1. Introduction
images/keystick.png
Figure 1. The Mini Graphical Interface
Keystick is a minimal text based interface.
2. Installing
To use keystick change the DISPLAY setting in the ini file setting to:
DISPLAY = keystick
3. Using
Keystick is very simple to use. In the MDI Mode you simply start typing the g code and it shows up in the bottom text area. The ? key toggles help.
