1. Introduction
Halui is a HAL based user interface for LinuxCNC, it connects HAL pins to NML commands. Most of the functionality (buttons, indicators etc.) that is provided by a traditional GUI (mini, Axis, etc.), is provided by HAL pins in Halui.
The easiest way to add halui is to add the following to the [HAL] section of the ini file.
HALUI = halui
An alternate way to invoke it is to include the following in your .hal file. Make sure you use the actual path to your ini file.
loadusr halui -ini /path/to/inifile.ini
2. Halui pin reference
halui.abort (bit, in) - pin to send an abort message (clears out most errors)
halui.axis.n.pos-commanded (float, out) - Commanded axis position in machine coordinates
halui.axis.n.pos-feedback (float, out) - Feedback axis position in machine coordinates
halui.axis.n.pos-relative (float, out) - Commanded axis position in relative coordinates
halui.estop.activate (bit, in) - pin for requesting E-Stop
halui.estop.is-activated (bit, out) - indicates E-stop reset
halui.estop.reset (bit, in) - pin for requesting E-Stop reset
halui.feed-override.count-enable (bit, in) - must be true for counts to work.
halui.feed-override.counts (s32, in) - counts * scale = FO percentage
halui.feed-override.decrease (bit, in) - pin for decreasing the FO (-=scale)
halui.feed-override.increase (bit, in) - pin for increasing the FO (+=scale)
halui.feed-override.direct-value (bit, in) - false when using encoder to change counts, true when setting counts directly.
The count-enable pin must be true.
[This function had been released, but is currently withdrawn for further development. It may or may not be present in your version of LinuxCNC.]
halui.feed-override.scale (float, in) - pin for setting the scale for increase and decrease
halui.feed-override.value (float, out) - current FO value
halui.mist.is-on (bit, out) - indicates mist is on
halui.mist.off (bit, in) - pin for requesting mist off
halui.mist.on (bit, in) - pin for requesting mist on
halui.flood.is-on (bit, out) - indicates flood is on
halui.flood.off (bit, in) - pin for requesting flood off
halui.flood.on (bit, in) - pin for requesting flood on
halui.home-all (bit, in) - pin for requesting all axis to home. This pin will only be there if HOME_SEQUENCE is set in the ini file.
<n> is a number between 0 and 8 and selected.
halui.jog-deadband (float, in) - deadband for analog jogging (smaller jogging speed requests are not performed)
halui.jog-speed (float, in) - pin for setting jog speed for minus/plus jogging
halui.jog.<n>.analog (float, in) - analog velocity input for jogging (useful with joysticks or other analog devices)
halui.jog.<n>.increment (float,in) - pin for setting the jog increment for axis <n> when using increment-minus or increment-plus to jog.
halui.jog.<n>.increment-minus (bit, in) - pin for moving the <n> axis one increment in the minus direction for each off to on transition.
halui.jog.<n>.increment-plus (bit, in) - pin for moving the <n> axis one increment in the plus direction for each off to on transition.
halui.jog.<n>.minus (bit, in) - pin for jogging axis <n> in negative direction at the halui.jog.speed velocity
halui.jog.<n>.plus (bit, in) - pin for jogging axis <n> in positive direction at the halui.jog.speed velocity
halui.jog.selected.increment (float,in) - pin for setting the jog increment for the selected axis when using increment-minus or incremet-plus to jog.
halui.jog.selected.increment-minus (bit, in) - pin for moving the selected axis one increment in the minus direction for each off to on transition.
halui.jog.selected.increment-plus (bit, in) - pin for moving the selected axis one increment in the plus direction for each off to on transition.
halui.jog.selected.minus (bit, in) - pin for jogging the selected axis in negative direction at the halui.jog.speed velocity
halui.jog.selected.plus (bit, in) - pin for jogging the selected axis in positive direction at the halui.jog.speed velocity
halui.joint.<n>.has-fault (bit, out) - status pin telling the joint has a fault
halui.joint.<n>.home (bit, in) - pin for homing the specific joint
halui.joint.<n>.is-homed (bit, out) - status pin telling that the joint is homed
halui.joint.<n>.is-selected bit (bit, out) - status pin a joint is selected* internal halui
halui.joint.<n>.on-hard-max-limit (bit, out) - status pin telling joint <n> is on the positive hardware limit switch
halui.joint.<n>.on-hard-min-limit (bit, out) - status pin telling joint <n> is on the negative hardware limit switch
halui.joint.<n>.on-soft-max-limit (bit, out) - status pin telling joint <n> is at the positive software limit
halui.joint.<n>.on-soft-min-limit (bit, out) - status pin telling joint <n> is at the negative software limit
halui.joint.<n>.select (bit, in) - select joint (0..8) - internal halui
halui.joint.<n>.unhome (bit, in) - unhomes this joint
halui.joint.selected (u32, out) - selected joint (0..8) - internal halui
halui.joint.selected.has-fault (bit, out) - status pin telling that the joint <n> has a fault
halui.joint.selected.home (bit, in) - pin for homing the selected joint
halui.joint.selected.is-homed (bit, out) - status pin telling that the selected joint is homed
halui.joint.selected.on-hard-max-limit (bit, out) - status pin telling that the selected joint is on the positive hardware limit
halui.joint.selected.on-hard-min-limit (bit, out) - status pin telling that the selected joint is on the negative hardware limit
halui.joint.selected.on-soft-max-limit (bit, out) - status pin telling that the selected joint is on the positive software limit
halui.joint.selected.on-soft-min-limit (bit, out) - status pin telling that the selected joint is on the negative software limit
halui.joint.selected.unhome (bit, in) - pin for unhoming the selected joint.
halui.lube.is-on (bit, out) - indicates lube is on
halui.lube.off (bit, in) - pin for requesting lube off
halui.lube.on (bit, in) - pin for requesting lube on
halui.machine.is-on (bit, out) - indicates machine on
halui.machine.off (bit, in) - pin for requesting machine off
halui.machine.on (bit, in) - pin for requesting machine on
The maximum linear velocity can be adjusted from 0 to the MAX_VELOCITY that is set in the [TRAJ] section of the ini file.
halui.max-velocity.count-enable (bit, in) - when TRUE, modify max velocity when counts changes
halui.max-velocity.counts (s32, in) - lets you hook up an encoder to change the max velocity
halui.max-velocity.decrease (bit, in) - pin for decreasing max velocity
halui.max-velocity.increase (bit, in) - pin for increasing max velocity
halui.max-velocity.scale (float, in) - the amount applied to the current maximum velocity with each transition from off to on of the increase or decrease pin in machine units per second.
halui.max-velocity.value (float, out) - is the maximum linear velocity in machine units per second.
Sometimes the user wants to add more complicated tasks to be performed by the activation of a HAL pin. This is possible using the following MDI commands scheme:
The MDI_COMMAND is added to the ini file in the [HALUI] section.
[HALUI] MDI_COMMAND = G0 X0
When halui starts it will read the MDI_COMMAND fields in the ini, and export pins from 00 to the number of MDI_COMMAND’s found in the ini up to a maximum of 64 commands.
halui.mdi-command-<nn> (bit, in) - halui will try to send the MDI command defined in the ini. This will not always succeed, depending on the operating mode LinuxCNC is in (e.g. while in AUTO halui can’t successfully send MDI commands). If the command succeeds then it will place LinuxCNC in the MDI mode and then back to Manual mode.
halui.joint.select (u32, in) - select joint (0..8) - internal halui
halui.joint.selected (u32, out) - joint (0..8) selected* internal halui
halui.joint.x.select bit (bit, in) - pins for selecting a joint* internal halui
halui.joint.x.is-selected bit (bit, out) - indicates joint selected* internal halui
halui.mode.auto (bit, in) - pin for requesting auto mode
halui.mode.is-auto (bit, out) - indicates auto mode is on
halui.mode.is-joint (bit, out) - indicates joint by joint jog mode is on
halui.mode.is-manual (bit, out) - indicates manual mode is on
halui.mode.is-mdi (bit, out) - indicates mdi mode is on
halui.mode.is-teleop (bit, out) - indicates coordinated jog mode is on
halui.mode.joint (bit, in) - pin for requesting joint by joint jog mode
halui.mode.manual (bit, in) - pin for requesting manual mode
halui.mode.mdi (bit, in) - pin for requesting mdi mode
halui.mode.teleop (bit, in) - pin for requesting coordinated jog mode
halui.program.block-delete.is-on (bit, out) - status pin telling that block delete is on
halui.program.block-delete.off (bit, in) - pin for requesting that block delete is off
halui.program.block-delete.on (bit, in) - pin for requesting that block delete is on
halui.program.is-idle (bit, out) - status pin telling that no program is running
halui.program.is-paused (bit, out) - status pin telling that a program is paused
halui.program.is-running (bit, out) - status pin telling that a program is running
halui.program.optional-stop.is-on (bit, out) - status pin telling that the optional stop is on
halui.program.optional-stop.off (bit, in) - pin requesting that the optional stop is off
halui.program.optional-stop.on (bit, in) - pin requesting that the optional stop is on
halui.program.pause (bit, in) - pin for pausing a program
halui.program.resume (bit, in) - pin for resuming a paused program
halui.program.run (bit, in) - pin for running a program
halui.program.step (bit, in) - pin for stepping in a program
halui.program.stop (bit, in) - pin for stopping a program
halui.spindle-override.count-enable (bit, in) - when TRUE, modify spindle override when counts changes.
halui.spindle-override.counts (s32, in) - counts * scale = SO percentage
halui.spindle-override.decrease (bit, in) - pin for decreasing the SO (-=scale)
halui.spindle-override.direct-value (bit, in) - false when using encoder to change counts, true when setting counts directly. The count-enable pin must be true.
halui.spindle-override.increase (bit, in) - pin for increasing the SO (+=scale)
halui.spindle-override.scale (float, in) - pin for setting the scale on changing the SO
halui.spindle-override.value (float, out) - current SO value
halui.spindle.brake-is-on (bit, out) - indicates brake is on
halui.spindle.brake-off (bit, in) - pin for deactivating spindle/brake
halui.spindle.brake-on (bit, in) - pin for activating spindle-brake
halui.spindle.decrease (bit, in) - decreases spindle speed
halui.spindle.forward (bit, in) - starts the spindle with CW motion
halui.spindle.increase (bit, in)- increases spindle speed
halui.spindle.is-on (bit, out) - indicates spindle is on (either direction)
halui.spindle.reverse (bit, in)- starts the spindle with a CCW motion
halui.spindle.runs-backward (bit, out) - indicates spindle is on, and in reverse
halui.spindle.runs-forward (bit, out) - indicates spindle is on, and in forward
halui.spindle.start (bit, in) - starts the spindle
halui.spindle.stop (bit, in) - stops the spindle
halui.tool.length-offset (float, out) - indicates current applied tool-length-offset
halui.tool.number (u32, out) - indicates current selected tool
