Table of Contents
1 Halui
1.1 Introduction
Halui is a HAL based user interface for EMC, it connects HAL pins to NML commands. Most of the functionality (buttons, indicators etc.) that is provided by a traditional GUI (mini, Axis, etc.), is provided by HAL pins in Halui.
The easiest way to add halui is to add the following to the [HAL] section of the ini file.
HALUI = halui
An alternate way to invoke it (especially when using a stepconf generated config file) is to include the following in your custom.hal file. Make sure you use the actual path to your ini file.
loadusr halui -ini /path/to/inifile.ini
1.2 Halui pin reference
1.2.1 Abort
1.2.2 Axis
1.2.3 E-Stop
1.2.4 Feed Override
1.2.5 Flood
1.2.6 Jog
<n> is a number between 0 and 8 and 'selected'.
1.2.7 Joint
1.2.8 Lube
1.2.9 Machine
1.2.10 Max Velocity
The maximum linear velocity can be adjusted from 0 to the MAX_VELOCITY that is set in the [TRAJ] section of the ini file.
1.2.11 MDI
Sometimes the user wants to add more complicated tasks to be performed by the activation of a HAL pin. This is possible using the following MDI commands scheme:
[HALUI]
MDI_COMMAND = G0 X0
1.2.12 Mist
1.2.13 Mode
1.2.14 Program
1.2.15 Spindle Override
1.2.16 Spindle
1.2.17 Tool
