Table of Contents
List of figures
1 KEYSTICK
1.1 Introduction
Figure: The Mini Graphical Interface
Keystick is a minimal text based interface.
1.2 Installing
To use keystick change the DISPLAY ini file setting to:
[DISPLAY]
DISPLAY = keystick
1.3 Using
Keystick is very simple to use. In the MDI Mode you simply start typing the g code and it shows up in the bottom text area. The “?” key toggles help.
Index
