The command "loadrt" loads a real time HAL component. Real time components need to be added to threads to do anything. You can not load a user space component into the real time space.
The syntax and an example:
loadrt <component> <options>
loadrt mux4 count=1
The command "addf" adds a function to a real time thread. If you used the Stepper Config Wizard to generate your config you will have two threads.
addf <component> <thread>
addf mux4 servo-thread
The command "loadusr" loads a user space HAL component. User space programs are their own separate processes, which optionally talk to other HAL components via pins and parameters. You can not load real time components into user space.
loadusr <component> <options>
loadusr or2 count=2
The command "net" creates a "connection" between a signal and and one or more pins. The direction indicator "<= and =>" is only to make it easier to read for humans and is not used by net.
net <signal-name> <pin-name> <opt-direction> <opt-pin-name>
net both-home-y <= paraport.0.pin-11-in
The command "setp" sets the value of a pin or parameter. The values will depend on the type of the pin or parameter.
For more information on floating point numbers see:
http://en.wikipedia.org/wiki/Floating_point
Some components have parameters that need to be set before use. Parameters can be set before use or while running as needed. You can not use setp on a pin that is connected to a signal.
setp <pin/parameter-name> <value>
setp parport.0.pin-08-out TRUE
If you used the Stepper Config Wizard to generate your config you will have up to three HAL files in your config directory.
Hal contains several real time logic components. Logic components follow a "Truth Table" that states what the output is for any given input. Typically these are bit manipulators and follow electrical logic gate truth tables.
The "and2" component is a two input "and" gate. The truth table below shows the ouput based on each combination of input.
Syntax
and2 [count=N|names=name1[,name2...]]
Functions
and2.n
Pins
and2.N.in0 (bit, in)
and2.N.in1 (bit, in)
and2.N.out (bit, out)
Truth Table
| in0 | in1 | out |
| False | False | False |
| True | False | False |
| False | True | False |
| True | True | True |
The "not" component is a bit inverter.
Syntax
not [count=n|names=name1[,name2...]]
Functions
not.n
Pins
not.n.in (bit, in)
not.n.out (bit, out)
Truth Table
| in | out |
| True | False |
| False | True |
The "or2" component is a two input OR gate.
Syntax
or2[count=,|names=name1[,name2...]]
Functions
or2.n
Pins
or2.n.in0 (bit, in)
or2.n.in1 (bit, in)
or2.n.out (bit, out)
Truth Table
| in0 | in1 | out |
| True | False | True |
| False | True | True |
The "xor2" component is a two input XOR (exclusive OR)gate.
Syntax
xor2[count=,|names=name1[,name2...]]
Functions
xor2.n
Pins
xor2.n.in0 (bit, in)
xor2.n.in1 (bit, in)
xor2.n.out (bit, out)
Truth Table
| in0 | in1 | out |
| True | True | False |
An "and2" example connecting two inputs to one output.
loadrt and2 count=1
addf and2.0 servo-thread
net my-sigin1 and2.0.in0 <= paraport.0.pin-11-in
net my-sigin2 and2.0.in.1 <= paraport.0.pin-12-in
net both-on paraport.0.pin-14-out <= and2.0.out
In the above example one copy of and2 is loaded into real time space and added to the servo thread. Next pin 11 of the parallel port is connected to the in0 bit of the and gate. Next pin 12 is connected to the in1 bit of the and gate. Last we connect the and2 out bit to the parallel port pin 14. So following the truth table for and2 if pin 11 and pin 12 are on then the output pin 14 will be on.
