling back tool lathe solved reported on the forum from Schaap ver 3.0.9 - added settings to set min, default and angular velocities for angular jogging. No keyboard shortcuts for jogging angular axis, all prepared for doing so, but no idea which keys to use ver 3.0.8.3 - The function to arrange jogging buttons relies on the dict that hold available axes to be in the same order as defined. in python 2.7 that is not the default behavior of dicts. So the function (with a XYZAB machine for example) gave two sets of row/column numbers for four buttons, leading to two buttons not being available. Thanks to Chris Morley for fixing this ver 3.0.8.2 - minor bug in enable_dro handling from gremlin dro, special case for non identical kinematics - some additional print statements and code clearance ver 3.0.8.1 - bug reported by Markus, jogging in diameter mode would only jog half the requested distance, what is OK for X axis, but not for all other axis. ver 3.0.8 - added the possibility to add also images to macro button. The images will be resized to fit the buttons (72x48). The macro file need to contain a line like (IMAGE, ./macros/images/goto_x_y_z.png) the path must be absolute or relative to the config dir, "~" is allowed in path ver 3.0.7.3 - Ralf reported an error toggling the Edit Offsets button. It was caused because I missed to change the widget handling of the dynamically created widgets on this special page. ver 3.0.7.2 - did not update the gmoccapy.tool measurement hal pin, so tool measurement ended with an error after a restart of the GUI Thanks to Mark and Ralf for reporting .. ver 3.0.7.1 - jogging of non trivial kinematics need an int for jogging ver 3.0.7 - jogging on configs with missing axis like XZ (Y missing) did lead to an error due to not taken care about the homing status. Not homed requires the joint number, while jogging in homed state requires the axis index. ver 3.0.6 - Most widgets like homing and touch button are now generated on the fly, leading to the need of less resources and a quicker start of the GUI - gmoccapy now supports 9 axis and 9 joints - configuration of joint axis relation are now applied as given in the INI file, allowing also strange configs like XZCW lathe configs or scara or 6 axis robot arms - Display of cutting speed is now correct, even on a lathe with constant surface speed - Jog increments on a lathe do now take care of being in diameter or radius mode, so if you jog 1,0 mm in diameter mode, the X axis will only move 0.5 mm! - a lot of internal stuff has been optimized ver 3.0.5 - solved bug with macro button if no virtual keyboard ver 3.0.4 - changed combi_DRO to emit two signals, if clicked on the left side in the range of the axis letter, the signal will open the set_axis_value dialog, clicking on the right will toggle the DRO readout ver 3.0.3.2 - tool measurement check, just once, not from several sides, store it as self.tool_measure_OK ver 3.0.3.1 - double function place in table ver 3.0.3 - fullsize preview button now stays synchronized ver 3.0.2 - minor code style changes - get rid of the screen2 stuff, as screens can be displayed using hal commands ver 3.0.1 - bug being in full-size preview in auto mode and loading a file led to normal view as expected, but the full-size button stayed activated ver 3.0.0 - added the possibility to use up to 9 axis and 15 joints - no limits to configuration of axis and joints - support for lathes with additional axis like XZCW - support up to 16 macros - if an angular axis is used it will display an additional jog vel slider ver 2.3.5.1 - removed unused import statements vte and pango from gmoccapy.py file ver 2.3.5 - jogging a not homed machine did change the button state of MDI and AUTO to be sensitive, what is not correct. - it was not possible to jog a unhomed machine over the given limits, what is not a correct behavior. ver 2.3.4.2 - introduced new keyboard shortcuts (not case sensitive) R = run program P = pause program S = resume program This keys will only work in auto mode, not being in edit mode and a program must be loaded. Pause and resume do only work if a program is running and / or paused. ver 2.3.4.1 - Philippe mentioned that a change of the DRO Size on settings page will be saved as expected, but after new start of the GUI, the value did note be restored properly. I have corrected the behavior ver 2.3.4 - Leon82 mentioned, that offset page did close after editing a column and leaving the edited cell. This was caused due to a hidden mode change to MDI because leaving the cell would apply the change using MDI commands from offset page_widget.py. Gmoccapy now checks the state of the "EDIT OFFSETS" toggle button and does not react to MDI Mode switch if that button is active. at the same time, the mode buttons etc. are disabled! Same changes as with gmoccapy 1.5.11 ver 2.3.3.4 - a merge of 2.7 to master resulted in a call of a widget, that does not longer exist in master (adj_max_velocity) causing an exception on halui pin changes. Thanks to COlger81 and Chris Morley for reporting the bug ver 2.3.3.3 - editing offsets, led to a error output in the console, due to missing widget btn_zero_x ver 2.3.3.2 - toggling the chk_toggle_readout, raised an exception on 5 axis config ver 2.3.3.1 - small changes to the code, as there was a possibility the label was shown, even if auto tool measurement was not used ver 2.3.3 - added a label at the button of the preview window to show the actual block-height value - the value is stored in the preference file and will be reloaded on start up, the corresponding hal pin is set to that value - the block-height label is only visible, if the "use auto tool measurement" check-box is active! Thanks to Rubenv and crislacuf for reporting ver 2.3.2.4 - most of .format code rework done ver 2.3.2.3 - display message as dialog, when critical errors do avoid the start of gmoccapy not only report in terminal ver 2.3.2.2 - ongoing reformatting the code to new .format style ver 2.3.2.1 - formatting bug in Vc, when over 100, float can not be formatted as int ver 2.3.2 - added a new label to toolinfo box, showing the cutting speed Vc it uses the tool diameter on mill and the x-relative value for lathe - first code updates to the new string formatting (not % but .format), as this will be needed to switch over to python 3 ver 2.3.1.9 - dialogs, changed entry_dialog check for integer before show_all This was only a cosmetic change - Solved bug in lathe mode, changing the size of DRO, did not change the Y DRO (D). Thanks to Partic T for reporting ver 2.3.1.8 - made dialogs a Class and enable gobject signals with the dialogs Now a sound will be played if a dialog pops up. This is a first step to modify all the handling within the GUI to make most parts react to signal and slots. ver 2.3.1.7 - minor bug in self periodic, forgot to change an AUDIO_AVIABLE setting - some work on tool handling, i.e. not possible to delete tool in spindle any more and after applying changes the tool in spindle will be marked ver 2.3.1.6 - solved the bug, that the decimal separator was changed after starting the gui the was related to the import of gst, as this import does change the value of locale.localeconv()["decimal_point"] I do not know why, but the import of gst prior to locale settings solves the problem ver 2.3.1.5 - some code clearance, as the tooleditor stuff was reparted on several places Now it is together in _init_tooleditor. This is the beginning of finding the bug of decimal separator handling Push reload will replace the German "," with the "." Why = ????? ver 2.3.1.4 - if no sound is available make the sound selecting widgets on the settings page not sensitive, Thanks to Rene for reporting this misbehavior ver 2.3.1.3 - changed the import of the player module, as Stretch does not support gst in the way Wheesy or Jessie did ver 2.3.1.2 - rodw reported that gmoccapy reported a wrong error if JOINT was mentioned in the error report. That was caused due to an old change from Joints to axis in _show_errors. ver 2.3.1.1 - added KeyPad Jogging as a wish from "suspension" from the forum ver 2.3.1 - added a new hal pin for tool diameter ver 2.3.0 - joint axis branch did change the handling between joints and axis. Previously it was needed to include a unused Y axis for a lathe and now that is not longer needed. There are some more changes, that needed some additional changes to gmoccapy. I have passed a lot of code over to get_ini_info. - all config files have been changed to support the new behavior. I tried to make all the code compatible with older configs. Some might need the not used axis to be included in homing entries in the INI files. ver 2.2.5.2 - if the GUI tries to reload a tool on restart and that tool was not found in the tool table, the GUI remained in MDI mode, while it was showing the manual view. This led to the problem, that jogging was not possible, but users thought they where in MANUAL mode, where jogging should be allowed. ver 2.2.5.1 - added a new dictionary self.joint_axis_dic to maintain the relation between joints and axis. This was tested with gantry and non identical configs. There might be configs out there witch won't work with gmoccapy. I found that the only way to get gantry XYYZ and i.e. XYZCW config to work with the homing button and the DRO settings ver 2.2.5 - this repairs the parts I broke on glade applications and the former used code in CombiDRO moved in a similar mode to gmoccapy. Now after the merge of sequential homing branch it is easier to use a gantry config with gmoccapy. There is still need to adapt the "on_btn_homing_selected" part of the GUI, as now a XYZC config will not allow homing of C, as the joints are not ordered correctly ver 2.2.4 - introduced a check for double axis letters in [TRAJ]COORDINATES = X Y Y Z to set the homing button of the double mentioned axis. This is to protect a gantry from being damaged homing only one joint of two. Thanks to rodw for insisting to solve the misbehavior ver 2.2.3.3 - check on homing for double letters and get the correct joint number for homing ver 2.2.3.2 - solved a bug caused due to an unappropriated merge of Sebastian Kuzminski causing a hal pin to be created twice. ver 2.2.3.1 - solved the reload tool on start up bug after homing twice if there is already a tool in spindle, the user homed the second time, unfortunately we will then not get out of MDI mode any more That happen, because the tool in spindle did not change, so the tool info is not updated and we self.change_tool will not be reset Thanks to timmert for reporting ver. 2.2.3 - added patch from gmoccapy 1.5.7 - new hal pin gmoccapy.ignore-limits so that this function can be handled from hardware switch Ask by some users, done because of a wish of Timothy Snowden ver. 2.2.2 - When running a program, press pause, then stop, the axis will make a jump to a unknown position, (I think related to read ahead). I added a additional command.aboard(), even that this command is already called within hal action. I do not know why, but this solved the issue as far as I can see. Thanks to racedirector for reporting ver. 2.2.1 - if linuxcnc is restarted without shutting down gmoccapy, it was not possible to close gmoccapy (except from commandline with killall -9 gmoccapy I added a check to status.poll and now a raise SystemExit will be called. as this also applies to CombiDRO a added that there too. I added gmoccapy to the linuxcnc script to be killed on restart ver. 2.2.0.3 - changed the height and width adjustments for the window size in the glade file, as width was limited to 1280 pixel. Now the max limit is 3920 pixel. ver. 2.2.0.2 - if no MACROS was given in INI file, the getiniinfo returns a NONE, leading to an exception in gmoccapy, corrected that ver. 2.2.0.1 - make the reload tool option a selectable feature on the settings page. It will be on by default! ver. 2.2.0 - gmoccapy will save the tool in spindle on every change in its preference file and reload that tool with it's length offset till now only tested for mill! This will not work if NO_FORCE_HOMING is used, because with such a configuration the signal "all_homed" will not be emitted. ver. 2.1.6.5 - changed the expanding way of the widgets in the INFO box to better appearance on 16:9 screens, the tool info will not grow alone, but also spindle and vel info boxes ver. 2.1.6.4 - Added the patch from ver. 1.5.6.9 * if no MACROS where given, or the paths where not correct, the Keyboard button in MDI mode was not any more in the most right position, leading to wrong order in horizontal hal button handling ver. 2.1.6.3 - Dawey Garret changed the init_glcanondraw() behavior, making some changes in gmoccapy and getiniinfo. That is why I changed the release number ver. 2.1.6.2 - better solution for the G96 bug ver. 2.1.6.1 - bug handling of G96 CSS, related to the update of the real spindle speed label Thanks to Hakan for reporting this - Jumping spindle speed label due to a calculation error between two functions, and double setting of a label, Solved! ver. 2.1.6 - merged the changes I made to 1.5.6.5 to 1.5.6.8 details see below ver. 2.1.5 - halui spindle override bug, caused by a race conflict Thanks to pippin88 and dinkata to help solving his one ver. 2.1.4 - lathe wear offsets has been displayed by default, IMHO that disturbs most users, as the wear offsets do only work with remapped code. That part is only weak documented. - If the user wants to use wear offsets, he will have to include in [DISPLAY] LATHE_WEAR_OFFSETS = 1, otherwise the additional tabs will be hidden. ver. 2.1.3 - mode change was possible with keyboard shortcuts, even if the interpreter was running. - if the user changed with keyboard shortcut a mode and after that to an other mode with button, it was not possible to change to the previous mode with the keyboard shortcut, as the last key event is recorded. Now the hal status event will reset the key event ver. 2.1.2 - spindle label besides the 100 % button has not been updated ver. 2.1.1 - starting with estop-reset, caused some errors, because it is not possible to JOG_STOP with machine in OFF state ver. 2.1.0 - reworked Combi_DRO to fit the needs of JA requirements - some configs must be adapted to the new hal pin names, as they are put together in groups, so all stuff with jog is in that group - Hiding the jog button in world mode is possible with a command line argument - reorderd some code to be more understandable - deleted a lot of debug prints - still having problems with matchbox-keyboard, it is found, but not shown on every config, need more testing. ver.2.0.26 - bugfix: if toggle button user tabs was active and the user changed the mode (Manual,MDI or AUTO) the user tabs button staid active, but the screen layout changed to the corresponding mode, letting the button pressed. - if embedded tabs was set in the INI file, the toggle button user tabs got active, even if no tab was configured for "ntb_user_tabs", changed this and sorted the code to be together with the rest of user tabs - error in getiniinfo.get_increments, default values contained "," insteadt "." ver.2.0.25.1 - some changes to support new homing by joints, not by axis still work to do! - do not allow any more the change to mdi or auto in Joint Mode! ver.2.0.25 - introduced hal pin to jog joints, make sure not to allow joint jogging in world mode and vice versa - renamed most hal pin, so they are better organized, kept together in groups - big bug in all homed signal of hal_glib avoid pushing to master ver. 2.0.24 - reduced digits of velocity label to 2 digits for imperial ver. 2.0.23 - bug in _update_slider, caused by units change and the needed recalculation of jog_vel ver. 2.0.22 - corrected the reading of preferences, under some circumstances as bool written settings, couldn't be read correct from file, leading to wrong settings. This is a known bug in ConfigParser. I went over to write all bool settings as string, this way it works like a charm. At the same time all bool values must be read with type = bool! ver. 2.0.21 - added Joint Jog Button, _init_joints_btn will show only the needed button, so from now on gmoccapy supports 8 Joints and 5 axis - still problems with the initialization of optional stops - some button renaming to distinguish joints and axis jog button due to special case 4th and 5th axis - reworked on_jog_btn_pressed and released to support joint jogging could be done better, will need some additional rework - deleted some print messages ver. 2.0.20 - small bug in _reset_override in rapid handling, as it would reset to 100 % on change to any state, instead only on pin.get() ver. 2.0.19 - deleted the settings to hide axis 4 if used as tool changer as that is not longer needed on Joint Axis branch - corrected a DRO display issue on 4 axis config - deleted unneeded handlers for axis touch off to zero ver. 2.0.18 - deleted adj_jog_vel and use spc_jog_vel - If a user uses analog input signals (i.e. gmoccapy.jog-speed.analog-enable) the 100 % button will be hidden as pushing this buttons will lead to unsynchronized state between GUI and hardware. Also the turtle and rabbit jog velocities can not be different in there percentage, as the can be using a jog wheel. we will also hide the plus and minus button of the widgets, as they also can not be used together with analog input - changed pin name from jog-speed to jog-velocity - changed back the override frames to original order ver. 2.0.17 - deleted adj_feed and use spc_feed - corrected a strange way of updating spindle override values - corrected a lot of typos within this file and gmoccapy.py ver. 2.0.16 - deleted adj_rapid_override and use spc_rapid ver. 2.0.15 - finally found a way to avoid jumping DRO size of axis 4 and 5 if the amount of numbers change, i.e. from 99.999 to 100.001 as it need more space. - added a togglebutton to switch from joint to teleop, this button will be hidden on identity kinematics machines - small bug in spc_spinlde handling (to many get and set led to jumping values) ver. 2.0.14 - deleted adj_spinlde and changes the code to use directly the settings of the SpeedControl widget. This way we save resources, because we need one adjustment less. I will change the code also for the rest of the sliders. ver. 2.0.13 - updated debug server to use newest version on my computer ver. 2.0.12 - bug in touchscreen slider if machine units and display units not equal - corrected some strange entries in INI files ver. 2.0.11 - some small changes in INI configs - changed the DRO Size settings depending on number of axis - set the init_colors of the combi DRO to hex values instead of names like green, as different desktops do interpret the names with different color values ver. 2.0.10 - jog vel touchscreen slider was not initialized with the correct increment due to a type in a variable - changed some default values in the INI file of 4 axis gmoccapy.ini ver. 2.0.9 - added some 5 axis IDENTITY kinematics sim configs ver. 2.0.8 - 4 axis config did not hide y replace label, leading to touch of button being to nerow ver. 2.0.7 - bug in key handling of F12 (switch mode) as mode was also changed in IDENTITY kinematics - bug in _init_extra_axes ver. 2.0.6 - corrected some small bugs, avoiding gremlin to switch to full-size preview, - got back some missing handlers in the glade file ver. 2.0.5 - merged with the touchscreen slider version - deleted unneeded INI entries - Attention: Hal pin names have changed during change from 1.n to 2.0 ver. 2.0.4 - merged with the gmoccapy JA version ver. 2.0.3 - bug in DRO size handling ver. 2.0.2 - added user mode as command line argument - added logo as command line argument ver. 2.0.1 - when using hardware button to jog the axis, the 5th axis was not recognized, resulting in a jog of the 4th axis. I solved this bug and introduced a new config to test this. Thanks to Ludwig for reporting the bug ver. 2.0.0 - initial push of beta gmoccapy with 5 axis ver. 1.5.11 - Leon82 mentioned, that offset page did close after editing a column and leaving the edited cell. This was caused due to a hidden mode change to MDI because leaving the cell would apply the change using MDI commands from offset page_widget.py. Gmoccapy now checks the state of the "EDIT OFFSETS" toggle button and does not react to MDI Mode switch if that button is active. at the same time, the mode buttons etc. are disabled! ver. 1.5.10 - fixed a misbehavior of the turtle button If machine and system units was not identical, the turtle button destroyed the values set on the jog vel slider thanks to sliptonic from linuxcnc forum - while moving the max vel slider and units of machine and system not being identical, results in a jumping slider, as the factor has not been taken in account on the halui pin checking ver. 1.5.9 - fixed a bug on import gst, leading to an exception if gst is not installed - fixed a bug, not taking care of Y-DRO (D) in lathe mode if the user changed the size of the DRO ver. 1.6.0 - changed the initial sound files to fit freedesktop path was set to ubuntu till now - first steps to support teleop mode Homing is possible as gantry and as identity kinematics Jogging is possible in both modes Mode change can be done pressing F12 or $ the mode is displayed with the gremlin view DRO, combi DRO will not change jet. - ToDo: * Add widget to change motion mode * Init GUI to have a jog button per joint and not only per axis * change GUI appearance according to motion mode ver. 1.5.7 - new hal pin gmoccapy.ignore-limits so that this function can be handled from hardware switch Ask by some users, done because of a wish of Timothy Snowden ver. 1.5.6.10 - if no MARCO was found in INI getiniinfo returned a NONE, leading to an exception in gmoccapy, corrected that. ver. 1.5.6.9 - if no MACROS where given, or the paths where not correct, the Keyboard button in MDI mode was not any more in the most right position, leading to wrong order in horizontal hal button handling ver. 1.5.6.8 - gmoccapy poll time for the GUI was hard coded till now, I changed that to take care of the INI File settings. If no or a wrong entry is in the INI file a default value of 150 will be used. ver. 1.5.6.7 - reading of subroutine paths did not take care of ":" separated paths so it was not possible to use NativeCAM together with gmoccapy macros I corrected that misbehavior of gmoccapy. That change was used to clear some macro code and I transferred some checking to get_ini_info ver. 1.5.6.6 - check at start if there is a INI entry for DEFAULT_SPINDLE_SPEED and set the gmoccapy settings accordingly. ver. 1.5.6.5 - merged the bug fix from 2.6 branch gmoccapy 1.5.6.2.2 ver. 1.5.6.4 - bugfix: if toggle button user tabs was active and the user changed the mode (Manual,MDI or AUTO) the user tabs button staid active, but the screen layout changed to the corresponding mode, letting the button pressed. - if embedded tabs was set in the INI file, the toggle button user tabs got active, even if no tab was configured for "ntb_user_tabs", changed this and sorted the code to be together with the rest of user tabs ver. 1.5.6.3 - bugfix: In _init_IconFileSelection the icon size was fixed with 48 so changes the user makes to the glade file was not been taken care of - In glade file a signal on_btn_load_state_changed was set, but no handler present, leading to a error message on start in the terminal, erased the signal ver. 1.5.6.2.3 - bug in handling a subroutine call from MDI, containing G96 code. Thanks to Hakan for reporting this. ver. 1.5.6.2.2 - halui spindle override bug, caused by a race conflict Thanks to pippin88 and dinkata to help solving his one ver. 1.5.6.2.1 - bug in initialize optional stops ver. 1.5.6.2 - bugfix: run from line was trying to set an entry in the alarm page, which I dropped in 1.5.6 I cleared the code from unneeded imports and comments ver. 1.5.6.1 - bugfix: If a user did jog with keyboard and while jogging changed the increments pressing "i" on the keyboard the jog move would never stop. I do check now for self.stat.state and do avoid that way the increment changes if the user changes the jog-increment using the hal pin, the increment will change to the new value, but the jog command will be aborted. - corrected some typos ver. 1.5.6 - deleted the alarm_entry log page, as it has not been used by users to report bugs, and therefor it was designed. - changing DRO mode by click can be disabled on settings page - corrected and added information to the docs - added a new property to combi_dro to disable readout toggling ver. 1.5.5.5 - if using gmoccapy jog hal pin in MDI mode a error was thrown on button release - Typo in settings page, corrected also the translation files ver. 1.5.5.4 - corrected a error shown on start up, because I used greeen instead of green - glade file did contain a signal "on_gremlin_clicked", but gmoccapy did not offer a handler, resulting in error messages in the terminal on start up. the unneeded signal has been erased - The horizontal buttons of gmoccapy will stay synchronized with the iconview widget ver. 1.5.5.3 - deleted the working area limit pin, as this can be realized better with standard hal pin and did not work well with gmoccapy - settings page, all previous settings are now in one frame - updated the documentation - new serbian translation files, and corrected the language code was rs.po instead sr.po ver. 1.5.5.2 - unloading a tool with M61 Q0 did not reset the tool information because the tool number changed to "-1" and I tested only for "0" To unload the tool with M61 Q0 the command has to be executed twice because of a linuxcnc bug (IMHO) ver. 1.5.5.1 - corrected the step by step behavior ver. 1.5.5 - gmoccapy will take notice of the settings "DISPLAY", "POSITION_FEEDBACK" in the INI File and set the DRO accordingly (Code basis from Steffen) - Added keyboard shortcut F3 to change to manual mode - Added keyboard shortcut F5 to change to MDI Mode - Added keyboard shortcut "Enter" for MDI Mode to submit the selected command - Added keyboard shortcut "i" and "I" to switch jog increments forward and backwards like in axis ver. 1.5.4.1 - changed full-size preview button in manual mode to new position to be the same place in auto and manual mode. ver. 1.5.4 - changing in auto mode, being in full-size preview to edit page led to blank screen, I corrected that bug. ver. 1.5.3.1 - solved a bug in widget handling, not enabling the ignore limits checkbox, being on a limit switch ver. 1.5.3 - added a gscreen patch to search also in the user dir for themes ver. 1.5.2.2 - if a user did reduce spindle override to zero and switched on the spindle, gmoccapy produced a division by zero error. Fixed! reported by "tekmobile" ver. 1.5.2.1 - corrected a bug on btn_brake_macro, not being active if no virtual keyboard has been installed Thanks to Frans (franstrein) for reporting ver. 1.5.2 - In Lathe mode and with startcode G7 the DRO has not been set correctly, while starting in G8 was OK. - Some code clearance ver. 1.5.1.4 - Two missing self. led to errors if logging was active, Thanks to Frans (franstrein) for reporting ver. 1.5.1.3 - As in full screen mode the GUI covers also the clock, I added a clock and date label under the right buttons. ver. 1.5.1.2 - The handler from glade_status got lost somehow, so some hal pin has not been updated correctly - in the glade file the spindle at speed led changed its color to red, I don't know how, I think glade is coming to its limit ;-) - changed spindle label handling, now the labels display actual values, not the read values. - The spindle buttons will now be sensitive in auto mode, but only the one witch is active, so spindle direction is displayed clearly ver. 1.5.1.1 - some print commands has been commented out to avoid to much condole infos - there was a limit of 100 for tool sensor height, I extended to 999 mm ver. 1.5.1 - solved a bug in counts handling, if only one MPG was used for all sliders and axis, there was a jump after changing the selection Now it does not matter, if the user connect only one MPG or use for each slider an own MPG ver. 1.5.0 - new hal pin, and some renaming of hal pin to reflect the same names and behavior as halui-pin * gmoccapy.jog-speed.counts * gmoccapy.jog-speed.analog-enable * gmoccapy.jog-speed.count-enable * gmoccapy.jog-speed.direct-value * gmoccapy.feed-override.counts * gmoccapy.feed-override.analog-enable * gmoccapy.feed-override.count-enable * gmoccapy.feed-override.direct-value * gmoccapy.spindle-override.counts * gmoccapy.spindle-override.analog-enable * gmoccapy.spindle-override.count-enable * gmoccapy.spindle-override.direct-value * gmoccapy.max-velocity.counts * gmoccapy.max-velocity.count-enable * gmoccapy.max-velocity.analog-enable * gmoccapy.max-velocity.direct-value - gmoccapy will now react to some halui pin as counts or direct value Be aware, that some of this may have side affects, it is strongly recommended to use the corresponding gmoccapy hal pin. * halui.spindle-override.counts * halui.feed-override.counts * halui.max-velocity.counts * halui.abort * halui.spindle.start * halui.spindle.stop * halui.spindle.reverse * halui.spindle.increase * halui.spindle.decrease * halui.program.run * halui.program.stop * halui.program.pause * halui.mode.manual * halui.mode.mdi * halui.mode.auto * halui.mist.on * halui.mist.off * halui.flood.on * halui.flood.off * halui.machine.on * halui.machine.off * halui.home-all * halui.estop.activate * halui.estop.reset - to reflect the new hal pin connections I introduced a new sim config gmoccapy_pendant.ini, demonstrating the connection of a remote pendant with selection switches - deleted gmoccapy_jog_wheels.ini, as pendant.ini demonstrates it better ver. 1.4.2 - removed the save and run button from the edit page, because of security reasons - removed the integrated terminal, as it was not real useful and all terminal work can be done from normal terminal - translations for German and Spanish has been updated ver. 1.4.1 - corrected broken layout style, as the jog-increment buttons has not been modified to change there background color, getting only dark grey instead of yellow, if they where active. No the follow the gmoccapy style. - the number of digits of the DRO can now be set on the settings page, so users of fragile machines can reduce the digits. ver. 1.4.0 - introduced turtle jog, allowing two scales for the jog vel adjustment - new hal pin "gmoccapy.turtle-jog" to switch from rabbit-jog (fast mode) to turtle-jog (slow mode) using a hardware switch - new hal pin for analog input * gmoccapy.analog-enable (must be True to activate the analog inputs) * gmoccapy.spindle-override-value * gmoccapy.max-vel-value * gmoccapy.jog-speed-value * gmoccapy.feed-override-value all four taking a float input as percentage, meaning a value from 0.0 to 1.0, setting the corresponding slider directly to the given value - some code rework, mainly in the _init_hal_pin section and on encoder counts handling ver. 1.3.5.1 - forgot to reset the gcode error, resulting in showing it only once, it ws not shown again if a good file was loaded and than again the wrong one, now the load and edit button do reset the error code. ver. 1.3.5 - added the new signal from hal_gremlin to gmoccapy so we do get a message of gcode errors when loading a file and not only when the interpreter does read the wrong line. A warning box will inform about the error details. ver. 1.3.4 - if no virtual keyboard was installed (nor onboard or matchbox), the checkboxes on the settings page has not been sensitized and the settings has not been reset correctly from the preference file Thanks to Roland (concierge) for finding this one ver. 1.3.3 - the combobox for the mouse button mode has not been initialized correct, if it had the default value of the glade file. It is a bug in glade. The work around is not to set a default value in glade but in the python code. ver. 1.3.2 - fixed a small bug PAUSE button did not get active on M01 Thanks to Rick (LAIR82) for pointing on it. ver. 1.3.1 - fixed very serious bug PAUSE / RESUME / STOP issue Program jumped to strange positions if STOP has been pressed while PAUSE was active. Thanks to Mael (papaours) for finding it. ver. 1.3.0.1 - corrected a bug, toolchange velocity hal pin have not been preseted with values, if the user worked with the default values, so a probing with vel = 0 was possible, resulting in an error - corrected an error in notifications.py, as the text to be displayed has not been checked for correct pango format, a message like "vel <= 0" resulted in an error. Now the necessary check is done ver. 1.3.0 - added replace function to the edit page - added ignore case to allow case sensitive search - added reload button on edit page, so if you mixed up to much, you are able to reload the original file - corrected an error at start up, giving a button a label, conflicting with a button label - changed a wrong icon on the button go up one directory ver. 1.2.2 - changed the way the window size and position is handled, as before the default values did appear several times in the code - If no virtual keyboard could be initialized, we disable now the corresponding part on the settings page and the related button. Check will be done for and - starting gmoccapy did throw an error to the terminal that a widget could not get default. Finally I found the reason, the glade file did contain a property "has_default" and that is not allowed by builder. ver. 1.2.1 - due to the behavior of XFCE of the new hybrid.iso I had to change the width settings of several button to stretch them to fit some text and images - The same reason forced to set new default start position of the main window and the notification messages. ver. 1.2.0 - changed GetIniInfo to return also user message setups - notification now supports pango markup in the messages - added hal user messages similar to gsreeen to gmoccapy see gmoccapy_messages.ini for usage information - updated the translation files for German and Spanish ver. 1.1.5.9 - prepared yesno_dialog for user message, it does accept now pango markup - wrong values in axis offset didn't show a message to the user, I fixed that ver. 1.1.5.8 - message at start because of return(PlasmaClass(halcomp, builder, useropts)) instedt off return[PlasmaClass(halcomp, builder, useropts)] resulting in iteration over none object ver. 1.1.5.7 - init dynamic tab now in try except to avoid python exception on user typos in INI file - loading a tool using remap, led to an error if no file has been loaded before the change, we do check for that now to avoid the error ver. 1.1.5.6 - introduced three new hal-pin to signal program progress information gmoccapy.program.length = S32, OUT (total number of program lines) gmoccapy.program.current-line =S32, OUT (current executed line) gmoccapy.program.progress = FLOAT, OUT (progress in %) This pin do not work very perfect when using subroutines or remap procedures ver. 1.1.5.5 - if using remap, an error has been launched, if the user used the buttons of the tool edit widget to change the tools (not possible to change to auto mode) I moved the resting procedure of self.tool_change to hal_status_intp_idle to solve the wrong behavior ver. 1.1.5.4 - solved a bug showing screen2 at start up. Screen2 was initialized to early resulting in a runtime error ver. 1.1.5.3 - solved a bug if the user have NO_FORCE_HOMING in his INI and did a homing of an axis, resulting in some widgets being unsensitized. Thanks to Marius for reporting that one - after a tool touch off no G43 was committed even if that code was active so I added that command to be executed Thanks to Rene to report that one - some minor changes to lathe.ini, having HOME two times in the AXIS config ver. 1.1.5.2 - solved a bug, on clear G92 offsets handling, switching the GUI to MDI Mode, due to a strange behavior of the offsetpage widget, not going back to the previous mode. ver. 1.1.5.1 - solved a bug related to the gmoccapy error pin. This pin has not been reset if the user used the mouse or touch screen and erased the message by clicking the message button. It was only done right if the delete-message pin was used. I modified notification.py to emit a signal if a message has been deleted and connected this signal to gmoccapy. - corrected also a small mistake in _show_errors, it was possible to get messages without text, added a default text. ver. 1.1.5 - added a option to hide the 4'th axis, this is useful if that axis is used to control a tool changer, as than the axis DRO and jog button are not needed. This has to be activated on the settings page, axis 4 is shown by default. This needed some code rework (moving code around) - solved the problem of pin_value changes on start up / initializing, because I introduced a new intern variable self.initialized, leaving defs if not True - introduced a adjustment widget on the settings page to allow the user to set the font size of the DRO, it will be reduced by 3/4 if 4 axis are used ver. 1.1.4 - added again the gcode.lang file, it got lost, after changing gmoccapy to be stand alone - the show screen2 button is now only sensitive if a file gmoccapy2.glade does exist in the config dir. ver. 1.1.3 - it was possible to push btn_set_selected on offset page to set a coordinate system with G92 selected, or being in edit offset mode, this is now avoided. ver. 1.1.2 - after changing units according to G20 / G21 the scales to be applied to the jog wheel pin (jog_vel and max_vel has not been changed, resulting in very large jumps after changing from metric to imperial, i.e. one count should move the slider 100 increments in metric, but did that amount also in imperial, instead only advancing 4 steps. - all sliders and vel infos are now changing according to G20/G21 being active. - There is still work to do on the offsetpage widget, IMHO it is buggy ver. 1.1.1 - small bug in macro button handling, if a macro was not found, gmoccapy raised an exception, because wrong variable name. ver. 1.1 - this is the "final" version, ready to be included in a release candidate I did not change anything related to the last push, but after 1.10.2, I made a mistake with the release number, this push correct the error. ver. 1.0.3.2 - includes version number also in settings page as label in the bottom button bar ver. 1.0.3.1 - previous changes to NO_FORCE_HOMING resulted in automatic starting from line if a line has been selected in preview, I changed that so the line is just preselected, but not taken in care if run is pressed. The other way was to dangerous. ver. 1.0.3 - solved some bugs in NO_FORCE_HOMING not handled the correct way with start button and mode changes after setup page - get rid of hal_toggleaction_run and hal_action_stop, as the run widget caused one of the problems ver. 1.0.2.1 - spindle feedback bar changes will not effect any more the speed label value. It was double information and at the same time confusing for users. The spindle feedback bar will indicate the real spindle speed and the feed label will show the programmed value. ver. 1.0.2 - solved a bug in getting active gcodes, because I took also the first element of linuxcnc.stat.gcodes, but that seems not to be a gcode, but some kind of control number or something like that, so it causes wrong code and changed gmoccapy behavior in an erroneous way - In this bug finding I also needed to change the gladevcp widget combiDRO to get the correct results ver. 1.0.10.2 - solved a small bug with _set_spindle in auto mode ver. 1.0.10.1 - gremlin mouse button mode has not been initialized at start up ver. 1.0.10 - changed the behavior of the spindle feedback bar and the speed labels we do not change the bar limits from negative to positive, we use from now on only abs values! That is the reason I did include a additional abs in the postgui hal file - corrected an error, not allowing to switch spindle on / off while program paused ver. 1.0.9 - the ignore limits has not been called, due to a missing signal from the glade file, also the checkbox was hidden if machine off, so it could not be activated after hitting a limit switch. ver. 1.0.8 - Thanks to Steffen Noack we got new gremlin function for the mouse button behavior. Gmoccapy allows selecting the button mode from the settings page ver. 1.0.7.1 - when a external ESTOP was active and the tbtn_estop has been clicked it changed its color, but should not do so, solved - when external estop was active, it was possible to click the on button and the GUI changed state making several widgets sensitive, that behavior was wrong, solved that. - If you feed override has been changed and the machine went into estop, a estop reset also reset feed override to 100 % , now it will remain with the value it had before estop. - If a user activate logging actions, the logging was lost after shutting down the GUI, now the content of alarm_history will be written to a file called gmoccapy.log in your config dir. The file will be overwritten on each shutdown of gmoccapy with the new content. - EXIT Button is now only sensitive, when machine is switched off, so it is not longer possible to accidentally shut down the machine. - pressing estop from MDI mode with spindle on, resulted in an error, solved. ver. 1.0.7 - Reworked the emergency button behavior as well as the on/off button, as it was possible to set the GUI in an ESTOP_RESET state, even if an external SWITCH was in ESTOP State. The important bug has been found by Steffen, he also supplied the initial patch, witch has been adapted to my coding style ;-) - Next changed the error handling, separated the error reporting from periodic to an own function, so we are able to launch also our own errors over the same channel, and get error pin height and also the sound will be played. - Deleted some unneeded or double code. ver. 1.0.6.3 - Bug turning on flood with M8 and logging actions on, found by Stephen, solved that one ver. 1.0.6.2 - changed the standard setting of box_custom_? from expand = True to expand=False, so the panel will fit better found from verser building Z_compensation ver. 1.0.6.1 - forgot to set error pin height if an error occurs ;-) ver. 1.0.6 - Stefan found an error in getiniinfo, getting the PROGRAM_PREFIX from INI file, if the entry does not exist. Solved! ver. 1.0.6 - introduced new locations for EMBEDDED_TABS, it is possible to use in addition to the previous ones now also: * box_cooling (will hide the cooling frame and introduce your glade file) * box_spindle (will hide the spindle frame and introduce your glade file) * box_vel_info (will hide the velocity frames and introduce your glade file) * box_custom_1 (will introduce your glade file left of vel_frame) * box_custom_2 (will introduce your glade file left of cooling_frame) * box_custom_3 (will introduce your glade file left of spindle_frame) * box_custom_4 (will introduce your glade file right of spindle_frame) requested from verser ver. 1.0.5 - because of wrong steps in initializing the increment pins has not been made, I changed the init order and now they are there again ;-) ver. 1.0.4 - only plasma - make the gmoccapy_plasma glade panels react to theme changes after the theme change, a restart of the GUI is necessary ver. 1.0.4 - corrected the way of executing a program step by step ver. 1.0.3 - pressing the OFF button will bring you back to manual mode, because there is the "EXIT" button ver. 1.0.2 - solved a spindle button issue and included a check so it is no possible to exceed the limits of the spindle with override values. i.e. a spindle has a max of 6000 rpm and the user enters S 5500 M3 now he can increase the spindle override, but it will be limited by 109 %, because otherwise he would ask the spindle to run faster than allowed. ver. 1.0.1 - solved a bug, because I forgot to include some signals in glade file, so no jogging with button was possible ver. 1.0 - we reached the stable state! gmoccapy get completely separated from gscreen, resulting in a faster reaction and easier support and maintenance, as there is now less influence from the other gui. ver. 0.9.9.9.16 - a manual entry in the preference file logo = True in combination with logofile = "absolute path to logofile" will hide the jog button, jog increments and ignore limits and display the logo instead. ver. 0.9.9.9.15 - new hal pin gscreen.error as bit out, to show an error to the hardware, so a light can lit or even stop the machine. It will reset with the pin gscreen.delete-message. This command will delete the first error and reset the gscreen.error pin to False after the last error has been cleared. Messages or user infos will not affect this pin! ver. 0.9.9.9.14 - The usage of "EMBED_TAB_LOCATION = box_coolant_and_spindle" will not hide the velocity widgets any more, plasma handles that one now over tool_info_panel ver. 0.9.9.9.13 - solved a bug switching on/off the spindle if also log_actions was active, ver. 0.9.9.9.12 - added two hal pin to reset feed and spindle override gscreen.reset-feed-override gscreen.reset-spindle-override ver. 0.9.9.9.11 - solved startup bug, window not starting in position and dimensions as set in settings page - set new limits to size adjustments ver. 0.9.9.9.10 - added a refresh command to iconview, otherwise adding a file and reopening the view, would not refresh the view, so the added file could not be selected ver. 0.9.9.9.9 - I added three new hal pin. This pin do allow to reduce or enlarge the soft limits, so a pin is able to protect your rotary table from collision, because if you do not use it, you just reduce your soft limits, or you got a tool changer in the working area, you do not want a collision during normal work, but you are forced to enter the tool change area to change a tool, so during tool change you enlarge the soft limits. The pins are documented in the WIKI. You will get an error if you reduce the limits and you are outside the area! ver. 0.9.9.9.8 - toggle button setup was not handled correct by hardware momentary switches, fixed that ver. 0.9.9.9.7 - add gcode highlight by clicking in the preview clicking a line in the preview will highlight the corresponding line in gcode listing ver. 0.9.9.9.6 - solved show tool edit after program run after running a program and changing back to manual mode it was not possible to enter again the tool edit tab, as we where taken to MDI mode this was mainly caused by the check for G43 being active. ver. 0.9.9.9.5 - changed override behavior: feed override reduce the max velocity and the feed velocity, but the jog vel slider will remain with it's value, the override value will reduce the jog vel also! ver. 0.9.9.9.4 - added a new pin to delete the last message ver. 0.9.9.9.3 - scl_feed_override bug at start up, did not handle G0 Override correct, thanks to Marius for reporting that bug ver. 0.9.9.9.2 - scl_feed_override did not take influence on G0 velocities now it will take influence G1 and G0 velocities ver. 0.9.9.9.1 - there was a bug in tool touch off, discovered by Jim solved that ver. 0.9.9.9 - gmoccapy is now able to do auto tool measurement after an manual tool change - introduced a INI config to simulate that - still to do: If user click on abort while the tool change message window is still open or he closes the window with the small X on the right upper corner, the hal pin will not be rested properly ver. 0.9.9.8.2 - gmoccapy_plasma, changed pin names to follow the pin naming convention - included THC Button state in persistence (plasma.var) ver. 0.9.9.8.1 - self.data.jog_increments now is self.jog_increments changed the increments handling a little bit so there is no need any more for self.no_increments - changed code from self.gscreen.halcomp to self.halcomp, because it is the same ;-) - prepared to be able to get an gmoccapy hal component ver. 0.9.9.8 - bug in jogging with buttons and SHIFT hold down, as that would result in a move at max velocity, not taking in care the max vel slider - renamed self.data.ob to self.onboard_kb to make code clearer - self.data.plot_view was a relict from gscreen, because gscreen needs to toggle through the views, we can select them directly, so this data is gone now - self.data.hide_cursor is now self.hide_cursor so this is different to gscreen, so both GUI should not influence each other - self.data.key_event_last changed to self.last_key_event (distinguish from gscreen) - corrected some typo in release notes - self.data.file replaced with self.stat.file, as it is not necessary to hold that on data - self.data.estopped replaced with self.stat.task_state - self.data.machine_on replaced with self.stat.task_state - self.data.all_homed is now self.all_homed so I know that this value is not set from gscreen - self.data.spindle_speed and self.data.spindle_direction replaced with self.stat statements - self.data.flood and self.data.mist replaced with stat statements - self.data.active_feed replaced with stat statements, resulting in auto units change also for the speed labels - self.data.diameter_mode is now self.diameter_mode so its clear it come from gmoccapy - gremlin does react now on auto_units behavior of Combi_DRO - all sliders (scales) change according to active Gcode G20 / G21 - executing an MDI command will change the keyboard button to allow linuxcnc.abort() ver. 0.9.9.7.6 - solved the bug wrong units on start up without the preference file I needed to replace gscreen.status with my my own status, because gscreen does deliver wrong values! - changed some more gscreen.data stuff to self.stat..., because IMHO it is not necessary to use data to store something what is available through stat module - replaced the preference file handling from gscreen to an own one, expecting that gscreen does not mess my files up, if no preference file will be given in the INI, we will use gmoccapy.pref stored in the config folder, so there could be different configs with different settings - don't need gscreen.emc any more, all is done now directly with the linuxcnc python bindings - I do not use any more the gscreen.ini, we use now the linuxcnc.ini version from the python module ver. 0.9.9.7.5 - typo in initialize_preferences - deleted the statusbar widget - no more option to use gscreen error handling - no more option to use desktop notify - the optional stops button worked opposite it should - renamed some stuff from emc to linuxcnc or shortened the names - onboard keyboard showing in edit mode corrected - plasma.py changed order of getting widgets from builder, to avoid errors at load time - notification change line wrap mode to character, so longer file names will not be cut ver. 0.9.9.7.4 - the default tool change dialog now shows the tool number and the tool description - after deleting the preferences file you get an error starting the GUI, because it tried to load a file " ", I deleted the SPACE to solve that ver. 0.9.9.7.3 - plasma screen now hide also the vel_info_box - minimal changes on the glade files - modified the plasma.py file to support persistence variables the settings will be stored in plasma.var in your config dir - I set the plasma.py file under GPL license ver. 0.9.9.7.2 - introduced an better gcode highlight for sourceview ver. 0.9.9.7.1 - replaced the hal_scale_jog_vel with a normal scale, as there is no need for a additional hal pin - renamed hal pin gscreen.hal_hbar_spindle_feedback to be gscreen.spindle_feedback_bar gscreen.hal_led_spindle_at_speed to be gscreen.spindle_at_speed_led This way all spindle pins are together in halshow ver. 0.9.9.7 - make gmoccapy react to external mode changes, i.e. start program with net start halui.mode.auto => halui.program.run <= hardware.button ver. 0.9.9.6.3 - changed again the plasma layout, as Marius still want more widgets - most hal labels are not needed any more, so I changed them to gtk.label ver- 0.9.9.6.2 - added a lot of hal pin to gmoccapy_plasma, with the new plasma.py file - reworked the plasma.glade file to fit Marius needs - new order of configs, many files have been moved by Dewey Garret ver. 0.9.9.6.1 - solved a bug in plasma.py, having a call without function ver. 0.9.9.6 - made a new config folder to show gmoccapy as plasma screen - included some minor changes to be able to place user glade panels over the coolant and spindle frame, hiding the original widgets so plasma screen can easy be realized This will hide also the spindle speed label in gcode info frame. - the tool info frame can also be hidden by a user glade file, because tool info is not needed for plasma. - corrected an error in handling python calls in / for user glade screens, as example introduced plasma.glade plasma.hal and plasma.py demonstrating all possible communications ver. 0.9.9.5 - added color chooser for homed and unhomed colors, as recommended by BigJohnT to help people suffering from protanopia (red/green weakness) - corrected an error updating the DRO colors in lathe mode ver. 0.9.9.4 - initializing some warnings at start up, corrected that - deleted some unneeded print messages ver. 0.9.9.3 - if the user tried to make a new file and there where no RS274NGC_STARTUP_CODE in the INI file, an exception has been thrown fixed that bug - if the user tried to make a new file, after he made already one, an exception has been thrown, because the file was loaded already fixed that bug ver. 0.9.9.2 - solved a bug, entering the edit mode from auto mode, caused by a typo in a widget name ver. 0.9.9.1 - solved a bug showing the gremlin DRO, caused by a typo in a widget name - some buttons and widgets did not have tooltip text, added that ones - corrected German translation - corrected Spanish translation ver. 0.9.9 - introduced a new DRO, showing all three positions (Abs, Rel, DTG) at ones user can toggle the DRO by clicking on them - The new DRO also indicates the actual coordinate system - The new DRO will change its units according to the active gcode (G20 / G21) - There are still the three buttons, but they are hidden by default, this can be changed on the settings page, but when the buttons are visible, the user looses the auto units feature of the DRO Hope too get the permission from the users to delete that button as soon as possible - made the documentation for IconViewFileSelection - made the documentation for Combi_DRO - This change saved some lines of code in gmoccapy.py and made the code a lot easier to understand - updated German translation - updated Spanish translation ver. 0.9.8.4 - diameter dro does not show imperial units, even if machine units are imperial, fixed. - tool info only with three digits in imperial mode, now 4 digits - active feed and active vel label not in machine units, if in imperial mode, fixed - cosmetic changes to gmoccapy_lathe.ini - introduced an imperial lathe INI ver 0.9.8.3 - BUG: forget to update the coordinate system after changing the error system, causing the ABS/REL button not showing the correct label, fixed - BUG: inserted Jog Increment continuous instead of 0, so could cause an exception on translated GUI, fixed - BUG: when changing the mode from outside, i.e. starting a program with an external button, the GUI did not change the style to auto mode, so it was not consistent, fixed - deleted unnecessary icon and introduced new icon for machine on off and for the mode button (Thanks to Dejan/probamo) ver. 0.9.8.2 - make the design from spindle and coolant frames more beautiful - added both to a hbox, so later this box may be replaced by user controls, i.e. plasma cutters ver. 0.9.8.1 - introduced new Serbian translation ver. 0.9.8 - introduced notification as gmoccapy error messaging system - rebuild the settings page to make the message system settings available - new default startup position - changed DRO textcolor label to DRO background color label, because that is what you change - jogging with keyboard will jog full speed if SHIFT is hold down - key will delete the last message of gmoccapy message system - + delete all gmoccapy messages at once - switching on the machine will reset the GUI to manual mode - the setup button is no longer a member of the mode radiobuttons it is now a toggle button, so pressing it twice will bring you to manual mode ver. 0.9.7.5.1 - missed to change the version number in gmoccapy_handler.py corrected that ver. 0.9.7.5 - translation of the Continuous Jog Button now possible - solved a bug, when selecting the continuous jog button when it was translated - added ABS, DTG and GTD to translation file - added "show or hide tool path" to translation - corrected a bug changing spindle bar min and max values changed the widget only on restart - added to translation the complete gscreen.py file, even if there are a lot of things nobody need to translate, but that gives the possibility to translate the entry dialogs and some button labels ver. 0.9.7.4 - added the Serbian translation - corrected some mistakes in Spanish translation - moved some files to get them in the corresponding locale folder - modified .gitignore files so my locale folder will not be ignored any more ver. 0.9.7.3.1 - removed some print/debug lines - new order of the button in Auto Mode (requested from svenakela) - corrected some translation errors - changed the order of the jog button and the DRO, now when jogging on a touch screen, the right hand will not cover the DRO. Better handling?! - deleted the button reload from auto to get space for fullsize_preview, so the user can switch to full-size preview, while the program runs. - erased the close button in bottom button list edit, because the back button does the same - corrected the hardware button behavior, was needed because of the new order and the reason that not "clicked" is emitted, but "pressed" - button edit offsets now shows automatically the offset page - the buttons for full-size preview on auto and edit offsets getting yellow when active - pressing the button new in edit mode will make a new file in /tmp with the content from [RS274NGC] "RS274NGC_STARTUP_CODE" followed by 3 linefeed and an M2 ver. 0.9.7.3 - the buttons tbtn_view_dimension and tbtn_view_tool_path of the gremlin view was in an undefined state after the start of gmoccapy. Now the state will be set according to the state when leaving the GUI, default is show both - the state view of gremlin was by default "p" no the state on leaving the gui will be restored after restarting the GUI - corrected an error entering the settings page, and aborting the dialog, then the message appears two times, because the signal used was clicked and that is emitted twice on a rbt when changing the state of the buttons in the group ver. 0.9.7.2 - check for NO_FORCE_HOMING included ver. 0.9.7.1 - changed the structure of the files, so the user do not need to copy files after an update he only needs to adapt his config files, this follows the new gscreen structure and all files should be present after installing linuxcnc - corrected some typos in code - changed my way to show the entry dialog as integer only to the gscreen way - added a file chooser to settings page to select the jump to dir for IconFileSelection - file extensions are now taken from INI file and converted from raw data to correct format in an own function, taken in care in IconFileSelection and file to load chooser - solved an error in IconFileSelection, crashing the GUI if button up was pressed being in the root dir ver. 0.9.7 - added a file selection dialog, for touch screen use - in MDI mode it is now possible to add more commands, even if the interpreter is running - do not block any more the spindle buttons while the interpreter is running, so spindle can be switched on and of at any time - added a selection for show keyboard on file selection in settings page - changes button home_4 to show different icon, depending on INI settings of 4th axis - moved some code "G95 related" from periodic to _update_vel - corrected some align values in glade file - removed units from max_vel_label (glade file) - corrected hardware button behavior - added again a sim hardware INI file - uniform usage of "" instead of sometime '' (just to clear python style) - user can select on settings page, if he want the offsettab or the preview tab to be displayed as default, the ntb_tabs are shown, so changing is possible at any time - prepared to get later our own error handling, introduced Notification Class, at the moment disabled - corrected an error if setting the coordinate system after setting axis values in touch off dialog ver. 0.9.6.1 - fixed a bug editing a tool while G43 is active! - added a feature, that will update G43 after a toolchange if it was active on toolchange start - tooloffset in Information frame does now show the real pin values motion.tooloffset.z if connected to gscreen.tooloffset_z in postgui.hal file (for lathe also x values) - cleared the code from some unnecessary ".gscreen." ver. 0.9.6 - included the 4-th axis, buttons will change according to INI file settings - corrected not taken care of PROGRAM_PREFIX path set in the INI file - G95 Bug solved, it was caused from sim_spindle_encoder.hal, using now a modified hal from axis - cleared a warning of missing handler ver. 0.9.5.1 - bug in spindle switching while in LOG Mode - ESC and F1 keys will work now, even if use Keyboard shortcuts is not activated - solved a bug in run_from_line, the start line was not reset after program stop, and I missed to reset self.data.restart_dialog to None ver. 0.9.5 - Keyboard shortcuts, now ESCAPE only aborts and F1 emit estop - spindle can be switched on and off while program is paused, without getting an error - sourceview now with search and do / redo, while in edit mode - added an offset page in ntb_preview with the possibility * to select directly an coordinate system * edit the coordinates of every system * give the systems human names - fixed a bug in tooledit, trying to touch of a tool not in spindle, I must check if this should be allowed or if it better only allowing touch off with the tool in spindle - changed gmoccapy keyboard to "onboard", if the layout is not correct, the following command will correct it setxkbmap -layout gb for Great Britan, de for germany, etc. - changes in gscreen broke gmoccapy cycle start seems that hal_action run is not any longer permitted, now hal toggle action is needed, corrected this - changed the entry dialog, so in some cases it is only possible to enter integer values - added a button to select a tool by its number, it is easier, if you have a lot of tools - cleared the code a lot - settings page, it is possible to select if you want to use the onbord keyboard also in tooledit page and in offset page editing - deleted the hardware button simulation INI, because it will not work as it should and I was not able to find a solution. ver. 0.9.4 - corrected a lot of typo, thanks to David for his help - renamed some widgets from "cero" to "zero" - deleted one increment in every INI file, so the GUI fits better to smallest screen size - translation to german included and prepared for more languages - there was still an error in key handling with incremental jogging, hope I solved it now for final - changed the dialog "run_from_line" to use gscreens default, resulting in the need to rename "hal_sourceview" to "gcode_view" - renamed all pins and definitions from "override" to "override" because of typo - avoid getting to the touch off button, while the machine is not homed - hide Y touch off buttons in lathe mode - solved a bug executing a command constantly related with feed and periodic - Tool change from tool editor now works like it should even with T1 M6 as with M61 Q1 - the tool in spindle will be checked if you enter the tool editor. ver. 0.9.3.2 - aligned the jog_button and jog_rates frame on the top (just cosmetic) - The Page-up and Page_Down keyboard keys moved the Z axis in opposite directions - Feed values will only be shown with digit if G95 is active - added classicladder button to the list of buttons to be able to handle it with hardware button - changed hardware button handling to fit also to lathe mode - included a test to avoid speeding the spindle over its limit using the spindle speed override i.e. max = 6000 but S = 5500 and override = 120 % would result in 6600, but only 6000 is possible - also check spindle speed if the commands are given through MDI and override is to high will reduce the override value to max allowed ver. 0.9.3.1 - A message window will warn the user in case he try to use G95 - Changed the required screen size to fit on 979 x 750 ver. 0.9.3 - included the patch for key_jogging from Chris - support now also back tool lathes - after M61 Q tool change, the Gui didn't leave the MDI modem resulting in problems - the btn_view_Y2 has now a yellow background - changing the max vel slider had no effect, I fixed this ver. 0.9.2 - added lathe mode - added classicladder button - added button for tool touchoff in X and Z axis - corrected the key handling, now also F1 and F2 works and ESC emit emc.aboart() ver. 0.9.1.2 - trying to jog the machine with the keyboard a python error was launched, because Chris renamed the data.event_up to data.event_last solved this renaming the data also in gmoccapy ver. 0.9.1.2 - missed renaming one widget in code, due to the changes on the settings page, resulting in an exception solved this renaming the widget in gmoccapy ver. 0.9.1 - show offsets and show dtg for gremlin are only sensitive if show gremlin DRO is active, other behavior makes no sense - settings page can be reached now also in estop state - desktop notify can be disabled in settings page, makes the gui faster - file to load on start up can be selected on settings page - in init_file_to_load added a selection of filters given in INI File - button save and run has now a tool tip text, it wasn't shown, because it was set translatable and no translation was available - check on macro execution for errors before starting the macro - added a checkbox to select the use of keyboard shortcuts - reconnected the sim spindle to gmoccapy - in MDI Mode giving S0 now switch the spindle off - from INI [DISPLAY] min_spindle_override is used to set the slider limits - spindle settings moved from INI to the settings page and preference file - def init_gremlin now in gmoccapy, to avoid widget name conflicts - DRO settings changed in settings page, checkboxes instead of toggle button and all settings related to DRO in one frame - added scale settings for the hardware mpg encoders to move the sliders, otherwise for max vel being 14000 the changes was to small, counting one by one - hardware keyboard now works also in settings page and debug page - Screen2 can be shown now, but I noticed, that if the screen is very complex, the application will crash! ver. 0.9.01 - fixed a bug in keyhandling mentioned by Chris * changing the jog velocity while jogging in continuous caused by focus jumping from widget to widget when holding down a key * Keyboard autorepeat caused moving the machine by several increments instead of only one. ver. 0.9.0 - unlock settings now with tool tip text - I forgot an letter in hal pin feed-override-counts - The button Rel/Abs changes its label according to the active coordinate system and its background color does change if G54 is not active - solved the estop error not showing the correct state on start up - solved a bug giving value 0 to macro, the entry widget checked this value as False - merged with new master and also with gscreen with new widget names - gscreen fired a error when there is no keyhandling in gmoccapy, i introduced a dummy - after start some buttons wasn't set in correct state, it was possible to enter MDI Mode without homing before. - avoid switching screens to MDI and back to manual on tool change - cooling mist and lube can be switched on and off every time you want - you can jog the machine in 3 axis with the keyboard button, but only in manual mode this is just a test, I don't now if I leave this feature in gmoccapy - as run from line is not very secure and also not working yet correctly, I made it selectable in the settings page - in settings you can select now qwertz or qwerty keyboard layout - in settings you can select whether the On Screen keyboard are shown by default or not for mode MDI and mode EDIT separately ver. 0.8.9 - new icon for btn_user_tabs - new icon for btn_fullsize_preview - all dialogs do react to keyboard input now - System theme has not been set properly on start up, fixed this. - added a new place for user tabs, within ntb_preview, showing then the tabs - added a test to show actual velocity in machine units. - added hal pins to be able to connect a hardware selection switch to jog_increment radio button - entering the edit mode sets the focus in the hal_sourceview widget, so working with keyboard is possible without any cklick - After editing the tool offsets in table, the button "Apply" will not only apply the changes to tool table, but also to the tool in spindle, but only if G43 is in active G-codes - speeded up the tool change screen refresh, by adding self.on_hal_status_interp_idle(self) in the button press event - added hal pins for jogging the axis with hardware buttons for each axis in self.data.axis_list - deleted the metric button from settings page - changed hal_pin_names to use "-" instead of "_" - on tool table page I missed to add tool tip text to the buttons, I added them now - added a hal pin to unlock the settings page, so a key-switch can be used to unlock the page ver. 0.8.8 - there was an error getting the increments from the INI file I begin counting from 1 instead of 0, that is why the first increment was missing - solved a problem while switching flood or mist on/off with MDI commands, the buttons got active like they should, but the icon didn't change from on/off, solved that changing _update_coolant - when the tool was changed using M61Q, the screen has not been set back to manual mode properly, this was caused by asking if tool:, but as at the beginning toolnumber is zero, this decision was taken wrong, after changing it to if tool or tool == 0: it does work - running a macro changed the image and function of the keyboard button, but the tool tip text didn't change, I fixed this. - it was possible to reduce the max_vel of the machine less than the jog_velocity, so it was possible to jog faster than the max velocity you set with the corresponding slider I fixed this, if you reduce max-vel lower than jog_vel, jog vel will be reduced too - spindle bar won't grow with negative values (spindle reverse); I know it worked already, why did I have to fix this again? - entering the MDI Mode sets the focus directly to the entty of hal_mdihistory ver. 0.8.7 - changed the button to delete status bar messages from text to icon - changed the INI files to display the side panels vice versa - made vcp_box.glade fit better in the screen ver. 0.8.6 - all buttons on settings now with active back color "yellow" - added a button to set logging or not, will add later a option to store the logging in a hidden file - solved a bug switching fullscreen views, I missed to add a size request to window1 in glade file, smallest window possible = 979 x 782 - added a button to clear the statusbar information - new hal-pin jog_increment as float out pin - copied init increments from gscreen to gmoccapy and modified it to not get added an continuous at the end, I want it with first upper letter and as first position, to not get problems while creating the buttons dynamically - removed some print commands - changed the test for gremlin DRO from preferences file to button state - made hal pins to connect MPG Wheels to the sliders * gscreen.spindle_override_counts * gscreen.feed_override_counts * gscreen.max_vel_counts * gscreen.jog_speed_counts Does anyone know, why the connection in postgui hal change the jog counts by one and modify this way the scale from 100 to 101? ver. 0.8.5 - included a button to toggle gremlin fullview but getting out of the fullscreen mode will hide the DRO not taking care of preferences, I do not not why - implemented a function to set gremlin grid Grid is set in INCH, not taking care of the preferences file ver. 0.8.4 - thanks to Chris the software starts now on a new installation with "Follow System Theme" theme - Keyboard now with upper and lower letters (SHIFT Key included) ver. 0.8.3 - there was still a problem with DTG and DRO switching, now everything is working like it should - now not the gscreen colors are used, on first start every color is set to black, after that the colors are handled as they are in gscreen. - Delete MDI is working, but until now only for the running session - I deleted some lines of code in 0.7.05, resulting in damaging the tool editor, fixed this - reorganized the order from buttons to be modified during INIT, now they are in alphabetic order - made several INI Files to show the behavior with side panels and user tabs and simulated hardware button - included the following buttons in settings page - enable gremlin DRO - Show gremlin DTG - show gremlin offsets - check if tool in spindle == tool to change, then give message and return ver. 0.8.2 - solved the error related to the DTG Button - clearing the code - added a SPINDLE section to INI to get the min and max spindle speed - change the spindle bar properties by code to show also negative revolutions - spindle speed label shows also negative values if spindle runs reverse - solved a bug in macro execution, when wrong values has been given ver. 0.8.1 - clearing the code - unlock code now in the hidden preference file, but I still need to include an change function in the settings page - emergency exit is now default on start - there is still an error changing from DTG to GTD in ABS and REL changing ver. 0.8.0 - colorselection for the different dro states now works, but there is still a small error, after changing a color, it will not show the eventboxes in proper color. After a new start of gmoccapy it works like it should. I searched already three days for a solution, but I couldn't find any. - removed some unused print() commands - gmoccapy.glade is now able to add side panels, on the left and right - user tabs are working, I need to make some documentation ver. 0.7.09 - changed tool change dialog from axis dialog to gscreen dialog, you can switch back if you like by commenting the tool change lines in postgui.hal file. - btn not implemented clicked now logs the button ver. 0.7.08 - merged with /origin/master instead of mah/master - using now hide_buttonbox from tooledit widget instead of hiding the box by an own method - solved a problem reported by Chris, blinking coolant button. The behavior was caused from _update_coolant() - renamed tbtn_coolant to tbtn_flood - bugfix on macro goto position caused from self.on_btn_macro_pressed() - finished the hal connections also for the vertical buttons to test with simulated buttons, you have to uncomment the corresponding lines in INI and postgui.hal then two buttonlist will appear - There was a problem executing the macros with the hardware button, user where able to start a second macro while the first was still running, solved that - Running macros can be aborted, the show_keyboard button will change it's image and get an other function ver. 0.7.07 - solved a problem switching main button list, wait on tool change has not been reset properly - now I hide the hbuttonbox of tooledit widget instead of every button, this saved 6 lines of code :-) ver. 0.7.06 - finished the h_button hardware pin connection - macros can be run by hardware button to test the features, just uncomment 3 lines in INI File DISPLAY section, see comments there and uncomment the connections made in gmoccapy_postgui.hal I need someone to test this with real hardware, as with gladevcp buttons there seems to be a problem with the mode settings, change a tool with M61 will not bring you back in manual mode using the software keys, due to gladevcp in my opinion. ver. 0.7.05 - made the tooledit button work on my layout - all bottom button have there own hal pins, witch can be connected to hardware button so no touch screen is needed. v_button still to do and macros not working jet. - added an icon for tool-change ver. 0.7.04 - added preference file path to INI file - added the release notes file - hide the button of tooledit widget - all tool change thinks are now done with the tool_edit_widget by selecting the tool from the list ver. 0.7.03 - added Release Number to title bar, so it is easier for users to see if they got the latest release ver. 0.7.02 - added the capability to launch macros with variable parameters - MDI and Auto mode can now only be reached if state all_homed = True - added sample macros ver. 0.7.01 - changed the foldername to use only lower letters - cleared the directory gmoccapy, all hal files are now again symbolic links - renamed the scripts folder to subroutines and moved it in the nc_files folder - icons folder not touched at the moment - changed INI File to use other paths and renamed SCRIPTS to macros, next it will be changed to be the same as in touchy ver. 0.7.00 - finished the keyboard, it does now scroll in EditMode as well as in MDI Mode - Solved a problem with the index tool button, it stays unsensitized after an machine off, now it is working like it should - smaller changes in the icon folder ver. 0.6.09 - some more new icon - merged with master - added some new icon - changed the position from the right button - in emergency state the button to close gmoccapy was disabled, so it wasn't possible to close the application in fullscreen mode. ver. 0.6.08 - Virtual Keyboard included and working on MDI and AUTO Mode unfortunately the corresponding windows will not scroll as they should - bug found in setting G54 origin, solved! ver. 0.6.07 - I finished the keyboard, in editing mode it is working fine in MDI mode I have to find out, how to move the selected row in the hal_mdi_history using the cursor buttons! ver. 0.6.06 - Edit program works - make new programs works too - new keyboard with nearly all keys - Attention: On editing a program the keyboard need some more fine polishing, to allow editing text in the middle and I have to include cursor keys ver. 0.6.05 - begin to include the edit mode for G-code programs not working jet, still work to do The graphics part is finished, just the icon are not very nice ver. 0.6.04 - changed hal pin connections to control homing to gscreen matter so nearly all connections to postgui hal are not needed any more - all messages prepared to get translated _(message) - Run from line is now included, but at the moment without control of previous lines, this is still to do. - settings page begin to work + fullscreen is included + hide cursor is working + sounds are selectable + spindle start rpm is working ver. 0.6.03 - optional blocks now working - optional stops working too - added missing button in MDI Keypad (I missed I ; J ; K ) - cooling and spindle buttons react to emc stat, so setting an M7 will toggle the corresponding button, so will an M3 or an M5 This is not working in AUTO MODE with interpreter running to avoid error messages. - changed the test files to have optional blocks and stops. ver. 0.6.02 - all icons moved to icon folder - implemented get toolinfo, tool frame now shows correct data - implemented user mdi command through gscreen, so there is no need any more to import linuxcnc - added some more icon ver. 0.6.01 - solved the problem that widgets don't get sensitized after a pause and a later resume. - there will appear an error if in Pause you push coolant or spindle button because the command mode will be changed, the program will run later as usual ver. 0.6.00 - mostly I changed the name to Gmoccapy as invented by Chris - some minor changes in code ver. 0.5.08 - program label at start up was wrong - after pushing manual button staying in settings, main button list was not changed back to manual - max velocity now again in units per minute, seems Chris changed it back ver. 0.5.07 - axis setting to an value with preferences is working fine - DRO labels changing colors like they should - Added a button to set tool with M61 Q? - Commented a little bit more the code - prepared INI File for scripts execution - Fullscreen is included now - HalScope Button added - Prepared to execute MDI commands, will later read them also from the INI File as HALUI_COMMAND ver. 0.5.06 - added hal scope - cleared the code a little bit more - removed unused jog-increment-out pin ver. 0.5.05 -cleaned up and solved merge conflicts This is a version for first tests by users!
