1. General Info
The Pluto-P is a FPGA board featuring the ACEX1K chip from Altera.
1.1. Requirements
  1. A Pluto-P board
  2. An EPP-compatible parallel port, configured for EPP mode in the system BIOS or a PCI EPP compatible parallel port card.
Note
The Pluto P board requires EPP mode. Netmos98xx chips do not work in EPP mode. The Pluto P board will work on some computers and not on others. There is no known pattern to which computers work and which don’t work.
For more information on PCI EPP compatible parallel port cards see the LinuxCNC Supported Hardware page on the wiki.
1.2. Connectors
  • The Pluto-P board is shipped with the left connector presoldered, with the key in the indicated position. The other connectors are unpopulated. There does not seem to be a standard 12-pin IDC connector, but some of the pins of a 16P connector can hang off the board next to QA3/QZ3.
  • The bottom and right connectors are on the same .1" grid, but the left connector is not. If OUT2…OUT9 are not required, a single IDC connector can span the bottom connector and the bottom two rows of the right connector.
1.3. Physical Pins
  • Read the ACEX1K datasheet for information about input and output voltage thresholds. The pins are all configured in LVTTL/LVCMOS mode and are generally compatible with 5V TTL logic.
  • Before configuration and after properly exiting LinuxCNC, all Pluto-P pins are tristated with weak pull-ups (20k-ohms min, 50k-ohms max). If the watchdog timer is enabled (the default), these pins are also tristated after an interruption of communication between LinuxCNC and the board. The watchdog timer takes approximately 6.5ms to activate. However, software bugs in the pluto_servo firmware or LinuxCNC can leave the Pluto-P pins in an undefined state.
  • In pwm+dir mode, by default dir is HIGH for negative values and LOW for positive values. To select HIGH for positive values and LOW for negative values, set the corresponding dout-NN-invert parameter TRUE to invert the signal.
  • The index input is triggered on the rising edge. Initial testing has shown that the QZx inputs are particularly noise sensitive, due to being polled every 25ns. Digital filtering has been added to filter pulses shorter than 175ns (seven polling times). Additional external filtering on all input pins, such as a Schmitt buffer or inverter, RC filter, or differential receiver (if applicable) is recommended.
  • The IN1…IN7 pins have 22-ohm series resistors to their associated FPGA pins. No other pins have any sort of protection for out-of-spec voltages or currents. It is up to the integrator to add appropriate isolation and protection. Traditional parallel port optoisolator boards do not work with pluto_servo due to the bidirectional nature of the EPP protocol.
1.4. LED
  • When the device is unprogrammed, the LED glows faintly. When the device is programmed, the LED glows according to the duty cycle of PWM0 (LED = UP0 xor DOWN0) or STEPGEN0 (LED = STEP0 xor DIR0).
1.5. Power
  • A small amount of current may be drawn from VCC. The available current depends on the unregulated DC input to the board. Alternately, regulated +3.3VDC may be supplied to the FPGA through these VCC pins. The required current is not yet known, but is probably around 50mA plus I/O current.
  • The regulator on the Pluto-P board is a low-dropout type. Supplying 5V at the power jack will allow the regulator to work properly.
1.6. PC interface
  • Only a single pluto_servo or pluto_step board is supported.
1.7. Rebuilding the FPGA firmware
The src/hal/drivers/pluto_servo_firmware/ and src/hal/drivers/pluto_step_firmware/ subdirectories contain the Verilog source code plus additional files used by Quartus for the FPGA firmwares. Altera’s Quartus II software is required to rebuild the FPGA firmware. To rebuild the firmware from the .hdl and other source files, open the .qpf file and press CTRL-L. Then, recompile LinuxCNC.
Like the HAL hardware driver, the FPGA firmware is licensed under the terms of the GNU General Public License.
The gratis version of Quartus II runs only on Microsoft Windows, although there is apparently a paid version that runs on Linux.
1.8. For more information
Some additional information about it is available from KNJC LLC and from the developer’s blog.
2. Pluto Servo
The pluto_servo system is suitable for control of a 4-axis CNC mill with servo motors, a 3-axis mill with PWM spindle control, a lathe with spindle encoder, etc. The large number of inputs allows a full set of limit switches.
This driver features:
  • 4 quadrature channels with 40MHz sample rate. The counters operate in 4x mode. The maximum useful quadrature rate is 8191 counts per LinuxCNC servo cycle, or about 8MHz for LinuxCNC’s default 1ms servo rate.
  • 4 PWM channels, up/down or pwm+dir style. 4095 duty cycles from -100% to +100%, including 0%. The PWM period is approximately 19.5kHz (40MHz / 2047). A PDM-like mode is also available.
  • 18 digital outputs: 10 dedicated, 8 shared with PWM functions. (Example: A lathe with unidirectional PWM spindle control may use 13 total digital outputs)
  • 20 digital inputs: 8 dedicated, 12 shared with Quadrature functions. (Example: A lathe with index pulse only on the spindle may use 13 total digital inputs)
  • EPP communication with the PC. The EPP communication typically takes around 100 us on machines tested so far, enabling servo rates above 1kHz.
2.1. Pinout
  • UPx - The up (up/down mode) or pwm (pwm+direction mode) signal from PWM generator X. May be used as a digital output if the corresponding PWM channel is unused, or the output on the channel is always negative. The corresponding digital output invert may be set to TRUE to make UPx active low rather than active high.
  • DNx - The down (up/down mode) or direction (pwm+direction mode) signal from PWM generator X. May be used as a digital output if the corresponding PWM channel is unused, or the output on the channel is never negative. The corresponding digital ouput invert may be set to TRUE to make DNx active low rather than active high.
  • QAx, QBx - The A and B signals for Quadrature counter X. May be used as a digital input if the corresponding quadrature channel is unused.
  • QZx - The Z (index) signal for quadrature counter X. May be used as a digital input if the index feature of the corresponding quadrature channel is unused.
  • INx - Dedicated digital input #x
  • OUTx - Dedicated digital output #x
  • GND - Ground
  • VCC - +3.3V regulated DC
images/pluto-pinout.png
Figure 1. Pluto-Servo Pinout
Table 1. Pluto-Servo Alternate Pin Functions
Primary function Alternate Function Behavior if both functions used
UP0
PWM0
When pwm-0-pwmdir is TRUE, this pin is the PWM output
OUT10
XOR’d with UP0 or PWM0
UP1
PWM1
When pwm-1-pwmdir is TRUE, this pin is the PWM output
OUT12
XOR’d with UP1 or PWM1
UP2
PWM2
When pwm-2-pwmdir is TRUE, this pin is the PWM output
OUT14
XOR’d with UP2 or PWM2
UP3
PWM3
When pwm-3-pwmdir is TRUE, this pin is the PWM output
OUT16
XOR’d with UP3 or PWM3
DN0
DIR0
When pwm-0-pwmdir is TRUE, this pin is the DIR output
OUT11
XOR’d with DN0 or DIR0
DN1
DIR1
When pwm-1-pwmdir is TRUE, this pin is the DIR output
OUT13
XOR’d with DN1 or DIR1
DN2
DIR2
When pwm-2-pwmdir is TRUE, this pin is the DIR output
OUT15
XOR’d with DN2 or DIR2
DN3
DIR3
When pwm-3-pwmdir is TRUE, this pin is the DIR output
OUT17
XOR’d with DN3 or DIR3
QZ0
IN8
Read same value
QZ1
IN9
Read same value
QZ2
IN10
Read same value
QZ3
IN11
Read same value
QA0
IN12
Read same value
QA1
IN13
Read same value
QA2
IN14
Read same value
QA3
IN15
Read same value
QB0
IN16
Read same value
QB1
IN17
Read same value
QB2
IN18
Read same value
QB3
IN19
Read same value
2.2. Input latching and output updating
  • PWM duty cycles for each channel are updated at different times.
  • Digital outputs OUT0 through OUT9 are all updated at the same time. Digital outputs OUT10 through OUT17 are updated at the same time as the pwm function they are shared with.
  • Digital inputs IN0 through IN19 are all latched at the same time.
  • Quadrature positions for each channel are latched at different times.
2.3. HAL Functions, Pins and Parameters
A list of all loadrt arguments, HAL function names, pin names and parameter names is in the manual page, pluto_servo.9.
2.4. Compatible driver hardware
A schematic for a 2A, 2-axis PWM servo amplifier board is available from the (the software developer). The L298 H-Bridge can be used for motors up to 4A (one motor per L298) or up to 2A (two motors per L298) with the supply voltage up to 46V. However, the L298 does not have built-in current limiting, a problem for motors with high stall currents. For higher currents and voltages, some users have reported success with International Rectifier’s integrated high-side/low-side drivers.
3. Pluto Step
Pluto-step is suitable for control of a 3- or 4-axis CNC mill with stepper motors. The large number of inputs allows for a full set of limit switches.
The board features:
  • 4 step+direction channels with 312.5kHz maximum step rate, programmable step length, space, and direction change times
  • 14 dedicated digital outputs
  • 16 dedicated digital inputs
3.1. Pinout
  • STEPx - The step (clock) output of stepgen channel x
  • DIRx - The direction output of stepgen channel x
  • GND - Ground
While the extended main connector has a superset of signals usually found on a Step & Direction DB25 connector—4 step generators, 9 inputs, and 6 general-purpose outputs—the layout on this header is different than the layout of a standard 26-pin ribbon cable to DB25 connector.
images/pluto-step-pinout.png
Figure 2. Pluto-Step Pinout
3.2. Input latching and output updating
  • Step frequencies for each channel are updated at different times.
  • Digital outputs are all updated at the same time.
  • Digital inputs are all latched at the same time.
  • Feedback positions for each channel are latched at different times.
3.3. Step Waveform Timings
The firmware and driver enforce step length, space, and direction change times. Timings are rounded up to the next multiple of 1.6μs, with a maximum of 49.6μs. The timings are the same as for the software stepgen component, except that dirhold and dirsetup have been merged into a single parameter dirtime which should be the maximum of the two, and that the same step timings are always applied to all channels.
images/pluto_step_waveform.png
Figure 3. Pluto-Step Timings
3.4. HAL Functions, Pins and Parameters
A list of all loadrt arguments, HAL function names, pin names and parameter names is in the manual page, pluto_step.9.
