1. Actualizando de 2.4.x a 2.5.x
As of version 2.5.0, the name of the project has changed from EMC2 to LinuxCNC. All programs with "emc" in the name have been changed to "linuxcnc" instead. All documentation has been updated.
Additionally, the name of the debian package containing the software has changed. Unfortunately this breaks automatic upgrades. To upgrade from emc2 2.4.X to linuxcnc 2.5.X, do the following:
1.1. On Ubuntu Lucid 10.04
First you need to tell your computer where to find the new LinuxCNC software:
Click on the System menu in the top panel and select Administration->Software Sources.
Select the Other Software tab.
Select the entry that says
http://linuxcnc.org/lucid lucid base emc2.4
or
http://linuxcnc.org/lucid lucid base emc2.4-sim
and click the Edit button.
In the Components field, change emc2.4 to linuxcnc2.5, or change emc2.4-sim to linuxcnc2.5-sim.
Click the OK button.
Back in the Software Sources window, Other Software tab, click the Close button.
It will pop up a window informing you that the information about available software is out-of-date. Click the Reload button.
Now your computer knows about the new software, next we need to tell it to install it:
Click on the System menu in the top panel and select Administration->Synaptic Package Manager
In the Quick Search bar at the top, type linuxcnc.
Click the check box to mark the new linuxcnc package for installation.
Click the Apply button, and let your computer install the new package. The old emc 2.4 package will be automatically removed to make room for the new LinuxCNC 2.5 package.
1.2. On Ubuntu Hardy 8.04
Go to Settings->Repositories.
Select the "Third-Party Software" tab.
http://linuxcnc.org/hardy hard emc2.4
or
http://linuxcnc.org/hardy hardy emc2.4-sim
In the Components field, change emc2.4 to linuxcnc2.5 or emc2.4-sim to linuxcnc2.5-sim.
Back in the Software Sources window, click the Close button.
Back in the Synaptic Package Manager window, click the Reload button.
In the Synaptic Package Manager, click the Search button.
In the Find dialog window that pops up, type linuxcnc and click the Search button.
Click the check-box to mark the linuxcnc package for installation.
2. Config changes
The user configs moved from $HOME/emc2 to $HOME/linuxcnc, so you will need to rename your directory, or move your files to the new place.
The hostmot2 watchdog in LinuxCNC 2.5 does not start running until the HAL threads start running. This means it now tolerates a timeout on the order of the servo thread period, instead of requiring a timeout that’s on the order of the time between loading the driver and starting the HAL threads. This typically means a few milliseconds (a few times the servo thread period) instead of many hundreds of milliseconds. The default has been lowered from 1 second to 5 milliseconds. You generally don’t need to set the hm2 watchdog timeout any more, unless you’ve changed your servo thread period.
The old driver for the Mesa 5i20, hal_m5i20, has been removed after being deprecated in favor of hostmot2 since early 2009 (version 2.3.) If you are still using this driver, you will need to build a new configuration using the hostmot2 driver. Pncconf may help you do this, and we have some sample configs (hm2-servo and hm2-stepper) that act as examples.
3. Actualizando de 2.3.x a 2.4.x
Las siguientes instrucciones solo aplican a Ubuntu 8.04 "Hardy Heron". LinuxCNC 2.4 no se encuentra disponible en versiones mas antiguas de Ubuntu.
Debido a la existencia de incompatibilidades entre 2.3.5 y 2.4.x, su instalación actual no se actualizara automáticamente por el agente de actualización a 2.4.x. Si usted desea correr la versión 2.4.x, Cambie al repositorio LinuxCNC-2.4 siguiendo estas instrucciones:
Ejecute System/Administration/Synaptic Package Manager
Vaya a Settings/Repositories
En la lista de “Third-Party software” debe haber al menos dos lineas para linuxcnc.org
Para cada una de ellas:
Seleccione la linea y haga clic en Editar
En la linea de componentes, cambie emc2.3 a emc2.4
Haga clic en OK
Cierre la ventana "Software Preferences"
Haga clic en "Reload"
Haga clic en "Mark All Upgrades"
Haga clic en Apply
4. Cambios entre 2.3.x y 2.4.x
Una vez completada la actualización, actualice cualquier archivo de configuración de maquinas que tenga previamente configuradas siguiendo estas instrucciones:
4.1. emc.nml cambios (2.3.x a 2.4.x)
Para configuraciones que no posen un archivo emc.nml personalizado, remueva o comente la linea NML_FILE = emc.nml en el archivo .ini. Esto causara que se use la versión mas actual de emc.nml.
Para configuraciones que tienen un archivo emc.nml personalizado, un cambio similar es requerido.
El no realizar el cambio puede ocasionar la aparición de un error tal como:
libnml/buffer/physmem.cc 143: PHYSMEM_HANDLE: Can't write 10748 bytes at offset 60 from buffer of size 10208.
4.2. Cambios en la tabla de Herramientas (2.3.x a 2.4.x)
El formato de la tabla de herramientas a cambiado y es incompatible. La documentación muestra el nuevo formato. La antigua tabla de herramientas sera automáticamente actualizada al nuevo formato.
4.3. Imágenes del firmware hostmot2 (2.3.x a 2.4.x)
Las Imágenes del firmware hostmot2 son ahora paquetes separados. Usted puede:
Continuar usando la versión ya instalada emc2-firmware-mesa-* paquete 2.3.x
Instalar los paquetes nuevos desde el manejador de paquetes Synaptic. Los nuevos paquetes se llaman hostmot2-firmware-*
Descargar las imágenes del firmware como archivos tar desde http://emergent.unpy.net/01267622561 e instalarlos manualmente.
